View Full Version : Automatic Transmission
- Jake's Performance now offering Lenco and LencoDrive Transmissions and Service
- Budget TC Recomendation
- Squealing 4l80e
- no reverse 4l60e
- 94 4l60e vavle body swap question.
- 6l80E
- 4L60E 2-3 shift issues
- fresh 60e and ss3600 coasting shudder
- 4l60 e help?
- Doing my Jakes 4l80e swap soon. Anything I'm missing?
- 1995 gmc z71 4l60e
- transmission
- can anyone identify this trans?
- 4l60e to 4l80e testimony and FAQ's
- early 4l60e behind 05 engine
- 4.8 Turbo: Th400 trans question?
- Who to go with for built 4L60, FLT or RPM? (updated!! 11/11/12)
- Nagging Question
- Can this linkage be fabbed
- 1994 4L60e slips
- 4l60e fluid
- 4l60e tranny problems
- circle d th350 coverter question
- L96 or LY6 and 6L80
- 4l65 in a 98 z28.....
- Converter talk on a turbo car.
- Looking for pictures of aftermarkt a4 shifters installed
- No reverse,3rd, and 4th gears
- How long to warm up?
- REv limiter
- 4L60e squeaks on 1-2 after corvette servo
- Wire harness plug pushes into trans case
- 4L60E quick fix? (sunshell spun)
- 2.84 Low Gear Planetary
- Installing a pro stick
- Th400 to lq4! Please help before it to late.
- stock ls1 stall speed ?
- 98 SS M6 to TH350 swap
- th400 Bolts
- Yank SC series vs SS series converters.
- Save your Ducks
- 4l60e leak
- LS1 converter in LT1 4L60E
- Poor Shift Feeling
- Best way to siphon trans fluid
- Sonnax 77701-076 opinions
- 1-2 Shift Delay and Sluggish/ No 1-2 Shift WOT HELP!!!
- 4L60E Govenor Screen
- 3800 Stall to much for a bolt on ls1?
- 4l80e and controlling it in a high HP street car??
- 1/2 shift only when gas pedal lifted
- Performa, FLT or RPM....
- Feedback: Performabuilt lvl 3 and billet converter
- help
- 700r4 or th400
- Stall: Custom spec'd or Off the Shelf
- 4L80e pump bolt torque specs?
- M6 To A4 trouble
- 4l60e shattered pump impeller
- what convertor for DD??
- Corvette Servos
- selecting a 4l80e
- 4L80E Trans-go question
- 4l60e swap
- Choosing a 4L80E.
- Need help! Anyone please!
- lock up transmissions
- 4l60e vibrations please help!!
- 4l80 cooler line help
- hard shutter when starting from a stop
- Vent line question
- 4L60E shift kit question
- occasional hard 1-2 shift
- Have anyone tried this Stall will it work good?
- Trans Problems
- Did I screw the pooch?? HELP!!!
- trans cooler lines on 98 ta
- 4l60e to 4l80e 1/4 Mile Times
- lt1 blazer 4l60e prob .. HELP!
- LM7 5.3L bolted to 4L80E
- October Sale on 4L80E's and TH400's.
- turbo 400 shifting issue
- Random Converter Question
- FTI converters
- 700r4 4.3l
- Need 4l60e help
- will this work
- 4L60E limp mode?
- Its Back The PerformaBuilt Yearly Holliday giveaway! GET IT FOR FREE!
- 4l60e assistance please
- 4L60E Front Pump Clarification
- 4th gear shudder/surge
- 2000 Ws6 4L60E shift problem
- whats wrong, TC or tranny??
- trans tune question???
- converter break in period ??
- 2000 z71 trans issue.
- Need advice putting trans dip stick tube back in..
- Choosing a race convertor
- Trans temp problem...help?
- Trans slipping?
- need to upgrade trans cooler
- LT1 Transmission Tourque Converter hits 5.3L Flexplate before Bellhousing meets motor
- Installing my torque converter this weekend
- Disappearing 4th Gear or OD
- LT1 M6 to TH350 or 400?
- 4L60E Bouncing off limiter before shifting into 3rd at WOT??
- do i need a tune for my converter?
- YANK SS3600/ stock bolt on car?
- how to remove trans line fittings?
- revmax torque converter problem???
- Will 4L60e reliably handle 510rwhp / 460rwtq!!!
- 4L60E Shifting?
- RPM Transmissions Track Rental October 24th 2012
- 80e to LT1 flexplate
- 5.3L swap, 4L60E PNP switch wiring issue
- Flex plate balance M6 -> TH350 swap
- Transmission clicking into gear?
- What type of oil does a 4l60e use?
- Driveshaft hard to remove/install
- Stall for TH350 Swap-Forged 346 Polluter/Nitrous?
- Need help identifying my tranny
- fair price for 4l60e?
- Delivered!!
- adjusting shift extension
- rebuild 4l80e
- 4L60E slips in every gear. Did a pressure test and here are the results...
- 1st to 2nd shifting issues th350
- Stall converter...How high should I go?
- 4l80e stall lockup slipping please
- Car in air wheels move car on ground it doesn't move?
- Good hoses to use for tranny cooler lines.....??
- any special kind of oil for stall??
- Picked Up A 3200 Stall FTI
- 6L80E YANK Stall fitment issues...
- performabuilt 4l60e in a 98 ls1
- Torque conveter markings what brand
- 4l80e moves forward in Neutral any help welcomed
- Need TH400 for +1000 Trans Am
- Transbrake and Valve Body Sale
- Th400 to LS1
- a4 GTO stuck in 3rd gear (limp mode)
- 4l60e problems!! Help
- Sale through September, free shipping on all transmissions
- When racing what do you do?
- Need rear shift cable bushing for 2000 auto
- Tranny issues
- trans temp gauge
- Help me figure out a plan to swap my T56 for an auto
- camaro a4
- TH400 no speedo?
- fluid
- WOT upshift into 4th
- 4L60e bellhousing to trans torque?
- Broken pan bolt
- Converter slipping/bad?
- 4l60e nitrous issue
- 4l60 help I have a little problem
- Should my trans pressure fluctuate like this (vid)
- wont shift inot third!!
- not shifting into 3rd at WOT?
- Testing a TCC solenoid ???
- 4l80e Valve Body Interchangeability
- ASR engaged after button is pushed to disengage
- 1979 el camino SS LS1 Engine swap
- Part # for flexplate
- Random Idea with Segment Swap
- P0502 code last night at the track
- Need some help
- looking for advise on selling a 4l80E
- 4L80E in 2008 GMC Sierra...
- 4l60e in limp mode HELP (dd)
- Should I rebuild?
- Installed converter, car won't drive.
- 4l80e cross member
- Stupid 4l60e and a 2-3 flare shift, here we go again VIDEO ADDED
- Need help ! keep killing trannys
- please help! stuck in gear
- 4l80 rebuild
- 4l60e 2-3 bind
- 200r4 vs 700r4 physical dimensions
- TH350 install help/info needed
- Here is my problem ..... need advice!!!!! HELP
- 4l60e with lq4 dont know what years
- Tuner recommended overfilling tranny to help shifting with a big stall
- need diagram
- What trans should I use?
- Is changing transmission fluid bad if the transmission needs a rebuild?
- 99 2000 long crank work with 4l65e
- 4l60e deep pan
- New From Mad Dog Transmissions!!
- 4l60e wiring need help!!!
- torque converter o ring *URGENT*
- 4L60E TCC lock up jerking
- Wiring harness help
- Guys running a th350/th400 come in
- 4l60e HELP!
- What stall speed to run?
- trans wont go back together
- 4L80/Transbrake newb
- need help with trans cooler fitting adapter....
- Any "better than stock" options for these trans parts?
- th400 pump sealing washers and o-rings
- Noise from 4l60e in park and neutral only?
- How do i unlock a lock -up converter
- 4l60E blowing fuse
- My th400 just stop working
- Help- NSS switch install
- What would cause this
- Open House/Car Show Tomorrow
- th400 tci ls/th400 torque converter not seating
- bad transmission
- Does all Manual Valve Body have Check Balls?
- torque converter getting very hot
- Transmission Sale
- 4L80e with HD2 Not Holding First
- Street driving a rmvb auto
- Littel help trans cooler
- 4l60e pump
- 4L80e Stalls Car When Put in Drive??
- Tbrake users, any delay when you activate?
- 6L80E replacment parts???
- Trans pan bolt/holes
- Burnt 4l60e
- getting pulse instead of steady V to 2-3 solenoid
- Th350 guys
- SOS 4L60E Rebuild Gone Bad
- Advise Please!!
- Torque converter storage?
- 4L60e interchange
- Question about two steps
- th350 problem after ATI sprag installed
- converter pick?
- Best shift kit for 4l85E?
- Is it toast can you identefy the noise? Video
- 4l80 questions
- TransGo 4L80 Full Manual ... No second gear compression braking...
- 94' z28 apparent limp mode problems
- Wont shift out of park.. Shift release?
- P0758 code 2-3 shift solenoid B circuit fault
- Swapping 4l80e cases
- converter vibration?
- Safe Shift Point...
- Transmission depo??
- 2000 s10 5.3 4l60e trans tune
- trans cooler
- Do any 5.3's come with 4l80e's?
- codes after harness replacement
- Any experience with 4L60-E rebuild prices?
- no 1st gear (1-2 solenoid rattles) 4l60e vacuum valvebody full manual
