PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 [69] 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. What torque converter is this?
  2. If you have disassembled and reassembled a 4l60 come in.
  3. 6L80E guys i have some questions for ya
  4. Is this a bunch of BS??
  5. OBD1 4L60E Questions
  6. please help won't go into 1 gear.
  7. M6 to A4
  8. Th350 vs 4l60e
  9. need help with 4l80e
  10. Vig 3200 to Yank pt4400
  11. Good transmission companys???
  12. Can holding your 4l60e in a specific gear ...
  13. GP for performance built anyone interested?
  14. 2004R 1st gear slipping help
  15. smoked the th350
  16. pt 3800 with a procharger...
  17. In need of a good boost converter for 400
  18. Dumb Question About My Trans
  19. Stall and nitrous question
  20. V6 firebird Tranny: HELP
  21. Trans shifting to early??
  22. 4l60e 3-2 bind up
  23. Trans won't shift after install
  24. cooling line -pressure question
  25. which converter for 10sec turbo car?
  26. no 2nd gear upshift
  27. Adjustable servo pins for 700R4 & 200-4R
  28. Need some info on an 08 TBSS 4L70E
  29. Th 350 Question help please!!!!! fast
  30. just ordered my circle D level 3 converter
  31. Slipping into neutral on brake in 4th??
  32. help with tranny
  33. 91' silverado trans problem
  34. new leak, what holds the plug up?
  35. trans loses 3rd and o/d after 20 minutes of driving
  36. banging third
  37. any sponsors going to run any specials on tc??
  38. Need Help Buying a Stall.
  39. Tci 3600
  40. 4l60e to 6.0l flywheel and upgrade
  41. 4L60E no 4th gear, no SES light
  42. Have a Escalade AWD 08 6l80e, can it be converted to 2wd?
  43. trans question
  44. tranny help
  45. Humming noise in overdrive
  46. Question about driving in "Drive"
  47. transmission question
  48. ? to Yank about my converter hub wear?
  49. Drove to Houston, Towed it back!
  50. is their a high performing tranny that work with stock converter ?
  51. lt1 4l60 to ls1
  52. 2001 Truck tranny, does it have the Vette servo?
  53. Installing a ratchet shifter in a 93 A4...Need advice!
  54. TH350 In A 94 Z28
  55. Swapped 4l60e for th400 how do i get the speedo to work?
  56. What could this be??
  57. Help 4L60e hard 1st shift
  58. Trans cooler help?????
  59. Code PO751
  60. T56 to 4L80E swap
  61. transmission help asap plz.
  62. Need Part # for F-body Shift Linkage
  63. TH400 Experts!? Mount spacer cause vibration?
  64. 4l60e= toasted!
  65. need help with speedo cable
  66. 4l60e shifting problems
  67. 4l60e issues - need help!
  68. No drive in all ranges?
  69. Quick question about stall brands
  70. Wierd tranny damage, opinions?
  71. 4L80E 1993 vs 1995
  72. Tranny additive
  73. price?
  74. PerformaBuilt 2 day only 4th of july sales event !
  75. 4L60E in a Mercedes - shift cable??
  76. What lenght shifter cable should I get
  77. 60e wiring
  78. TCI sfi Flexplate????
  79. vigilante stall bolts
  80. New best. Thanks to Circle D.
  81. Vibration under load - shim trans crossmember?
  82. *update* Verdict is in on my broken input sprag thread!
  83. Great Converter
  84. How many use their stock M6 crossmember with A3
  85. 4l80e line pressure
  86. Park to Neutral??
  87. Buddies tranny is acting up, any help?
  88. TH400 Trans Fluid Check
  89. Can a stock converter be stalled?
  90. please help put it in gear and it dont go no where
  91. 4l80e trans tune!
  92. 4l60e..Help please!!!
  93. Torque converter question
  94. Must the trans be pulled to install a shift kit?
  95. 4L80E FMVB Question
  96. Question?? M6 to 4L80E
  97. running th-350 on the street
  98. Trans cooler??????
  99. Can anyone suggest a shop to put a Transgo in and how much?
  100. I am stumped.
  101. 2-3 clutch pack in 60E?
  102. What size stall should i get for my ta
  103. Leaking tranny fluid from dipstick cap??
  104. turbo 350
  105. 4l60e
  106. Cheap tranmission ?
  107. 4L60 4L65 4L70 Trans dimensions/heigh
  108. reverse manual valve body
  109. m6 to th350
  110. Art Carr converters?
  111. 4l60e no first gear?!?
  112. It's time for a new one
  113. stock a4 shifter with th350
  114. Need advice on a 4L60E PCS
  115. 4l60e converter lockup question
  116. Heating issues
  117. No revert ? need help ASAP !!! please
  118. nos stall ?
  119. FLT Level VII + YANK TC = #1 Qualifier
  120. Going from M6 to TH400 and need help ASAP
  121. Pan magnet issues in 4L80 pan long!!!
  122. Poll: stock 4l60, can it take a TC?
  123. Help wtb asap adaptor for 1995 4l60e for l92
  124. PY3400 feels like a stock converter????
  125. Trans Question
  126. Need help Please Read!
  127. Any 6L80E news?
  128. I have a couple of 4L60E questions?
  129. Shifting problems..Help
  130. Draining Converter?
  131. Tranny fluid
  132. Yank Converters?
  133. fti install need help
  134. Clunking noise under Accel/Decel also over bumps!!!
  135. My DD T/A transmission is going out...
  136. Transmission feels like in Neutral
  137. 4t80e
  138. WOT shifting problems
  139. 4l60e bucking after rebuild, BUILDERS INSIDE.
  140. Shifts a little soft, took pressure readings, need advice
  141. Metal "tink" noise when going into gear
  142. Tranny only leaks when I hammer the car??
  143. tcc 04 gto
  144. Shift lever position
  145. Shift problems
  146. Transmission cooler W/Fan Wiring Questions?
  147. 4l80e problem on my first test drive
  148. Hurst Pro stick in a 6 spd console
  149. TH350 For Sale
  150. torque converter question inside
  151. couple ? with trans
  152. Is my tranny giving up??
  153. Replacement trans
  154. trans. fuild change ? on TC fuild
  155. '04 GTO A4......Corvette Servo?
  156. are neal chance converters worth it?
  157. pressure port an acurate place to measure trans temp
  158. Is my 4L60E dead?
  159. b&m shiftplus+ install?
  160. 4L80e Sun Gear Shaft Bushing(s)
  161. Newbie Question
  162. so who running tci 399753 with th400?
  163. i finally found the perfect 4l80 rear fitting
  164. Sufficient cooler?
  165. Line pressure issue?
  166. Tranny Similar To This For 4l60e?
  167. Keep 700-r4 or go to 4l60e?
  168. 1st gear is locked?
  169. The 4L60E "IMO" ...
  170. Broadcast codes..
  171. how often should trans. fuild be changed
  172. th400 Converter in a 4l60e?
  173. Thanks Chris- Circle-D
  174. First time out with the Yank SS4000
  175. 4l60e Pump vane clearance
  176. 305 TPI 700-R4 TV/detent cable
  177. my gear, with TH350?
  178. 9 days left on FTI converter SALE
  179. Having obd1 4l60e trans issues
  180. Anyone break a stock trans mount with poly motor mounts and relocated torque arm?
  181. Won't move with shifter in OD
  182. personal experiences with 3600stall
  183. Help Car doesn't move.
  184. No reverse lights after auto swap?
  185. delayed 2-3 shift..billet servos installed
  186. 4l80E into 97 Z28
  187. Hey you guys
  188. Thanks again to FLT trans and FTI verters
  189. Thanks Rossler Trans.
  190. Replacing my transmission, question about converter.
  191. Hard kick when putting in drive after LS1 swap...
  192. Tranny starts in 3rd sometimes?
  193. Looking for a good shift kit
  194. Is this normal for the tailshaft??**video included**
  195. Converter Won't Seat
  196. Blowing though the converter?
  197. Car on the lift in neutral, should the wheels spin?
  198. I need convertor selection
  199. Shifting problem
  200. Thanks PerformaBuilt T400 still tunning the car.
  201. What torque Convertor do i need
  202. G8 6L80E trans output shaft
  203. any builders have problems with torlon balls on old plate?
  204. wot shift into 4th?
  205. Broke shifter cable
  206. TH400 swap shifting early, help!!!
  207. lockup
  208. autozone flywheel?
  209. any ideas???
  210. Yank SS3600 or SS4000??
  211. 4L60E hanging in 2nd..
  212. Converting from older aluminum pistons in 4l60e?
  213. 4L60E Difference in 4.3's awd 4x4???
  214. shuddering after trans rebuild
  215. Trans Overdrive Issue
  216. Gear vendor speedo issue
  217. Ok guys I really need some suggestions
  218. Converter question
  219. No reverse when warm
  220. M6 to TH350
  221. tranny cooler question???
  222. Who's running an aftermarket TC+stock tranny?
  223. Lockup for Transgo 4L80E FMVB
  224. Big hp guys what trans mount are you running?
  225. New stall, my old oil cooler good enough?
  226. Hughes rebuild kit for a 4l60e
  227. New 4l60e and convertor. now stuck in between gears?????
  228. slow shift
  229. Aftermarket shifter or knob that works with auto console?
  230. need some ratings on a 2800 stall?
  231. What are you TH400 guys running??
  232. part number for transgo kit
  233. Shimming Coverter?
  234. Rev Limiter?
  235. th400 swap drive shaft ?
  236. LT1 4L60E Vs LS1 4L60E?
  237. vig 3200 and bolt ons, what to expect?
  238. M6 to 4L80e or Th400 (various questions)
  239. Switch to Yank results in three 151 MPH runs!
  240. Converter install?
  241. Stock gear ratio?
  242. Trans never starts off in 1st unless I manually start in 1
  243. 4l60e transbrake
  244. 4L60E manual lever position switch??
  245. new tranny jumps out of gear at WOT
  246. getting rebuild on 460lE
  247. Just ordered my new trans/converter combo from Performabuilt
  248. 4L80E Questions
  249. Curious about the rice..
  250. 4l65e beefup
