- Having KR issues and losing MPH - EFI Live files
- Predator diagnostic monitoring
- Added a little timing to 2000 WS6...
- Diablo Predator custom tune how does this look.
- Auto Headlights LS1 Edit
- i accidentally logged 02% instead of mv.. convert?
- 02 problems
- Heads/cam computer tuning ?
- MTI 427 engine startup problems
- For those of you using Keyspan USB/Serial adaptor
- predator tuning help please
- Remidies for Knock
- Do the years have to be the same on flash files?
- hyptertech
- Random 2000rpm idle / 2 part question
- Diablo /Predator..Torque Management ??
- ATTENTION! All registered members inside please.
- Simple o2 questions
- Car hunting for idle...what do you think??
- a/f question for you guys...
- SES Light...need help!
- LS1 Edit, MAF calibration=Out of byte range
- ATAP or EFI Live Pro
- service engine soon light
- Fuel Cell shows 15 always..instead of 22.....wtf?
- Will the ObdII that only goes to 99 work on 01ls?
- LS1Edit: How to adjust timing?
- M6 Idle Question
- MAF 11250 Hz limit
- SVO injector?
- egr & air/smog removal ls1 edit?
- LS1 VE Tables
- Have a bad maf sensor on a tuned heads/cam car
- WHEN YOU CHECK FOR KNOCK RETARD..... ?
- Question on multiply by a % with edit
- Boost Tuning ?'s
- trans fix
- Predator Questions
- still have o2 problem
- Z-Industries tuning????
- A/F RATIO WITH THE PREDATOR?????????????????????
- Has anyone measured stock motor IAC counts?
- Tweak Fan on Temp setting with stock thermostat?
- check out my turbo atap log, race tomorrow.
- Got Wideband Tuned At MTI!!!
- Injector, PE vs RPM, and MAF table tuning info?
- Attention Newbies: Learn from my mistakes!
- Should ATAP disconnect when you start the car?
- What do you think I should do...Tuning with MAFT
- Used LS1Edit for first time, now car wont start???
- can I tune my cammed ls1 with predator?
- Programmer for 2002 Sunfire
- Good Deal...
- Going to dyno tune tomorrow - any tips?
- Display dissapeared?
- PREDATOR SHIFTTING
- LS1 Edit...... PE vs. RPM?
- Lost 5 MPH in the 1/4 and 4 tenths Any Ideas????
- Tuning for startup
- Oil Light Indicator
- LS1 EDIT VERSES AUTO TAP
- Flashing SES light, but no codes thrown?
- NEED A TUNER IN DFW FOR SATURDAY!!
- The REAL truth about Idle and IAC counts....
- ALDL cable for LS1 edit
- diablo predator tuning Help
- LS1 edit won`t connect
- Diablo sport users > Some ?'s
- How do you lean the car out at idle?
- RPM SHIFT POINTS?????
- Need atap help: 02's read 0, timing is 4.5, and...
- Help with Maf tuning with LS1 Edit
- Can edit make a A4 pcm work in a M6 swap?
- ATAP Needed near Cleveland Ohio.
- Which kind of tuning software/hardware to get?
- Rev Limiter for 98 LS1 LS1Edit?!?!?!!??!
- Using Cags As A Shift Light?
- Could somebody help me out with an Excel Question?
- What could cause random multiple misfire code?
- IAC counts.
- Help tuning w/MAFT
- Help
- My ls1edit file
- M6---A4 PCM question
- Wiring Harness and PCM question????
- Goods and Bads of Setting Your REV limiter lower
- First time trying to tune with MAFT
- misfire at idle on 2 cyl clears up after 3500rpm
- Need help with troubleshooting: engine bogs
- Serial port connector
- Can rear o2's be used as front's?
- need info on tuning VE table
- Simple PCM swap question...
- Dyno Pull in 2nd Gear.. how much loss?
- HPP3 Question
- Help! Car running very lean!
- OBD-II connector on car - warrenty question
- SES Code PO135 what is it?
- Should DTC0108 MAP High/Low cause a no start?
- Hesitation after LS1-Edit
- 4.7 degrees of knock in a 98 z28
- Anyone know of any tuners in Tenn. area?
- Cooling fan problem
- Torque Converter Chatter and Misfire Programming
- how are these numbers? and why wont my car start?!
- my knock sensors donīt work, need help
- Car dies on startup, but idles high when hot
- After 30 seconds on cold start car surges for.....
- Toasted PCM
- car wont turn over!! security light is on?
- converter plug supplied with HPP 3
- Car stumbles off after 30 lb injector install?
- What causes High Voltage in temp circuit???
- cany you clean o2 sensors?
- Car just dies out of nowhere while driving
- i wanna hear what your a/f is with these mods
- air/fuel after predator and getting !CAGS
- Test forum 3
- Pros and cons of open loop tuning?
- Does Atap support Fuel Trim Learn and Loop parameters?
- A/F ?
- Need help on tanslating Codes
- Help with shift points and TM
- Accel DFI
- how long for ls1 edit
- anyone know the link for PC program for predator?
- question about adding fuel in Edit
- Hotcam installed, idles great, BUT hard to start?
- Fan temp settings for 160 stat???
- 02 signal wire
- Code help please!
- someone?? anyone?? predator questions
- Wiring Diagram for '98 LS1
- Autotap?
- Using O2 Simm while dynotuning?
- I am completly confused
- Install AutoTap on 2 computers??
- High Idle Issue .............
- skip shift not eliminated help me please!!
- NEED HELP FAST! fan temps and air/ fuel
- FAST HELP PLEASE!! fan temps please, and air fuel
- Need Predator tuning tips!!!
- atap ?'s
- Building a PCM Breakout Box - need connectors
- Question about LTrims
- problems with right 02sensor
- will LS1live Pro work on a non-LS1 engine?
- For Sale LS1Edit and Two 98 PCMs
- Could a wire short cause this?
- Looking for a stock 98 vette ls1 edit file
- ls1 edit program
- Best place to have my Computer Programmed
- help
- M6 Rev Limit woes... Anyone please help
- speed sensor symptoms?
- LS1 Analyzer Timing Question
- O2 SIMs
- Questions about routing the MAFT inside the car
- If you have changed your knock sensors, inside please
- Do u need O2 simms w/ LS1 Edit?
- Hypertech Programming
- Weird O2 reading.
- ran through puddle of water...now problems
- Can knock sensors be 'de sensitized' with LS1Edit?
- PCM tuning options with a 98...
- LTRIM's confusion / headaches
- Can you get the P0410 from...
- Car Threw A Code. Car Needs Reprogramming. Lost For Help
- Help with Iac count problem with atap
- surging at idle
- Can you program an A4 PCM for a T350
- few ?'s about predator
- pcm connector question
- EFILive question, loop display
- Tuning Factoids - Spark, Fuel, etc. - Looking for Individual Results
- help with po121
- please help...SES light
- best replacement o2 sensor?
- Hypertech Take care of TC Swap Probs
- Changing Shift Point With LS1 Edit!
- seen this before??
- ed wright programming or ls1 edit
- Is LS1Edit Resellable?
- How to erase trouble codes
- Anyone mount their Autotap laptops in their cars? Where?
- Maf tunning with bassani mid length headers?
- torque management
- torque management
- hey, what do you think about predator logging??
- F.A.S.T. bank/bank or sequential ?
- hey guys, how can I set my knock retard with predator?
- Predator reveiws.(post up)
- WTF just happened
- Is it suppose to do this
- Who Here has had their Ed W PCM flashed by the Dealer back to Stock?
- Help! tuning question for an A3
- 3.5-4.0 Degrees K Retard > Please look at this
- Fuel Trim Cells only in 20-22
- Silverado Refuses to Start
- Cruise Control Problem
- Damn 2-3 shift still will not work.. Need help
- New Timing Table Values, What Do You Thin?
- Why Set the Rev limiter
- you are a car god if you can answer this one
- ed wright's phone #??
- O2 and LTFT readings
- Please Help, Which AUTOTAP software to buy...?
- Spark Advance Primer Needed
- Anyone have an edit file for the G5X-2 cam?
- Need advice on where to tap in for gauges
- Need help with a misfire that isn't related to coil packs, plugs, or wires...
- PCM shut down code P 0601
- Throwing PO420, what does my EFILIVE crap mean?
- Would a bad cat make me misfire? What would it do? Showing PO420 on the scan...
- Running Lean...how to fix this issue? (tuning newbie)
- LS1 Edit questions
- LS1 edit is the shiznit
- PREDATOR SHIFT POINT HELP NEEDED
- ls1 edit question
- What's the best A/F on a dyno?
- Using AutoTap to see if injectors are maxed out?
- Guru's and LS1 experienced ANY IDEAS ????
- Autotap help
- Timing Advance Missing
- Question about LTFT and how to adjust with ls1 edit
- HELP,keep getting this code P0135
- do i need comp tuning??
- Help! Freaky 2nd gear only rev-limiter problem...
- misfires ...autotap logs inside... need opinions
- Dyno numbers and Wideband funnny stuff
- Code TCS C-1286 Need Help
- trans swap (m6 to a4)
- Electrical problems continue
- 31.5 degrees timing anyone?
- CODE P1336 Need HELP!
- LS1 Edit and my lap top
- LS1 Edit or EFI Live
- HELP with CODE
- Tuning with MAFT, need help!
- what does it mean when my heater performance bank2 sensor 1 has a trouble code?
- knock sensor circuit
- Hey NoGo
- Help me get this car into closed loop!!!
- Fuel Trim Cell 22 at IDLE ????
- Need help with codes P0137 and P0157
- Knock at 5000+ PLEASE HELP
- Some EFIlive runs ???? about timing and KR
- 130 mph /service engine soon ?
- 2 huge problems for the experts.
