PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. LQ4 TH350 vs TH400
  2. 4l60e delayed reverse when hot
  3. Need some 4l60e experts to take a quick look at this
  4. 4L80e valve body mismatch?
  5. 8l90e coupled to a 210hp 6 cyl Perkins diesel
  6. Hard downshift
  7. Do I have the wrong converter???
  8. 4l60e delayed shifts
  9. 4l60e dipstick reading
  10. 4L65E won't go into overdrive
  11. Th400 to 4L80
  12. Whats the best transmission for a 1,500hp LQ9?
  13. m6 to 4l80e questions
  14. th400 2.56 converter question
  15. 4l60e dipstick tube questions.
  16. First time build questions 4l60e
  17. 210 transmission temp
  18. 4L60e loses 3 and 4th gear intermittently. P1810
  19. 2002 Trailblazer 4.2 4l60e into a 2002 4.8 Silverado
  20. 4l80e slow 2-3 shift
  21. Burnt 3/4 Clutch's 4L80e
  22. 80E goes to limp mode at times
  23. Stall for 4L80e TVS2300 daily driver?
  24. Teach me flexplates
  25. 2013 ram with 4l80trans problem
  26. gear indacator
  27. 1993 4l80e
  28. Transmission uncooperative
  29. 5.3 4l60e flexplate
  30. 4l60e pump rebuild kit
  31. How to Test Continuity
  32. 4l60e downshift
  33. 4l80e rebuild
  34. 2008 Silverado 4l65e into 2003
  35. 4l80e build
  36. In the market for a 1000+ hp th400. Who to contact?
  37. 1st ever 4l60e Teardown 4WD to 2WD conversion 4l65e
  38. 4l60e from 04 GTO in 01 TA WS6
  39. Vehicle speed sensor
  40. 6L90 question
  41. 4L80 2nd and Reverse only, probably electrical
  42. UnInstall TransGo 4L80E-3 Manual Kit
  43. 4L65E Cadillac Escalade
  44. 2003 Chevrolet Express Van
  45. FTI -hard hit- converters
  46. Rebuilt 4l80e blows front pump seal.
  47. RTV under pump bolts
  48. Another 4L60e going bad thread
  49. 4l60E 5.3 Compatibility
  50. Converter Sale for May
  51. noise manually downshifting 4L60E
  52. 4L60E converter spacing (big gap)
  53. 6.0 th400 stall
  54. Torque 4L60E transmission pan
  55. T56 to 4l80e Swap. Only have 1-2 and Reverse
  56. 4L60E Lock Up Question
  57. 9kcd tag
  58. Yank PT4400 WOT
  59. Pre-'97 4l80e issue (on 2000 model install). Need Advise.
  60. Drive shaft stuck in rear end
  61. Transmission code p1815
  62. Vss color wires
  63. Torque converter bolts
  64. Best 4l80e rebuild book/video
  65. Sierra 4l80 swap *specific ?'s*
  66. Reverse input drum
  67. 6l80 converter- what did I get
  68. Converter, trans, tune or normal?
  69. 4L60E converter difference?
  70. 4l60e crossmember bolt size
  71. Th400 idle surge
  72. 4l65e 4WD to 2WD
  73. What other vehicle 4l60e will fit 1999 Z28 Camaro
  74. Bellhousing to block cover plate?
  75. 4l80 and the limp mode of death
  76. 4L60E output shaft snap ring wont go in
  77. engine swap
  78. 6l80e
  79. gmpp lsa
  80. 4l65e rebuild
  81. Th350 1st gear feels like trans brake after build
  82. Low fluid pressure 4l80e
  83. Tranny fluid - 4l80e
  84. "Simple" 700R4 lockup wiring?
  85. TC Lockup
  86. th400 whine/squeal noise
  87. CircleD 3C, 4C or 5C?
  88. 4l80e broke direct drum
  89. Mastershift (anyone using one) - TH400 & Gear Vendors
  90. 2000 Trans Am transmission
  91. 4l60e
  92. A4 Transmission questions
  93. Live L3 Performabuilt l3 build
  94. 4L60e 1-2 issue - Accumulator?
  95. Help me decide: Sponsored Trans Owners
  96. Project: NO Boring Automatic for me!, Rookie 4L60e Rebuild:
  97. 4l80e identification MCP or MJP
  98. NP 246 transfercase
  99. Trans builders/experts 4l60E burnout
  100. rear pump glide delete and build for 1khp help needed
  101. I have a 4l60e out of 1993 gmc c2500 5.0
  102. Looking to get more serious. Need advice
  103. Converter bolts hitting the back cover bolts
  104. Converter or clutches
  105. The Good, the Bad, the Ugly, 2-3 shift
  106. Tweaked with my 4L80e tune, now won't downshift from OD/4th into 3rd while coasting..
  107. Stall choice for custom cam
  108. Finish line trans
  109. 4l60e swap
  110. 4l60e reaction shaft tight over output shaft
  111. Silverado 4L60E vs. S10 4L60E ?
  112. Cooler Thoughts........
  113. 6L*0E Transmissions Whats wrong Whats right..
  114. Built 6L80E Slipping and Throwing Codes
  115. 4l60 pump issues
  116. Wiring for TH400 swap Questions
  117. Another victim of a smoked 4L60E
  118. Anyone using Jake's 4L80e Rebuild Kit?
  119. Swap out the TQ head bellhousing bolts ?
  120. And So It Begins!
  121. Will my flexplate work?
  122. Msd Atomic trans controller
  123. Weird fluid movement question
  124. ISO th400 converter
  125. sprag question
  126. 4l60e shifts fine at the start but not for long
  127. 99 Camaro ss 4l60e problems
  128. TCC draging
  129. Truck 4l60e fitment question?
  130. Fuddle Racing Converter
  131. is there a vaccume connection on my 4l60e trans? i found a vacuum line hanging down
  132. 60E Shifter Troubles
  133. Looking for advice on a Budget 4l80e Converter.
  134. 4l60e wiring harness, help needed (PNP switch)
  135. Transmission I.D.
  136. 2004 wedge or o'ring seal
  137. ls 6.0 with a 700r4 ? what will i need to bolt up
  138. 2005 6.0. transmission options ? Help
  139. swap,2000motor ss auto into 98 z28 6 speed roller
  140. Help or some ideas please (4l60/65)
  141. transmission troubles
  142. Shifter linkage issue with new trans.
  143. Flexplate Gen3 6.0 4L60E?
  144. 4l60E straight cut gears
  145. First Th400 build and of course I have questions
  146. Other Parts?????
  147. 4l80e Rossler trans brake does not work.
  148. 4L60E jerks back on engine start
  149. 4l60e transmission need help
  150. C6 corvette 6L80 converter
  151. How to put 1999 vortec, transmission and electronic transfer case in 1994 truck?
  152. What's a decent quality 4L60e hi stall converter nowdays?
  153. Ratchet Shifter in Stock 4L60E
  154. leak from bellhosuing?
  155. Fluid black within 10 miles
  156. Tune: MAF vs SD trans problems????
  157. Ecsb 4x4 broke the case
  158. 4l60e vs 4l80e = problems
  159. transmission cooling lines
  160. how was this even working?
  161. Transmission overfilled after driving?
  162. Can this transcooler be refurbished
  163. Which Flexplate for my swap?
  164. Hard shift 1-2 on 4l60e transmission or Hard shift from P to D or N to D
  165. what yoke do i need 4l80e
  166. Swapping 2012 4l60e Valve body with Older 96-07 Valve Body
  167. need a 60e pump interchange expert
  168. Transmission mount
  169. 4L60 Issue...
  170. 6L80E conversion kit for C6 Z06?
  171. Part number for tailshaft housing seal and bushing?
  172. 4L60E - Drive Shaft Turns In Park
  173. Help decoding 4l60e?
  174. DIY Vacuum Test Valve Body
  175. 4l65e wont fit in 98 trans am
  176. 6L80E conversion kit for C6 Z06?
  177. 4l70e to 4l60e
  178. Th400 swap
  179. 6L90 seems to be shifting harder...
  180. 4l60e Bell housing bolts
  181. Recommedations for a Stage3 4L60E/4L70E
  182. Changes required when replacing a late 4L80e with an early version?
  183. I need an A4 but what will fit?
  184. Transgo HD-2 Kit
  185. 6l80e to 8l90e
  186. Old 4l80e with new model convertor.
  187. 4l65e monster transmission
  188. 4l80e no reverse, dumb question
  189. Need some 4L60E help with my swap
  190. 6.2l to 4l80e Question
  191. 4l80e to engine torque spec
  192. 2005 4l60e interchangable with 1999???
  193. Performabuilt 4l60e fluid out the dipstick
  194. Torco LoVis ATF in 4L60E Family
  195. FLT vs Gearstar 4l80e
  196. Stand alone 4L80E cooler requirements
  197. Starter grinding with 4l80e install
  198. 4L80E spacer
  199. Shifting problem
  200. Can a converter go bad and cause vibrations?
  201. Shift Rite Transmissions
  202. 4l60 to 80 swap 04 gto
  203. 4l65E TO 4L80E LS2 69 Pro Street Nova
  204. TCC pwm
  205. Junkyard 4L80E won't engage first when manually shifted after shift kit install
  206. 97 Trans Am holding gears too long at full throttle
  207. 4L60E with manual valve body and lockup possible?
  208. trans assembly lube
  209. Converters
  210. 4R70 to LS motor
  211. Do's and don'ts th350/370 or th400
  212. 6l80e 3 bolt adapter choice?? And custom driveshaft Co....
  213. 4l60 vs 4l80 in 69 camaro 1000+HP
  214. Anyone want a 4L60e?
  215. Which ARP bolts for flexplate
  216. Break down on a 4L75E
  217. Cracked transmission case!
  218. 4.8 80e 3.23 stall speed help
  219. 07 Chevy Tahoe trans issues.
  220. Torque Converter Need it or not????
  221. Braided Transmission Lines keep springing leaks
  222. Transmission Bench now has rebuild and mod videos for the 4l80e
  223. Converter lock up kit suggestions
  224. Ford/ZF 6R80 behind a LS3?
  225. Can somebody verify my wiring, t56-4l80 (pic enclosed)
  226. What pnp plug do I have?
  227. Converter Slippage - Is this normal?
  228. Transmission problem (4l60e)
  229. RPM Transmission
  230. 4l80e converter recommendation
  231. T56 to 4l60e swap question
  232. Fresh TH400 Question
  233. 4L60E 2nd-3rd no shift under medium throttle
  234. 4l80e 4000 stall
  235. 700r4 to 5.3
  236. 4l60e HP/Torque Limits?
  237. 4l80 manual low tie-up help
  238. Any advantages to keeping PWM following a P1870?
  239. Diagnosing no reverse 4l80e
  240. 4L60E is going to have to be rebuilt again
  241. 8 bolt LSX with LT1 4l60e
  242. Flexplate and crankshaft
  243. Have you heard the internet rumor plastic ckeckballs wearout ?
  244. S10 Transmission with LS Swap
  245. Check out our super chevy artcle thanks
  246. Will any 95' 4l60e work with my 95' LT1?
  247. Gen. 5 Camaro/4L80?
  248. Help transmission problem
  249. 4l65e 500 hp rebuild kit
  250. 6l90e help
