PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. 4l80e neutral safety switch
  2. New trans...
  3. 4l60e - No 3-4, but doesn't seem like clutches.
  4. Any TCI bolt together converter reviews?
  5. Overheated Transmission - 4l60e
  6. M6 neutral/safety switch wiring
  7. shift parameters for 4L60E
  8. Converter recommendation for C5
  9. Hi I have a question I have a 98 4l60e and a 02 envoy can i use this tranny in it by
  10. Level 4....4L80E.....1,000+ RWHP street car use only.....What fluid temp is too cool?
  11. How much am I missing out on with a cheap converter?
  12. Recommend a trans cooler?
  13. 2000 lq4 4l80e flexplate question
  14. need quick answer on torque arm mount
  15. 4l80e 2nd to 3rd gear shift ... help needed!!
  16. Trans temp gauge question
  17. Will I be disappointed?
  18. 4l60e 9TTD, what's inside
  19. 6L80E. Leak coming from rear of the housing where the harness plugs in.
  20. 4l60e pump
  21. 4l60e Tuning w/3600 stall Yank
  22. New 4l80e banjo fittings
  23. Trans wiring to activate relays? 4L60e/4L80e
  24. Corvette 6l80e adaptability
  25. 2006 TBSS with 4L70E looking for South Florida builder
  26. CTS-V 6l90E yoke
  27. Repost: 4 Speed or 6 speed auto?
  28. 4L80E, recalibrate speedometer, now no reverse.
  29. Trans Cooler Location?
  30. How long will it last? Rebuilt 4l60e and 500 hp
  31. 4l60e problem after new engine
  32. 4L60 lost 2nd gear/ wont shift into 2nd
  33. TH350 or 4L60E?
  34. Shift solenoids or worse
  35. 4l60e problems
  36. 200-4r rebuild kits
  37. Biggest tranny cooler with rubber hose? 70266 or 70274 work?
  38. Thread locker for converter and flexplate?
  39. Trans fill tube install
  40. 6l80
  41. What to do for a shifter in a hotrod swap?
  42. 01 SS A4: car wants to keep moving forward when stopped but in drive
  43. flexplate ?'s regarding weight, runout, etc.
  44. Need schooling on flex plates
  45. 4L80E reubuild kit
  46. 4L80E toughness in OD
  47. 4L60E Pictures
  48. 4L60E rebuild air testing
  49. sudden increase in overall line pressure - 4L60E built
  50. Transmission fixture
  51. 4l60e tailshaft housing on 700r4 for LS swap.
  52. Trans cooler
  53. Measurements on th400 34 sprag please?
  54. need help with 4l80e swap.
  55. Hello with 99 Sierra LQ9 4L60E question
  56. 4L60e Shifter
  57. 4l80e fitting problem
  58. 4wd to 2wd
  59. 4l60e acting up - won't automatically down shift and won't hold manual first
  60. Where/how C6 torque tube & TH400...
  61. Running (not driving) a 4L80E without electronics?
  62. 4l80 vs th400?
  63. 4L80E cooler line fittings
  64. M6 to 4L80E wiring question
  65. Monster trans
  66. Which transmission?
  67. Machining 4l60e pump
  68. Another will this 4l60e work with that thread
  69. Modified 4L60E problem?
  70. Vette C5 4L60 trans cool options?
  71. 2005 Corvette 4l60e Loud pop now no 4th gear
  72. What is wrong with my 4L60?
  73. What will it take to convert a 6l80e 4wd to 2wd?
  74. What brand of stall?
  75. Grinding with new trans/tc install
  76. Strange intermittent noise on fresh trans, video inside
  77. Th400. Long or short tail?
  78. 4l60e versus 4l80e
  79. Prepping for Stall Converter
  80. 6L80E shifting options? How to limit max gear?
  81. ? On a prndl switch
  82. 4l60e problems
  83. High Performance 4L60E Build Thread
  84. Transmission issues
  85. Leaking transmission after converter
  86. 4wd tranny on 2wd truck
  87. 3200 Converter???
  88. best converter for me
  89. 4l65e trans no1 st or 4 th
  90. 1999 z28 th400 swap
  91. Flexplate for LZ1 6 bolt converter on 6L80
  92. Converter not staying locked
  93. 2800 compared to 4000 stall
  94. Rear band pin length?
  95. Need some clarification on flex plate and th350 swap
  96. 4l60e Dipstick question
  97. 4l60e Trans Rebuild
  98. Can I use an older trans in my '04 Avalanche
  99. 2007 4l60e with a 13 pin connector?
  100. 4L80E Rebuild
  101. Rebuild trans
  102. 70264 Trans cooler DOPE STYLE & SSRA install pics inside
  103. Anyone use a 13 pin 4L65 trans in a 15 pin 4L70 vehicle?
  104. Need tune file for 4L80E swap
  105. Need help asap! 4l60e issue!
  106. 1000 rwhp th400
  107. TH350 to Foxbody Driveshaft
  108. 4L80E missing part?
  109. Acceptable operating temp for Jakes Perf Stg 2 4L80E?
  110. 6.0 and 4l80e swap converter/flexplate
  111. 10% off on all Yank converters this weekend
  112. Best N/A 4L80E converter
  113. Anyone using a TH400RMVB with engine braking?
  114. Need help diagnosing a 4L60 Problem!
  115. Which transmission would you choose?
  116. 6L90E tranny cooler lines.
  117. Boost Valve ?
  118. 4l80e swap complete and didnt have to touch trans tunnel?
  119. 4L80E what year
  120. TH350 cooler lines
  121. Shifting problems with 4L60E
  122. Help sorting out my 4L65E issues
  123. RPM drop on WOT
  124. Modded 4l60e shift issues
  125. Yank ss 3600
  126. Camm'd my car, now need a converter.
  127. Help with TC choice
  128. controlling trans temps.
  129. 4l80e rebuild hard to turn
  130. Ahem....Please offer your STR opinions.
  131. 4L80E rollerized output shaft: TH400 bushing orientation?
  132. 4L60E Flexplate
  133. Converter selection
  134. Torque Converter lock up question
  135. Want some opinions
  136. FLT Stg4 built 4L60E failed?? Need advise vendors welcomed!!
  137. Vette c5 4l60e for LS swap
  138. What is this sound?
  139. Acting up after Stall
  140. 2009 4l60e valvebody in a 2008 case ?
  141. Tru cool cooler
  142. 4L80E DIY transmission controller
  143. 4L80e low line pressure, flare/slip
  144. Which Yoke for a 4L80e?
  145. Neutral Safety Switch heat shield - 4L80E
  146. Changing Trans Cooler Size/Location
  147. The A8 transmission in the C7 Z06
  148. 4l60e using tci-374090 help
  149. 4L60E Noisy transmission pump but shifts smoothly
  150. 98 Z28 4L80E Swap
  151. 4L60E Replacement options
  152. 4L80E: torlon check balls & separator plate repair
  153. 4l80 swap in a 98 Transam, yes it's a 98 PITA
  154. I need HELP!! no 1st or 4th.. 4l60e and 4l80e
  155. Colorado /turbo lq4 / 4L80 stall recommendation needed
  156. Precision Industries converter
  157. riddle me this, 4L80e manual low gear binding
  158. 4L80e shift shaft pin removal
  159. 4L80E, lost all gears
  160. 4l60e bellhousing help!
  161. Coolant in 4l60e
  162. Stock 4L80e torque converter ?
  163. T-56 to 4l80 swap code p0717
  164. What should the MPH shift points be with factory 3.23s on 4L60E?
  165. Yank PAS3800 Install/6l80e...DAMN!!!
  166. fti th400 esr converter nitrous?
  167. which cross member can I use- first f body I've owned
  168. Communications issue?
  169. 4L80E in Limp Mode - Speartech Harness Issues
  170. Transmission Swap
  171. 4l60e need help ASAP thanks
  172. 4l60e won't go into first
  173. P0740
  174. 4l60e transmission
  175. transmission fluid level has me stumped??
  176. What kinnd of custom converter is needed for long crank lq4 and 4l60e?
  177. Gen IV 5.3 / Early 4L60E
  178. Line pressure problem: causing Very odd 3rd gear issue. HELP!
  179. 4L80E Valve Body Rebiuld
  180. How strong is a 6L90.....how much RWHP/RWTQ can it handle.....?
  181. Recommended upgrades for 700R4 "in car"
  182. Transmissions 4l60e
  183. Engine Swap Converter Trouble
  184. Do not buy B&M flexplates
  185. TH400 Torque Converter Run-out problems
  186. Dope style details (f-body)
  187. 2000 4L60E Interchange with 2005?
  188. 4l60e and 6l80e mounts?
  189. 4L80E forward clutch clearance?
  190. new flexplate with new 4l60e?
  191. Need advice please!
  192. Trans cooler making car run hotter?
  193. PTC talked me into a 3200 for 00 SS
  194. Orange and black wire on the pnp switch
  195. Flex plate
  196. Trans cooler size?
  197. 4l80e
  198. deep sump pans worth it?
  199. tci 4l80e valve body
  200. 454 lsx to 200R4
  201. 4l60e hitting limiter on 1-2 and 2-3 shift
  202. Torn on stall choice for DD G8 GT
  203. Trans Problem
  204. 4L80E: 0.028" clearance in the overrun?
  205. code for solenoid A
  206. 2003 4L60E compatibility
  207. Pump Seal
  208. 4L80 Swap , will not move in 1st gear
  209. Best Stall post help I've seen (for noobs)
  210. Pin 9 on neutral safety switch
  211. SSRA mod idea for trans cooler
  212. Torque converter
  213. 4l80e stand alone controller which one is the best
  214. 6l80E High Stall. Whose convertor and why?
  215. i think i see a rebuild in my future...again
  216. source for 36 element intermediate sprag/direct drum 4l80e?
  217. Help wiring TCI EZ-TCU
  218. Name of member / website who specializes in trans go kits for 4l60e????
  219. Certain year 4l60E,4l65E for LS3 swap?
  220. TCC solenoid always locked
  221. Is my 4l60e a 1999?
  222. Motorhome transmission swap out.
  223. 4l85e problems
  224. More 4L80e rebuild questions
  225. Getting a cheap converter to live
  226. Pin position 4l60e/5.3 e38 2003 tahoe
  227. N/A converter with spray.. When to lock-up?
  228. Best place to buy a built 4l65
  229. What's the go to flexplate for a th400 swap these days?
  230. Circle D specialties
  231. Best transmission mount ??
  232. 4L60e swap takes off in 2ND
  233. Anyone mess with the TransGo 48-act-tl kit?
  234. Th350 swap
  235. 4L60E 2-3 Shift Slip/Flare
  236. Cheapest and Easiest Transmission Diagnostic Tool
  237. Th400 speedometer removal
  238. 4l60e have reverse but no forward gears
  239. Trans lines connection
  240. Output shaft rotational endplay?
  241. Another 60e issues!!!!
  242. 4L80e direct drum bleed hole: did I screw up?
  243. Reverse input bleed holes
  244. 99 SS shifting hard from 1st to second.
  245. Can this 4l80e planetary be saved?
  246. Need help !!! 4l60e manual lock up switch
  247. 4l80e swap slip yoke question
  248. TH400 pressure issue
  249. Converter help for turbo ls
  250. 4L80E pump gears: measured clearance?
