View Full Version : LT1-LT4 Modifications
  1. Anyone from MASSACHUSETTS IN THE HOUSE?
  2. 94 Trans am won't start
  3. Almost ready
  4. Header swap.
  5. Best cam for my Lt1
  6. diff between 93LT1 and 94-97
  7. 2 series 3.73's vs 3 series/ring and pinion install question
  8. LT4 composite valve covers not fitting...Need help fast.
  9. How to stop rust?
  10. Water Pump
  11. crank hub pullier
  12. 96 wiring + PCM on 93 LT1?
  13. Need some help/advice badly
  14. Yea its another "wat cam" thread
  15. Thanks MADMAN!!!
  16. Recommended TStat degree?
  17. If you have 4 channel ABS and get a Moser 9"
  18. nasty LT1
  19. need info on abs delete
  20. Suggestions please
  21. look for ideas for valvetrain parts for cc503 cam
  22. I underestimated the Lt1
  23. wooooooooo
  24. nice short block!
  25. Almost finished with the polished corsa exhaust (LT1), pics
  26. Question on the GM chevy black valve covers
  27. Help Me Out Asap!
  28. Does bbk make a mid length header?
  29. xfi 280 or 276 on 300cfm heads on 355
  30. blowby
  31. msd opti?
  32. Quick Rocker Help Urgent
  33. Does bbk make a mid length header?
  34. Center Mount EXhaust?
  35. Removed Heater, How Do I Reroute Hoses
  36. Bogging Problem on LT1 A4.... HELP!!
  37. ::::::::::::::::ford 9" and 12 bolt for a 96t/a help info
  38. dod retrofit
  39. Worse place to drop a bolt?
  40. how can you tell if a rear end is posi.
  41. weight of thing of f-body cars
  42. LT4 Stroker plans
  43. Turbo Lt1 question
  44. Cam suggestions
  45. Running like junk!!
  46. Engine Starts, runs 10 second and dies
  47. PCV Question
  48. Y-pipe bolts
  49. car died and wouldnt start
  50. spark in none out
  51. few last questions! (lifter/pushrod help)
  52. 357 build ?s
  53. Oil Pathway Diagram
  54. Crap....I dont think the car will start
  55. What size pushrods to use?
  56. pacesetter LT install ?
  57. Motor Mount Question
  58. electric water pump
  59. Gutted Cat
  60. Weight Reduction Question
  61. Where to get fuel for nitrous on lt1?
  62. Optispark question
  63. Whatever happened to that guy.....
  64. car seems to be running very rich
  65. Header Question
  66. Max mill on LT1 cylinder heads...
  67. Camaro NOT RUNNING RIGHT PLEASE HELP
  68. XFI 280 or XFI 292
  69. Speed Inc cleaned up my engine bay pics..
  70. Defroster problems
  71. Car will not start need help
  72. Strength of 3.90 gear vs others?
  73. Gauges out: Oil pressure, engine temp, fuel
  74. Few update pics on the build!!
  75. how much did you pay for your headers installed?
  76. How hard is it to crack an LT-1 block?
  77. bad lifter??
  78. undoing the drivers side motor mount bolt
  79. quick question about pcmforless
  80. Heads...
  81. Tune
  82. any problems running xfi 280 on a 355
  83. Gears?
  84. looking for high 12s
  85. Bad News
  86. 4 bolt main question
  87. cc503
  88. lt1 tuner system?
  89. FI springs for lt1???? need help
  90. Trick flow head flow numbers?
  91. Trouble with cammed lt1
  92. Bad Vibs @ 2K RPM
  93. how to tell between the two
  94. 94Z not running right right ?
  95. 383 stroker
  96. O2 sensors
  97. good place to buy gears?
  98. buzzing when turning the ignition to on position
  99. OTVC install??
  100. Galley plug location
  101. New project
  102. Ac and Smog delete
  103. Jet fuel pressure regulator
  104. 85mm MAF users!
  105. Brake booster help....
  106. back fire popping
  107. Just finished installing my intake gaskets
  108. custom LCA's on the T/A
  109. timing cover? with double roller
  110. LT1 exhaust ports V/s Brodix T1 23deg D shape exhaust ports.
  111. lt1
  112. LT1 Plug Swap w/ Headers - Advice Needed!
  113. Weight DIff Alum vs metal Drive Shaft
  114. Found out something cool today
  115. dipstick tube removal....
  116. Another 94z28 problem!
  117. is this the right opti?
  118. MSD Digital 6, Pictures needed.
  119. Fuel Pump?
  120. Weird Misfire only when cold
  121. Missfire at idle
  122. almost running! help!
  123. driveshaft????
  124. looking to trade hood OH,WV,PA
  125. Weight of lt1/t56 setup??
  126. kink in the wheel of my 355 build
  127. Getting ready for LTx Shootout
  128. Stock WS6 exhaust question
  129. LS1 springs
  130. What do I need to get in the mid 13s?
  131. Delteq or LTCC with FAST?
  132. Smog legal Cam more aggresive then cc305/Hot Cam?
  133. What to do?
  134. where can i buy a o2 simulator
  135. Who Would Win
  136. RRRRR!! Pacesetter Long Tube Install is starting to REALLY irritate me!!
  137. How did you elimante knock? POLL
  138. This is false knock right? HELP!!
  139. Lt1 Cam Install/rockers/push Rods Cost
  140. Anyone know where I can get replacement TB blades?
  141. What shift light
  142. b&b triflow
  143. what size/brand tire for a 15x4 wheel?
  144. need a part number for a bleeder hose
  145. Just got a 97 Z28..Advice on next mods?
  146. Ok last converter thread i promise...
  147. need help
  148. rear seat delets installed
  149. why cant i find cc305, cc306, etc.
  150. Lt1 swap in a 94 3.4 5 speed
  151. Email to Lloyd Elliott
  152. 2.73s to 3.42
  153. to make a lt1 faster??
  154. What type of gains with a cut out??
  155. how will my car run with no cats?
  156. What's the part number for this boot?
  157. Fuel all over engine bay and under car!
  158. Converter Hanger
  159. how much boost should i run?
  160. chugs,cuts-out only after 10min or so
  161. engine removal question
  162. 93 z28, problem? Please help
  163. It runs...and hooks
  164. It's Alive!! Aaaalive!
  165. just got back from the track and am looking for some advice
  166. eibach drag launch springs
  167. Can Opti Cam Pin be put in wrong Hole?
  168. part number for correct ARP head bolts
  169. uh oh another missing out thread
  170. So I got bored today...
  171. what cam is right for me?
  172. won't stay running
  173. engine sensor fuse
  174. Yes...another "do I need a 58mm Throttle Body" thread...???
  175. just got back from the track and looking for some feed back
  176. another kid wanting a hp guess from u guys
  177. 383 Startup/idle video
  178. check engine light.
  179. Those of you with 30lb. SVO's
  180. 58 mm Throttle body?
  181. Would the edlebrock dual cat shorties fit on my single cat camaro?
  182. No Start Condition on my 94 formula
  183. 1 Chamber vid clips?? True duals.
  184. I just got my hotcam car running!..Now what do i do about these problems...
  185. Opti: MSD Vs Dynaspark
  186. I wanna run 12.0s
  187. Heavy duty Meziere pump, Griffin radiator and factory fans...how?
  188. More problems with my carr.......
  189. Opti rotor
  190. Timing chain Kit
  191. stripped throttle body bolts
  192. Looking To Install A Good Cam "which 1 Should I Get"
  193. Pacsetter?
  194. B&M console Megashifter or similar for 4th gen
  195. has anybody run the Crane 109621 214-222 ?
  196. LT1 opti troubleshooting
  197. Raptor shift light install
  198. Injectors and stall
  199. Running rich!!one!!11one!!11!!
  200. Spark plug wires
  201. Opti Help
  202. List of goodies for spring
  203. 94z28...HELP!!!
  204. tuner cats- whats the first thing i need to do
  205. Cam Change question
  206. tsp rumbler
  207. I Hate Ls1's
  208. LE2.2 idle though a Borla XR1
  209. wideband o2?
  210. lt1 mods
  211. Ignition box effects on Cap and rotor
  212. P1351 Due To Delteq
  213. Anybody use Ethanol or make their own
  214. best aftermarket oil pan to buy?
  215. Question about bolts.
  216. Reccomended Opti change?
  217. LTCC guys post your pictures!
  218. daily driven lt1 formula ???
  219. Bad Starter again
  220. mac catback
  221. trouble finding pics
  222. oil pressure help
  223. new issue :bang:
  224. Magnaflow or Hooker exhaust?
  225. any good guides on porting intakes?
  226. My new exhaust...
  227. Tranny Mods To Prevent Damage
  228. kinda ashamed to ask but..
  229. LT1 to LS6 swap????
  230. Aftermarket heats
  231. Average gains from going to a 1.6 rocker
  232. any potential for a rebuild (?)
  233. removing heads ='s disaster?
  234. Track time question
  235. LT1 timing chain and gear question
  236. relocate alternator/Havc-PS deleted
  237. a4 and m6 crank diffrence
  238. Need some advice
  239. Compression Test Help Please!
  240. Valve cover clearance...
  241. LT's plus cats....pics? suggestions?
  242. cam help needed
  243. guys with just headers and bolt ons hp?
  244. Lloyd Elliot heads
  245. fuddle torque converter 3000 stall
  246. Few Questions for a new F/I build...
  247. Another question
  248. LT1 Heads Question
  249. another satisfied comp cams customer!
  250. inspection cover...
