View Full Version : Automatic Transmission
- Fresh rebuilt 4L60E has a "whine"..??
- nitrous and converter balooning
- TC question
- Help! Anybody know stock shift points in 99A T/A?
- help, quick
- Anyone run Maual VB 400 and NO shift lite?
- Car won't take off after cam
- H/C plus 150 shot w/3.73's - Which TC?
- LT1 4L60E into a LS1 ?
- changing trans fluid ?
- Going back to stock conveter with a cam?
- tranny rebuild... again
- Who has NOT had problems w/ 4L60E?
- A4 diagram
- Coming shortly: A video of the TCI SSF 3500
- who builds the best 4L60E??
- Corvette Transmission
- Shift Kits?????
- diff questions
- Is the Trans Go Shift Kit worth it????
- TH400 opinion questionair
- Speed Inc stage 3 4L60E...what can it handle?
- sonnax reamer
- shifting into 2nd too early and DTC code
- Next mod choice.....
- Need Help!!converter Install
- Pump rebuild kit?
- Question on filling 4l60e.
- 2500 Stall.. Is it a waste of time?
- Ok Guys,Got X1 cam and Stage 2 Heads installed,Now what converter to get?
- Explain Torque Management
- having a hard time contacting Yank
- What The Hell, Rpm Changed From Going 2500 At 70 And Now Its At 2500 Going 60
- TC intall: Pro or self?
- question about how my car shifts
- Gains from Vig 3200?
- Is it the Conveter or Trans (Newbie help here)
- Midwest 3200/2.0 (3400now) redone/redynos 14hp loss unlocked/locked (prev. 35hp)
- Converter for a '00 3.8L F-bod same as '00 LS1 F-bod?
- Powerglide in a LS1
- A4 Abuse Question ?
- dipstick for th400 swap?
- SS4000 good bolt on converter?
- 2.73 Gears.. What STR/Stall should I shoot for?
- need help removing a4 shifter knob,!
- Where to find 2.95 planatry gearset for 400 turbo?
- Banging in reverse
- Py3800
- 4L60E shifting problem 1-2nd
- 200r4 On A Ls1?kick Down Cable Q?
- no 3-4 shift
- 00 z28 auto revs
- Any Luck With These Guys???
- firm/hard shifts?
- Need a part for a 4L60E
- desired shifts?
- getting my VIG3200 in today!!!!!
- TQ Bolt Stripped
- what is od ratio of 4l60e?
- Measured slip/efficiency 3400ish converters- anyone? my redone Midwest in and tested
- PT-4400 + 100 shot=?
- PT4200 or UY4600???
- anyone using a remote located trans filter?
- clutch-a-matic
- vavle body torque specs
- 2000 camaro Z28 3.42s
- works good so far
- 98 and 00 trannys?
- 4L60e clutches
- LS6 + 4L80E? What am I getting myself into?
- 4l65e or built 4l60e
- New GM flexplate revision #12850709
- Manual Valve body for a stock A4?
- Trans lines at trans side 4l60e- Please someone go check their car for me..
- New TCI SSF3500 or used Yank SS360
- What can I expect from a Torque Converter?
- A4 Removal,Poly Motor Mounts
- TH350 Fluid sprays out!
- torque management
- trans problem ??
- Oil around output shaft
- what to launch a vig 4400 at
- Help!! Torque Converter "Shudder"?
- SLP 2800 opinions
- How much power can a stock 4L60 E handle?
- M6 to TH400 early questions..
- can i use a different bellhousing???
- newbie to a stalled auto
- Need to swap out my tranny for a 4l80e!!!!???
- quick question
- 4L60E weak link...?
- 96 camaro 4l60e into a 94 camaro z28?
- Auto Trans in a Cobra?
- Which converter to get
- please help
- How Hard Of An Install?
- rear planets
- The car is shifting weird...
- trans temp sender...
- Big thanks to TCI and Kevin Winstead!
- How to tell if trans is messin up?
- Solenoid B ?
- TH400 Flex shield
- Why do i keep buring up 3-4 clutchpack
- Bulletproof tranny?
- going from D to 3?
- New racer needing help for sweet spots?
- all of a sudden getting a vibration
- best converter?
- need to know what tranny cooler to use and trans mount HELP!
- Will this hurt the transmission?
- Update on overheating TH400:
- Ls1 Rx7
- Getting in touch with Mike @ Yank.
- New times on TCI SSF 3500
- Trans. slipping ONLY in OD?
- talk about eating horsepower
- tranny cooler
- RPM's dont drop right away
- Trans "slips" after alot of driving?
- TP4200 vs. 3200 Vigi on 150 Wet Shot?
- e-clips
- Hitting the rev limiter
- HELP! clutch packs might be roast?
- Converter bolts
- Just Got Back From The Track!!!!
- D and OD
- Sbc Th-700r4
- Would code P0121 (TPS) cause built trans not to downshift at WOT?
- Hating My A4!!
- How many quarts?
- Clutch noise. Help
- How to figure/determine shiftpoints for best results?
- Question about buying a used converter
- thinking aout converter
- Got my car back from 2001zz today
- Tranny?
- tranny cooler ?
- Converting from M6 to TH400 - 1 quick question
- Vig 3200
- 3.42's and 3200 Vig/ Is it worth the gear change ?
- PO 748 Code
- 4l60e to a 4l80e in 98 z-28
- My TC and Gears are in now......
- Tranny weight
- Will the tranny drop with LT headers on?
- Can't decide which verter
- Shifting Concern!!! Need Advice!!
- Can you reuse the stock TC bolts with new coverter
- Shift kit?
- where can i get TC bolts?
- Best Daily driver converter?
- Need Help with a 4L60E
- m6 to a4 swap,guys with 4,600 stalls in daily drivers.help!
- Tranny spittin fluid HELP!
- Weird problem with my 4l60
- Whoo Hooo fixed my yank sportsman pro
- How difficult to go 6-speed to 4L60E
- how to make speedo work with 350
- Transmission Slipping
- stall??
- corect way to check tranny fluid? a-4
- whats the best converter for me
- Spraying 150 wet on a TCI SSF3500
- Converted from M6 to A4, do you think the PCM needs tuning?
- 4l60e / 4l80e
- 19,000 tranny cooler question
- Do 1999 have torque management?
- Anyone running manual valvebody A4?
- Shift solinoid sticking..
- Speed Sensor problem? And anyone know the part number?
- Someone Has Used Stock Shifter w/an A3
- Anyone did a 4L60E to TH400 swap?
- What shifter used; th350
- PT4000 vs PT4200??
- Can I use B&M trick shift in this?
- TH350 vs. TH400
- ordering a custom verter. got a question?
- Recieved the new YANK 4400 in today.... *not 56K friendly*
- Ordering a converter, very important question...
- Any advantage of ordering directly from yank?
- Torque converter lockup & unlock.
- 3200 Vigi good for Nitrous?
- 3.73 make my c5 slower
- 4l60e shifts 1-3, no second gear
- advice with launch.
- air bubbles in tranny fluid
- I am about to give up..M6 to Auto Switch.. Help
- what size stall for hotcam
- Verter on my Convert A-4 ??
- Too Much Stall??
- trans temp guage ?
- No Overdrive
- transgo spacers
- Whats the diff between 93-96 4l60e, and 96-99 4l60e?
- Will my TC make my Tranny slip too much?
- About to get a PT4000; reassure me or talk me out of it!!
- Leaky TH350
- Midwest Converters....
- Tuning for Sy3500
- Driveshaft lenght for TH400 on 12bolt
- If a converter is rated at 3200 for a 346, what would it stall at with a 383?
- what brand of TH400 is good
- rev limiter on 2-3 shift...problem SOLVED
- *UPDATE* on YANK converter problem....
- Derale deep tranny pan + deep truck filter ?
- Converters in the Detroit area
- Trans. Problem FIXED
- Trans shop in Houston?
- Found a bearing in my trans pan, what's it from?
- Need opinions, TCI SSF3500 or Yank SY3500?
- Need your help
- Lockup and unluck points
- Any problems with stock bolts on a vig converters?
- What could cause this?
- Whats wrong with my tranny?
- is a converter recommended with a cam??
- Blew My Yank
- Pro Yank Shift flare on the 2-3
- B&M hammer users
- Need Help Asap!!!!!
- What needs to be done to swap a 700 stall in a LS1 4L60e
- Shop or myself for TC install?
- Trans blown when ASR light goes off?
- Car making a clunk when i go WOT
- TC Install???
- Art Carr vetter
- A4 won't do 2-3 shift on WOT
- T/C & Missfires???
- which converter for my setup
- Burnout with an A4
- Trango shift kit. Yes or no?
- What is the stock convertor stall?
- vig 3600...what gears???
- Questions about choosing a stall for an LT1
- trans-brake
- Converter lock up switch...
- Best brand of torque converter?
- Anyone run higher than 3800 stall in their daily driver?
- Any luck in rebuilding a 4L60E
- how should i hook up my vacuum modulator transmission
- B&M hammer install??
- torque arm with TH350???????
- sideways with an A4
- What should I go with?????
- Thinking about 3.42's or 3.73's
- What do u think about my trany set up ...
- Need help fast!!
- SE of converter brands/types?
- Shift Kit or HPP3 or Both?
