View Full Version : Automatic Transmission
- Revmax installed and trip to the track...very pleased
- 2 steps & transbrakes
- FTI Stall Converter Special Pricing
- Circle-D Budget converter a+
- Rpm level 5 4l60e hp rating?
- Are all 97 year/model 4l80E tailshafts the same?
- Stupid 4l80e question
- 04 4l60e codes/problems! help!!!!!!
- 93 4l80e Wiring question
- Can you guys help me with unlocking converter problem&code?
- Need some quick advice on a firmer 1-2 shift upgrade!
- 4L60E Deep Pan??
- stock trans temp sensor?
- Tranny Cooler Questions/suggestions?
- Does it work? Budget build.
- 4L60E-WOT, let off, falls out of gear.
- 4l60 surging
- Torque converter hub depth into crankshaft?
- Help with installing stall in nyc tri-state area
- Noise when downshifting
- Tranny Cooler For High Stall Converter 4000+
- 04 4l60e electrical pinouts and "pin-ins"
- 02 z28 a4 ??
- 1-2 accumulator piston?? Help.. getting tuned mon.
- Any sponsors offer Mark Williams products?
- 4L80E boost valve stuck in pump
- 4l60E-HD2-C questions
- TH350 shifting problem. What parts are involved in 1-2 shift?
- 4L60e upgrade help
- how to change the trans plug on top of the 4l60e
- Can't install my billet servo...
- 4l60e for my 98 z71
- 4l60 ?s
- I found a 3600 stall for 1K - guys, need some input pls!
- Draining and cleaning a converter.
- 4l60e to moser 9" DS length and slip yoke length
- what is ppr and signal for 96' 4l60e?
- 3 4 clutch setup
- Newbie with 4L80e questions
- 4l80e coolant lines
- ppl who street drive thier th400
- Installing the beast shell question.
- t-56 to powerglide swap?
- Performabuilt vs Finish line
- fao jakes performance
- 3rd gen with ez-tcu opinions?
- 4L60E transmission revs between 2-3 shifts
- Tech Left Plug In Transmission Fill Tube- What Problems May I Have In Future
- Vibrations in transmission while in park?
- what is this trans part?
- 1st time 4l60e build
- 4L60E Budget build advise anyone
- 97 4l60e to 2006 4.8 ?
- what trans?? 6.0 turbo car?
- TH400 Converter
- bad vibration above 3k rpm *experts please help
- FTI Specials
- 4l60e to the 4l80e what year do i need
- vigilate converter, tci flexplate. which bolts
- What pn do I need
- What to do with 4l60e core
- Hurst shifter jumping gears.. Why??
- 02 Z28 A4 Shifting from 1st to 2nd
- 4160e TransGo problem 2-3 shift
- Announcing PerformaBuilt Transmissions “Spring break/Easter Holiday Sale”
- Is my tourqe converter out of date?
- Sticky Worthy: Torque Converter Stall-Torque Ratio (STR) Guide
- strengthen 4l60e
- Opinions on this setup! Tranny/Stall/Rear/1000rwhp street car
- 4l60e No Reverse
- Big Stall Guys Come In! (Yank Gurus)
- which transmission should i go with?
- 4L65-e TCC signal for swap
- what rpm to launch at with yank ss4000
- noob 4l80e question
- PG issues....
- C5 tranny tunning and cooler to prevent wear?
- 5.3 to th350
- Lokar has me confused and worried..am I full?
- Non billet converters
- A few 4L80e questions
- Issue with shift lock control solenoid - can move out of park w/o brake pedal pressed
- Shipping Transmission
- t56 to th 350 swap ?
- How do you by pass the neutral safety switch on a auto
- Scangauge 2 Trans temp
- Transmission Fitment Question
- honest opinion
- 99 Trans Am/ Auto
- 4L80e for road racing / Auto-X
- Guys running th350/th400 help me pick a stall
- Anybody have a stock tune for a 4l80 with efi live
- Opinions yank ss 4k
- Tru-cool 40k after a trans break with metal debris
- 4l60e blowing dipstick out of tube and fluid on engine.
- Pulling my hair out helppppp
- Transmission Line Pressure Tuning vs. Boost
- auto trans heeeelp
- Flex plate for 4L80E and long nose crank.
- 98 trans am kickdown
- Flexplate question and gearing T56 to 4L80E.
- Broke my transmission
- Jake's Performance 4L80e converters
- 4l80e billet shaft???
- stall
- Slight leak of ATF, now a whirring noise in park and neutral
- bouncing the rev limiter in D from 2-3
- shifting and staying in gear issues, help please
- 4L80E wiring in 96 Camaro
- 86 gmc 700r4 questions
- s10 4l60
- glide or th400
- 4l60e Overdrive
- 4l60e no first, fourth, od
- Recommend me a tranny for my 408 c.i.
- converter issue
- Hooking up gauge to VSS 4l60e
- nitrous convertor?
- Putting a th400 or powerglide behind my 5.3
- Gear about to go
- turbo 5.3/ th400 stalling issue. Go T brake?
- Stupid dyno/converter question...
- 4l80 swap, spedo reading with witn car in park and vss unhooked
- 4l60e 3-4 accumulator pin missing?
- Checking auto trans oil level? Dipstick won't release
- TH400 swap questions...
- What did I break in my 4L80E?
- Trans connectors blocked.
- Issue after stall converter install
- Torque convertor seating problems..
- Rattling from transmission tunnel
- First 4l60e rebuilt - a few questions
- 4l80e mvb vs t56
- What PCM to control 4l80e without LS engine at this time
- 350 trans to 5.3 ???
- PTC Converters
- Yank Converters Tax refund SALE has started
- 2000 WS6 Automatic Making Noises. Need Help
- what flexplate do i need asap...
- 4l60e trans in bad shape
- 700R4 Governor issue?
- 6l90e trans
- Man I'm glad I went with a 4000 converter
- Quick Shifter Question
- Revmax converters
- Hard shifting only when hot
- Possibly the worst 4L60e carnage ever???
- rebuild question
- reverse drum
- Converter fitment issue
- Big tube and fin on condensor change to b&m 70264 dope style.
- 93' Wont shift
- A4 slipping into neutral
- Convertor question: TCS 2600 vs. stock Capri (police)
- yay more 4L60 problems
- Converter spacing confusion
- trans?
- Need help/opinions on trans
- Trans mount?
- 700r4 only shifts when you let off fuel. help please.
- Input shafts for 4l60trans in Camaro
- 4l60 vs 4l80
- 94 4l60E, 130k miles, blowing fluid from dipstick, slipping some.
- trans?
- calling all sponsers
- 4l70 shifter ideas?
- 4l60e problems
- installing torque convertor questions.
- 4l80e swap questions
- Tranny leak
- CDS aluminum flexplate torque converter bolt depth
- TH400 used in 1200 RWHP combo for 2 years teardown.
- Big cam, road racing plans - what converter?
- 98 z28 trans swap manual to auto
- How many of you installed your converter without rebuilding the tranny?
- Transmission advice
- I bought a transbrake button,....now what?
- I hillclimb, what is the best 4l60e rebuild kit
- What tranny oil pressure using 3-4 zpak clutches?
- nNew working relationship with FTI Converters.
- Converter/trans problem
- 4l80e manual valve body questions
- 4l60e swap no 3-4
- What exact transmission do i have?
- Output shaft leaking please help
- 4L80E junkyard horsepower
- Need help with finding a 4k-4400 stall
- looking for a 3000 to 4000 stall for 4l60e
- Opinions on TCI
- Loud metal on metal bang
- Best 4l80e lockout shifter in 4th gen Camaro?
- 4l80e Yoke selection help
- Convert/adapt 29 spline 6L90?
- 700R4/4L60 Questions
- Performabuilt lvl3 not right?
- help select trans for build
- trans cooler
- 4L60E Making a knocking sound?
- prndl/neutral safety switch
- C5 shift points and tranny tune
- 700r4 or t350 in 79 vette ls1 swap
- 4l60e problem after rebuild please help
- 3-4 clutchpacks toast?
- 60E guru's, ?
- 4l60e teardown problem
- JW Performance SFI 4L80E Flex Plate
- Locar 4l60e dipstick length
- th400 flexplate and driveshaft ???
- i just dont get it need help
- think its time for a rebuild
- A4 Hitting Rev Limit on 3rd gear before shifting
- Any idea what this noise is after letting off WOT
- Thinking about a stall....
- 4l60e problem
- 700R4 Troubling Pains
- what is going in with my 4l60e
- 4l80e revmax stall question
- 6L80 vs 6L90 for turbo LY6
- 2006 Monte Carlo SS Transmission thread
- remote transmission filter kit
- Contemplating bigger stall-What gains have YOU seen from going bigger?
- No Headlights
- What converter should I go with?
- v6 camaro flexplate
- Powerglide Turbo Guys
- th400 what stall?
- Need Advice! 4l60e builders please chime in
- Need Help: TH400 to 4l60e
- flexplate, starter issues.
- Recommend a stall....
- 99 A4 Trans am wont shift into 2nd
- What to do to fix cracked pump th400..
- Difference between trans go hd2 and hd3
- NEED HELP!!! 4l60E - FLT/Yank VS Performabuilt/PS Conv.
- Transmission Cooler Results
- 4l65e
- Wiring question for A4 shifter
- High stall with a 2step
- Line Lock and Shift Solonoid?
- Rossler 4l60e terminator 3 limits?
- Built TH400 recommendations.
- converter retune
- Trans overheating
- Help with shifting issues 4L60e
- What fluid temps for checking hot level on dipstick
- trans go boost valve on a 98 4l60e?
- Swap troubles
- Weird shift issue
- Might be coming to the dark side.. T56 to 80e!
- 4l60E No 4th or Reverse? No warning.
