View Full Version : Automatic Transmission
- th350 questions.
- Anybody know about the th200
- Chevelle...5.3 w/ TH350. Have spacer, anything else needed?
- 3200 Stall
- my A4 shifts the same way as an M6 < check out this thread I don't know what happened
- My A4 hits 70 in 1st... WTF?! how practical is an A4 to M6 swap?
- Manual to auto questions..
- Rebuild, Replace, or Ride Out???
- Torque converter question
- converter stall?
- t56 to a 4l80e swap harness
- 4L60E wont shift until i let gas off
- sponser help with TC bolt length
- HELPPPPP!!!!!!! Dumb 4L60E wont shift!
- Are the flexplate-convert bolts threadlocked?
- 4l60e to 6l80e LS1 Trans Am
- Difference between Crossmembers and DS safety loop
- Anyone running yank 3600?
- 4l80e question
- Confused on torque converter spacing/discoloration
- what starter for powerglide and LQ4?
- Just finished dealing with Jakes Performance
- Will a '98 4l60E work behind my 2000 5.3?
- Speed Inc / Yank converter sale!
- 4L60E Shift Problems
- Built 4L60E 1-2 shift problems
- Identifying 4L80E
- Clank clank clank!
- how much punishment can a TCI trans pan take?
- I stalled out tonight
- stall recommendations
- 2002 4L80E Transmission Cooler In/Out to Hose Barb Adapter?
- Link to some interesting information about 2-3 flare shift possible cause
- 6L80e Hose connection?
- help!vigilante converter and gears installed
- 700 to 4l60e linkage question
- Just an update on my FLT lvl 4+SS3600
- Beware of Circle D!!!
- Is this a blown trans or converter?
- Help! code p0740 after trans go shift kit install
- Stock Stall
- So, how screwed am I?
- Do I need a rebuild?
- trans or converter?
- Not your normal stall question...
- Help! just installed trans go hd 2
- 4L60/700r4 build and discussion
- Which flexplate?
- WTB stall converter/4l60e
- Torque converte issue resolved, Torque converter making a ticking noise after install
- 4l60e rebuild woes
- TC Lockup Woes...
- Circle D - Cool Updates
- Is there a difference
- AOD to LY6?
- jakes 4l80 wiring question
- help with my decision needed
- Can anyone tell me what kind of stall this is?
- 3200 stall
- blown pump
- New Transmission 700R4 level 3
- Mid 1.3x 60' in a 3,400# car with an ACE TH400
- Help! 4L65E New GM trans slips in OD like it's in Nuetral
- If you're in or around D/FW Oct 28th you'll want to be at Texas Raceway!
- What kid of fluid??
- 4l80 quick question
- Educate me on converters!
- Damn bell housing Bolts!!!
- More 4L60E Problems! Help!
- Need help finding tailshaft housing
- has any body heard of these guys
- water in trans
- Help me decipher what broke
- Trans go hd 2 questions?
- Bought brand new Performabuilt tranny but still having the same issue
- occasional gear loss?
- Powerglide question
- C4 mating to a 5.3L
- 2800 yank stall is openning at 1500
- stock dipstick length 4l60e
- GLIDE to LS1 flexplate question!!!!
- 6l80/90 4WD VSS
- Need help choosing stall converter
- th400 runs slower then the t56?????
- Stall recommendation
- TH400 vs. PowerGlide (RX-7 Content)
- 96 4L60E behind LQ4
- Need some general info on 4l60's
- Questions about the 6lxx A6 trans
- What about this combo?
- Kinda stumped!
- T56 to 4L80e conversion
- lucas transfix additive
- SSYank2800Stall/LSA223/231:610CAM?????
- 1998 Z28 trans problem
- My converter is stuck...can't remove
- 4l60e and ls1 going into a 68 camaro - have a trans question
- Will this Fit??
- Pop in and out of lock-up....what causes it?
- 4l60e help
- Weight and stall?
- 700r4 converter
- th400 tuning?
- 4l60e w/ corvette servo
- attn:98+ vette and f-body owners or mechanics....
- help with converter id
- swaping to a 4l60 from t56
- 700R and ZF questions form a newbie
- How to modify dipstick without destroying it?
- What type of core TH400 to buy for a build?
- Help me shim my TC
- need tailhousing info please
- NSN for the 4l60e, 4l80e, 6l80e, and 6l90e
- Slipping or Torque Converter problem?
- A couple vids of my car at the LSX shootout and pics. PerformaBuilt T400 street car
- RevMax
- help please anyone 4l80e issues
- Fresh rebuilt 4l60e soft delayed all shifts??
- What TH400 year or style do I need?
- 4l60e no shift after engine overhaul
- TH400 guys inside...post pics of your center console/shifter
- Need 4l60e build advice.
- Vig 3600 vs. ss4000
- 4l80 fitment issue
- strange sound
- What trans should I go with??? Help me choose.
- 4l80e issue
- 4l60e help
- 4L80E - no movement, no line pressure... Ideas?
- Need help now! 4L60E wont go into any gear!
- car wont start,transmission no installed
- yank ss4000 with stock cam what rpm are you shifting????
- Best Vendor 4l60e and how long will my stock 700r4 last?
- transgo shift kit
- Small leaks at trans cooler - what can I do?
- Tran crossmember won't line up. Please help!!
- Bad U-joints?
- "Speedo gear housing"
- Whos installed/removed tranny themselves?
- M6 to Th350 w Pro Ratchet Shifter
- 4L80E out of a 4x4 question
- EDGE converter with nitrous???
- RPM 4L60E in the 8's!!!!!!!!!
- Really??? more problems? HELP PROBLEMS AFTER STALL
- Turbo 400 swap. Shifter question?
- newbie on stall converter
- Spinning tail shaft bearings
- No first gear engagement 4L60
- Tranny Cooler Install
- Performabuilt Holiday Giveaway is back get it free. Maybe?
- HELP NEEDED!! 2-3 shift on limiter still...RPM
- My 4L60E needs BEEFED up
- Whats up with my fully built trans? (4L65E)
- Trans or convertor? Something went boom
- lock up not working
- stock torque converter with bolt ons
- 4000 stall
- Technical help needed.
- 4l60e slight problem
- 4L60 2nd gear shudder
- 4l60 Shift and Vibration Issues - Help
- Which style converter is right for my ap?
- Vendors? I need a stock torque converter?
- is this right??
- Advice/Info on Rebuilding 4l60e
- Circle D 4C or 5C?
- 5.3 and lt1 4l60E what else do I need?
- M6 to A4 swap ?
- Going from Yank SS3600 to Yank PT4000 or PT4400
- Trans mount?
- 4l80e valve body mods
- manual shifting automatic transmission
- 2000 trans am 6 speed to 4l60e wiring
- 4L60E no 3rd gear?
- What converter style? 98 blazer trans 00 6.0flatflexplate
- Thanks to Peformabuilt and N20 outlet King of the street CAR drags w the T400
- torque converters installation problems
- Automatic trans for a standard
- weak sauce 4l60e
- line and fitting help
- Review of my new performabuilt trans.
- 4L60e Shifter question? [road course]
- stock th400 and converter ok for boost?
- th400 short or long tail?
- HELP..4l60e having major problems.
- Lets talk manual valve bodies..
- Th400 Vacuum Modulator Bracket
- Can I use my shift colum with a 700r?
- 4l65e
- how to take the pump out of a 60e?
- Should I go TH400?
- WHAT CONVERTER FOR TURBO glide
- Highstall or Diff gears?
- trans overheating f250 5.4
- Lost 3rd gear 4L60E
- 6l80 in F body?
- 700r and ls1?
- M6 to A4 can I keep my 98 PCM and tune ??? And use A4 harness
- Stall question
- Experienced A4 guys, Please help!!
- 4l80e lockup problems
- 4L60E issues engaging into 4th after rebuild
- car in reverse than....BANG!
- century stage 4 4l60e?
- No downshift when I punch it???
- 4l60e problems
- No reverse im my 93 4l60e.. Sun shell is fine
- TCI Flexplate....
- B&M SFI FLEXPLATE FOR 4L60e
- 15% Off Any ACE Racing Transmissions Tranny
- 2 Transmissions, 2 Rebuilds
- for your info 4l60
- Tranny wont shift properly :/
- stall help
- Well I finally caved in and did it....
- mph shift changes with ss4000, what's yours????
- 4l60E shift issue.
- My trans "clicks" while driving in reverse
- Yank performance !!!
- Help! Smells like burnt transmission fluid.
- Need some input :) THANKS
- Trans fluid looks like watered down oil.. why??
- 4l60e wont do 1-2 shift without hitting the rev limiter. Ideas?
- Trouble with pulling trans
- FTI converters
- help. installed yank ss4000
- 4l60E wont go into 4th gear?? any ideas
- Flexplate to Torque Converter bolt thread size?
- 2500 stall
- 4l60e no 1st or 4th gear
- TH400 cooler mounting location???
- stall converter proble, stripped holes
- stripped converter holes
- Trans comparison
- help asap 4l65e in to fbody
- 2nd gear issue-4L60e
- Pic/info request: M6 -> A4 floorpan blockoff plate for shifter
- Hit a bump now car wont shift right!
- Stall before cam and tune?
- Just got my Circle D GM 245mm Pro II 350/400 LS Torque Converter
- Use oil temp guage for Trans temp guage??
- Shift points for mild H/C/I car with 2.73's???
- where did you get your TH400 from
- Trans wont stay in park....??
- 4K on T brake on a 3600 stall will it hurt it?
- OPINIOnS
- Ordered the flexplate/spacer kit for a 4L80e, only got the flexplate...?
- 4l60e shifts out of drive once come to a stop
- 4L60e issue
- Newb question
