View Full Version : Automatic Transmission
- Stage 3 tranny with 380 miles on it has a few drops of fluid around inspection covers
- surging when converter is locked
- TH350 3rd Gear Vibration
- Short tail th350 need drivershaft
- a4 ratchet shifter for 4l60e
- 4l60e
- 4L80e 4th Lip Seals
- Opinions on stall level for my project???
- 4l60e aftermarket temp. sensor?
- range selector needed? p1810 code
- 4l60E VSS and seal questions.
- 4L80E and P1810
- Can anyone de-code this 4L60E trans for me?
- 99 6.0 & 4l60e Trans - Looks like it will work, No?
- TH350 to TH400 DS
- 4l80e......4l85e help
- keep my loose stall or tighten it up ?????
- Replace Overdrive gear
- converter locked for upshifts.
- 4L60e rebuild
- th400 or glide in my carbed 347 3000lb t/a
- counterbore slip yoke 4l80e?
- Results after the T56-80E swap 3k stall Circle D converter
- can i use a stock shiftier?
- Let's see those shifter setups!
- Quick stall question
- 4l80e shifters for Fbodies
- 4l80e will not shift after doing the tune for the swap! Help plz
- 4L60E shift cable problem
- stock rebuild
- 93 4l60
- Retune?
- where would you put your trans cooler?
- 22201140 Transmission mount on an A4
- stall/shift kit
- Bushing tools 2004r
- 4l80 issues
- junkyard trip for 4l60e slip yoke
- 4l80e No third, fourth gear
- 67 nova 4l80e
- Auto Trans
- ditched the 4l60e for a th350, what to expect?
- What's up with the factory trans cooler in the radiator????
- 96 z28 beef up transmission??
- 2-3 shift slow band release
- 4L80E transmission controllers for us carbed guys??
- Not your Average 4l60E build.
- 4L70E Wont Shift Automatically
- Resized input shaft sealing ring issue (4L60E)
- driveability
- 4l80e start in second Odd Question GURU needed
- After 4l80e swap now have shifter linkage problems
- Hello LS1TECH
- Trans help please.
- transmission cooler line size 1/4 big enough
- -AN fittings for 4l80e Case?
- 4L80E not shifting as hard as it used to
- Another 4L80e stall question
- Patc converters any good?
- Transmission length questions
- LS1 4L60E Shift Kits??
- 60e and 80e interchangeability sticky request
- Anyone ever use a “Monster Transmission” brand Torque converter?
- Trans go shift kit
- Mating older 4L80E to 5.3L engine
- Which 4L60E's work with LS1's?
- need help deciding, 4l60e vs 4l80e
- simple shift from PCS 4l80E Controller?
- Transmission Rebuild ?
- Ascender 6L90-E swap
- 4L60E won't shift.
- 6.0 with TH350 or TH400
- what yoke to use with 4l80 trans? (pics)
- Looking to go auto w/ big power
- ordered a psc 9.5 converter
- 4L80E with TransGo Vacuum modulator questions
- Can i use a stock 4L80 trans with 600-700 hp?
- 4l80e drive shaft length issue
- 4l60e converter question
- TH350 dust cover doesn't fit.
- Converter stall suggestions on nitrous motor
- How can I drop the transmission a little bit to access cooler line fittings?
- 2000 trans am trans problem
- Do not buy poly trans mounts!!!!
- bought a serviced 4l60e pump on ebay would like input, i think its bad pics inside
- Revmax stall? Any good?
- trans mount for power glide
- 4L80E converter?
- Stall for a 4l60e ?
- 4l60e truck trans info?
- Actron CP9580 scanner read trans. temps?
- Intense Vibration - Built Car
- 4l60e to a 4l80 swap help
- Basic auto questions
- Looking for info on 6 Speed 4l80e Mods
- What version and year is the best for the 4l60e and 4l80e
- 4l60e 1st gear shifting problem
- Any advise?
- Possible th350 swap.
- car shuts off when put in drive
- 4th gen 4l60e, will it work in a 2002 1500 4x4?
- 4l60e issues.
- Re-stalled my Circle D converter. - RESULTS ARE IN!
- Hawks 3rd Gen Poly Trans Mount ?.
- After torque converter install HELP!
- 4L80 or 6L80 in 69' Skylark
- 6 speed 4l80e w/ paddle shift?
- 4l65e
- Torque Converter install ruined pump?
- trans mount question
- 4l60e problems HELP!
- Yank <3 LOL
- wtb-4l60e shift linkage for a camaro
- NEED HELP! 4l80e trans wiring pinned to 4l60e ecu
- BOP to ls engine?
- What tires to run with TH400 and 3.73 gears?
- Tapping trans pan(4L80) for temp gauge?
- Vig converter bolt holes not threaded?
- 4l60e shifts hard at W.O.T Help!
- any one ever install a gauge to monitor 4l80e line pressure?
- Swap Tranny Choice
- Please help pick a converter
- 5.3 engine question
- TCI 4L80E Input Shaft
- Transmission Cooler with SSRA/Chris1313 mod
- Making a 4WD 4L60E a 2Wd / cutting involved
- Motorcraft fluid in 4l60e?
- I got my 3500 converter restalled to 4000 and lost 5+mph!!
- 99 Z28 M6 to TH350 Questions
- 02 4L60E tailshaft housing *Emergency*
- newbie!! help me pick out a converter!!
- anyone identify this plastic ring 4l80e
- Holiday year end converter sale
- Customer Appreciation FREE converter giveaway!
- Jake's Performance Winter Specials and Updates
- 4L60E coolant line question
- 4L80E tailhousing bushing play
- High-Flow 160F Transmission Thermostat
- Trans and Converter weight inside- Info thread
- 2.73's to 3.42's
- Fittings for 70274 cooler help!
- another 4l60e issue
- 4l80e question
- stock flywheel strength
- Torque Converter with no tune?
- 4l80 from a 4.8 fit the 6.0?
- need help picking tranny asap please
- What's the right stall for my application
- Removing pilot bearing for auto trans
- stall convertor from boosted car into a n/a car?
- quick tranny question
- 4l60e shift point out of sync
- 4L80E using stock converter w/ cam change?
- Flexplate help
- flex plate for 4l80e that bolts to ls1 will it work on lq9???
- Wondering how far to back converter up
- Will a 95 V6 Camaro 4L60E fit a 96 V6 Blazer?
- *Our Holiday Sale is going on! Great gifts at great prices!*
- '01 4L80E question
- tci stall any good?
- 4l60e servo cushion springs
- GM 4L80E Transmissions
- Which Transmission do I have?
- how much power can a TH-350 take
- 2nd Gear Bog
- Time to buy a torque converter
- 02 Firebird Transmission Problems...Need Help!!
- Gearing questions
- 4L60E, 6k mile on rebuild, 3/4 slipping
- 460LE Help!
- Stock th350 cons on letting it eat?
- Why 4L80/4L80e
- what parts needed for 1000hp 4l80e... turbo motor
- no engine braking
- 4l60e issues... dented trans pan causing issues looking for advice pics inside
- yank converter in trailblazer ss..
- Any c5 corvette's with Stealth Pro Ratchet shifter????
- 1995 4l60e code definitions needed
- probuilt questions,
- Rebuild a 4L60E to be a 4L70E?
- Converter Brands
- T42 4l80e tune file e38 car
- 4L80 conversion questions
- What's my problem? Trans or convertor?
- 4l60E Overdrive slippage
- 4l80e manual shifting issues....pls help
- FTI TH400 converter question
- 4l60e rebuild not turning.
- Bad vibrations at higher rpm worst in 3rd
- 4l60 to th400 in 02 camaro
- TH400 crossmember
- need help identifying a converter
- Anybody running a trans break in a 4l65e
- 4L80E converter not locking..
- Tracking down this clunk!!
- Help! Stripped threads on shift lever
- low/reverse roller clutch snap rings ? 4l60e pics added
- 200R4 or 700R4
- Thinking out Transmission
- Quick question about my torque converter
- PTC converter install in my 4l80. Now it feels like my tc is locking at stops.
- transmission range sensor hepl!!!!!!!!!!!
- Built 4L60 losing 3rd and 4th few questions
- I've heard that converters "multiply" torque - what exactly does that mean?
- 4L60E wont shift to overdrive
- Reset cpmputer?
- used 80e or rebuilt 60e???
- lq4 / 4l80 help i dont no what i should do.
- Th400 swap! Help!!
- Circle D - Annual Black Friday Sale
- best quality job?
- 93-97 4l80 connector
- Any differences in 4l60e pumps, 1995-1996
- Revuilt transmission question
- 4L60E bolt size???
- steel molded pistons in a 4l60e fitment ?
- Should I send my verter back in to get loosened up?
- 4l60e truck year into fbody?
- 60e vs 80e dyno comparrison and questions
- 4l60e shudder
- 4l80E issues until warmed up
- 4l60 has been sitting 3 years
- How is your aftermarket trans cooler routed ?
- Rebuilt 60e slips 2nd in high rpm
- 80e Internal Harness
- Anyone offer a 4L80e accumulator block off plate?
- Trans or Converter Issue?
- 4l80e swap
- 4L60E rebuild put in 3k ago, now stalling
- transmission slips when kicking down a gear
- bad transmission or bad tune?
- supermatic controller hookup
- 4l60e trans cooler question
- 4L60e
- 4L60E (2002) wiring harness - how to test?
- Tranny
- 1995 4l60e not shifting after hard launch?
- LQ4/Powerglide crossmember in Gen1 ChevyII
- What SFI Flexplate For This Flange
- Pre-97 4L80E Question...
- Stall probs
- Can a ls1 flywheel be used on a 4l80 with aftermarket converter?
- 4l60e input drum wore into sun shell ? pics added
- 4l60e shifting issues
- Should I buy this?
- What do I look for P1810
- 4l80e swap info (wiring)
- 4L60E grinding or Pinion/Ring Gear Grind
- T56 swap to 4l60e
- Question about dynoing an automatic transmission
