View Full Version : Automatic Transmission
- Where to purchase TH400 kits?
- Non-computer controlled trannys...disadvantages/drawbacks?
- computer proplem
- Auto Trannys
- TH400 Pics Posted
- From TCI 3500 to Yank 4400 how much of a gain will i see?
- Fitting 15x10 rims, grinding calipers
- spraying the stock converter
- new converter=new vibes
- How difficult is it to do a 4L60e rebuild yourself?
- A4 to M6 trade in Texas area
- Effects of driving around with too much tranny fluid?
- Too much converter???
- truck flywheels?
- Driveshaft noise?? help
- cheaper alternative to Pro Yank 3600 Extreme
- the transmission is shaking at 3 gear
- I need everyone's take on TM??
- Porting the MAF and tranny probs.
- Trans mount question
- 4L80E
- converter choice
- Tci SFI approved Flexplate...Here it is!
- BIG PROBLEM
- 98 a4 for sale or trade for t 56 set up
- Dynoeing with Py3600E Verter
- dyno diff b/t locked/unlocked stock verter? alos, % loss??
- Vig converter, Lock-up or non ? Ways to tell ?
- is a flexplate the same as..
- TC Choice
- diagram of th350?
- new torq converter
- The new Transmission is in
- Converter locks up for a sec in 3rd during normal driving???
- how should i tune for new converter?
- does TCS have a website?
- TH400 Guys Need Help
- What is the stock stall?
- Who all makes aftermarket flexplates?
- STR and rear wheel torque, are they directly related?
- What is meant by shift extentions?
- I HOPE TO SEE YOU THERE?
- F-Body vs Truck 4L60E
- T-56 swap to 700 R4
- locking up the converter at top of 3rd...bad or not?
- ? about Vig restalls
- Tranny and Differential Fluid...which Fluid?
- 4l80e?? use 4th or not for racing
- Want to buy a new tranny!!!
- Converter install how hard?
- I need help
- a good stall converter for a a-4 w 3:42's w a 150 shot
- What to do?
- Vig 3600: Is it really that inefficient?
- Installed yank PT4400
- Installing new converter soon
- Converter? for 4L60E in light car
- Just installed tranny cooler...Help Fast!!
- Best way to check trans fluid?
- Suggestions: tc and gears
- i really need some suggestions before i torch it!!
- servos
- Trans cooler or no trans cooler?
- transgo installation
- Figured out my "wont shift" problem...
- tranny shift ?
- Questions about Yank Pro Thruster 4000
- 4L60 into a LS1...what all do i need ?
- 13 vane pump stock?
- Help,choosing the right stall.
- P0757 Shift Solenoid B Stuck On
- could this trans cooling idea work?
- when to lockup converter at the track
- LS1 4L60E ?
- Vig 3200 STR?
- AXODE stops shifting when hot
- got the midwest 3400 2.0 in and its worse then stock!!!
- Tranny temp gauge
- Computer Short Shifting?
- pics of aftermarket shifters for th350/400 in f-bods
- What driving tips, help keep a 4L60e alive?
- Where are you shifting your PT4400?
- What are your thoughts on the 200-R4?
- Yank Trans
- If I don't delete Tq Mgmt, will 4L60E hold against Heads/cam
- trans dipstick tube install!
- Poll: 4L60E, How Much is Too Much?
- People that have installed tranny coolers, IN HERE.
- Need advice/opinions
- vigalante have a phone number or something?
- TH400 on stock 10 bolt
- Couple of ?'s about my new Yank...
- Looking for Detroit F-Body with converter
- Best way to hook up extra cooler...
- Transmission Maintenance
- HELP...VIG 3200 is MUCH looser than my VIG 3600, WHY?
- Possible Tranny Problem??
- converter upgrade
- desperate now! Help!!!!!
- Tranny cooler install write up?
- AOD any one using them on their LS1???
- weird 1st-2nd shift?
- Maybe yall can help...
- opinions on the PY3400E from yank?
- How does this work?
- Bolt pattern Info Request
- Best (cheapest) way to convert TH400 to VSS for speedo?
- BIG problems...UPDATE
- People who swapped in a TH400 come in got some ???
- should i lockup in second gear?
- Shift points, questions.
- switching from 4l60e to th350
- wont shift from 2-3 under full throttle or 3/4 throttle.
- What tranny do I have? Do I already have a tranny cooler?
- will i 700r4 tanny pan work on a 4l60e i think it should but
- Who sells a built 2004R?
- Where to get GOOD tranny parts!!!
- About to test new converter from BTE
- Possible TC Upgrade
- Help............A4 Question
- Need help with A4
- What's Trans brake?
- what would cause tranny not to shift to od
- Converter issues
- Picking a AWD Truck Converter
- What STR for a street/strip car?
- truck stealth 2400 wut can i expect???
- Hooking up autometer temp gauge...need help!
- TCI 3800 stall w/ stock 3.23 10 bolt, too loose for street?
- Braided line instead of drill mod
- Vigilante 3200 vs. Yank SS3600
- Possible low 12s with 3200 TC or shoud go higher?
- When is an aftermarket flexplate needed?
- ?s about the built-in electric fan on tranny cooler? (B&M)
- Is my trans slipping or is my converter FUBAR?
- What MPH should I lock up converter??? Please help.
- Other converters for a 4L80E
- Trans-Brake on a 4L80E or 4L60E????
- TC for nitrous
- Almost stock -- Shift points?
- granatelli tranny tuner
- will not shift 1-2 @ WOT
- Tranny Cooler - Running w or w/out Series *DELETED*
- Silly Sauce killed my converter, suggestions...
- Quick...what is a good line lock?
- FLP Level 4 Vacuum Line Pressure Control vs Stock Question
- Good article of the new 4L65E in Oct issue of HPP
- another VIG3600 #7 pump thread..
- TC Phobia, please help!
- Help!!!!
- Help with trans cooler placement?
- Tranny tricker question
- Are 3.73's harder on the tranny than say 2.73's ?
- Thinking about convertor swap vig 3600 #7 to yank pt4400
- B&M EC System
- Tranny lines
- My tranny got screwed up bad today! what could have happened
- Wheres the trans cooler go exactly?
- Anyone running a Hughes stall?
- Tranny doesn't shift at the track.
- Torque specs
- noob looking for an answer
- Tiptronic
- TC Question from Newbie
- thinking about a new TC, suggestions?
- Got my TCS 4200 installed
- Redline trans fluid
- 4L80E Conveter not locking up any help would be appreciated!
- Where to buy stock 4L60E?
- AC condenser/ Trans cooler
- Trans cooler/AC condenser
- FREE TCS WIDOWMAKER CONVERTER!!!
- WTF is wrong with my tranny?
- Transmission swap.
- TCI Converter Issues
- 4l60e won't shift into 4th
- Shift points / lockup speed
- should I get a Torque Converter???
- keep blowing rear seal out?
- Best way to launch my Vig3800 stall?
- outta these 3 converters/
- Rebuild kits
- Radiator without Tranny fittings ? Knowledgable ppl inside..
- hey guys Yank PY3600E, 3.73 gears, predator, and Transgo
- need automatic advice
- 3000 stall 2.5 str midwest owners. i need your help
- Another 3-4 clutch pack takes a dump
- Converter issues
- 4L60E OPERATING TEMP?
- Quick ???
- Which stall should i use?Vig-3200 or Yank PT3800
- 4L60E will not shift into 3rd under WOT?**Problem solved!!
- 4l80e almost done
- need help..
- vaccum modulated...???
- Th350 in ls1, converter crank hub not close /w washers?
- do you think a th-400 is smart for me ?
- Code P0751, solenoid in 4l60E not working, which one???
- 'LOOSE with High Stall'
- install transm tempGAUGE
- Can this converter handle a 150 shot?
- shift points and rev limiter for 373 with 3600 2.0 str
- should i sell my midwest 3400/2.0 for a yank ss3800?
- Anyone use a TP4400 with 3.23s?
- Need help ASAP!!!! TC Bolts
- 4l60e dont last
- GM 4L60E 1qt. extra w/drain plug pan
- Is this the correct Flexplate to use with TH400 in an LS1?
- Flexplate or Flywheel for T-56 to TH400 swap?
- Four digit code on our stock converters...
- a4 with 3200 vig and 410's in a 12 bolt????
- Second gear locks up?
- 200R4 questions
- b&m shifter in a-4 console
- TH350 question
- Signs of a bad converter, does it feel like tranny slipping?
- what size tranny cooler??
- Does your 400T clunk hard when you put it into gear?
- TH400 what brand??
- TH400 Driveshaft question???
- shifting problem
- Vig 2800 + Tuning????
- Help,Anyone know where the TCC solenoid is in a 4L60E?
- #7 pump, please explain
- Any suggestions on which auto trans to buy?
- new flywheel Look at this!!!!!
- 4L60E vs. TH400 vs. 200R4
- Stock tranny cooler?
- TCI 3500 TC
- TCI and the SFI Flexplate , Where are you guys?
- install my new T/Converter TCI 3500
- Need help deciding where to put shift extensions?
- What should I be launching at with a Vig 3200?
- Question about Yank SS 3200
- What's broken: Converter, 4L60, or both?
- locking up torque convertor
- what should tranny temp be with a cooler ?
- Help! Trans problem 4L60E
- what should i set my shift firmness to?
- Possible converter problem?
- HELP CAR WONT SHIFT
- Questions on TP4400, Help me out.
- GM automatic shift knobs
- 3500/3600 users, why are you all going to a 3800?
- Vigilante converter/B&M cooler weekend special
- TH400 Bellhousing, UltraBell question
- Trans not shifting into 3rd at the track. Any Ideas????
- What can I expect???
- HELP! somehting is jacked
- Going from SY3500 to TCS4200 what kind of gains?
