PDA
View Full Version : Automatic Transmission
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 [143] 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163
  1. Stall converter??(DID SEARCH)
  2. TCI SF3000 or SSF3500 for daily/street driven
  3. How long have you ran your 'verter before problems?
  4. Trans?!?! Why Me!
  5. Stage 3 4L60E lost reverse
  6. Weight difference between 4L60E and TH350?
  7. 4L80e core
  8. Hey auto guys, what's your voltage???
  9. whats the most reliable tranny(a4) for 700+rwhp?
  10. What would you like to see addressed in the TH400 FAQ?
  11. Corvette servo part number?
  12. Clearance issues dropping tranny
  13. New Converter....Help with Stall
  14. TH400 guys - post your upgrades . . .
  15. How do you check to see if your trans mount is busted ?
  16. Car shifts after I have stopped at the junction and hold my foot on the brake
  17. 4l60e trannygoooonbybye
  18. Good Trans Shops in SW MI
  19. When TH400's blow up... (Pic)
  20. Vacuum modulator
  21. Who has a SSF3500 w/ a 2:73 Gear?
  22. TH400 guys with spray, what converter to get?
  23. bad gas mileage and low speed vibration
  24. Some M6 to A3 Qs
  25. TH400: JW ultra bell worth it?
  26. Why buy a scattershield?
  27. Converter ?
  28. Those with 224 cam... what converter...
  29. any loss of MPG with a TC?
  30. Vig 3600 good idea for daily driver? yes no?
  31. The TH400 FAQ's.
  32. About to install a Transgo shift kit...
  33. 4l60e going ?
  34. Best performing and reliable convertor?
  35. 3-od shift
  36. Converter and gears ?
  37. will slp 60103 work in an f-body?
  38. Had car tuned now trans seems gone!
  39. Torque converter lockup questions
  40. Shift Kit?
  41. th400 questions
  42. Help with a New Vig 2800 and a Transgo Shift Kit
  43. Shift adaption time
  44. whos tranny would you choose
  45. PCM tricker for a4 to TH400
  46. what gears with a 3500 tc
  47. Oops, 4L60E truck vs. FBody?
  48. What to do to fit....
  49. A4 Computer + TH400
  50. Should I sell my A4 and get a M6?
  51. Prothane or Energy Suspension Poly mount?
  52. Any idea???**
  53. 98s.With 3500stall without tune&shift kit?
  54. SS3800 and Nitrous.
  55. th400 speed-o hookup
  56. M6 to TH350/400 guys come here!
  57. TH 350 conversion
  58. need th400 help
  59. 2002 cars running stalls without tuning?
  60. Summary of my TH400 – give me your input
  61. Do you have to lift off gas to shift a TH400, like a manual?
  62. 4L60E bangs rev limiter ONLY from a roll, not dig...
  63. How EXACTLY does a trans-brake work on a TH400?
  64. Tranny cooler and stall?
  65. Would it be a good idea to get steel line/fittings for the cooler lines?
  66. TH-400 vs TH-350 vs 200-4R
  67. Jiffy Lube killed my trans?
  68. 4l80 swap
  69. What Flexplate do I need when doing a 4L60e to Th400 swap?
  70. Any disadvantages to upgrading from the stock TH400 gear?
  71. TH350 or NOT
  72. Gear Vendors / Speedo question
  73. 97-02 C5 Vette Tranny
  74. Yank ss3800 or TCI ssf3500
  75. tc launch and drop
  76. tc question, lock up
  77. Pros and cons of changing tranny fluid with a stall?
  78. A4 problems
  79. quick question
  80. someone asked about 3.0 1st gear in TH400
  81. M6 to an TH350
  82. CSI Composite Shield help
  83. Trans brake on a TH400, how hard is it on the motor, car, rear end, etc?
  84. Here is why I am going TH400 . . .
  85. whats the GM part number for a4 shift switch
  86. Converter Lockup Issue..Need Help!!
  87. New Vette Tranny finally the Savior for A4s??
  88. How to Roll race in A4?
  89. A4 drag
  90. Question for those with a Cheetah shifter
  91. Gear Vendors
  92. Tranny Prob.. banging Rev limiter after stall.
  93. TH400 guys, how do you shift?
  94. Where to buy parts and what to get for rebuild?
  95. Does the TH400 bog off the line?
  96. A4 tranny gears
  97. Yank transmission ????????????
  98. What converter will give me the best trap speed?
  99. Th350 In A 01 Ss
  100. Stall Converter/New Gears
  101. Tranny Problem
  102. vigilante 2800-3000 or tci 3000?
  103. whats the converter of the month?
  104. Vig 3200? whats going on?
  105. Best way to flush cooler after trans/verter let go?
  106. Tranny Question
  107. Changing over to auto from Manual
  108. 4l80 tranny pan fit on 4l60e?
  109. TH400 Common Upgrades?
  110. Tranny is leaking around driveshaft
  111. do i need that TC cover
  112. How much am I going to pay.......
  113. Back with another VIG
  114. A4 shifter won't go into park!
  115. 4L60 Bell housing noise
  116. TH400 & V2OD vs. gear vendors
  117. Help with High-Mileage Tranny
  118. A4 builders and those that have had their A4 built
  119. I've decided to get a TCI3000 Street Fighter
  120. Stock TC stats?
  121. Fitting for trans lines going into radiator
  122. To shift or not to shift
  123. TH400 guys . . . get a tach/shift light?
  124. where is the best palce to get a new pump and rebilud kit for 4l60e
  125. Yank denies warranty
  126. Probuilt Transmissions?
  127. TH400 Trans Brake Problem........
  128. TCI or Midwest
  129. Balooning T/C
  130. all 4l60-E haters come share
  131. TH350/400 with 6.0L adaptor and flexplate
  132. Truck Won't Start!!!
  133. vibration in 3rd only
  134. How many quarts to chg. all trans. fluid?
  135. speedometer problem
  136. TCI SF3000 drops over 8 tenths off my ET?!?
  137. stall question
  138. 4l60E shift kit Q
  139. 4l60 price
  140. Need Help! Broke A Sensor Off of Tranny!!!
  141. How do I-- 4l80 a Fbody
  142. input shafts
  143. TH400 shifter questions?
  144. How exactly does the Gear Vendors Overdrive unit work?
  145. Trans-brake for 4L60E..
  146. Slipping..
  147. Possible Trans Problem?
  148. 2nd Gear Whine
  149. New Tranny, but cant decide???
  150. manual valve body for 700r4/4L60 ?
  151. raptor th400 ls1 kit
  152. will using a 98 pcm with a 99 A4 tranny cause my problem
  153. 6.0 iron block work with 4l60e?
  154. Can a ST3800 be restalled to a PT4200?
  155. Converter Efficiency
  156. Vibration, Help
  157. slipping tranny?
  158. New converter needed.
  159. Making my mind up this weekend, go TH400 or try another 4L60e. Any TH400 regrets???
  160. Tranny Problem Solinoids?
  161. How to convert a 4L80E to 2WD
  162. Installing My Transgo This Weekend!
  163. Kevin @ TCI, 4L80-E TC
  164. Vig3200 is dead
  165. question about torque converters
  166. Here's A Question For All Of You 4l60e Junkies
  167. TCI Flexplate
  168. explanation of gears and stall?
  169. No Lock-up after rebuild
  170. TCC Unlock
  171. Just another word of warning for TCS stuff...
  172. TH400 people inside!
  173. Converter still locking up through shifts...
  174. Trans Shifting Very Hard after Engine Work
  175. When converter is locked up car very slowly accelerates
  176. How hard is Trans-go to install yourself?
  177. 4L60E no drive after rebuild
  178. Anyone running a non-lockup converter in a 4L60E?
  179. Anyone ever have the drum flower out?
  180. Is it a proven fact that aftermarket converters lose hp over the stock converter?
  181. messed up my converter(pic's), fix it or try a vig?
  182. What are the signs of a bad valve on the trans?
  183. Do 98s have torque management?
  184. Help Pick a TCI 'verter for my Friend's car.
  185. Bad Bearing in my tranny? for an A4
  186. th 400
  187. 4L60E Stuck in Fwd AND Rev!
  188. TCi or Vigilante or Yank?Opinions plz?
  189. shifting problems after TCI 3500 install
  190. Trans mount help
  191. tranny help
  192. th 400 swap?
  193. powerglide or th350????
  194. Stock Torque Converter
  195. shifting into OD too soon
  196. why is the th400 better than the 4l60e?
  197. will tci ssf shave as much et off as a yank tc?
  198. any gains going from TCI 3500 to a Yank SS3800?
  199. Help with powerband
  200. tranny spontaneously fixes itself?????
  201. WOT Shift Question
  202. sk4l60e 1/2 accum. valve
  203. quick help needed...must order by monday!
  204. Tranny blanket for 4L60E
  205. Converter/flash issue
  206. TCI #399753 Flexplate?
  207. py3400e or py3600e for street tires?
  208. Next tranny question.
  209. How you do get this darn pan off?
  210. Converter Re-Stall help..what to get
  211. transgo squeal 4l60
  212. How do torque converters work?
  213. Vig 3200 or PT4000
  214. SS3800E whines like a turbine
  215. PTS Shiftronic--manual automatic
  216. Cooling a Cooler?
  217. Street tranny tuning
  218. Slippping Tranny????
  219. Transmission woes...
  220. car dies when put in reverse
  221. Serious Problems
  222. For those of you without hard lines going to your cooler...
  223. How many trans related troubles??
  224. FLP or Rossler 4L60E
  225. Tune after converter install.
  226. aftermarket auto shifters
  227. Converter Comes Unlocked...
  228. everyone who went from 4L60E to th400 please help
  229. converter got VERY hot, YANK is closed, what should i do with it?
  230. Who makes the strongest 4L60E?
  231. Colonel, what is a reasonable tranny temp
  232. Thinking about swapping 4L60e to Th400, what additional parts will I need?
  233. Opinions on daily driving on a TH400?
  234. No 3rd or 4th gear.
  235. SS4200 efficiency?
  236. Anyone using FAST standalone transmission controller?
  237. which size stall/torque converter
  238. Torque convertor break-in
  239. Experts - How about a summary/breakdown of all the different F-Body trans available?
  240. Thinking about tossing my 4L60e and going TH400 - what are the pros/cons?
  241. Problem with 3-4 shift
  242. Trans is "holding" back until second gear . . .
  243. need a rebuild, who do you reccomend????
  244. Not your typical newbie TC question...
  245. Who has the best prices on the Yank PT series?
  246. Maximum shift RPM in 4L60E?
  247. Help Please
  248. how to adjust shift times
  249. Where to get T400 converters for LS1?
  250. Fbody vs Ybody Flexplates
