PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 [61] 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. Where the hell is C200 Pin E???--- m6 to A4 swap
  2. Pulling the tranny
  3. Anybody run a powerglide in a heavy car?
  4. Opinions on TH350 build
  5. Shift lock wiring and PNP?? Searched stickies and have a question
  6. M6 to A3 swap- flexplate bolts and tranny mount?
  7. How do hook up a Trans Temp Gauge?
  8. 4l80e tail housing HELP!!!
  9. Only 1st Gear... What Has Happened?
  10. Autometer Single Gauge pod any good?
  11. Will this Tranny Cooler do the job??
  12. how much power should an 05 silverado 4L60E handle?
  13. step on the gas, doesn't go forward, goes in reverse fine
  14. will i be ok?
  15. Converter snout too big?
  16. What classifies as a "Stage 2" transmission?
  17. Who is NHRA legal, without an UltraBell?
  18. 4l80e/speedometer problem
  19. 98 Camaro 4l60e no 3rd or 4th gear
  20. Upgrading flexplate at trans shop - should I upgrade anything else in that area?
  21. Tearing down my 4l60E again
  22. trans differance
  23. 93-97 LT1 torque converters???
  24. FLT or Performabuilt...??
  25. Just rebuild 1st transmission...now I have a big problem...
  26. 4L60E problems
  27. Clunking sound
  28. Auto Tranny Issue any help Appreciated! 2000 Trans Am Formula
  29. What converter
  30. stock shifter and 4l80?
  31. Transbrakes are f---ing AWSOME!
  32. 2 questions on my PB level 2, lock up and fluid?
  33. having second thoughts about putting my tcin my stock tranny
  34. transbrake engagement question.....
  35. 4L60E second gear gone
  36. Sluggish shifts
  37. 4l60 overhaul
  38. Full Manual 4L60E
  39. 4L60 vs 4L65E
  40. Tranny Questions
  41. whitch built tranny i should buy????
  42. tranny cooler install q's
  43. Looking to swap out M6 to TH400
  44. auto to 6-spped convert
  45. Beast Sunshell upgrade, use supplied thrust washer or OE torrington bearing?
  46. When my tranny goes...
  47. 4L60E Leak
  48. 4l60e atf
  49. made a killer bracket for a LOKAR dipstick *pics*
  50. LQ4 to 2002 LS1 4L60E?
  51. 2nd gears shifts sluggish
  52. What transmissions will work with the long crank 6.0
  53. 96 LT1 converted to a auto(th350), which bolt pattern flexplate?
  54. t56 to a th350 help
  55. Yank sbs3000 for street only car
  56. 4L80 Manual Valve Body/T-brake suggestions
  57. What in the 4L60E breaks?
  58. Trans fluid changed color on me?
  59. 200r4 guys step on in
  60. Stock tune with 3200 stall converter ok?
  61. TH400 shifter cable adjustment with stock shifter?
  62. Couple of a4 questions for you techsters!
  63. Ats contollers
  64. 1993 4L60 TV cable assist, Corvette /ASR
  65. GM Overdrive transmission Questions
  66. Should I flush???
  67. Need to cool a 4L60E without a radiator...would this work?
  68. Glide work with m6 Crossmember
  69. Th400 tranny filter?
  70. 4.10's in an a4
  71. transmission dipstick seal where to get one
  72. fittings
  73. 4L80E rubbing BMR trans crossmember...
  74. 4l80e swap guys aftermarket pans revisited ,deep, finned etc.
  75. Running a powerglide? come on in.
  76. help finding park neutral switch and pigtail
  77. Buddy has a shifting problem
  78. new stall question about size????
  79. 4L60E For LQ4?
  80. 4L60E Early and Late Model
  81. Just finished 4L60E swap, ok to drive on stock tune settings?
  82. transmission problem
  83. Pink converter??
  84. TCI 4L80E Transbrake Valve Body
  85. Visual inspection on a used TH400?
  86. what is the limit of 6L80E ?
  87. 4L60e tailshaft
  88. Tech question for the sponsers
  89. Yank SS3600 or PT3800 for a daily driver/roll racing?
  90. looknig for a good brand and stall speed for a tpi car
  91. 4L60E case cooler line size
  92. 14k cooler big enough?
  93. Just some tranny problems
  94. performabuilt trans and yank pt4000 - 12.1@113
  95. transmisson cooler
  96. 4l60 rebiuld video or manual
  97. 2000 Olds Silhouette Ticking.......flywheel/flexplate??????
  98. ? about tranny fluid in 4l60e
  99. question about shift kits 4l60e
  100. Circle D stall size help
  101. Manumatic on Stock A4
  102. 4L60E with input shaft sensor question
  103. recommend me a tranny cooler
  104. 4L60E Question-Tranny Gurus Chime In
  105. th400 trade?
  106. Just ordered me a Circle D converter.
  107. Could a small 2.0 3200 stall kill my stock trans?
  108. Flexplate Bolts
  109. Is there a way to chage out a flexplate without pulling the transmission?
  110. use the radiator for cooling?
  111. New transmission time I think!!!!
  112. Test for locked up converter?
  113. help coolent line clips? (look)
  114. 4l60e question
  115. 3-4 clutches in my A4?
  116. Won't shift ???
  117. 40T reluctor wheel problems, need some input.
  118. SFI Plate for 80E
  119. Tci flexplate owners
  120. Turbo 400 Flywheel
  121. gap between crank and input shaft th400 (pic)
  122. transmission swap
  123. How much work
  124. How far will a stock A4 take me?
  125. New WEBSITE and GMHITECHPERFORMANCE article
  126. B.O.P.TH400 on a 02 5.3
  127. Flexplate Sizes
  128. Need helping figuring out which Auto transmission to go with
  129. tranny mount?
  130. 4l60e limits?
  131. th350 swappers what converter are you running??
  132. 4L 80e BLOWING OIL
  133. stock stall of 4l80e
  134. 4000 converter question
  135. Tranny cooler ???
  136. V6 Stall same as LS1 car?
  137. starting the car with no tranny fluid?
  138. 96 4l60e?
  139. How well do these hold up with near stock power?
  140. First Goat in the 8 sec zone on IRS with FTI
  141. Looking to go auto...convince me!
  142. 4L60E - 4th gear no lockup, possible?
  143. yank ss
  144. Stock trans rpm limit?
  145. Where to mount B&M trans cooler w/ fan on F body?
  146. car not going when transmission is in D
  147. Stock/Aftermarket tranny cooler lines
  148. Heeeelllppp!!!!
  149. Bogging Down and "breaking" feel in 3rd
  150. 4L60E to Th400 tune change?
  151. 2nd Gear went?
  152. my stall wont stall help
  153. th350 swap question
  154. Circle D
  155. 4l60e pan.
  156. Converter lock question
  157. ATT: LQ4 6.0 / 200R4 / 700R4 Users need help
  158. 4l60e or 6l60e help please transmission out...
  159. Transmission mount
  160. question bolting up 4l60e to 6.0?
  161. 6L90 Dimensions
  162. builders please help?!?! 4l60e problem
  163. flt power lvls
  164. Just installed a new 4L80E transbrake
  165. tranny gurues!!! got a question
  166. wallowing out flexplate holes.....
  167. More TH350 trans ???'s
  168. 4L60 ATF Fluid Data, best etc?
  169. Tranny or Rear End NOISE???
  170. Ok heres a question for you tq convertor guys.
  171. th350 swap question (BMR/UMI look in here!)
  172. 4l60e/4l80e swap crossmember info needed
  173. GTO 4L80E conversion has begun from M6
  174. M6 to auto Console swap?? Anyone want to trade?
  175. leak question on an A4
  176. 4l60e re-fresh with pics
  177. bolt on bellhousing problem?
  178. TH400 rebuild
  179. road racing a 4l6e
  180. TH350 swap questions
  181. trans remove help v6 camaro
  182. can i spray through downshifts?
  183. tranny slipping?
  184. 4400 HUGHES STALL...full race for street use??
  185. Need Help cannot get new tranny to work
  186. New FLT trans on the way.
  187. Mixing different brand ATF, any issues?
  188. I need help
  189. TCI Flexplate
  190. 4L80E in a Fox
  191. tough ?
  192. LSx into 98 Blazer 4x4
  193. small convertor in light car big motor, need cam advice
  194. 4l60e separator plate gaskets?
  195. auto trans SOTP Question
  196. Converter Installed
  197. 6L90 Oil
  198. hep me choose the best 4l60e?
  199. Cooler location
  200. Debating M6 to A4 swap, reccomend me an auto trans/stall
  201. 3000 converter
  202. What trans do I have?
  203. doing your own tranny work
  204. P0751 Light Came On
  205. Stepped on it....car shuttered, now what?
  206. Which transmission should I go with?
  207. 4l60e problem?
  208. 6L80 in 2000 F-body
  209. Tranny Build!
  210. th400 driveshaft
  211. Lq4 + th350...
  212. 4L80E converter suggestions?
  213. TH400 swap, what stall?
  214. 4l60e trans problem no 2nd..
  215. USED stall... Am I look for trouble
  216. What upgraded Flexplate did you get?
  217. Can a stock a4.......
  218. TH400, what shifter?
  219. Need help finding a4 harness converting from T-56
  220. Troubles with Flexplate and 6 bolt Verter. (ATI/Yank)
  221. what tranny cooler with yank ss3600
  222. 4l60e converter check ball
  223. 4L60E snapped input now what else?
  224. 4l60E Pop no go
  225. Truck pan questions
  226. Flexplate might be cracked
  227. FLT 4l60E Trans level 5 or 7
  228. Anyone use the tci stand alone unit for there 4l60e
  229. speed sensor question?????
  230. experience? setting up the PCS tcm with a 4L80E
  231. 4l60e Exssive shifting at 45 mph OD maybe?
  232. T400 and 4L80 internals
  233. Shift kits
  234. now logging actual line pressure in A6, less than 100psi in 3rd
  235. How much did your M6 to A4 conversion cost you??
  236. harder shifts after highway cruising
  237. th400 to ls1 converter flexplate problems
  238. Trans ?
  239. Rear seal leak
  240. Trans Install
  241. Th400 Shifting problems
  242. Locking Circle-D 4C through diagnostic port?
  243. PLEASE HELP!!!!! what stall to get
  244. cut n cleaning stall easy
  245. trans and converter are in thanks circle-d
  246. 4l80e fourth gen f body swap guys with aftermarket pans
  247. Weird Problem with Tranny and Speedometer
  248. Best Trans for my needs
  249. 4l80e
  250. TH350 Back to 4L60E
