PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 [155] 156 157 158 159 160 161 162 163
  1. Help ,New P.I. Vig 3600 and no lock up?
  2. Installing VIG 3600 today...
  3. 2.73s and Vig3600??
  4. Adding Trans cooler, how many qts?
  5. Do I really need a transmission cooler?
  6. Gearing questions w/ torque converter
  7. 4L60E limitations
  8. Getting converter..what to expect???
  9. Converter for th400 with spray?
  10. Vig 3200 and 3.73's on a 10 bolt?
  11. Torque Converter queston?
  12. Stall Converters
  13. Yank Converter destroying my trannies???
  14. weird drivetrain noises after master cyl. install
  15. trans temp gauge manifold diameter...
  16. Free Restall 2800 to ?
  17. What size of stall do I need????
  18. Putting a Vig in next week..
  19. Any tips for converter washer install?
  20. 4.10 install not a good one -what to do? Help!
  21. anyone know of a replacement flexplate we can use
  22. Swapping from M6 to A4???
  23. What to re-stall a PYE3400 to?
  24. Yank SS3600 installed!! break in?
  25. Installing 4.10's in m6 z28
  26. Which transmission cooler with 3200 stall?
  27. converter help
  28. th400 dust cover?
  29. time for a new stall
  30. still need A4 to M6 Swap WIRING HELP ASAP!!!
  31. Torque Converter Install...
  32. 2002 and torque management w/ stall
  33. TP4000 ordered, do Yank need to know about my 427?
  34. converter
  35. How do u lock/unlock a torque converter?
  36. How to check the clamping force of pressureplate?
  37. Transmission and convertor ?
  38. anyone lock-up the convertor at WOT
  39. Folks with a stall ..
  40. TP4500, Shift Extension, and Shift Points....
  41. stock 4l60e
  42. *Which converter is best?*
  43. Drive shaft length for th400 and u joint specs
  44. TH400 on highway
  45. Yank Crossmmber TH400
  46. Moser install question....
  47. TH400 and TQ Management
  48. Why doesn't a 00 (a4) driveshaft work on a 01 car?
  49. 4L60E just turned into a slushbox on me...
  50. Everyone with a TCI converter, inside please...
  51. Do I Need A Trans Temp Guage With a SS3600?
  52. What stall to run?
  53. A4 Question
  54. People with th350 how is your daily driving
  55. How do i get the converter off IF.....
  56. What stall speed converter to use????
  57. Weird Idle after converter install ?
  58. Help me with my A4 tranny
  59. TH400 shifter
  60. SPEC III Ceramic installed - first impressions...
  61. Raptor 700-E Transmission
  62. Highest stall without any problems or BS?
  63. converter not locking up anymore
  64. help with checklist for M6 to A4 swap....
  65. Need some bolts for tranny install ASAP
  66. wILL A TORQUE CONVERTER HELP THIS?
  67. 4L60E swap to 4L80E?
  68. Syncros install help
  69. All 01 & 02 A4 Owners with Converters !!!
  70. HELP! tranny wont shift out of first (4L60e)
  71. How good are TCI torque converters?
  72. Rear gear installer
  73. TH400 w/ lockup for a Corvette... Yeah Baby
  74. Yank SY3500... Opinions inside please.
  75. A4 driveshaft bolt up to T56?
  76. Yank Ultra Thruster 4600?
  77. any tech info on swapping from a A4 to a M6?
  78. th350 or th400
  79. Aftermarket Converter Survey!
  80. th400 for a ls1 (swap over)
  81. yank 3000 torque converter or TCI 3000 Torque?
  82. A4 to M6 swap
  83. Vigilante Multi-Disc
  84. New Converter Turns Into NIGHTMARE!!!
  85. 02 Z28 A4 wanting a Vig 2800 stall, got some ???s
  86. Lockup Turbo 400s now available for C-5s!
  87. Trans Go shift kit
  88. What converter & Trans
  89. 4L80E lengths?
  90. Leaking tranny fluid outta high pressure hose....
  91. 4L80E or TH400
  92. Please help me pick out EXACT torque Converter...
  93. A4 guys Bad tranny mount? What to use?
  94. 4L60E + B&M Deep Trans Pan fluid Change
  95. converter install and having idle problems....
  96. Trans-Go + 2001 "Z" = -10deg timing after shift??
  97. Hammer/stock a4 in!
  98. Help!: Gear swap on A4. 3.23s to 3.42s.Need edit?
  99. install a turbo 400
  100. Which converter is better?
  101. Speed Sensor on M6 same as a4?
  102. A4-M6 swap.is the wiring the same as 97' for a 99'
  103. How hard, what needed, cost of M6 to A4 swap?
  104. Vig3600--info please
  105. HELP!!! Newbie to Torque Converter, where to begin
  106. Gears + converter = loss of power??
  107. In the middle of a Moser 12 bolt install
  108. MAC rear end Girdle Install
  109. HP loss with built 4L60E?
  110. HP loss thru TH400
  111. Vigilante Owners ...Idle question ?
  112. Ram 910 disk, 402 PP and Hayes Billet FW installed
  113. Converter Bolt Access???
  114. A$ 2-3 shift...bouncin off rev limiter....too much
  115. Regular SBC stall in a TH350/LS1?
  116. Best converter for NA 427, PT4000 or PT4400?
  117. frame rail mount tranny cooler?
  118. People with 3800 stall and 3.73's inside
  119. Installing non ABS Ford 9",,,,
  120. gear and converter ?
  121. Vig 3200 or Vig 3600?
  122. Considering M6 to A4 swap Which tranny and Stall should I get and why?
  123. Loss of power after converter install
  124. a4 shifting funny, codes thrown
  125. Converter w/street tires
  126. Vigilante / TransGo GP
  127. Newby SS converter ?'s
  128. Tell me what yall think: 4l60e performance rebuild kit
  129. Tips for adjusting stock Shifter linkage on A4?
  130. A4 Tranny filter and fluid change ?
  131. A4 to M6 Wiring Questions
  132. Where does that pipe/tube on top of the 4L60E go?
  133. is vig 3200 right for me???
  134. Help! 4L60E trans capacity?
  135. Best auto tranny?
  136. cammed A4 running 100 shot, what convertor?
  137. SY3500 and 3.73
  138. TH400, Factory torque arm usage?
  139. Which of these converters is best from a roll
  140. My A4 Tranny is toast, I want a TH350....Cost?
  141. INSTALLED TRANGO AND GOT SES.
  142. ? about installation kit for a 4.10 gear
  143. Converter and Torque MGMT on a 1998 SS
  144. Ordered my FLP T400 for my 700rwhp project
  145. Pumps going out on 4L60Es
  146. Should I attempt Pinion Bearing Replacement or take to shop?
  147. Trans problem after shift kit and converter install
  148. stall question
  149. How Do I Bullet Proof My 4L60E?
  150. novice question
  151. UGH!!! Need FLP Tranny Help (E-Clips)
  152. Part # for 4L60E front Seal???
  153. TH400 1.8x 60fts????
  154. any pics of shifter for TH350 or TH400?
  155. Converter / Drivability Question - Need Feedback ASAP!
  156. Need help with convertor.
  157. Transgo Shift kit
  158. Lakewood driveshaft loop installed w/ pics
  159. need th400 speedo plug
  160. Stage III 4L60 - Car doesn't move! HELP!
  161. Will any 4L60E Transmission work in my 98 TransAm??
  162. Which Converter... Yank, Vig, Midwest
  163. 4L60E hitting the rev limiter???
  164. Bent Pressure Plate (Cartek)?? FIXED!!
  165. Can I install a Trans Go myself ?
  166. Vibration in D with new 4400 converter??
  167. 4l60e vs. th350
  168. a4 questions
  169. New converter & Cam = Car won't shift! WTF? Help
  170. Torque convertor trap speed
  171. FLP Level 4 just intalled...2 Problems, please help ASAP!!
  172. A4 to M6 swap
  173. R.I.P my stock A4 tranny (just a story)
  174. TCS, TCI, Midwest Owners Inside Please
  175. what stall to run with stock 2.73 gears
  176. Is my converter OK??
  177. Vigilante 3600
  178. Is anyone running a B&M 28000 gvw tranny super cooler ?
  179. Where can I get Performance parts for my 4L60E?
  180. Turbo 400 behind LS1
  181. what converter would work best for me?
  182. Lakewood D/S loop fits nice w/FLP's & big driveshaft
  183. 4L60E
  184. Dilema thinking about going to Vig 3200 over my 2800??
  185. converter screwing up
  186. converter install and tuning question
  187. A4 buzzing sound
  188. is the yank ss3800 right for me?
  189. How to hook up Th350 swap kickdown?
  190. Some ??? for those with TCI converters
  191. torque convertor
  192. Converter questions?
  193. C/F Pressure - Ram Disc - Fedanza Fly wheel - Cartek Adj. M/C ( my set up )
  194. Big Stall driving advise please
  195. A4 pull question??? PLease help
  196. Neal Chance Converters, need input please
  197. How will an FLP level 4 drive compard to stock tranny w/ Transgo?
  198. TCS converter choice
  199. Yank SS3600 qtr mile improvement
  200. Questions about 3.73's in A4
  201. Tranny temp gauge (question)
  202. Which Converter???
  203. Installing a rear gear?
  204. What SFCs work with FLP headers?
  205. Help, need part numbers for pilot bushing, pressure plate bolts
  206. A4 to M6
  207. Stock shift points?
  208. Yank YTP Convertor
  209. anyone with Trans Temp Gauge A4orM6
  210. Vig3200 installed and now bouncin the rev limiter
  211. 4L60E problems
  212. Who is running a vig3600 and how much of a difference is there from a vig2800?
  213. Pictures of installed SLP SFC´s?
  214. Installing Safety Loop with BMR Crossbrace & 3.5" driveshaft
  215. Drivability With A Vigilante 3200
  216. Best way to Launch Vig 2800 at Track??
  217. TH350 converter, how do i shim the converter to the ls1??
  218. HELP!!! Spec III Install Problems!!! HELP!!! HELP!!!
  219. Help pick my gears... A4
  220. Trans line pressure/Trans Go ?
  221. ? Does anyone know the stall rpm on the 2001 vette
  222. Tranny temp prob?
  223. Yank Converter Users Fash Stall or Brake Stall??
  224. SFI flexplate for turbo 400 w/ LS1?
  225. tranny cooler
  226. 1998 Corvette Torque Converter
  227. 1998 Corvette Torque Converter
  228. TH400 & GVOD Install Tips...
  229. adjustable torque converter
  230. Dangitman, ST3500 chatter
  231. Problems installing gears
  232. HELP!! bent flexplate a lil, is it still ok???
  233. Question about a Stall
  234. Any converter owners running Nittos?
  235. Converter install, how hard?
  236. shift probs in A4
  237. Transmissions Shudder.... A4
  238. Where to get CONVERTER insalled?
  239. Which converter for a bolt on/ nitrous car???
  240. A4'S WITH 4.10'S GOT A QUES?
  241. problems w/yank sy3600, anyone??
  242. Talked to Mike at Yank, Interesting Response.
  243. Tranny question, 90 chevy truck 400 T- GV/ 4L60 E swap
  244. TCI and Midwest Converter guys !!
  245. NEED T/C O-RING PT # FOR 01 SS A4
  246. What is involved ( both parts and cost wise ) to go from A4 to M6?
  247. Converter Problem: Update
  248. seal/gaskets needed for converter swap?
  249. FILL TORQUE CONVERTER, HOW MUCH FLUID?
  250. SFI FLEXPLATE Whats up
