View Full Version : Automatic Transmission
- need a sturdy 4l80e
- trans coolerS in series???
- 4L80E Install Pics
- No second gear
- shift kits
- Flexplate bolts
- 4l80e swap.. Good Price?
- Need help badly, P1870
- Had a flex plate come appart on you? inside please
- Pulling trans.... have a few questions.
- Help Me Build My Own Powerglide
- New tranny Yahhhhhhhhhhhhh!!!!!!!!!
- Difference Between Lt1 And Ls1 4l60e
- Quick question, th400 vs 4l80e
- 6-pinion planet gear
- Simple question regarding PWM
- Is there a difference in an LT1 converter and LS1 converter???
- Where can I find new cooler lines?
- I need a 4l80
- turbo 400 on an lq4
- Shifts from 1st to Over Drive!?!?
- 2nd to 3rd shift problem please help
- GOt a ? about tuning with new Stall
- vibration once converter locked up around 50-75 mph
- Tranny slipping
- stock flywheel resurface Q?
- 4l80e log lockup seems to be slipping
- Blown Tranny???
- 4l80e lockup?
- RPMtransmission level 4 4l60e
- new setup
- Yank SS series vs Yank PT series and nitrous
- help with 12 o'clock bolt!
- trans temp guage sender in pressure port and temps take forever to rise
- Fuddle 3400 quit locking up
- Please help! Bolt size for mounting the trans to the rear of the motor???
- 2800 Stall question
- Won't shift 1-2 under WOT, after trans and converter install.
- What would help? 2-3 shift
- i need a good transmission rebuild kit any recommendations
- Performabuilt 4l80e installed
- Looking for reliable BACK-TO-BACK stall data
- Yank Pro-Thruster 4000 vs 4400....Which for me??
- Tranny Fluid
- Locked/Unlocked Converter...what does this mean
- Is a Yankss4000 To BIG???
- Good street/strip converter for TH-350
- 4L80E TCC limit Valve in pump question (FLT),others help
- Cryo treat?
- 4l65E for 2002 suburban
- 4L60E problems
- Can any sponsor get me....
- Effect of a low lockup mph with aftermarket converter?
- Shifter install help needed
- whats the deal with gear vendors??
- Checklist needed for odd noise. Please?
- Which is a better option, rebuild or replace?
- Silverado SS converter question
- Will the stall work fine?
- 700r4 on ls1...
- 4L60e help!!
- What shifter would you buy?
- hp on a stock 4l60e
- Rebuilt 4L60E Price too low??
- Add spin-on filter to cooler line?
- Need Trans Help!!!!
- Digital Trans PSI gauge found!!!!
- flexplate question
- whats best
- Torque Converter install ISSUE!!
- Shift MPH question
- Planning on doing my performabuilt 4l80e swap this weekend
- Whats a good size stall
- TH400 as a DD
- trans cooler
- What is the stock trans in a 2000 Firebird?
- won't go into gear
- unusual t/c question...road race
- Drop car into 1st, takes off in 2nd
- slipping around 85ishMPH?
- Whats goin on?!
- Converter for Powerglide.
- Converter or Gears
- Torque converter
- Installing aftermarket shifter...Help!
- Yank 3200
- what to get: 4L60e tranny and Torque Converter
- made a mistake?
- Vacuum Line hook up?
- what stall and gear? help me decide
- 2001 Chevy Van 4l80e
- THis the right SFI Flexplate for 4l80e?
- temp gauge
- No lock up, brake light switch?
- Transgo HD-2 C sep plate drill sizes
- Need some help please!
- Yank PE Series?
- which converter is best
- 4l60e lockup
- Vibrating Noise at lock-up
- stall?
- What size stall for a 383 lt1?
- 4L80E parts interchange DETAIL
- new turbo 400 install by ace racing perf-
- B&M trans temp sending unit
- deep tranny pans.
- Lock-up intermittent at highway speeds...
- 4l60e shifting issues when warmed up
- Need 4l80E
- Ordering a performabuild this week
- Did i install the trans cooler line correctly ???
- Question for Tranny Pro's out there~!
- Thinking FLT...
- Loud thump when shifing into drive
- stock mount vs replacement ( looks different ) ?
- lt1 stall in an ls1
- t56 to a4 harness question
- Converting automatic to 6speed
- Good price for a brand new Fuddle 3400 stall and other stuff?
- Going From A 6 Speed To A 700r4 Has Anyone Done This And Can Tell Me How?
- Hughes hp4004 flexplate
- th350/yank
- About ACE Racing Transmissions Converters
- Help with my TH350
- All LT1 Trannys the Same?
- It Might Be The Coolers
- Ok Here's the Deal!!!!!! "TCI 4L60E"
- 700r4or 4l60 which would you go with?
- Stock Converter?
- Going Form 6 Speed To A Automatic Need Help
- Any advantage doing a shift kit without a stall?
- weird Trans/rear noise
- 95 Z28 does not drive in 'D' (auto tranny)
- 4L60e locked up in manual first
- Tranny has been sitting...
- A6 6L80E in an f-body?
- tranny fluid dye
- 4l80e tranny lines, and other questions
- What info do i need to order the right yoke for my 80
- Performabuilt converter vs Yank SS
- First time ls1 auto
- Hughes sfi flexplate ??
- Is this a stock convertor
- Not your typical th400 speedo question....builders inside
- speedo?????
- stock flexplate
- Tranny wont go into overdrive?
- after vig 3600 -3800
- How do I wire the shiftlock control and PNP switch ?
- 4l60E tail housing broke.. normal????
- How many people have noise when going D - R
- Aftermarket shifters?
- Rear main sail just got fixed, should I take it easy for a while?
- Awesome TH400 setup
- Flexplate for LQ9
- Stealth cam vs lingenfelter cam?
- help car won't stall
- Stall 4 Th350
- 700R4 Lockup Vacuum Switch
- Cheapest place to get rubber trans mount ?
- Hurst V-Matic 2 install??
- Free Shipping Special For January!!
- Drivability with PT4400 and 3.42 gears?
- th350
- Powerglide
- Flexplate
- 4l60e problems
- late model 4L80E vs early style differences
- 6.0 flexplate on a 5.7?
- Which 6L80E?
- WOW! 3 year Warranty on YANK converters!!!
- Wanting to Put Aftermarket Shifter in A4 ?
- Do All 4l80-e MT1 trannys fit into fbodys?
- 6l90e ....... Is Here.......
- Shifting Issue
- 4l60e and 4l80e
- Tranny Fluid In 4L60E Tailstock-Yes or No???
- RPM fluctuation at WOT
- Which trans cooler with fan
- Opinions on Edge Converters?
- Tranny starts in 3rd when really cold
- th350 temp sensor?
- got a friend with a 2000 hyundai accent automatic
- Broken 4L60e ?'s
- Good Stall on bolt on lt1?
- Do i have a shift kit?
- 4L80E Swap sticky
- Help car dies when put in forward gear
- Price on TH400
- How important/benefitial is a T-Brake?
- yank 4000SS on the street...
- burning up clutches
- Used 4l60e value?
- Trans Replacement Difficulty
- Tranny Leaks from the Fill Point
- Shifter question
- Hey questions about shocks guys
- New to the A4 - Trans Leak at front - Help!
- FLT Transmission Power Gain
- What's a stock 4l60 worth?
- Anyone had this problem before?
- Would it be worth to rebilt my stock converter to 3200 for $250??
- Tricks to getting pump out??
- Anybody running a Stef's pan for a TH400
- 4l60e input drum problems
- why does a stall lead to lower HP #'s?
- problem with tanny shop
- growling noise in 4l60E-help
- Is this a vent or Vacuum line?
- 4L60E...Problems (LT1)
- Tranny swap issue, help needed
- Gear vendors, troubleshooting?
- Circle "D" at your service!
- Break in period for a rebuilt auto . . .
- Performabuilt what do you think
- performabuilt 3600 stall
- Aluminum Accumulator Piston
- New Setup!! Sound Good???
- performabuilt?
- hayden tranny cooler hose
- Thinking about going with Performabuilt tranny, how's their converters?
- Transmission builders... your opinion of this th400?
- Mystery A4 Shifter Issue
- New shift plate/lens?
- Whats a good Stall converter?
- 4L60E wiring question.... please help
- What gauge/sender for trans temp?
- This Really Sucks....help Help Help
- th350 vs th400?
- 4l60e help, i need a tranny genius please!
- Th350 swap
- new vert with bad tranny
- tranny problem/question
- TH400 Rebuild and Stall
- Just ordered the last part needed for my performabuilt 4l80e swap
- 4l60 transmission doesnt down shift correctly
- car didnt want to shift into 3rd.
- 4L60E vs. 200R4
- Turbo 350 Bellhousing Question??
- Where to buy GM flexplate?
- Help with picking out Converter
- 4L80E force motor interchangability from '92 to '98
- converter locked vs unlocked on dyno
- Low Throttle Lock-Up?..
- Which gets the better 60 ft A4 stall vs M6 with same tires/gears/mods etc?
- First gear problems
- Car Goes Into Safe Mode When Trying To Stall Help
- Please help me!!!!!!!!!!!!!!!!!!!!!!!!!!!! doing engine swap!!!!!!!!!!!!
- 4L60E issue.
- 3500 stall?? tuning??
