PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 [67] 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. Quick Clarification please on RMVB, TCI won't respond to my emails
  2. 4l60e LEAKING
  3. PerformaBuilt Post Labor Day Sale Now through Friday!
  4. fastest 60 ft on drag radails
  5. New Pro Yank 3600 and FLT-VII go 152.64Mph
  6. 4L80E Slip Yoke (I've read the stickies)
  7. What keeps a tranny from shifting before fuel cutoff & rev limiter?
  8. ATF leak at the output shaft; it's not the seal.
  9. cost of rebuild
  10. Auto Trans Question
  11. A4 crossmember and driveshaft questions
  12. 4l60e transmission line help
  13. T56 to a4 back to t56 question
  14. looks like my aps turbos outlasted my th350
  15. more trans problems please help.
  16. Problem came back
  17. Anyone using Rock-On Transmissions?
  18. 4L60 no first gear
  19. TCI flexplate Q....4L80 application
  20. Lt1 retune after stall ?
  21. SS3600 to SS4000
  22. 4l60e help funny in first gear and bad down shift
  23. ss4000 converter ?
  24. New torque converter whining
  25. yank 3600 VS 4000
  26. Drives in 1st and reverse only!
  27. wish i knew
  28. what do 3.23s run rpm wise at 70, mph?
  29. help with the converter on my turbo car, converter gurus????
  30. TC install, is this bad?
  31. P0751 Code Question
  32. TH400 tailshaft difference
  33. 4L60E/65E Longer Tailshaft?
  34. transgo hd2 shiftkit
  35. 4l60e Camaro question,
  36. Question about clutch packs..
  37. Torque Converter
  38. south florida th400 800-1000hp tranny builder?
  39. torque converter lock up
  40. What stall would you recommend?
  41. Th400 Oil?
  42. Horrible stupid problem please help
  43. STILL having problems with this POS 4l60e
  44. how much power can a stock 6L80E take??????
  45. TH400 guys, what OTC fluid?
  46. trans cooler
  47. 408/Auto guys come in....
  48. 03' 4L80E what upgrades do I need to do?
  49. t56 or built 4l60e with 3400 tc. which is faster and which do u recomend
  50. clicking sound
  51. 4l60e low roller cluch? limp mode? or?
  52. 700r4 swap
  53. Continuously Variable Transmissions
  54. 4l80e or turbo 400????????
  55. 4T65, can it last?
  56. A cam with a stock 4L60E?? Crazy or not??
  57. used stall question
  58. a4: drive vs overdrive
  59. 4l80e Fluid level?
  60. 4.10s for a4?
  61. What does STR mean?
  62. Wont go into lockup!
  63. 4l80e swap on a 98 z28 camaro
  64. Vigilante Stall Question
  65. Is there a way to monitor transmission slip with a scantool?
  66. Fuddle converter guys, what do you trap (MPH) in the 1/4 mile?
  67. 400 trans rattle when turn car off
  68. tailshaft seal?
  69. trans feels like slipping after burnout
  70. T brake question and cooler suggestions
  71. tranny
  72. what flexplate for a th350?
  73. TH350 won't go into gear after pass unless I rev it
  74. WTB 700-R4 1990 K5 blazer
  75. Problems with a PI 4k
  76. circle d converters
  77. trasnmission problem
  78. Can I use a 700 trans with this engine?
  79. 4l60e or 700r4 need help !!!
  80. Building a TH400.. What's needed?
  81. What do YOU recommend?
  82. Need alittle assistance with center console
  83. Manual Valve Body Stock A4
  84. C.A.T. Power FP with ARP FP bolt- shimming FP questions
  85. TCC Slippage.
  86. another tranny problem
  87. New Gear ratios for the 4L60E from PATC !!
  88. Will a 700r4 converter fit my 4l65e !?
  89. torque converter doesnt fit t400 to lq4?
  90. 4l60e problems....any ideas?
  91. tranny help !
  92. 4l80e clutch kit opinions??
  93. Rossler man shift kit
  94. 2 step on an a4
  95. Home made teflon seal tool
  96. Trany Mount??
  97. 4L60e to TH350
  98. how long . . .
  99. How much slower is an A4 stock compared to M6?
  100. Shift points
  101. Attention attention
  102. 4L80E in LT1 TA
  103. 4l80 E HELP PLEASE
  104. Need shifter for a4
  105. Need ls1 sfi flywheel
  106. Those with aftermarket converters step in...
  107. Anyone use anything BESIDES Lines?
  108. Ive broken my Circle D Convertor..
  109. New idea(maybe) for trans cooler location
  110. 4l60e reverse problems!! Help
  111. Getting Tranny Beefed Up- HELP Quick!
  112. 13 pin connector on 4L60e? (TH400 swap)
  113. best turbo 350 converter
  114. Sprag Mod ?
  115. LQ4 bolted to old style 4L60E
  116. th350 high power build
  117. No forward gears
  118. 4l60e shifting issues
  119. Performabuilt Transmissions
  120. FlexPlate question with Th350..Help!
  121. How much does the stock ls1 flexplate weigh?? (2001 A4)
  122. Just Put My Shifter In
  123. Short tail TH350??
  124. need help
  125. Which converter?
  126. lq4 t400 what size stall diameter?
  127. Stall Questions..N20,STR,etc
  128. Cover Name / Part Number
  129. Need Opinions on Torque Converter
  130. th400 to ls1 starter doesnt engage all the way
  131. Why do i have to drain the fluid on a converter swap?
  132. 4L60E - broke front pump for the 2nd time
  133. LSX 4L60E 1-2 shift
  134. 4l80 problems
  135. what size stall/ gears?
  136. 4l60e limp mode i guess?
  137. th350 setup
  138. small problem?
  139. 2-3 Shift Problem, Any Ideas?
  140. TKO500 Complete transmission Kit [where from?]
  141. a4 camaro 1/4 times?
  142. New torque converter, is this normal?
  143. Did a Converter swap, now something isnt right...?
  144. need advice
  145. Alright guys need suggestions on converter
  146. Why do so many people hate on the A4?!
  147. HELP!!! a4 problem
  148. 4L80e Cooler Line Tubes
  149. Random 2-3 shift prob 4l60e
  150. Weird tranny problem!!!
  151. Im sure torque converter questions get old
  152. What is the best way to ship a transmission?
  153. Built 4l60E & 3k stall value ?
  154. T56 to 4l60E Questions
  155. Interchangeable stalls
  156. 4L80E and PST 3.5" driveline issue... PST not long enough?
  157. Another 4l60e rebuild list help post....
  158. burned 3/4 cluch pack
  159. Stall ?
  160. S10 ls swaps, what th400 did use and why?
  161. How would a stock ls1 react with a pretty high stall?
  162. So I just replaced my tailshaft bushing and...
  163. Found out I'll need a rebuild soon
  164. need my tranny built
  165. flywheel bolts
  166. 4l80e questions
  167. Tuning after stall
  168. sbs 3800 stall by yank
  169. having trouble with 10 O clock bolt...converter install
  170. Stock tranny but need a harder shift.
  171. OK how many passes and Miles have your build 4L60e/65e lasted?
  172. 4l60e input drum
  173. 08 Denali Steering Wheel Swap
  174. 4L60E Stall Install questions
  175. 6l90 to 4l80e questions
  176. 6L80/90 swap
  177. a4 trans cooler?
  178. Finally got my line pressure guage hooked up..but
  179. tested the FTI converter today
  180. mail order tune for a4
  181. Swap fluid level
  182. PT4400 videos?
  183. i lost 3rd gear help!
  184. Tranny problem
  185. bad vibration with turbo 350 swap HELP PLEASE
  186. 3rd and 4th slipping
  187. Top Bolt on bell housing Help
  188. Billet aluminum 4l60e input housing
  189. 6 speed auto transmission?
  190. 4l60 shifting problems
  191. Question: Stall installation
  192. th400 revs slow past 5500-6000
  193. Q on t-56 to 700 swap
  194. Help quick warranty expires in a month
  195. Best shift RPM on A4 with 3.43 gears for 1/4 mile
  196. Help extermely hard shifts
  197. 4L70E Specifics? Differences from 4L60E?
  198. art carr a4 shifter pics?
  199. help with trans remove
  200. t56 to th400 swap complete. HELP
  201. Torque Specs for TC,Flexplate & Bellhousing bolts
  202. Thanks FTI
  203. Can't DD A RMVB?
  204. 4L60E Transbrake. Where to get?
  205. When you have a stall in..
  206. Poly Tranny Mount
  207. Transmission sitting for 5 years. Buy or don't buy?
  208. Stall= MPG??
  209. Help me choose a converter 99 Z28 A4 2.73
  210. Loud bang when downshifting
  211. Drive or Overdrive?
  212. Considering 4L80E? What Years?
  213. manual valve body
  214. Switching to a TH400
  215. Drawbacks of TH400 in a basically stock F Body
  216. Which planetaries are effective in each gear?
  217. Trans help, 01 Silverado
  218. tcc engage
  219. 4x4 4L60E/65E into a LS1 Fbody.
  220. trans questions????
  221. 1996 camaro rs 3800 transmission
  222. Corvette servo on a stock 4l60e ?
  223. Which trans cooler?
  224. 4l60e Not Shifting From Park
  225. :read: Just had trans rebuilt :read:
  226. B&m trans cooler with fan
  227. Bellhousing to engine bolts?
  228. Th350 problems lost?
  229. Th350 problems lost?
  230. No One BUY!! from ACE RACING (Gilbert)
  231. Need some help (everyone please look)
  232. adapter the use the vss and mech speedo cable
  233. RPM Stage IV how much HP can it take?
  234. TH400 transsmission type
  235. Tranny or Rear Diff??
  236. A4 bouncing off rev limit between 1st and 2nd
  237. Transgo shift kit to fix torque converter lockup/ hard 1-2 shift
  238. Time for Restall Maybe?
  239. Pinging sound when going into reverse??
  240. Automatic Shifter Replacement
  241. Which tranny do I have and what converter
  242. trans problem
  243. Th400 Build.
  244. Pump seal
  245. Converter or Tune Problem
  246. TH350 fittings for trans cooler
  247. shifting issue
  248. SS4000 owners come on in
  249. what shift kit
  250. trans pressure monitoring
