PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 [75] 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. flexplate install
  2. Flexplate??? Internal/external/zero balanced, which one?
  3. converter bolt broke off... WTF?
  4. what tranny fluid to use?
  5. 4l60e Help And ???? please help
  6. Need a 1998 ls1 4l60e vin for reflash.
  7. Which trans cooler should I use?
  8. Line flush help
  9. Yank is updating its website today
  10. TH400 VSS plan
  11. 4l80e stand alone controller
  12. Buying a TH400 for buildup - how old? does it matter?
  13. A stall
  14. 1989 chevy 1500 no reverse
  15. 4l80e main harness connector
  16. 700r4 4x4
  17. swaping to auto what should I upgrade.
  18. converter of choice
  19. Major props to Circle D
  20. Aftermarket Shifter?
  21. What size is our stock converter?
  22. is it any good
  23. *VID!* Flexplate wobble? how much is to much
  24. 4l80e & Ls1 in former LT1 car, what crossmember?
  25. 4l80e cooler line ?
  26. Converter is installed, have some shifting concerns
  27. Flexplate? Stall? what's this ticking!?
  28. It's time for a new tranny!!!!!
  29. 4l603 and miss fire??? failsafe on trans?
  30. TH400 Tranny Cooler Parts List
  31. Question about Performabuilt info in sticky thread
  32. gears or tc?
  33. new 4l80e press test w/wo mod
  34. Truck 4L60E in Fbody?
  35. 4l60e output shaft play??
  36. p0803 after M6 to A4 swap
  37. Converter Install Question
  38. 4l60e build gone bad
  39. 700r4...
  40. bolt specs for th400 to LS1
  41. Unbalanced stall?
  42. Driver side inspection area (TC bolts)
  43. 4l60E issue racing a 01 lightning
  44. Built 4L60E or TH400 Swap???
  45. th400 torque converter to flexplate bolts
  46. transmission oil
  47. 1,000 RWHP on spray...4L80E
  48. Just picked up my custom th400 from yank pics inside
  49. TC bolt size?
  50. 4l60e wont shift out of park
  51. Need advice- sometimes reverse feels like brakes on...
  52. New 4L60E Tranny Swap in LS1 Wont Move
  53. Stall suggestions/ideas needed....
  54. Abbott spedometer adapter/4l80e
  55. Transmission issue.
  56. shifts to 4 early
  57. 4L70e DTC P0700 - Trans Overheating??? Calling all techs for Help!!!
  58. lokar 36in dipstick
  59. spraying nitrous on an automatic car
  60. Trinity shift kit
  61. Wierd Shifting.. Help please
  62. Tune question
  63. prob with tranny
  64. Yank Converter
  65. Quick question, 3 speed/4 speed shifter difference?
  66. PB Billet TQ
  67. 4l60e shifts LATE???
  68. a4 reallllly stuck to motor
  69. Need help with ID of 4l80 parts
  70. should i restall my coverter or leave it alone?
  71. Cracked Flex plate ????'s
  72. whos running a 4k plus stall on stock 4l60e
  73. What stall do i need?
  74. What stall do i need
  75. 4l60e LT1 Trans behind LS1 will it work
  76. towing an A4 Fbody
  77. M6 to 4L80e conversion wiring problems
  78. Did any of you guys who have done the tq arm relocation notice a difference?
  79. Is a high stall gentler to the trans during shifts?
  80. 4l60e compatibility
  81. Dave at Yank has a one time offer for you!
  82. Trans Gear swap??
  83. Ok...No 1st or 4th...
  84. C6 rear mount TH400 or Glide ASAP!!!
  85. mail order transmission tune?
  86. LS1/4L60E problems
  87. TH400 questions
  88. Converter not locking
  89. How many RPM's are yall shifting at??
  90. 05 4l80e??
  91. Stall question. What will I stall at right now?
  92. Ltx awd bravada???
  93. Shifter cable the same between lt1/ls1 cars?
  94. Tranny in a 94 3.4L
  95. 4l80e speed sensor
  96. ss3600:lower,higher mph
  97. what th350 bolts to LT1?
  98. Question pertaining to a new tq arm relocation kit
  99. which flexplate
  100. Sonnax servo ?s
  101. Trans brake and stall question!
  102. need your .02 cents
  103. Now on to my next problem. pertaining to tailshaft problems
  104. Transmission Shifting Issues/Troubles
  105. Stall owners, especially Performabuilt TC owners, please LMK your thoughts
  106. A4 Question
  107. Whats with the 4L80E reverse band?
  108. performabuilt
  109. Off the shelf stall VS Custom Stall
  110. TH400 Vibration
  111. 4l60e
  112. fully built t56 looking for t400
  113. About how much would it be for the a4 swap?
  114. Hurst Quarter Stick & 4L80 Shift Linkage Problem
  115. Vibration after upgrade
  116. 4l60e,th350,th400
  117. 1993 camaro trans bad? 700r4 or 4l60?
  118. 4l80e shift kit ? about the check balls
  119. shift points and neutral feel
  120. Where can I find a 4l60e tailshaft housing on a 99 bird?
  121. Ss4000
  122. TCC in 3rd/4th gear
  123. Let me see your converter dyno! Site sponsors only
  124. Does my 4L60E have a MLP switch?
  125. m6 trans cross member
  126. How much beating will my trans take?
  127. Which Power Band? Alto Red Eagle or HP Carbon?
  128. Bad Converter or Trany?
  129. how in the hell did I break my tailhousing?
  130. 4000ss or 3600ss for lt1
  131. Fti converters
  132. Transmission Fluid
  133. 4l80e QUESTION
  134. FLT lvl-4 FMVB & PT4000
  135. assembly lube.
  136. 4l60e strength
  137. PerformaBuilt upgrade flywheel?
  138. about to get a Jasper tranny
  139. what to do about a broken tranny?
  140. Want to go from M6 to A3, Need info.
  141. Mustang guys I need your help (small leak)
  142. Too much stall for this street setup?
  143. 4000 stall to big?
  144. Can a torque convertor cause vibration ?
  145. TH 400 shift firmness?
  146. Trans Cooler write up? Photos? Install guide?
  147. significance of date on trans pan?
  148. How many different things does STR refer to?
  149. second drive
  150. Missing Bellhousing Bolts . . . Problem?
  151. good shift kits etc. for 4l60e?
  152. Force line pressure % question
  153. Better 4L60E trans out there?????
  154. Big thanks goes to Chris at Circle D for his excellent customer service.
  155. Little E40D help.
  156. Torque converter elimination? Has anyone ever heard of this?
  157. Torque converter question
  158. shifter for auto
  159. Need help!!
  160. what converter
  161. GMPP people I need some help
  162. performabuilt trans
  163. A good transmission company
  164. Anyone with a Performa Built LEVEL 3 Trans?
  165. 4L80E swap question
  166. 94 tranny in 96 car
  167. Tranny Cooler is leaking
  168. Does anybody sell the transmission cooler lines for an LT1 Fbody with 4l60e?
  169. Let me tell you some words about Frank and Performabuilt
  170. tranny won't engage in first help!!
  171. TH400 in a DD
  172. Trans temp gauges install questions
  173. What causes a transmission to slip?...
  174. Service port size on the 4l60e
  175. abbott speedometer adapter-4l80e
  176. rebuild video
  177. a4 to m6 conversion...
  178. Archor vs. stock tranny mount
  179. Sick and tired of problems, hate life.
  180. Transgo shift kit in a 4l60e install in North GA
  181. Circle D - 6L80 Converters
  182. Guys with no console and a 2 or 3 speed come in!
  183. Hurst Quarter Stick VS B&M Pro Ratchet for a 4L60
  184. Performabuilt Trans Is In!!!!
  185. Will I throw a code for slipping transmission?
  186. Th350/400 and C5?
  187. Ok i want this Cam. But have no clue for the Torque Converter
  188. Th400 and High RPM?
  189. Overheated 4L60E
  190. th350/cheetah shifter question
  191. No overdrive and ses light?
  192. Trans Cooler and making the trans last.
  193. are all 4l60e's the same??
  194. Torque conv. & pump noise before installed
  195. PI 9.5" triple disk vs. CircleD 9.5 triple disk
  196. Finally took my FTI TH400 and 4000 stall down the 1/4
  197. any results or people running the sbs3400 yank yet
  198. Big cam nitrous guys, what stall?
  199. 4l60e slipping, help???
  200. Switches on Pedals..
  201. 4l80e Low line pressure
  202. What converter bolts with a Circle D?
  203. Stock torque converter questions
  204. Reverse Fine, very little forward
  205. couple th400 questions
  206. 4l80e pressure test results
  207. Car free revs, no gears?
  208. Anyone who has completed a M6 to A4 swap
  209. TC shimming question
  210. 4L80e conversion pricing
  211. 4l60e Pinless 1-2 Acc. Piston with Transgo shift kit
  212. TH400 driveline question
  213. No Kickdown 4L65e
  214. Crossmember?
  215. 4l80e pressure test
  216. A4...Gears?
  217. Engine To Bellhousing Dowl Pins?
  218. 98-00 4l60e in 97 lt1???
  219. 4L60E interchangeability
  220. Hard Thump From 4L60
  221. T-56 tailhouse bushing interchangable with 4l60e?
  222. stock 4l60e rebuild problem
  223. Anyone heard of or used Durabuilt Converters?
  224. Help with tranny problem
  225. What is lock up exactly?
  226. Feel bump on 1st to 2nd shift in built 4L60E
  227. Truck 4L60E w/ Camaro wiring harness - compatible or not?
  228. 4l80e installed, then test drove it
  229. Rebuilt 4L60E- second gear start
  230. LT1/th400?
  231. Space between torque converter and flywheel before bolts installed??
  232. Shift Kit now what??
  233. C5 4L60 worthless?
  234. just did a th350 swap
  235. Why does it feel better in manuel 1st than "D"
  236. What can happen to a tranny?
  237. Help me pick a converter stall speed
  238. can it be done?
  239. PROJECT delayed because of violent shudder!!
  240. 4l60 to 4l80 harness
  241. weird tranny problem
  242. Question From PerformaBuilt to tuners out there?
  243. performabuilt reputation
  244. TC question
  245. Z-Pack clearance
  246. 6L80-E converters now here
  247. best converter for high hp turbo car with 4l80
  248. 4L60E goes Boom!
  249. Need a ghetto way to lock flywheel
  250. 4l60e Trouble
