View Full Version : Automatic Transmission
- Mw 3400 2.0 str impressions
- just put my Rossler trani in and......HELP ME
- quick tranny question
- anyone street drive a reverse-manual TH350/TH400?
- Anyone go from a 3500 stall to a 4000+...??
- Converter size
- Suggestions for a converter Plz help!
- when to lock up converter while racing?
- Core Charge
- Transmission fluid?
- Stock tranny's with nitrous and high mileage.
- Vig 3600 vs TCI/Yank 4000+
- Trans mount
- Kevin - TCI, TCU VSS question...
- Drove my car out of town this weekend with the TH400. what is everyone talking about?
- Yank TT3000
- Help With Shift Kit
- My tranny = WTF is happening?!?!
- is it time for a 4400 tci
- Cheapest way to relocate torque arm to crossmember?
- Has anyone ordered and recieved anything from Yank...?
- Diablo Tuner owners.....auto shift MPH and RPM question.
- Torque Converter lockup and unlocking and 2-3 shift miss
- Tci 3600
- TH-350 Question
- TransGo Shift kit users looky here.....
- Why is my car hitting the rev limiter on the shifts......????
- Art Car
- 2600-2800 Tc
- Anyway to find out if i have a shiftkit?
- Transmission cooler with AN fittings
- ssf3500 stall speed?
- T-rex cam converter????
- Shift Cable Rubber Boot
- Transmission problem?
- Which shift kit, TransGo or TCI?
- TH400: To upgrade or not (first gear)
- 2001 Lincoln LS 3.0 -5R55N Tranny
- ? for PT4000 owners
- dipstick tube question
- Torque convertor bolts? Size? Thread pitch?
- Best tc to replace my vig with?
- How does a 4L65E take 800ftlbs? Experts.
- Changing Dipstick Tube
- Vig.3800 Exactly how do they work?
- Driveline vibration?
- Need info on tranny swap and convertor selection.
- Please help me make my Final decision plz.
- cooler install how to?
- Which converter is right for me?
- rmoving shift knob???????????
- got the tc installed
- Hitting rev limiter in all gears even after edit
- thinking of different convertor
- Yank SS4000 Cause a surge when stop at a light?
- Efficiency of Vig Stalls
- Mileage and durability pt4000
- Blown up 2 Yanks in the past 6 months
- Open loop tuning messing with shift points?
- gear install ?
- no 4th, code 1870 ??
- 3300/2.2 Str
- Dyno stock converter vs. TCI 3800
- Strength of 4L60E
- older, but new SLP converter, good idea?
- Vote: Best Yank Model TC for Me:
- 4L80E - 2x4 & 4x4 swap
- Need an answer quick!!! TCI 3500 question
- Converter Question??
- TCS Phoenix Torque Converters?
- SSF3500, what RPM range to get graph on dyno
- Makeing 4L60-E to TH400 Swap, 3 last min questions.
- Torque arm for TH400
- Shift Pressure?
- part throttle shifts????
- PY3600E for a TH400???
- new verter = no traction... Please Help!
- Repairs on 4L60E worth it?
- Fix shift points?
- converter ? can i do it?
- Advice on choosing converter, LS1 420BHP, TH350, 3.73's.
- Speed Inc Transmissions?
- Suggest the best convertor for my TA plz...
- a4 vs. m6 from a roll
- just installed SSF 3500. WOW!!!
- got 224 cam and stage 2 heads stock a4 t
- *Help* Trans Go install sheet needed
- Vibration when verter's locked...
- 2 second delay before the trans kiks down...?
- SLP Shift Improvement Module
- What brand is this ?
- Good 4l60E Tanny Guys
- LS1 TH350 with spacer kit using standard A4 flexplate
- Stock shifter with TH400
- Need 4L60E tailshaft
- Benefits from aftermarket flexplate?
- New Th400 Price $900 Good/bad
- Super Street Raptor
- Push-Lok Tranny Lines?
- Need help with TH-400 - will not shift 1 to 2
- problems with 1-2 shift...
- A4 road course shift tuning
- powerglide questions .
- TC slipping????
- tranny goes from 1 to 4 sometimes???
- On the Road Again
- PLEASE HELP! My cars not shifting right
- tranny setup
- 230+/600+ Cam--What Stall?
- my review of the tci3000 street fighter
- ssf 3500 owners I got a quick question?
- Need Advice
- I need a no BS TRANNY TECH plz
- 2-3 shift problem
- Shudder when turning ...
- Vette LS1 to transmission?
- Trans temp sender?
- Which Stall Is Right For ME?
- Vacuum Mod for A4s
- Bad 4l60e problem, need help find a good tranny shop in Orlando
- Yank SS4000
- Power handling of a 4L60E
- trans temp gauge mounting options
- Traansfer Case Guru's ---> haaaalp :)
- nitrous and stall converter?
- Converter Slipping??? 4L60
- TH400 and PCM reflash??? What's the bottom line?
- So what's the deal with the C6 A4?
- 4L60E woes - what should I do?
- C5 Flywheels
- Tranny-engine block bolt size?
- Car not locking into park?
- Converter do I need a Rear End
- 4L60E to a 4L80E Trans??
- Help find the best priced trans cooler
- Did I toast my 4L60E? Video inside
- What happens when you overfill your trans
- Tranny going or overreacting
- Th-350 Lockup?
- Th350 Ds ???
- stock TC?
- TCI 3800 shift points and Torque Management questions.
- FLP vs. Rossler vs. Local tranny shop + parts ??
- Need some input picking tranny!
- Transmission change time
- 4L60E differences? - Vette vs. F-body, etc
- Coan coverters for TH400?
- Tranny not working after install
- Vig 2800 or Yank SS 3600,SS 3800
- How difficult to install a 'verter?
- Anyone running a TransKing?
- how much pitch on a 4l60 e
- 383+4l60e
- Weird 4L60E problem
- T400 delays going from 1-2 at track
- ***Serious Help Needed!!!!***Transmission Not Engaging gears
- how strong is the 700r4
- 1-2 shift problem
- Got my TCI installed!!!
- Running the tranny cooler
- buying a used VIG?
- B&M trans cooler
- 700ra tranny shifting, or stay in drive?
- Does a high stall converter reduce rwhp?
- Tranny Problems
- which trans
- Why is a lower stall better w/ lower gears?
- Small Cam on stock TC
- vibration
- converter question
- converter and gear question
- How to remove and install 4l60e pump
- ATF Fluid?
- TCI 4400 or Midwest 4400?
- 3200 stall on dyno will it give low numbers??? need help
- Transmission questions. Please advise.
- Tranny Problem *Help Please*
- Anyone have a write up for...
- 4L60E vs 4L85E
- Shift Points TCI 3500.
- RPMs drag slowly down after let off gas
- Pulling off TH400 speedo gear??
- th-350 convertor question...
- How much TQ can 4l60E handle?
- 4l60 swap to 4l80 ????
- 4L80E swap into SSS -- keeping the awd
- Do yourself a favor,bump your idle to 700rpm
- B&M 28,000 GVW or 24,000 GVW?
- Flexplate Torque Specs?
- How much HP can the drivetrain on an '01 Tahoe handle?
- M6 to A4 and A4 to M6 Conversion info
- converter questions if you please.
- Building new HC motor, do I need a higher stall converter?
- Converter question
- Can Some1 make a sticky?
- Im sure its been asked, but?? anyway!
- TH350 or Powerglide with OD for FI & Big Cube Torque?
- TCI3000 or TCI SSF3500
- slight whine in reverse????
- Shift kit and no Converter?
- V6-V8 4l60e
- 4l60e
- Need help finding good tranny shop in Orlando
- vig 3200 cars
- Trap Speeds?!?!
- Tci Ssf3500 Installed!!
- Where'd you get your TH400
- Help please, WHINE coming from my tranny
- Fbody pan vs Truck pan
- A4 to M6 wiring - HELP PLEASE
- Doing it yourself?
- TCI3500 what stall speed?
- tci 3500 installed today,, great but...
- line pressure vs trans temp
- convertor question??
- 4L60 Problem....
- how long can you go with out a trans cooler
- Anyone running a P.I. converter w/their TH400??
- TH400 Mount Spacer?
- Is this normal 1-2 shift
- Is it my tranny or converter?? Problem?
- Do you have to Break-in a TCI SSF3500???
- Where to buy shift soleniods?
- Th350 fluid temps?
- TH350 pan clearence?
- 4l80 in a lt1?
- What's this part?
- picked car up today, WOW!
- help installing A4
- For Those of You With Any Higher Stall Converter....
- Anyone have any TH400 in action vids?
- Bad converter or something else??
- will it hurt the trans to put a shift kit in and drive it without a tune?
- Lets talk PT4200 and nitrous
- New To Converters
- cost of stall including installation
- What Size Stall To get???
- TH400 guys: Which cooler are you using?
- Stall Questions
- B&M Cooler and SLP Cold Air Install
- wanting in on converter game
- Sy3500 and 3.73..?
- Delete 3rd Gear Lockup?
- Screens/Filters in seperator plate of 4L60E...where to get??
- What's an aftermarket stall like?
- tranny temp gauge question
- 2001 Tahoe 4L60E Questions
- A4 cars with aftermarket trannies--inside please
- Billet servo question?
- Th400 or Th350 D/S?
