View Full Version : Automatic Transmission
- What auto trans is in a 96 Firebird?
- Need 4L60E shift cable bracket
- Tranny cooler question
- Tranny Fluid
- 4l80e with mech speedometer
- Trouble choosing a stall
- 4L80E Transgo -3 FMVB line pressure ?
- shifter for a 4l80e trans
- I know this is going to sound retarded.
- Questions about 3200 Vig.
- 4L60E Rebuild
- help with incorrect converter installation (4l60e)
- stall converter ??? as well as rear end ???
- Just curious waht happen to my transmission.
- No neutral or park on 4L60E
- Transbrake & Transgo stage 3
- Yank Converter Question
- Slow Shift
- launching question
- Circle D - NEW - 4L80 Multi Disk - Billet
- 4l80e dipstick question
- Converter for pure street use
- 4l80e build but no (large 36 element sprag)
- 4l60E problems I'm Lost
- new 4l80e install what rear gear to run
- Reinforced reaction carrier
- 4L60E Cut-loose
- TH400 LS1 Car
- Tough time choosing a converter
- Billit servo's not working, stock is working??
- WTF no OD on my 4L60e
- Pics of my TH350 in
- 4L60E Question
- Opinions on Yank SS3600 with 3.23 gears
- tubo 200 vs 4l60e
- 700R4 Tranny
- AWD 4l65e to 2wd
- tranny fluid
- Too much tranny fluid
- Swaping an A6 into an A4 Camaro?
- th400 RMVB
- School Project 4l60e Rebuild
- sunshell and sun gear question
- Quick Flywheel/Flexplate question
- building trans?
- yank conv. ?'s
- Circle-D 4C was here today so I snapped pics
- converter bolt pattern question
- tranny fluid
- YANK has a killer deal for you on SS3600 converters
- TH400 cable, which are you using...
- what parts do i need to build a tough 4l60e
- Going for trans fluid tomorrow
- speed inc flexplate and th400 help
- Specs on a RPM stage 5 4le60?
- Blown seal
- wiring harness
- TH400 and TCI flexplate
- Trans won't allow shift from park
- new to a glide...questions
- What Does a Torque Converter Do..
- Any real gain from gears?
- trans line question
- Order a Circle D 4L80 Stage III TQ today
- need a sfi flexplate
- temperature of mi trany
- TH400 problem in 72 vette
- after 2 years i broke it
- trans temp gauge
- Yank vs Edge
- Sensor on Trans Relating to Speedo?
- upgrades to 4l80e?
- Adjusting line pressure on 4l60E to correct slippage on kickdown
- 6 speed to 4l80e what do I need
- lockup on stalled TH400?
- 4l80e problems
- what do i need for 400
- Car moves in neutral when revved....wtf??
- pwm tcc solenoid help
- 700r4 ???
- Circle-D converter bolts
- Weird clinking sound after 4l80E install
- dam 4l80e 4th clutch
- Trans cooler lines
- Full manual Trans go kit
- Anyone Locking in second gear?
- Stock vs stalled
- 4 wheel drive 6L80E 6-speed
- trans not getting fluid?
- 4L60 speedo calibration help plz
- Installed used trans.. replaced 1-2 solenoid now shifts... but shakes !
- trans cooler location with APS TT
- 4l80e bonded pistons
- 4L60E Problem Need help, its my DD!
- 3200 or 4000 stall for drag
- Ok, thinking of ditching the 4l60e, and going Th400
- Auto Trans Oil Pressure Switch
- 4L60-E: Unsure of what could have happened??
- What do you know about the 4L30E?
- Dont go to these transmission shops
- Lt1 /powerglide 4 1/8th mile racin'
- Hughes rebuild kits, opinions needed!
- Thank You TPTransmission
- Converter slip or gear?
- Atf
- Should I buy used Yank 3600 Converter
- will a 4l65e work in a 98 camaro?
- Changing Converter
- Gear Oil
- refreshing a yank converter
- Thoughts on this flexplate
- 4L80 pan wont fit after shift kit install !!!!
- 2004 & up tailshaft bushings
- New years 09 trasmission sale
- shifter setup,with 4l60,and six speed console?
- 4th Transmission just went out.
- TH350 help
- does anyone know about hemi
- Gain from a SS4000
- What size bolts for trans crossmember?
- Need 4L80 shift linkage ?
- 4l80e how strong.
- How Much Did You Pay For R&R Of Transmission?
- "older" 4l80e's
- Whats the difference in a 4l80 and 4l60 converter?
- My First A4 Question
- PT4000 gained .5 in the 1/8 (spinning)
- Shifting problem
- rpm difference question?
- trans ID tag
- WTF did i break?
- Servo Question
- Looking for converter recomendations
- Trans temp too cool?
- quick lock up question
- tranny or rear?
- Converter Install?
- Stall recommendations??
- anyone figure out how to mate a 6l80e to a fbody?
- TransGo HD2 Kit Impressions
- What STR do I want?
- flex plate help
- Question on TH350
- 4L60E shift kit installation question
- having issues after changing fluid and filter
- 4L80E vacuum modulator kit question.
- 93z28 auto question please help
- torqe specs for flexplate
- Stock LS1 flexplate
- best converter for my set up
- Gains from a 2500 stall on a stock 99 ws6?
- where to mount cooler
- Broke 4L60E HELP!!!!!
- 4l60 bolts
- Changing a M6 to a A4?
- TCC pressure modulator help
- TH400 swap..Torque converter question
- Need some help...
- Transmission Problem
- Deep transmission pan suggestion for 4L60
- How long do i have left?
- A4 Tranny Problems
- problem with auto shifter "safety switch" or in steering column?
- bye bye t-56
- Who do I use now****Update
- 4L60E life expectancy?
- m6 to a4 swap wiring question
- FTI TH400 and 4000 stall Review
- 01 Formula Bird Tranny Wisdom Sought
- Corvette A6 Tranny
- buy from a sponsor or local?
- got issues, need help pls.
- Emergency Transmission Problem
- check engine light on and stuck in 3rd?
- Yank ST3000
- What are some symptoms for a failing torque converter??
- Vigilante 2600
- what tranny and fly wheel is this
- stall question
- New Sponsor, Trinity Transmission
- Speedo reading wrong on TH400 Swap in 05 GTO
- what size stall no cam
- 93 Trans Am auto
- Who is Running a 5c converter from Circle D
- ms4?????
- Transgo spacers
- Separating 4l60e from motor?
- i think i lost 3 and 4 gears
- Ordered my circle D converter today
- Transmission temps
- need converter help
- Converter Question
- Full time lube mod
- selling my FLT4 trans/converter
- 700R-4 Question
- TH 400 ...conversion..tried search,,help please
- stall speed for my setup
- TH350 FAQ was wrong
- 3200 stall temp question
- need a part number or name for driveshaft balancer
- M6 crossmemebr for turbo 400 swap
- T-brake wiring?
- Where do you all put your coolers?
- Installed 4l80e and speedometer and tach dont work.
- Which converter?
- torquer2 vs ms3
- 3rd Gear Dies AGAiN!!!!! After repair lot of parts 10 month later it dies again..
- whats a good stall
- Shif kit or .490" boost valve?
- will this work guys
- mechanical transmission to electrical speedometer
- budget beef up
- Those With Performabilt..
- Are the tci converters good for 4l60e
- Manual vs Auto(locked)
- Is My Tranny Going???
- Should you bump shift an A4 4L60E?
- Tranny Temp gauge problem
- just to check before I start
- Removing Converter Bolts?
- tune with a small stall
- Cooler question
- Stall Question
- LT1 w/4l60e woes
- What should I expect to spend on Built trans?
- Modify stock shifter for drag racing(instead of B&M or the like)
- Question for Yank.
- 4l80e direct clutch failure
- Grinding
- Stall question
- stuck valve in valve body
- video of their TH400 while daily?
- witch to choose
- m6 aluminum ds in a4
- th350 in boosted car
- Yank SBS 3800 is in....HOLY HELL
- Need some guidance
- '98 Z28 Programmers and tranny problems.
- About to install my Vig 3600! Need a tune?
- transmission filter?
- Looking into an Ptc converter for my c5
- WOT 2-3 shift wont go 4l80e tuning or trans?
- How long have you had your stall on your daily driven car?
- Got me VIG 3600 today!!
- FTI does it again
- Stall with stock gears
- What tranny is this?
- electronic items needed for 80e swap
- For those who did a t56 to a 4l60..
