View Full Version : Forced Induction
  1. paging Harlan
  2. will a qmp with a t76 be enough for a 408
  3. Suddenly showing Knock...
  4. Paging Harlan
  5. Little update
  6. Twin Turbo Question
  7. HP kit or the PTK kit for F-Body.. Any New News
  8. Rear mounted turbo/exhaust
  9. Hey guys, what do you think of this?
  10. 4 PSI vs. 8 PSI Valve Float?
  11. question about FI in an emissions legal setup
  12. Finally dynoed car today with the new forged bottom end!
  13. Finally got some pics
  14. tuner help
  15. Tapping intake manifold for Boost?
  16. F1R for sale
  17. single or twin turbo
  18. anybody got 83's or 96's for sale?
  19. cam for 98 ls1/ati procharger
  20. Pics of where you pick up your boost signal....
  21. AP-Engineering is now an STS Turbo dealer!
  22. Anyone Want Turbo Tech Race Kit Hotparts??
  23. GTO supercharger comparisons inside!
  24. Detailed info about the GTO ATI ProCharger!
  25. Truck manifolds on ls1 heads facing forward?
  26. Special Thanks
  27. any Vortech Guys using Alternative Intercooling/Aftercooling?
  28. Couple questions for procharger experts.
  29. Best Belt Install Tool?
  30. What 3 bar map sensor are you guys running?
  31. Ati ?
  32. Turbo cam
  33. Wastegate question
  34. Turbo Truck For Sale inside
  35. Daily driver Intercooler combo
  36. Boost controller help
  37. Got a question about a boost vs fuel..
  38. Complete Procharger System ForSale
  39. G-trim & FMIC hard piping- pics
  40. built short block on the way. what can i expect?
  41. Need some opinions on Redline Motorsports turbo kit
  42. Best location for the IAT
  43. digital boost gauge?
  44. Analysis of turbo QMP t-63 dyno 5 psi valve float?
  45. turbo newbie...
  46. Question about TTi Street Turbo kit
  47. W2W 6.0 First Dyno 836/842
  48. SDCE alignment > Kyle > anyone??
  49. Lucas 42.5 injectors max rwhp
  50. Why do the super high F.I. power numbers not generally correlate to low ETs?
  51. Which Injectors and fuel pump?
  52. T04 "P" trim for remote mount?
  53. Speed Inc.-Single Turbo-348ci -844rwhp 813rwtq-stock pcm
  54. Exhaust Popping on cold start-up
  55. Stock bottom end LS1......
  56. .020 milled 5.7 heads?
  57. BOV before or after MAF ??
  58. What Turbos did CAS use
  59. Back in Business!
  60. Sounds like a LS1 F-Body roots style supercharger might finally become a reality
  61. K-member questions
  62. Compound charging
  63. Please Help!
  64. Need some plug wires for Coil Relocation..help plz
  65. ati pics
  66. What happed to those 1000 plus rwhp 408ci cars?
  67. Getting Closer
  68. "wonder if it's stock?"
  69. My FMIC Home Page Done... Watcha Think??
  70. OMG good video!!!
  71. well finally
  72. Please help with cam for Procharger
  73. Yet another cam question???
  74. D1SC 8-12lbs
  75. Kenne Bell Twin Screw Intercooled for LS1
  76. Map Sensor Upgrade?
  77. Anyone have any twin screw SC?
  78. Turbo question
  79. ATI procharger, help
  80. Best Exhaust style?
  81. manifolds to use for a twin turbo setup
  82. Sizing air to water IC's
  83. 8 or 6 rib?
  84. Forged Bottem End For SC Question
  85. Alky injection
  86. turbo's are better for...
  87. SC Info
  88. how far for a stock crank
  89. Boost Enginneering needed.
  90. Big Thanks to ET Performance!!
  91. New "TWINs IN TOWN" FLP
  92. cog setup f/s
  93. who has a powerdyne bracket or pattern for one?
  94. Arp L19 Head Studs...any Interest Again??
  95. Methanol injection pressure guage?
  96. Kevin@ NoGo
  97. FMIC Kit for STS Sale
  98. LS2 block for boost
  99. videos, dynos and/or times for TTi kit
  100. Fi Racing!!!
  101. Head Gasket Selection
  102. engine mods for ATI D-1sc
  103. Dyno for 5psi STS kit,
  104. home made turbo headers
  105. turbo gauge help
  106. Your Fuel System Setup?
  107. Better cam for d1sc.
  108. overdrive roots blower?
  109. Is It True??
  110. Looking for Turbo/FI Books
  111. What kind of valve springs to buy??
  112. how much timing to run
  113. G-trim hp? times?
  114. alternate ati fan setup and pics of your setup complete
  115. If You Had It To Do Over Again
  116. Need help ATI 383 runs hot
  117. Twin Screw
  118. If you have a partial Incon kit, email me.
  119. Reality Check, Colder Air and PE Tuning?
  120. Boost Level Estimate
  121. something interesting about diesels
  122. FMIC guys ... I need need parts
  123. That blue and orange piping
  124. Vortech owners inside
  125. Magnacharger SS
  126. ATI P1SC Z06, pulley swap, 4.25=8 psi now, what to get 12 psi?
  127. Magnacharger Z28 in the 10's!
  128. People with superchargers over 550rwhp what exhaust
  129. Experienced tuners of Turbo/SC's inside please...
  130. Guys with 50mm Tial BOV, help please
  131. Vortec V9 code problems
  132. Vacume pumps whos running one and what is it?
  133. Paging silver bullet, what u up to?
  134. Who's dynoed over 650rwhp with pump gas?
  135. Blower friedly maf set-ups?
  136. Any Pics Of A Ta With Sts Exh Tips??
  137. Who knows about MagnaCharger???
  138. Scat vs. Callies internals
  139. Which one is better?
  140. What is the next size blower pulley?
  141. Does the catback influence the turbo cars?
  142. Alternator relocation info/pics?
  143. Blower guys: Who is running more than 7 lbs on stock bottom end?
  144. cam + ati
  145. who has a incomplete CAS TT system?
  146. Which Boost Controller to use?
  147. If You Run Lean Could It....
  148. Need Source for High Quality Black Accordion Hose
  149. STS FMIC Camaro SS Complete
  150. Got a new best last night at the track!
  151. Is this a good exhaust for a blower
  152. Disconnect Water Lines On Incon - What Will Happen?
  153. Turbo guys inside
  154. Dyno Graph as requested
  155. How much boost could my stock internals take?
  156. Tommorrow She Goes In The Car
  157. STS before/after dyno w/ 5 lbs boost
  158. Blower pulleys hurt reliability?
  159. 10.0
  160. Something new this way comes
  161. best place to get 6.0 mls gaskets?
  162. 6 rib pulleys for sale
  163. Has anyone run a Vortech S trim on a Camaro in place of thier G trim?
  164. rods, pistons, cam?
  165. Copper Head Gaskets
  166. Anybody Installed an ATI Damper Crank Pin Kit?
  167. LS1 Motorsports
  168. Turbo Tech least expensive single turbo kit?
  169. ATI 8-rib super damper users, inside please
  170. Valve spring simptoms? Or anything else?
  171. Vortech T-Trim For Sale/Trade
  172. Sts kit at 8lbs!
  173. Looking for cam options for my TT427!
  174. Cam for Sale........
  175. Making Progress
  176. Seeing 7lbsof boost from a 5lb sts kit
  177. Hey Moser owners with big boost!
  178. STS turbo system question.
  179. What else would I need???
  180. Need tuning
  181. Who in here going to the southern shootout?
  182. Going Turbo
  183. STS turbo SFC problem. HELP
  184. A Monster is Born
  185. procharger with current cam?
  186. SDCE on the way
  187. D1SC and FMIC setup for lt1
  188. ***turbo cams.....need suggestions***
  189. Root S/c for My 98 SS??
  190. Want to thank Classic
  191. FS: V-2SQ SC-Trim Head Unit
  192. lq9 6.0L head questions
  193. cam and injectors FS
  194. Root or Screw Style Blower for a C5???
  195. Plugs for FI
  196. GTS76 Turbo vs. YSI vortech
  197. GT67 Upgrade?
  198. Miller cycle SC engine
  199. Diesel vs Gas turbos?
  200. Forced Induction Cost
  201. Just bought a Comp Cams Xtreme Turbo cam
  202. Price on TTi exhaust Tubing??
  203. What ring gap.
  204. Boost+Nos meats Mr.Detonation
  205. best supercharger for the $$$(already searched)
  206. TREX in a turbo car
  207. Custom kit fabrication
  208. Cam lift on FI car
  209. FMIC meets STS Camaro SS
  210. pushed it on the dyno yesterday, 630rwhp and 680rwtq
  211. can we make a freakin STS FAQ Sticky please!??!
  212. It's alive!!
  213. BOV on a sts!
  214. Blown 1996 355 Z for sale.
  215. STS Turbos-How Many
  216. Shes back....
  217. blower damage to cat?
  218. OBX intercooler size
  219. Track times for any STS kits yet?
  220. STS rear mount turbo ANY INFO?????
  221. STS Turbo questions/comments
  222. Need tuning help....
  223. who is the closest sts dealer to albany NY
  224. OBX FMIC track results (Vortech T-trim)
  225. SMC Water/Alky Instructions - Anybody Got 'Em
  226. Tial BOV vs. ATI Race Bypass
  227. Few questions about the STS turbo kit
  228. Going to retune, where to set rev limiter
  229. Should I install a cam before retune
  230. turbo on stock internals
  231. Loudest turbos?
  232. Is this noise normal for a ProCharger?
  233. T-Trim guys in here please
  234. Who want's cold IC coolant in LA?
  235. FMIC Piping question
  236. Is my boost gauge toast ?
  237. Speed Inc question about your turbo kits
  238. STS and Procharged owners, Reliability ??
  239. Headers and turbo
  240. Shooting for 800rwhp
  241. Finishing up Twin Turbo kit, need intercooler!
  242. Any vendors making FMIC kits?
  243. more timing with race fuel?
  244. stupid question...
  245. Initial dyno results for Magnacharged '69
  246. Twin Turbo 98-02 Trans Am in Upstate NY
  247. Latest project finished, more bling....
  248. CAS twin turbo system for sale
  249. What bottom end upgrades to safely run 8psi? (supercharged)
  250. STS kit results
