PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 [127] 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. problems getting the stater into the housing
  2. trans not shifting right
  3. 4L60-E removal questions - already searched
  4. Valve Body question?
  5. Help needed....did search
  6. Any A3 guys got their neutral safety switch working
  7. How are these numbers for a TCI SSF 3500 stalled 2002 WS6??
  8. What stall do i have?
  9. Which Tranny Would You Choose?
  10. Does Chuck Johnson still works at FLP?
  11. new tranny
  12. whining/deceleration
  13. Who do you talk to at TCI about converters?
  14. what do you guys think about this rebuild kit for 4l60e's
  15. vibration
  16. Transmission Cooler Fan?
  17. OD servo, int. servo, boost vlave info. request
  18. Is this normal for a TCI SSF3500?
  19. TCI SSF3500 review inside
  20. th400/manual valve body guys - ?????
  21. 4l80 Conversion Company...
  22. Tail-Housing Replacement
  23. torque converter suggestions for just a bolt on car
  24. DS and dipstick info needed.
  25. Anyone modify the A4 console and use a A3 shifter
  26. th-400 whining?
  27. good article on 6L80E in Nov 05 Hot Rod
  28. n00b auto tranny Q's, need help!
  29. Stall advice for 408 stroker?
  30. What are you base pressures at?
  31. fuddle stall
  32. Art Carr 4500 stall
  33. sfi sheild for the 4l60
  34. A4 shifter consol makes lots of noise!!!!!!!
  35. Rebuild kit, what should it have in it
  36. anyone build sick 4L60Es?
  37. yank ss3600 owners please help
  38. Fuddle VS Yank
  39. Newbie Question:I need to know about Torque Converters
  40. guys who converted to th-400-speedo?
  41. SES light after installing stall and shift kit
  42. Is A4 strong enough?
  43. LS1 Converter fit an LT1 Car?
  44. After market shift kit?????
  45. Uh oh symptoms....
  46. i wanna churp em...
  47. Yank 6-lug converter + TCI Flexplate?
  48. Aftermarket converter question?
  49. SS3800 and pro built shift kit is in!
  50. Converter won't stay locked up on interstate!
  51. Which Converter
  52. B&M Shift Plus???
  53. A Stall $$$$ ?
  54. 4L60E power range?
  55. What all does the car do in fail safe mode?
  56. Head is spinning after reading line pressure sticky
  57. What's The Trick? 4L60E Oil Line Connector Clips?
  58. need a good stall for ls1 silverado
  59. 2nd to 3rd pre shift quirk
  60. Does a lower STR also mean a converter is tighter?
  61. Transgo with my SSF3500?
  62. After market torque converter sounds
  63. TH350 Conversion need info...
  64. Trouble adjusting A4 shifter after converter install
  65. Temp sending unit 4L60E?
  66. loose tq arm, now loud banging?
  67. toasted tranny, need advice on new
  68. Tranny guys...
  69. I will buy TransGo shift kit towmorow. Do u agree?
  70. No TC lockup...?mechanical problems
  71. ROCK-ON Tranny,
  72. info on this tranny
  73. Post Your Stall Size And Manufacture.
  74. 4L60E vent tube??
  75. time for a stall??
  76. converter flash n/a vs spray?
  77. Grinding noise when put in reverse and more...
  78. 700r4l60e.com
  79. Vigilante 3200
  80. Looks like I will be joining the ranks of the A3 club!
  81. TCI converter problem...
  82. A4 Trouble please help..
  83. Anyone know about a neutral safety switch!
  84. Loud "POP" sound...
  85. 2-3 shift
  86. Dropped tranny pan. Is this normal? (pics)
  87. 4l60e in a 74 nova
  88. TCI 3800 stall vs. Yank 4000 stall
  89. Yank SS4000E, Bigger than 245 tires?
  90. What is it worth?
  91. Any Daily-Driver NOT happy after TC installed
  92. Where is the VSS sensor (4L60E)
  93. Will a TH400 bolt directly to a '98 WS6?
  94. v6 and v8 crossmember the same?
  95. very bad vibration
  96. Will a 400 bolt up to my tranny?
  97. What all does it take to convert to TH400?
  98. slipping after putting on 315's
  99. stall & cooler question
  100. Will my 700 R4 bolt to LQ4?
  101. Bad rattle ofter TC install
  102. Hitting OD in the 1/4 mile
  103. Tranny temp guage
  104. MegaMax Transmissions
  105. No more Rock On 4l60e for me
  106. Does a Yank SS3200, with 3.15 gears, feel looser than stock?
  107. Fuddle STR?
  108. Question on JW Ultrabell
  109. Which stall?
  110. stock tranny problems
  111. Please Help...broken Tailshaft Housing...please Help
  112. Forward sprag question
  113. Does the converter lock w/stock settings @ WOT?
  114. trans tuning after stall?
  115. Line pressure problems!
  116. Fuddle Track Results
  117. Stalling/idle problems with aftermarket converter?
  118. convertor question
  119. stupid question how does a stall work and
  120. stall locked and unlocked
  121. Yank 4000 stall results =)
  122. why can i stall higher in second?
  123. Who cracked their flywheel.. should i upgrade..
  124. Stall recommendation Please??
  125. Please help....swapping to an A4...questions
  126. Where to order tranny parts from???
  127. Vaccum modulation?'s
  128. Stock Converter
  129. Blew my tranny
  130. Stock trans, stock 10 bolt, 11's no problem.
  131. Question /Help with 3200 Stall
  132. Should I get a bigger stall?
  133. stock trans with stall
  134. MAy sound like an idiot but....
  135. Those with BMR or Yank TH400 transmembers.
  136. Gear Vendors OD Unit
  137. Two Fuddles in under 5hrs, very happy x2!
  138. When do i upgrade, and what to?
  139. A4 kicks out of gear?
  140. ratchet shifter ????
  141. Need some info on a converter plz help
  142. How Do You R & R A 4L60E Transmission Filter...?
  143. Strange noise
  144. Steps to r/p the sun or reaction shell - 4l60e
  145. Wont shift out of first
  146. Trans Mount Crossmember Stud-Torque Spec?
  147. Will it work???
  148. Th400 RMVB Questions
  149. 4l60e/3500 stall? will it hold?
  150. TH400 RMVB Questions
  151. ordered a 3800 stall with 2.2 str feels like stock
  152. Please help! Need advice on 4-speed
  153. 2->3 and 3->4 won't shift hard
  154. need a good stall
  155. What is a good Trans Filter?
  156. Hitting rev limiter
  157. my english paper on removing a 4l60e from a fbody
  158. Tranny rolls forward in reverse, no mph, but revs, in neutral doesnt roll back......
  159. Please help, looking for street/strip 4 speed
  160. 4l60e...will an '05 fit a '96 blazer?
  161. A4 guys.....come in
  162. TC bolts loose..TC knocked the rear main
  163. ShiftKit and TC install
  164. Front pump seal leak..need help..
  165. loud banging when going into gear.
  166. TH350 3rd gear problems - diagnosis
  167. Help reading Trans Fluid Level
  168. help me please
  169. Bulletproof transmision needed
  170. Transmission pan leak
  171. $l60E problems....
  172. Car "hanging" on 2-3 shift
  173. Is this normal? / Look OK?
  174. A4 vibration, 3rd gear only
  175. Loose noises after Spohn TA and Moser Rear
  176. Are C5 and F-Bod converters interchangeable?
  177. Trans fluid suggestions
  178. I think my A4 is going out
  179. How much can the 4L60E take ?
  180. 74 TH350 tailshaft bushing problem maybe?
  181. tuning 4l60?
  182. Non-drag Daily Driver: Stall or Gears? A4 2.73's...
  183. what type of th400 u guys run
  184. Need Help ASAP!!!!!!!!!
  185. trans temp high?
  186. Wheel hop at track... broke rear and tranny
  187. HELP: Auto tranny rebuild opinion
  188. poll.. what stall speed n/a f14 cam only ls1
  189. What's your best 60' with your aftermarket torque converter & REGULAR street tires?
  190. Fuddle owners?
  191. LT1/LS1 trannys'
  192. Torque managment ??
  193. 700R lost upshift.Help??
  194. Got a rear end transmission question?
  195. Does this Fit?
  196. How long does it take to install a converter?
  197. Stock trans cooler temps.
  198. Another Fuddle Review!!!
  199. Which A3 works with M6 Drive Shaft?
  200. Is tuning required after upgrading converter?
  201. WTF did I do?
  202. What's the most efficient converter that will work well with regular street tires?
  203. tranny warranty
  204. Help me pick a converter
  205. 4l60e s10 tranny lines
  206. 4l60e Experts Help!
  207. Hurst pistol grip (Th400) M6 console fit?
  208. tranny rebuild price?
  209. what converter to go with
  210. Stall question
  211. how much for 4l60e
  212. Dexron VI has made it to (some) dealers...
  213. fuddle owners-what mph do you lock-up?
  214. fuddle racing converter + drag radial = 1.4 60'!!!
  215. a4 vs. m6
  216. 4L80E Converters...
  217. Tranny won't down shift at WOT
  218. Weird slipping..
  219. Track Resutls of My Fuddle 4000 TC
  220. 700R4 to 4L60E
  221. Ideal operating temp
  222. Aftermarket A4 shifter
  223. what will kill my tranny faster?
  224. 1st gear in a 2000+year?
  225. help... something just happened to my tranny :(
  226. Rock on 4l60e made 10 passes today
  227. stall ?
  228. Yank PYE3600 WONT GO ON!
  229. Cam and Sprayed guys with stalls look!!!!
  230. Need Quick Help !!!
  231. Need part numbers for replacement seals
  232. AN fittings on a trans cooler overkill?
  233. Ordered Fuddle Converter today
  234. F type trans fluid swap
  235. Automatic vs 6 speed Standard
  236. TH400 Converters...
  237. how do you tell if a converter is good or not? this should puzzle quite a few of you
  238. Why is manual shifting bad????
  239. 4L80E hold 1,000+ rwhp?
  240. do i need to worry?
  241. 4L60E torque converter bolt torque specs
  242. '94 Z28 Auto Trans Trouble
  243. Again With The Noises!!!
  244. Where to get manifold vacuum for TH350 vac modulator?
  245. Add Horsepower
  246. need help.4th gear acting weird
  247. besides the th350 and stall what else do i need swap in for my 4l60e
  248. 4T65E Help
  249. Overfilled trans! Easy way to drain some off?
  250. Somebody help....
