View Full Version : Automatic Transmission
- 4l60e case casting flaw
- 4l60e Shifts into 2nd upon launch
- 8l90
- 4l60e will not shift automatically in drive
- 8L90 swap
- Bushing included with TCI 399753 Flexplate?
- LS3 and 4L80e into 1972 Chevelle for a customer
- 4L80E install....typical labor charge.....
- 4L60E pan
- Rebuild kit options?
- Reverse boost valve vs boost valve
- Building AN trans. cooler lines- help!!!
- o'ring and valve bdy gskets
- 4l60e burnout tips
- What temp is too hot for a powerglide?
- 4L80E CK Performance transbrake problems*SOLVED*
- SS4000 user, backhalf mph
- How to: B&M Pro Ratchet Shifter install
- coupling and shift extension??? HUH
- 3600 stall vs 4000 stall. Would 3800 be best of both worlds or pointless median?
- 4L80e HD2 Kit acting weird while driving
- 4l80e reverse shudder hot
- Truck pan
- For Builders and DIY Enthusiasts
- th350 / th400
- 4l60 jumps to high gear at track
- 2000 4L80E, no movement in any gears
- 4l80e pump seal leaking
- Opinions on trans options.
- convertor pilots?
- Engine VS trans torque management
- Can I reuse my original separator plate VS TransGo plate on a 4L80e HD2 kit install?
- B&M ratchet shifter with A4 center console come in
- 2007 Avalanche Transaxle wiring
- coan th400 rmvb transbrake
- 4l80e valve body separator plate question
- Trans cooler
- No converter Lock-Up......only after it’s warmed up.....??? UPDATE-FIXED
- Torque Converter woes
- How much power with the stock flex plate hold?
- 1994 GM K1500 4L60E mating to a 1999 GM LQ4
- Pre LS 4L80e and Converter onto 2002 5.3, Bought Jegs Kit
- 4L60E Full rebuild, now stuck in Limp Mode, I think.
- 80E or TH400 high powered street car?
- 4l80e checkballs
- B&M ShiftPlus on a 2000
- Front bell housing leak
- Th400 vs Powerglide (Ws6 3550weight)
- 6L90 or 4L80 for Cruiser C10
- Good or dumb question
- A4 cooling routing
- 6l80e
- Linkage Adapter for 4l60e in fbody?
- TH400 Best source?
- Converter?
- which way do I go for a trans
- Coincidence? (Trans failure pics)
- Ws6 4l80 Ls1 ( High Stall Tc opinion needed)
- 4l80e help
- Daily driver A4 with 3.42 2000 Trans Am
- 3.8l camaro auto tranny compatible with 5.7l camaro auto tranny???
- Th400 old style ultra bell to ls1 modifications questions?
- Transmission mount help!
- CK performance 4L80e D3 transbrake
- 4L60E Bellhousing
- 4l80 single vs triple disc converter??
- 4L80e Trans fluid level question
- B&M 4L80e any good?
- 4L80E swap
- 4l60e installed shift kit
- Torque converter lockup question
- 4l60e "rpm shift time" and trailblazer converter
- Troubleshoot 4l60 or get a junkyard 4l80?
- T56 > Powerglide install
- How much would you pay?
- Need some advice, trans related
- Purpose of the 3-2 downshift solenoid in the 4L60E?
- B&M stealth ratchet shifter install questions.
- 4L80e making pump noise in 1st gear when warm.
- 4l80e rebuild now pump noise?
- Trans temo gauge install on powerglide ?
- SONNAX 2.84 CARRIER worth it?
- 4l80e tcc control Holley HP EFI
- Best Trans for The $ and What Cooler
- Summit's new converter options.
- Checkball removal
- What SFI flexplate do you guys recommend?
- Hard shift into drive
- 98-02 A4 Shifter electrical plug adapter
- B&M pro ratchet shift wiring
- 4l60 upgraded input drum with wider frictions for more apply area.
- 4l60e slushy
- C5 Corvette 4L60E Rebuild...Need advice on parts
- Need Opinions on shady mechanic
- Which trans for 434ci LSX with 300 shot?
- Budget 4l80 converters
- Transmission and Kit Sale
- 4l80e rebuild
- 4l60e rebuild gone wrong
- What shifter for a 95 formula th400 swap?
- Fourth gear lugging
- Rollerised forward hub 4l80e
- What trans to run?
- 4l60e rebuild, 1997 parts vs. 2004 case
- 4L80E thrust washer location
- 99 4th gen Z28 auto transmissons questions
- Using a 4l65e torque converter on a 4l60e
- Powerglide or TH400 for Street/Strip Car
- 4l80e offroad upgrade recomendations
- Missing valve body gasket
- 60e to 80e relay digram
- 2013 L92 and 6L80E
- Faulty speed sensor???
- 6L80E or 8L90E do they fit in a C5 Corvette?
- 4l80e Pump Gears and Forward Clutch
- Please help th400 issues!!
- Need someone to verify a 60e to 80e swap.
- converting a 2008 C6 Z06 to 6L80E or 8L90E, can it be done?
- 4L65E no 1st, 4th, and no codes
- Torque Arm Clunking Movement
- Goodwrench 4l60e rebuilds -
- 4l60E build....few questions
- 4L60E lost 1st and 4th (correction)
- 4l60e (2003) dimensions
- Anyone running a line pressure gauge on their 80E?
- Honda trans fluid in 4l60e
- What Trans To Run And By Who???
- TH350 Trans
- ? 6 speed auto to 4l60e c6 covette swap
- 4th gen fbody transmission cable
- Small Leak - Replacing Main Connector Seal
- roadrunner converters
- FTI vs Mobil 1 transmission fluid
- PAS3400 vs SS4000 before and after launch vids
- 4L80E Manual control using relays
- 4l60e no 4th gear
- 4L65e performance shift
- Anyone have experience with the knockoff beast shell?
- Debris in rebuilt transmission
- 4L80E Torque Converter Issues
- Pusher or Puller fan needed ?
- LS3 with 6R80 Transmission (Ford)
- Where to buy th400 & converter?
- How to control 4L80E trans on budget no stock computer
- ARP flextplate bolts for 8 bolt crank??
- Transgo separator plate difference
- TCC Wiring Help, 4l80E
- Shift in stall question
- 95 4L60e Diagnosis.
- 4l80e no 1st gear
- 4l80e boost sleeve question
- 3 4 input drum comparability and clearance question
- 94 c1500 Weird Trans Problems!
- 4l60e question
- 4L60E temp question
- 4L60E TCC Anti-Bleed Solenoid Filter Screen?
- the not 1000 4l80e converter, which one?
- SS4000/4l80/3.73 street ability...
- 4l60e swap, 1998 vs. 2002
- TH350C with high stall
- C6 drag car solenoid B stuck on second built trans.
- Who Vacuum tests pump and valve body on rebuild 4l60e
- Need a little help with my 4l60e!
- LS1 4L65-E to 4L80-E/6l80E/TH400 HELP!
- Manual lever position sensor needed?
- My 4l60e build for my turbo car
- 4L60e line pressure same in reverse as drive
- Whens the 10L90 going to gebneral sale?
- Cheapest eBay 5.3 Turbo build and Th350 torque converter help
- T56 to 4L60E Harness Question
- Rear cooler fitting 4l80e
- No 2-3 shift@WOT 4L60E
- Ever had the reverse input drum snap ring pop off? (4l60e)
- 4L60E New Reverse Problem
- 4l60e failure??!!
- 4L60E trans go shift kit
- 4L60E stuck in LIMP MODE
- Transmission shift issue 4l60e
- Torque converter clearance
- 4l80e super slow kick down (10+seconds at wot)
- Jake's Black Box/SloppyMechanics Transbrake
- 4l80e accumulator delete
- Transmissionbench 4l60e videos
- Circle d converter spacing
- 4l60e sonnax Kit + corvette servo now no reverse! HELP!!!
- 4l60e or 4l70e?
- need gm supermatic 4l80 download
- 4l60e
- Which kit to buy (4l60e)
- 4l60e tcc apply valve in pump
- 700R4 or 4L65e
- Front stator bushing
- 4l70e?
- th400 reverse and third gear problems
- HD2 shift kit
- Forward input drum leak from case to input shaft - importance?
- Sonnax overrun clutch valve kit
- Silverado 6L80 Manual Mode
- 4L80E performance parts source
- Please help.
- 200 14L 60 E. I have 1st and 2nd gear no third and fourth
- LQ9 in '87 Monte Carlo SS- ideal trans/computer combination?
- Z-Pak Clearance help
- 700R4/4L60E Flex plate Dust Cover
- Bad tune or bad transmission?
- LS Tranny Mount (p/n 22174970 and corresponding nut p/n 10406946) on 97 LT1
- 4l60e servo pin
- Correct OEM 97 Camaro Tranny Mount
- BOP th400 to a 5.3l
- Yank SS3600 vs 4000 stall ?
- Torque Converter unlocking and locking
- gm trans adaptor 19154766
- 4L60 Codes question
- 4L65E recommendations
- 4l60e
- 4L80e failure; Innocent mistake or crooked rebuilder?
- TH350 and E Rod LS3
- PTC th400 converter
- B/M deep pan w/ stock filter?
- 6L80E Question
- 4L60E Rebuild Kit
- Ws6 4l80 swap , cant see trans temperature
- 4l80e yoke spline engagement input
- 4l60e low rev stack clearance
- Automatic Transmission Replacement
- 6l80e on 5.3 handle 500rwhp?
- Rebuilt 4l60e no OD or D
- 4l80e SFI Shield or blanket options Fbody
- p0785 after rebuild
- Trans issue 4l60e
- 4l60 swap wiring question
- 80e slips in OD after converter locks
- 4l80e manual/auto valve body??
- Vacuum Port on top of 4L60E
- 4l60e shifting issues
- Need advise
- 4l80e wiring questions
- trans bangs into lockup at 55ish mph
- 4l80e shifting strange
- 03 LQ4 6.0 swapped to 07 lQ4. Flex plate issue
- 4l60e to a 4l80
- 4l80e Converter for 1000+ rwhp Turbo car
- Rebuilding 4l80e
- How tall is a 4L60E
- LS7 flexplate
- 4l80e questions
- Bad TCC tune?
- 4l60e missing pwm solenoid
- Trying to figure out why my trans went bad
- Is a working PWM solenoid needed when eliminating PWM function
