PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 [36] 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. Trailblazer torque converter
  2. CDS- Updates
  3. Transmission Swap Question
  4. TH400 and M6 crossmember
  5. 4l80e swap?
  6. 4l60e pump help!!
  7. transmission experts step inside
  8. Do you guys replace/partial rebuild tranny parts when swapping converters?
  9. Thank You Jake
  10. Vigilante - Any way to i.d. externally?
  11. Leftover piece to 4l80e...
  12. dipstick
  13. Whats involved with a swap from 6-spd to turbo 350
  14. 4l60E Rebuild
  15. 4l80E part id
  16. TH400 newbie
  17. Thread seal for cooler line fittings?
  18. Powdercoating Transmissions
  19. Can you change out the drum brake tailshaft housing for a regular one on a 4l80e?
  20. 4l60 and trans brake question
  21. Trans controller help.
  22. getting my first LS1 fbody this weekend
  23. 00 Camaro hurst auto shifter height adjustment
  24. Just some assorted pictures from shop and a build
  25. Yank th350 crossmember
  26. Swapping a T56 for a 4L60 questions please helppp
  27. 4l60E Transmission difference 6 cyl
  28. LT1 Fbody converter = C5 converter
  29. One day only performabuilt 12/12/12 sale
  30. Shifting an auto
  31. Optishift Group Buy?
  32. Stock converter for stall
  33. Transmission Slipping Need Info!!
  34. Need help asap
  35. turbo 350
  36. having problems installing my 4l60e to my ls1
  37. 4l60e
  38. Which 4L80E do I need to get?
  39. How much?
  40. im so damn confused...somebody help me please!
  41. Rossler manual"Black box" for the 4L60E
  42. Jakes 4l80e and yank py3400. Do I need to install spring?
  43. TH400 Transbrakes and parts.
  44. rebuilding 1997 4l80 jakes level 2 kit, "better" overdrive??
  45. 3600 stall
  46. air checking 4l80e direct clutch and center support assembly
  47. 00 LS1 with 350 tranny help!!
  48. Bigger Stall guys, Trouble with stalling out in Parking lot?
  49. 4l80 swap.
  50. Does anyone make a converter for a 99-01 6.0 with long crank for a 99 4l80e?
  51. Transmission acting weird
  52. what do i do????
  53. Check out our new converter line!!
  54. T56 to 4L60E swap want do I need
  55. Revmax HOLIDAY SALE is coming! 12/10
  56. Jakes T Brake
  57. 4l60e problems
  58. Need advice asap! Looking to purchase stall for street/strip/medium towing
  59. Lq4 make it work with 4l60e
  60. FLT Stage 5 trans for 2000 trans am ws6
  61. 1-2 hardshift fix for 4l60e
  62. Converter fit issue - what is proper height for an LT1?
  63. 4l60e Rebuild: whose the best to go with
  64. 4L60E torque converter question
  65. LT1 4l60e Low Pressure, Bad tune, 52mm TB
  66. Trans for planned H/C/I build
  67. converter spacing issues
  68. 4k stall and tune
  69. Need help trouble shooting a 3 to 4 shift issue in a 4L60e
  70. converter ?
  71. plastic center support sealing rings on 4l80e
  72. Need expert input
  73. Teardown a 4L60 (with pics) experts look inside
  74. stall installed
  75. Transmission "Tuning" for Circle D 2800?
  76. Question about a 2 Step in Automatic Transmissions
  77. Turbo 350 behind an LT1
  78. Toms River Transmission
  79. Buying used auto trannys that have been sitting for a while, Got questions
  80. cheap stalls?
  81. Couple 4l80e questions
  82. Should i switch to a Glide?
  83. buying the rite kit
  84. Another one of those: Converter brand choice between CircleD, Yank, and FTI
  85. help me figure it out!!
  86. 99 LM7 to 01 4.3L 4l60 Torque Converter?
  87. Help Transgo 1-2 accumulator spring broken 4l60e
  88. stalled auto or 6 speed swap?
  89. Going to attemp an automatic Trans rebuild of a 4L60E
  90. What is a good converter for the price?
  91. transmission question
  92. Need help with tranny issues
  93. Installed tranny, now engine won't turn over?
  94. Best stall speed for my steup?
  95. **4l80e question?? Help appreciated!!
  96. Got Trans Problems
  97. 3-4 clutch stack need some info
  98. LS crank spacer?
  99. Gate shifter for a 4l80
  100. T-56 for 4L60E swap
  101. 4l60e swap
  102. Thank you Yank Converters for "over and beyond" service
  103. Need Help Identifying Converter- Is this a Fuddle?
  104. 4l60e to deadhook 450whp
  105. The Ultimate 4L60E 3/4 Clutch ?
  106. New member need trans help ASAP fellas please chime in!
  107. 4l60?
  108. Th400/trans cooler
  109. Issues with 4l60 E
  110. What should I do to my 4L80E?
  111. 4l60e out of a 2004 silverado ???
  112. 4L60E stall question
  113. 450-500rwhp do I need a billet converter?
  114. Jake's Performance Black Friday Sale
  115. HELP - Do new shift selnoids rattle??
  116. TH 350/400 guys
  117. A little confusion about bop th350
  118. tc swap questions
  119. 4L60E w/ manual valve body
  120. Circle d, black friday?
  121. torque converter locking and unlocking
  122. Spray through shifts??
  123. 6L90 transmissions what flexplate do I use
  124. Finally found out my stall size
  125. Electronic shifting instead of mechanical
  126. Yank SS4000 Results
  127. Black Friday Deals and Sales
  128. [B]Announcing the Count Down to Black Friday sale![/B]
  129. 05 C6 ls2 NA goes 1.32-60' 10.15 ET
  130. RPM Transmissions Cyber Monday SALE!!!!!
  131. My transmission finally went (4T65-HD) LS4
  132. shift knob
  133. Torque converter problem? New Issue
  134. "Built" 4L60E, Worth it?
  135. Junk yard 4l80e install...
  136. What is this sensor in 4l80e
  137. 4l80 Reverse Delay
  138. Is this rebuild kit good for stock set up
  139. 97 4L80e questions
  140. Non PWM Converter
  141. 4L80E makes a hissing sound when in gear
  142. What size stall?
  143. Likely gain from raising the stall?
  144. Converter/Cooler labor cost.
  145. 93 z28 4l60e isn't shifting right please help
  146. 4L70E Transmission Coolant lines
  147. Is this a 4l80e?
  148. Broken 4l60e....Decisions
  149. Used converter, question
  150. trans problem
  151. Cutting ears off bell
  152. Want to get my speedometer back after a th400 swap
  153. Difference between new modern 4l80e's and old 80e's?
  154. Jakes Trans Black Friday Sale?
  155. TCI 274500 kit
  156. 4l60e trans help
  157. Built 4l60E Running Hot.....
  158. 4,000 vss for th350 in my gbody.
  159. Transmission Issue?
  160. 2004r tv cable length
  161. 4L80E Speedometer moving with tachometer
  162. trans help
  163. 2007 LQ4 with 80e flexplate to 'glide. Will it work?
  164. TH400 speedo in 2002 z28
  165. some help
  166. Trans pan bolts
  167. Full manual 4L80 swap
  168. Who makes a stall that can be locked up with 1200 rwhp + for a 4L60E
  169. Our Article from Popular Hot Rodding and a Special Discount
  170. quarter stick in 98-02
  171. 5.3 with a 2004r trans have ???
  172. Who should build my 4L80E
  173. Converter Choice
  174. 98 4l60e same as 06 4l60e??
  175. Mustang LS swap - 4L60E or TH350?
  176. 08 5.3 4l60e tranny. will it work with an older harness?
  177. 4l60E no overdrive...rebuild. still same issue
  178. New Build: 4l80e behind L33 questions...
  179. Can I unbolt and leave out the center on TCI 399753?
  180. old school - installing a THM 400
  181. Car not moving after 4l80e install
  182. Faster times due to tranny manual shifting?
  183. 4WD 6L80 to 2WD
  184. how much fluid after doing all this?
  185. 2009 L76 with 2011 6L80
  186. Ridings Automatics contact info???
  187. 4l60e tcc
  188. Pros: How to prep sprag races and beast roller shaft
  189. Sonnax HD 2-3 Shift valve install question
  190. Tranny Downshifts In The Turns Too Easily...
  191. vigilante
  192. Powerglide
  193. 200 psi at idle
  194. are ynk eliminator converter good?
  195. got my car dynoed today only 650 rwhp wtf. is this my converter doing this??
  196. vibration after 4l80 install
  197. Important notice for storm victims!
  198. trans and converter install video
  199. 4L60E No Overdrive
  200. 4l80e flexplate for ls1?
  201. 4l60e/700r4 tail shaft
  202. shifter retaining pin
  203. Question on 4L60E differences
  204. 700r4 vs 4L60e
  205. V6 4L60E on a LS1?
  206. Th350 Transbrake questions
  207. 4L60E behind a LT1 without computer
  208. 98 4l60e behind ls 6.0-wiring question
  209. 4l80e swap in 99 Camaro
  210. 4l60-e question
  211. 4L60E doesn't spin, need help please
  212. shifter?
  213. car stalls when coming to a stop
  214. roller clutch 4l60e
  215. need to convert my 94 4l60e to 96' spec's what all do i need?
  216. 4L60E 1-2 accumulator
  217. im over powering my torqe converter and now i have a vibration at or right help
  218. Broken Converter?
  219. Freakshow Performance
  220. th350 ???? problems after rebuild
  221. Jw bellhousing and flywheel
  222. Please settle this debate!
  223. Circle d flexplate question
  224. Yank converter sale starts Thursday!!!!
  225. Tranny help pleeeeease!!!!!!!
  226. no movement in forward 4l60e
  227. Shift points too low?
  228. Shift kit guys
  229. 95 gmc 4l60e info
  230. 4L60E slips in all gears.
  231. i have to pull my long tubes to install converter
  232. 4L60 not shifting @ WOT
  233. rebuilding a 4L60e for a hi hp 5.3L, what upgrades are a must?
  234. 4l60e help
  235. Internal or external range selector switch (PRNDL)
  236. 4L60E 1-2 shift in drive is weak
  237. 4l80e VSS question (picture inside)
  238. 3600 converter with 10 bolt
  239. lokar dipstick, and inspection plate questions
  240. 2006 gto A4 tranny question...
  241. Budget rebuild
  242. Soooo.... I rebuilt my first automatic tranny! Advice for other newbs found here!
  243. Yank SS 3600 Question
  244. Side by side picture of a 4l80 and T56?
  245. Trans blanket or shield for street use
  246. Flexplate PN search and ?s
  247. 95 4l80e behind LSX
  248. Starter binding...Need help and Ideas...
  249. issues going from 2-3
  250. Ss3600 converter bolts
