View Full Version : Forced Induction
- Any reason you would not O ring grove std LS7 heads ??
- cyber monday vendors
- maggie bypass valve help
- Roots blower + LSX?
- injector for 5.3 truck manifold
- converting carbed LQ to procharger efi
- **LMR on Street Outlaws Dec 2**
- T6 crossover pipe
- Stock 3.62 Crank guys, how high are you spinning?
- Torque gains with adding length of pipe in between the edelbrock proflo intake and TB
- Huron Speed Custom Fabricated Twin Turbo Kit!
- When is it considered too cold for boost?
- Anyone ever use this cam is a 5.3/s480 set up?
- Boost controller solenoids
- Turbo oil feed restrictor size?
- Need some help on my 408 build
- Where can I buy turbo hot parts for 2000 f body?
- Dynoed my Procharged wastegated c5 (video inside)
- 5.3 gt45 turbo first 4 pass at 1/8 mile track
- 85 C10 turbo build
- Camaro ls2 with borg Warner s475
- Installed 2step now have a question
- Is the $165 radiator really good enough?
- Front mount intercooler facia mods
- Opinion on supercharger on 2000 ls1 z28
- F-body Turbo build
- Boost controller/wastegate questions
- 862 heads for turbo 5 3??
- Is more stroke or larger bore better?
- Just a little discussion about the chinese GT45 and the T76 and their best use...
- What size injectors? running rich
- Turbo stick guys and no lift shifting - please give me some insight
- Finally dyno'd the car.
- Will this cam have any chop to it?
- ATI super pulley for cog belt drives
- Magnacharged fbody worth it?
- What should I expect? 68 camaro* Lq4 ls3 heads, intake, 10psi
- '14 Silverado... Turbocharged by Vengeance Racing
- Any tips on building a set of log style turbo manifolds
- **LMR runs 6s in Las Vegas SCSN**
- First turbo build Pt88/4l80e/ac
- Opinions on the F1-X
- Post up pre and post intercooler pressures.
- Will the Edelbrock pro-flo xt intake manifold work good on a 5.3 with a s480?
- 370,390,402-408?
- Turbo 5.3 heads?
- MSD 2 Step Issues
- Downpipe Flex?
- mass air
- Best Place to Get a Cam Spec'd?
- Fast 102 VS single plane for boost?
- SKE Engine suggestions W/Twin Turbo
- choosing X over tubing dia size?
- Need help on stand alone ECM
- Mufflers with turbo
- Any one use the 1300hp thread stone IC?
- compound boost. turbo on ctsv, gt500, ford gt, terminator... keeping the blower
- Header question?
- Best Turbo For LQ4 T56 S2000 build?
- AES 374" LSX Goes 7.66 @183 NMCA Indy
- AES 374" LSX Goes 7.86
- AES LSX Chassis Dyno Video
- Aes lsx
- f1c procharger inlet hat
- Junkyard Turbo 5.3l Build Ideas
- Which LSX configuration is preferred for medium hp daily driver?
- LSX 427 - Supercharged/Temp NA - Need Temp Maf help
- Might buy this car but so many questions...help
- Help me with my Long block parts list?
- Huron Speed Twin T4 Top-Mounted HOTSIDE KITS!
- is a GT47/88r to large for 6Litre L98/L76?
- 5.3 turbo
- Single Turbo A-body question
- ID 1000 injectors
- 5.3 lm7 opinions needed!!
- Just your typical Heavy Street Car in the 8's
- Need help finding a belt.
- Aster bracket users step inside
- Made the cover of GM High Tech Performance
- 5.3 turbo head gaskets
- Question about smashed plug
- Where do you guys mount your external fuel pump
- s366 4.8 Camaro 6speed, Steven Sigmon
- Actual Comp 8079 experience?
- Boost Leash controller
- About to Turbo my N/A Build, Please Help
- turbo size help
- Meth going into motor while cranking "doesn't sound good"
- New PB and Records... 6.58@220MPH
- Injector size??
- inner cooler question
- what fuel pump?? 5.3 turbo
- Fan mounting brackets.
- hawks third gen turbo kit?
- Anyone else have agreed value insurance?
- Truck manifolds on a 67-72 C10?
- FIRE SPITTING, 550rwhp+, PROCHARGED GMC SIERRA
- New PB, C5Z, 402/F1R
- Intercooler questions
- considering holley dominator.. do I have all the right part #'s?
- MIR track rental yestarday new best and found the limit of my Ebay intercooler
- 5.3 rear mount turbo c5z. Getsomemotorsports built/SpeedFactory tuned. Dyno Results
- What muffler for a remote turbo?????
- thoughts please
- Got a deal!! Now I need input!
- XSPower BOV and WG's
- NA guy going turbo....Need suggestions
- Anyone having any luck with hyper pistons?
- which would you do in this situation?
- How often do you empty your catch can?
- Boring a 5.3
- Who is the best
- twin turbo foxbody mustang ???
- Turbo guru's - I could use your wisdom please
- Any 8 sec 6spd turbo ls f body's?
- Turbonetics 7875 Dyno Results
- Borg 171702 a good choice? (S475)
- Turbo Stingray(14)
- turbo tuning on stock ecu via flashing??
- World's Fastest True Stick Shitf Mustang; 8.58@165, 93 88mm Turbo Synchronized T56
- Turbo 408 Build, Good Cam Turbo Combo?
- GT45 Turbo down pipe V-band size
- Need ideas for intercooler..D1sc
- Turbo's for my 5.3L impala
- General turbo install questions
- Turbo Exhaust Flange Orientation Question
- another ebay turbo thread.
- My S10 5.3 Rear mount
- Help identifying S/C
- Underhood temps with turbo in 3rd gen TA
- question about back pressure?
- Need help keeping engine cool.
- *works at the track!*Force 4l80e into third from a stop to help spool tight converter
- ITS ALIVE we'll sort of
- non-intercooled ideas
- those with huron a/c turbo kits
- quiet 4" muffler/resonator
- what wastegate for 76mm 5.3???
- Goal Reached, Only took 5 years
- turbo gen 4 4.8 in 01 formula reluctor situation
- L92 valve train for boost
- Need a plug for my daily. What are my options.
- 99 SS Camaro 376 LS3 Topend Billet s480 275 Build
- TT manifolds?
- Tall deck LSX block for 408 build.
- C5 ZO6 Manifolds vs Truck Manifolds.
- 370 lq4 99 z28 build
- overboring a 6.0 to 4.065
- LS1 with a brodex supercharger
- Cam ??? for Ly6 with twin 76mm turbos.
- Quick question for you guys. 370|9.2:1 motor, TH400
- Holley mid rise install
- lq4 long rear crank snout? wtf
- TVS1900 on LS3 in F-body?
- what kind of hp or track times are you making on the 68mm gt45 turbo?
- debating ditching on3 70's on max effort 4.8.. thoughts?
- Ls7 magnacharger system
- My 69 Nova L33 S476 project (Finally Some Runs)
- How much more on meth?
- S480 on a 427?
- 1623 hp sbe 4.8l!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- L33 76mm malibu build - fuel tank mod ?
- 72 Ford Galaxie finally moves
- 754rwhp stock bottom end LS3
- Which BW s400 Series? Jose? Martin? Lil John?
- Low mph? 9.8 @ 138mph
- Alcohol injection/fuel pump diagrams
- IRT s480?
- 2001 5.3 turbo impala ss
- brake boost vs t brake
- Boost controllers - Linear power band and a turbo
- A2W intercooler for Holley Modular Hi–Ram Intake
- ProCharger Cash Back and Rewards Program: Extended AND Expanded!
- 4drush 8.30@164.8
- S480 LQ4 - LS3 H/I or 317/FAST 90?
- 5.3/80e/70mpt nova?!
- Good quality 3 Bar MAP ?
- F-Body Front Mount Intercooler
- gt42 on a 4.8/5.3 or a 6.0
- **LMR in Bahrain takes 1st place in Event**
- Turbo drain oiling??
- Best way to go FI from current set up.
- Diesel Truck Turbo? Yes or No?
- Guys using OBX headers, come inside.
- Rear mount newb question
- help me out
- blow thru carb setup or fi/?
- ls2 vs ls6 intake for boost
- How much boost should I be seeing?
- Datsun 280z Turbo Build - 5.3 / T7875 / Magnum T56 - Video on page 12!
- New PB 9.21@155mph
- Aeromotive 340 or walboro 255
- Critique this. S475/LQ9 6.0 setup.
- Meth injection help
- Vortech Air Assist
- Tight spaces and air filters
- LS1 swap in 1976 Trans Am, Now thinking of adding a Turbo. A few questions.
- Any 55-57 turbo LS builds
- Turbo Rebuild
- Buyer Beware: Turbo Technologies Inc.
- ProCharger i-1 on the track!
- Bw s475 or pt7675????
- Is this to Lean of an idle?
- Where are you at turbo guys? Need some input!
- Fuel system setups.
- nova intercoolers
- 365"-GT55-Holley EFI-Glide
- My new set of 6.0 with s480 :)
- who's the fastest using chinese turbos?
- Making a turbo spool sooner?
- Cool Race Car Pics From This Year, Impala
- G body turbo manifolds or headers???
- ZL1 blower on an LQ4...
- Which bmr k member for DIY front mount?
- Looking at going turbo.
- Mp112 any gains 75mm to 90mm TB?
- truck intake, new vs old
- Turbo brace for the huron speed kit? Yes or No.
- FAST 90 vs LS6 on boosted ls1
- 98 Camaro On3 No A/C Build. 11/18/2013 It Runs.
- getting closer.
- zl1 intercooler pump pigtail
- Milled 317's pushing water?
- PCM FOR TURBO?? need to change or not
- supercharged 5.3?
- VR C6Z - Stage II heads/cam, Whipple, 5 psi...
- compressor, turbine match
- Am I going in the right direction????
- turbo cams
- advice on injectors and fuel system for E85
- Do I need to go to a bigger exhaust wheel?
- 6.2 truck 740hp+
- AMS Hearse and 80mm ETR-HO
- Intercooler or not
- twin PTE5862's goal of 650 on Corn.
- -8 or -10 return fuel line?
- Lightweight DIY vertical FMIC mount for 4th gen F-Body (No welding required)
- made it to the track today finally..
- Low compression 383 turbo selection
- turbo .. what do you guys run for motor mounts
- 01 ls1 camaro turbo kit
- +Awesome deal on AEM Meth Injection kits!+
- 8.76@156mph with stock nissan IRS and JY 5.3L...
- Pre and post filter recommendations for Holley 1800 ?
- Recommendations for 1968 c10 5.3 turbo build
- Our Gangsta 76mm, LS in Fox body....
- 2000 RCSB silverado, now with Iron 370 and FI 76/92 billet
- 1500HP E85 Fuel System Daily Driver
- 2009 CTS-V 427lsx TT 6266's
- Rear gear for 12 bokt on Turbo setup.
