View Full Version : Automatic Transmission
- flexplate
- 700r4 vs 4l60e mount pad
- Stage II TH400 w/ RMVB transbrake
- 4l60e transmission shifting problem
- 4L60E issue
- Will a transmission dipstick tube and dipstick from a v6 car work on a LS1 car?
- 4L60e wont shift out of park
- 4L60E with 15 Pin Connector - What Year Models?
- Th 400 in a 1998 Trans Am
- pressure control solenoid
- Need a trans cooler!
- what converter?
- What should be inside a built 4L80e?
- T56 to Th350 Swap
- HELP! 4L60e lost over-drive!
- Keep 4L60E or goto th400?
- 4l60E from 2004 GTO same as 2000 camaro 4l60E????
- 4l60 / 4l65
- Learning the 4l60e, auto and manual?
- Torque converter bolts really close to oil pan, too close?......
- Got a Polyurethane Trans Mount
- 92 z28 gear shifter
- paddle shifting a 4l80e
- 4L60E to Th350 swap... Gearing Question?
- possible bad converter?
- Link to great information on a possible 2-3 flare issue
- What exactly is a stall converter?
- 4L80 Trans Cont
- Lokar
- Can't Decide on stall speed
- Driveshaft for TH400 to 10 bolt???
- '93 4l60 mystery
- Shifter wiring help please. Switching to pro bandit.
- Lazy 1-2 shift 4L60E
- One time deal! Stage II 4L80E with transbrake
- 3600 stall went great...then i got home
- Converter questions
- clicking/grinding noise when selecting first?
- guys with 400turbos & nitrous?
- Newbie 4L80 owner, is this how stall should work?
- Is a converter behind a diesel the same as a gas motor?
- Finding pigtails for the 4L60E
- extra non-working 4l60e what to do with it?
- no overdrive !!!!
- 93 4l60e swap
- TH400 Dipstick????
- 4l80e 4x4 rear case seal???
- LS 4L80E behind a SBC/BBC
- PRE ls 4l80e mated to a ls motor help?
- 4l80e reverse question
- Vigilante 3600 Stall.. need cooler..
- Cooler
- TQ converter
- 6l90e 4wd to 2wd
- what wrong with my trans
- bellhousing swap only?
- T56 to auto swap question...please help
- 4l80E transgo shift kit, why?
- Cheetah Shifter in a4 Console
- 4l80e sap
- Automatic Transmission Fluid?
- 4l60E on first gen smallblock
- 600whp+ TH400 build up suggestions
- Need Help from the Pros again!
- Removing Pan Gasket
- Advance Auto trans filter/pan gasket question
- How to ship 4l60e
- 4L80e pump bolt o-ring
- My automatic tranny doesnt shift past 2nd gear???
- 4L80E Different for 4.8 and 6.0 engines?
- Is my Full Manual 4L60E shifting correct?
- Help identify this spring.
- 700r4 converter in ls1 and 4l60e
- 4L65E Rebuild DIY?
- Performabuilt Customer Service
- 4L60E Third gear with high hp?
- tranny issue
- 4L80E Jake's Manual Controller for $150?
- Check ball capsule replaced with cup plug, is this bad?
- 08+ Rev Match/throttle blips A6 questions
- remove/or not
- TH400 Temps???
- Cam on stock converter , tranny problems?
- Best gear with a Yank 3600 3.23 or 3.42?
- footbrake RPM with a Yank SS3600*******
- transcooler fan switch
- Where can I buy GM A4 trans mounts?
- 4l65e -> 89 Formula -tailstock?
- Trans trouble
- Got a th350 ?
- Optimum rpm stall converter
- How can I figure out if I have a manually valve bodied th350?
- 4l60 question
- For those contemplating a stall
- 4l60e Hard Downshift From Lockup to 2nd
- 6L80E HP question
- How to chose stall speed?
- The best 4L60E?
- 4L80E Transbrake Special
- Clutches Slipping Past 5k RPM - Professional or Experienced Advice Please!
- Flex plate for PG converter to LS?
- custom gear indicator question
- trans cooler question/ what issues TEXAS HEAT
- Strange sounds coming from 4l60e
- 4L80E Flexplate
- Who knows what this is " 200 4r "
- 4L70E problems(no reverse)
- fluid line fittings for 1993 4L80e, connecting to fluid cooler
- Which TC for my setup?
- are they the same V6 between LS1
- Stuck in 3rd gear after stall & trans rebuild.
- 4l80e intermediate shaft
- 6.5l to 350 swap help me out
- 4l60e trans brake and upgrades necessary
- intermittent 4th loss and all drive loss??
- tranny pro needed
- are there different 4l65s?
- Need opinions
- Trans Swap... Remove the engine too???
- 4l60E shifting problems
- Do automatics amplify torque?
- using power steering fluid in a th350
- 4l60e won't engage in any gear
- rossler transbrake instructions
- 2003 lq4 + yank flexplate + 4l80e bolts and clearance?
- Tune lockup questions
- 3800 stall on a 3600 tune?
- Need Help! Converter wont lock
- Please Help me do this guys!!!!!!!!!
- 427 4l60 converter suggestion?
- 4L60e swap questions
- 4L60e Just the Facts
- No shift to 3rd @ WOT
- Th400 not shifting
- 4l80e has shifter module on it
- Shifter cable help!!!
- rebuild
- 4.3L 4l60E question... will it work?
- TH350 persistent drip
- How do you prime your transmission?
- Using stock shifter for powerglide swap?
- 3200 stall with MS4???
- Tranny problems lead to more issues
- 98 formula firebird tranny problems
- 4L60e forward clutch backing plates?
- Performabuilt transmission in a c5
- tunimg after a tc install*****
- Trans Has Been Sitting.. Need Help
- LQ9/4L60E trans wiring diagram?
- TH350 3-2 downshift
- General Automatic Transmission Question (NON LSx Related)
- Trans flush? or Trans fluid swap?
- Trans Controler Wiring in Michigan
- 4L60E issue
- Madman 4l80e dipstick
- 4L80E swap issues
- t56 to a4
- transmission shift selector cable
- Torque converter for 4L80E +800hp
- Worth the differance...
- Powerglide parts help please.
- torque arm mounts
- Need help, 1800 miles from home, and getting DTC p0785!!!!
- Help installed tc ,trans prob.
- 4l60e trans ??
- 4L60E Tailshaft housing
- Little vid of the TH350 swap
- LQ9/4L60E , DTC P0740, which wire?
- Is my pump broken? Different converter?
- stall
- 4l80e shifter
- difference in these two flexplates? prices are way different
- which flexplate for turbo build? B&M?
- 4l60e 2nd Gear hard shift no 4th at WOT
- Output shaft
- 4l60e help please
- What do you get when you mix a TT LS7 with a 4L65e?
- guys with ss4000 stalls
- which flexplate 2 use?
- 4l80E and my tuner
- yanks ss4000 vs tp4000
- TH400 vs. TH350 (and more questions inside)
- need stall recommendation
- yank py3400 TIGHT
- Help, transmission vibration 1800-2800rpm
- Poly mount review
- 4L60 help wanted please!!
- Is my 4l60E messed up?
- help th350 probs
- 4l60e flaring after new tune video inside
- CDS 278mm Upgrades
- Installed 4L80E feels like no 1st or 2nd, HELP!!
- Are these both C4 Transmissions?
- T56 to 4L80E 2005 GTO
- 4l80e duel feeding the direct drum
- How strong is the 4L80E overdrive?
- Dipstick for a 4l80e, 60e work?
- help thud, bang noise in rear can feel in car
- Please please please a flexplate speacialist needed!!!!!!!!!!!!!!!!!!!!!!
- Removing trans dipstick tube
- Trans not going into 3rd or 4th
- Silverado transmission pan on a `02 WS6 A4?
- So whats the top speed you have seen in your auto GEARED ls1??
- TH400 swap question
- 00 ss glide installed...first drive today
- Looking for yellow Signal B wire
- help with conversion vehicle please!
- Questions regarding M6 to A4 wiring
- Th400 w/stock shifter??????
- Will a 4l60e of a ...... Fit my 98 T/A?
- OCP code on Optishift?
- how long will my 4L60E hold?
- Need a pump
- Bad torque converter?
- 3-4 snap ring broke out
- daaco stalls?
- Newest old Sponsor checking in!
- Is this normal?
- 4l80e crossmember for 69 Camaro
- carnage pics and reinstallation q's
- 4l60e Bellhousing broke and dip stick question
- turning lockup off with diablo prediter
- 4L60E limits
- L460E swap? or not?
- ptc 3800 converter
- FTI new release available at Jegs High Performance
- Turbo 400 in place of 4L60E?
- trex cam
- Are shift kits any good?
- 4l60e won't shift
- 4L60E no staying in any gear??
- TH400 questions with a turbo 4.8L build
- Th350 swap i need help
- 6l90 into a fbody?
- Jake's Performance Updates
- What to do??
- NEED HELP doing a 4l60e to th350 SWAP in my '99 Silverado RCSB LQ9
- what is wrong with my trans, dipstick nonsense
- autometer speedo help please
- The 4L60E from hell
- 4l80e locks in reverse no 4th
- Building Info
- 6l90E 4x4 convert to 2wd?
- TH400 drive shaft yoke
- yank tc
- 4L60e sometimes shifts from 1 to 3 and does not react to kickdown
- untuned 3600 stall question
- th400?
- shift kit/ accumulator???
