View Full Version : Forced Induction
- should I upgrade my fuel system
- need help (PETER APS)
- Front mount swap how much hp gains
- I finally took the FI route...
- APS KIT/ TTI @ 1000rwhp possible????
- .224/.232 114 lsa good cam for forced induction with l92 heads?
- 2 bar MAP?
- Last runs of the season: Car goes 170+ mph
- Adapter, Tial 38mm to 50mm Jgs Wastegate
- t3 manifold change to t4?
- ProCharger Pulleys, Where to buy..?
- Good cam for 383 LT1 supercharged
- what cam for 408 t-trim supercharged!!
- diesel turbo?
- front bumper
- How can I get a fail safe MAP signal?
- stock ls1 coils
- Mike Brown in hospital with brain aneurysm
- Having it balanced?
- intercooler question
- New parts is coming pic :) .
- Anyone have pictures of PT-88 Turbo?
- anyone running the PTK kit *read*
- LS9 Crate Engine Next Fall!!!
- boosted oldschool
- Rear mount oil return ???
- Where to go from here.
- HELP with setup
- Ok aps guys with speed density what size silicone to eliminate the maf?
- spark to boost with cam 110
- looking for the right cam
- Custom Rear mount turbo
- ProCharger rebuild begins!
- Best Turbo Header gaskets?
- Well, Not the quickest-but maybe the fastest SC C5? 148.58?
- honest anwser should i just build a n20 car for a daily driver!
- does it make a difference?
- How much spray can you add to a single turbo set-up?
- Corvette goes Boom!
- Holset HX40W
- Turbo VW Bug Build
- PCV Layout Question
- Twin Holset Ls1
- Incon Check Valve Placement???
- Quick Compression check calculation
- ceramic coating or just header wrap??
- best tb and maf for t-trim vortech?
- My KYTP build
- LS1 turbo TB/Intake
- LS3/L92 head gasket?
- W2W twin turbo camaro?
- P1sc or F1A
- LS1 Custom Turbo wanting advice...
- Tuning timing for boost, msd 6010
- Looking to go turbo LQ9
- anyone know someone with a kenny bell on a ls1 camaro or trans am
- New To boost some questions
- i want a turbo or super charger need help
- How much boost will a stock 6.0 handle?
- Keeping AC, And Alt In Stock Location
- Sts Fmic Kit
- No way! More bad luck for ninetres???
- Anyone got problems with fluid dampr ??
- Zombie's 3 speed Th400 over drive solution
- Kinda random question about rear-mount turbo systems...
- Aps turbo f body guys tips ,tricks and questions thread.
- If 600rwhp was your end goal, would there be a downside to a rear mount.
- Blower Cam
- Where to have GMPP intake plumbed and ported?
- A 383 OR 355 Supercharged?
- Where to relocate fuse boxes
- i broke it...looking for imput/suggestions
- Procharger RACE blow off valve few questions and cheapest place to buy one
- 9.21 Letting out... *video*
- Turbo Opinion from Yall
- Who all have deleted the power steering cooler?
- Anybody have a Large frame Precision PT101ish off they can take some measurments of?
- Best budget head for boosted 408?
- What oil weight for the tt.....
- MS3/Procharger
- Major #1 Qualifier @ Orlando World Street Nationals.
- Package Turbo kit for LS1?
- TTiX stock motor 10.2@142 in car video
- 99 Turbo Ss Camaro 402 Need Help
- Car acting up Help!
- What does your 3bar map read
- 2048.9 hp/1507.1 lbsTq 400ci LSX
- Anyones serpentine belts affected by piping?
- LS1 Forced Induction Hall of Fame
- Question for you turbo guys
- Aps buds what size is the blow offs..20mm or 25mm
- cold pipe question.
- turbo 346 LS1 camaro
- Incon Install Help
- procharger question
- ebay "ls1 turbo kit"
- New ZR1 At The Track.
- Got a TH400 with brake....how to launch?
- upgrade stock 317s or get PP stage 2
- How much power is my fuel system capable of?
- injector size 427
- Are there any 6 Speed STS/Rear Mount Turbos in the 9's?
- Head gasket for twin 70 build
- Built a turbo civic, now I want to boost my T/A :)
- Everyone like T-netics TC testing.
- Patriot Duals the best spring for FI?
- A couple more runs with EPP Formula last night
- Twin Turbo and aluminum flywheel
- for those of you that ever run into a Procharger leak
- APS inlet tubes
- Procharger Oil Leak on Inlet Side
- More Problems!!!
- Ok some questions for the FI gurus. w
- Turbo too big?
- Who's making 700+RWHP on 346/347ci w/Blowers
- what happened to big birds post(inlet tubes)
- wanting to push the limits of a 408
- My new intercooler PIC .
- 600rwhp on a LQ4 6.0L
- what mods can be done to a stock S/C 3.8 V6?
- LSX Pontiac G-8 Magnuson Supercharger
- STS pump can you run a timer?
- Saying goodbye to an old friend
- anybody bought these pipes??
- Any problem with this setup for procharger?
- Installing remap problem,help needed!
- Turbo xs rfl
- LS7 Intake and Boost
- Need help selecting a tranmission for my setup
- Ron davis radiator and water pump questions on my aps setup
- Can you boost 11.3cr?
- Procharger FMU shot?
- I need some help with choosing turbos
- New intake manafold for the FI guys.
- Lt1 smoking
- Sound/loudess of turbo vs supercharger on same engine
- Turbo or Not to Turbo.. There beath the question my friends..
- KYTP.....single turbo + A/C
- LS1 408 cooling Problems
- get the most of my combo
- How long would it take to normaly install a SC kit?
- supercharged build on a STOCK ls1
- BIG Turbo
- down pipe for pt 91.5
- Turbo Theory books?
- Ofi Wtf
- STS sellers/vendors...etc
- car wont start, any ideas?
- 428ci LSX iron block...single turbo.....A/C.....????
- Where did OFI disappear
- anyone have a WPPP kit?
- Procharger used F1 system pricing help?
- Will I make more power putting 1.85 rockers on my boosted car.
- What AR ratio for a 428" LSX
- Why is this not making more than 6psi
- Fast 92mm Install
- Tom Kempf and the Stenod Crew in Florida
- zr1 blower on a gto?
- set of mannifold flanges for c6 and 6.0 truck manni turbo setup
- Late Model Racecraft's Procharged C6 Dyno Vid!!
- Late Model Racecrafts Procharged C5 Dyno Vid!!
- P1SC with Custom Bracket
- anyone running 2 black Procharger BOV's
- HELP with STS air pressure switch
- *** Cartek C5 Vette Rear-Mount 9.32 at 150+ ***
- Homegrown GTO tt setups anyone?Reference PICS
- Maintenence plan
- Forced Induction Cam
- my custom eccentric supercharger brace
- haveyou ever over tightened a procharger belt?
- need some opinions
- sts turbo lag?
- Second 2 Bar Map Sensor gone bad.....
- Turboed intake question
- cold side insulation....
- EPP's Project LT1 Formula in the 10's
- Procharger guys *LOOK*
- ****cartek Holds C5 Supercharge Record****
- Parasitic losses from different forms of FI?
- oil cooler
- Need a CAM!!!!
- Will this setup be decent, and how much power?
- 2bar vs 3bar?
- twin turbo results inside....
- new turbo build?
- Powerdyne LS F-Body Question
- Upgrade Procharger piping and clamps?
- boost problems??
- my friend vid trans 7psi p600p
- what dia. pulley to get 7 to 8psi???
- Preventing head lift!
- Foundation or Power House first?
- AIS trunk mount on left rear side of camaro/firebird
- how do forced induction engines respond to changes
- Texas Mile teaser-- LG Motorsports Twin Turbo Z
- I am running an sts kit and the clutch is slipping.(convert to auto?)
- LS2 Aluminum Block question??
- What c.i. LSX for TT?
- Video of my low 10 sec passes using only 1st and 2nd gear.
- where to start
- Turbo A/R question
- What head gaskets to use?
- Dr Turbo or Jose inside please, got a tech weather/altitude turbo question
- Final test before tune
- APS TT swaybar banging fix
- Hey PETER is APS having a Booth at SEMA this year??
- Our EPP Front Mount Kit with foglights
- OFI is making it in Headlines
- Cheap V-Band Clamps? Leaking.....
- ModularTurbo starter kit!!!!
- high compression and boost
- PTK/Ebay kit owners I need some pictures
- who built your 402
- Upcoming Turbo Build Questions.
- Am I getting greedy?
- Worth it to ceramic coat exhaust housing?
- Good internals for boosted 6.0 iron motor
- in search of boost motor
- ebay hot parts kit
- 3 bar map??
- STS longetivity
- 428" LSX - What size Turbo?
- how much boost would you run???
- Need input on heat and metal brake lines.
- TH400 swap questions (FI related)
- FM turbo LSx in a 3rd gen
- What rear gears are you turbo street people running? Highway race
- Late Model Racecrafts Turbo Mustang!!
- 317 heads & LS6 cam...
- Wastegate flange
- Initial D1SC plan
- New A2W intercooler finished
- Aps guys should I ceramic coat my exhaust manifolds?
- small frame 76mm turbos...
- What do you think of this air filter for my F1A???
- No 9's for me....broke the tranny. Need advice...
- I/C Water tank with tranny coolers
- 4" DP what are my options?
- does anyone know anything about this turbo?
- Gauge wiring
- Twin t76's
- NINETRES in the 9's all day!!!1!!1!!!
- 10.8-1 comp & 20#'s of boost ?
- Twin 76 first drive video.
- Which heads for 408
- guys with vented rocker covers inside
- Welding cast iron
- Install help on my aps asap..!
- Finally in the 9s, new best!
- Which Heads
