PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 [100] 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. ~~How to replace 2-3 Solenoid??~~
  2. need help
  3. steel or aluminum pan?
  4. 3600 or 3800 stall
  5. broken
  6. Tranny not shifting! HELP!
  7. who's pushing 400+ RWHP on there stock 4l60?
  8. How much can my Vig 3600 handle??
  9. ANYONE RUNNING A TH400 Trans COME IN!!!
  10. New FLT trans
  11. TC Bolt thread and length????
  12. 1992 4l80e...after 60 mph no 4th gear
  13. 4l80e question
  14. No Balls
  15. school me on stalls
  16. 4L60E - Someone school me on shift solenoids
  17. 95 4L80E from 4x4
  18. A4 guys with a cam and no converter, Come on in!!!!
  19. tranny issues???
  20. Stall!!
  21. ~~~Trans Will Not Shift Into Third!!!!~~~
  22. 400 in
  23. cold starts = hard shifting
  24. why shouldn't i use a hughes stall????
  25. problems after stall w/pcm
  26. tranny problem come help!!!!!
  27. Tranny finally crapped out
  28. Putting a prostick in and..
  29. Continental Converter
  30. th400 pan gasket?
  31. 700r4 ?
  32. Transmission Rebuilt Questions/Concerns
  33. driveshaft breaks while idling through a parking lot...pic
  34. Car is slow as Christmas
  35. 800rwhp 800rwtq
  36. best way to measure trans temp
  37. 4L60e Fluid Capacity?
  38. Transmission Conversion
  39. simple question
  40. 2800 stall not enough???
  41. Quick crank torque question...
  42. VSS O-Ring??
  43. Tranny vibration or not?
  44. Performabuilt lvl2 installed
  45. th350 speedo ?
  46. new th400
  47. 4l80e downshift points help
  48. got a pt4400 and a tci flexplate
  49. Stall or gears
  50. High Trans Temps
  51. Vig 3600 converter?
  52. New tranny already having problems.
  53. tranny help! PLEASe
  54. Yank 3200ss stall???
  55. 2-3 shift problem at WOT
  56. 4L80E differences?
  57. (((Help)) last transmission
  58. wtb a m6 trans crossmember
  59. 4L80E QDM or PSM?
  60. Whats a streetable th400?
  61. trouble shifting out of 1st
  62. My Poly Tranny Mount Experience
  63. how to paint transmission
  64. Does Mileage On An Engine Matter With A Stall
  65. Truck pan questions
  66. Shifter stop removal?
  67. anyone with a py4000
  68. flexplate question
  69. TH350 pricing
  70. TH350 reverse and 2nd gear not working???
  71. B&m temp guage anyone have problems with it
  72. 4l60e problem
  73. 4l60e 1-2 shift problem help!!
  74. shift kit or no?
  75. When does the stock 4L60E become inadequate??
  76. 4L60E Changes (builders?)
  77. Tq coverter opinions (Stock Z)
  78. so cal area reprogram my tranny back to stock
  79. those of you with TCI and PerformaBuilt LOOK
  80. Rebuilt 4L60E - SES Code 1-2 Shift Solenoid
  81. Yank 3600.. too big! what's the best option ?
  82. 4l60E Issues?, Check this out!
  83. Is my pump cover trashed?? Guru's inside please!
  84. I'm thinking about keeping the factory converter and getting a heads and cam combo
  85. Shifter Cable Probs???
  86. trans fluid
  87. ATI treemaster or fuel and blown verter?
  88. tranny help!!!!!!!
  89. Police Package 4l60e
  90. stall?
  91. Opinions about TransGo Shiftkit
  92. don't really know what happened!?!?!?!
  93. transmission mounts?
  94. The powerglide effect
  95. Transmission Help
  96. Vacuum Modulated 4L60E??
  97. A4 Tranny Problem
  98. Installed my B&M rachet shifter
  99. 95 tranny with a 2000 ls1 help
  100. TH350/shifter questions??
  101. vette vs camaro vs trans/am
  102. installing TCI controller for 4L80E swap, will there be SES lights?
  103. Aftermarket Shifter A3
  104. well i blew my transmission
  105. Cannot get 4l60e trans filter seal out sugestions...
  106. guys with the hurst 1/4 stick
  107. Planetary gear inplay?
  108. H/C with Stock Stall?
  109. new converter installed...couple of questions
  110. Spraying thru the shifts...
  111. SY3500 with twin bolt patterns?
  112. tranny removal? HOW TO?
  113. Yank PT4400-how much slippage?
  114. slow to shift into gear 4L60E?
  115. I want the biggest tranny cooler
  116. EL60E Problem
  117. Anybody installed a TCI trans shield on a T400?
  118. To those with the TCI SSF4000 converters...
  119. Carrier questions? Trans guys help me out.
  120. Almost wrecked car...
  121. Car will go into reverse, but when applying gas hardly moves?
  122. T-56 to TH-400
  123. Whose running a Performabuilt Tranny and stall?
  124. TH400 at 210*...any damage??
  125. M6 to TH350... What did you do for your console?
  126. 4l60 help
  127. Not trying to sound like a noob...
  128. 2007 vette 6 speed auto trans
  129. PWM question?
  130. Quick Converter question's
  131. Need a new trans
  132. How long does a verter last
  133. TH350 leaking from vent
  134. WSS and the burnout box?
  135. PT4000 to PY3600 swap, how much slower on the motor?
  136. Auto to th400?
  137. 4L60 Issue, Lost gears 2-4 then retained them?
  138. Yank Pro Eliminator 4200 lockup question
  139. Is it me or is my converter way off
  140. Trans Stuck on Engine!!
  141. Fuddle WOT Lockup
  142. Is this true
  143. Advice on stall converter for a stock 98z
  144. trans slams in to gear from P to R/D
  145. Lock up issues
  146. Trans cooler question?
  147. flexplate
  148. wierd sound after TC install
  149. Drive Train loss
  150. What trans is in my 93Z?? 700r4 or 4l60. How can I tell?
  151. speartech adapter???
  152. New Converter issues.
  153. Hard shift into 2nd sometimes
  154. 4L60E rebuild: I'm goin' in....
  155. What year 480LE or does it matter
  156. Hmmm..a new 4L60E, who?
  157. will 2 trans. coolers be better than 1
  158. 4L60E Interchange Questions
  159. Grenaded planetarys.. now what?
  160. manual VB not working right. advice please
  161. Just got my yank 3200 what now?
  162. Z-Pak on 2 month back order!!!!
  163. Tranny leak!!!!!!!!!
  164. tci flex plate
  165. 4000 Stall and my top end
  166. bone stock 4l80e
  167. Lost 2nd
  168. Line Pressure for my App.
  169. YANKs May special WOW!
  170. 4l60e questions
  171. Cool Looking Tranny Temp Guage
  172. Not too thrilled about my TC swap!
  173. Transbrake Reverse question
  174. Launching on a PG
  175. How much RWHP can a 700r4 take?
  176. Transgo 4L60E-HD2 shift kit install question
  177. Stall wont stall??? Why Fuddle 3800
  178. Yank 3400
  179. Need help pump cracked after 200 miles
  180. Can my fuddle stall really be this Ineffiecent???
  181. Soft lock-up
  182. This IS whats Needed for 4L60E to TH350 swap INFO!!
  183. Transmission temp. guage
  184. Where's your T-brake???
  185. @ WOT buzzed the REV limiter, on 2-3 shift!
  186. anyone use 2step with 4L60E?
  187. tractor hydrolic fluid in place of tranny fluid to tighten up converter?
  188. How much downtime?
  189. 4L60E slips badly in D3 or D4, run great otherwise
  190. 460le
  191. 5.3
  192. manuel valve body?
  193. using a v6 trans with an ls1
  194. Who sells good tranny temp gauges?
  195. Sportline springs + Rain = Wet tranny!!!!!
  196. Shuttering, vibration when TC locks up?
  197. 98 PCM controlling 4L80e
  198. converter not locking
  199. vette auto 98 who is 3000stall in it
  200. finished trans go install. My thoughts.
  201. Somthing Crazy Wid My 4l60 In The Goat.
  202. Barb fitting?
  203. Storing a tranny
  204. TH350 Help: Needing Part number for the transmission mount plz..
  205. is 1000rpm converter slip up top normal?
  206. 4l60 issue
  207. Transmission Noise
  208. th400 help
  209. what flexplate
  210. torque specs
  211. Transmission T.V. cable and accelerator cable off from transmission install
  212. Problems after installing a B&M shift kit
  213. trans has a growling sound..trans experts please
  214. Max RPM's for 4l60e and 4l80e?
  215. 4L80E temp sensor location
  216. "Performance transmission fluid" worth the $?
  217. vibration after installing mount
  218. shift kit
  219. Have a Turbo 350 tranny..Should i Swap it with a Built 4l60E or M6
  220. Drivetrain shakes hard after TC install
  221. need accumulator help!!
  222. Car won't move!!
  223. 99 trans am question NEED HELP plezzzz
  224. ultra noob question
  225. Converters (This should be a sticky)
  226. will any year of 4l60e fit in my 95 TA?
  227. hp/stall????
  228. How much HP can a 4L60E stand up to?
  229. RPM Transmissions
  230. TH400 People I Need Help
  231. ARP verter bolts or Grade 8 Bolts from local auto store?
  232. 4000 Stall Too Much?
  233. New tranny / dyno
  234. Tuning for a 4000 stall
  235. th400 swap
  236. Rossler TH350 HP limits
  237. TBSS letting go and hitting rev limiter @ WOT
  238. Advice on my 4L80e swap
  239. Changing 2-3 Shift Solenoid
  240. Want a Torque Converter, scared to put one in...
  241. year?? TH350
  242. Tranny Cooler
  243. Heard a Ping and Metal grinding, what could it be?
  244. How much RWHP......
  245. Converter?
  246. wut kind
  247. Yank 3000 st stall
  248. To those with Performabuilt Transmissions...
  249. Aftermarket shifter for 4l60
  250. Tci Flexplate
