View Full Version : LT1-LT4 Modifications
  1. LT4 Hot Cam with 1.7 RR's. Valve Spring?
  2. Cc305
  3. abs light with ss led light???????
  4. Looking for forged crank advice.
  5. what hardware do i need?
  6. Best 1/4 Mile times w/Full Exhaust & Spray??
  7. Stage 8 bolt sizes HELP?
  8. HELP! High RPM ignition missfire/breaking up issue
  9. Big Solid Roller, and my heads??
  10. Wierd high rmp issue
  11. 95TA vs. 97TA
  12. Scattershield?
  13. Engine Cleaning?
  14. Abs Inop
  15. 355 buildup....?
  16. will trade.
  17. good choice?
  18. HPs #, out all motor 396?
  19. Crane 210/224 Or Lloyd Elliot 2 Cam?
  20. FUEL PRESS Gage HELP
  21. lifters...
  22. how many qurts does the lt1 take???
  23. coil conversion nightmare please help
  24. O2 Sensor and Cutout Help
  25. Lt1 elbow
  26. Where To Find Motor?
  27. Lt1 Timing Chain
  28. help or suggestions please
  29. lt1 starter issues
  30. Best Cam To Run In A 383 Stroker?
  31. im noob
  32. New pics of the WS6, finally set the ride height :)
  33. what website is this car off of?
  34. ? Gm 847CAM where to buy and how is it ????
  35. Black smoke form exhaust......
  36. Dynatech Headers
  37. Help needed with drive shaft bearing/center support!!!!
  38. BBK Vs Holley
  39. Need Help Fast!!
  40. North Charleston shops?
  41. predict times with cam and spray
  42. S&W 8 point roll bar
  43. How fast are STI's?
  44. Ok, need some help
  45. To resistor or not to resistor...I'm new
  46. Air pump for engine important/affect performance?!!?
  47. Cams / Crank etc
  48. Pic's of my new heads...
  49. is this a good deal for a 396?
  50. Fastest bolt on times,
  51. Electric Water + Opti Spark = ??QUESTIONS?? have you done one. . .?
  52. CC306 Idle Video
  53. Wider tires slower times?
  54. lt4 intake direct port fogger 4 sale
  55. Typical Oil Pressure
  56. Help w/ my LT1 CSR waterpump!!!
  57. 323Gears MAX SPEED
  58. 93 to 94 gauges
  59. Which Cam and Tune?
  60. help help
  61. Slp dual cat shortys help!!!
  62. Does this sound like a bad torque converter?
  63. Idle problems
  64. 97+ gauge cluster swap
  65. "Cadillac Cam"?
  66. Minimum cam dowel pin length?
  67. Mcleod Clutch
  68. Adjustable Master
  69. nitrous question?
  70. Ported TB or MAF???
  71. 355 or 383
  72. HELP oil lines
  73. me vs eclipse
  74. if your car wont start, start here
  75. Fans will not kick on at any temp, need help to diagnose?
  76. LT1 Exhaust
  77. Stock internal 96k+ mile LT1 goes 11.67
  78. real quick question....how much is stock fuel pressure?
  79. Help HOT
  80. Will this spring hold cc306 lift??
  81. doing rebuild! 355, 383, 396?
  82. looking for a guide for headers install
  83. looking for a guide for headers install
  84. BBK mid headers? Anyone?
  85. Which cam?? for 3.73 and 3000 stall?
  86. Help 383 Carbed In 97 Ws6
  87. 383 build questions
  88. Ignition wiring question, need help
  89. Couple install price ?'s
  90. Give me an idea of the power for these mods?
  91. 95 corvette exhaust
  92. Car will not start after rain, Opti?
  93. what times with 230/236 cc
  94. Gas Mileage improvement?
  95. Hotcam/CC305 owners, what times are you running?
  96. Thoughts on Mac cat-back
  97. How difficult to replace the "Optispark" on a 95?
  98. wanting to upgrade from lt4 intake to carb intake help
  99. LT1 to LS1 swap ??????
  100. cheap horsepower
  101. 306 cam And check these valvertrain????
  102. What Mod Next?
  103. Valve Spring/ Retainers
  104. lt1 oil pump & head gasket????
  105. Hp Estimate
  106. HPE 383 Shortblock
  107. Noisy Valvetrain
  108. Taste Test...
  109. What cam should I run
  110. Anyone running a CC503 on a 114LSA?
  111. 1990 corvette
  112. GM847 vs. cc305 for a daily driver
  113. Pacesetter Header Questions
  114. Catalytic Converters
  115. ____3000 stall how is it with 306 & 3.73??___
  116. 355 6 Speed goes 10.49 @ 130.4 NA
  117. finally got the bottle in the car and got a few pics for ya guys on my 93 LT
  118. throttle body airfoil
  119. smog pump lines were do they go
  120. LT1 with no spark at coil
  121. What is the RPM rang for CC306?
  122. starter issues
  123. Any tips/guides for cleaning the MAF?
  124. How the hell do i tell?
  125. Header/Y-Pipe Combination Question for '97
  126. Header/Y-Pipe Combination Question
  127. Cooling a high HP 383 LT1
  128. Max lift on 986-16 valve springs
  129. Muffler...
  130. 30# Ford SVO red tops
  131. lt header question?
  132. Which cam for Ported LT1 heads??
  133. what couldi get
  134. Will a clogged cat prevent a car from starting?
  135. Someone lend a hand
  136. Any HPE guys in here???? Rick???
  137. lt1 block interneals = sbc internals? yes no?
  138. Vibration from exhaust. Any help?
  139. How hard to get 400rwhp from LT4?
  140. coil wire
  141. tunning
  142. what should i expect?
  143. Recommendatons on Y-pipe
  144. header and exaust install parts?
  145. what kind of numbers should i see with this cam?
  146. Post pics of your longtubes and y-pipes please!
  147. so i raced an 05 GT...
  148. Help Needed LT4 Valves
  149. Compression
  150. Cam Question
  151. CAI Adds How Much Power?
  152. Some updated pics of my project
  153. ??recommended valve springs
  154. Mod Update
  155. almost finished my LT1 rebuild...
  156. 355" LT1 goes 9's!
  157. flow numbers on a stock lt1 head??????????
  158. Looking for 383 396 LT1 Stroker Info
  159. rough idle backfiring after motor work
  160. 1994 formula six speed for sale,$2000 firm
  161. under hood pics
  162. Best heads and cam
  163. Best heads and cam setup
  164. LT1 headers problem
  165. Carbed 383
  166. LCA's worth it?
  167. Dynaspark no longer available at DTE
  168. underdrive pulleys
  169. noise when launching
  170. zz9 cam
  171. optispark
  172. Pacesetter Mid-Tubes Question
  173. Long Tubes or Converter ???
  174. Post Cam/Valvetrain Specs
  175. LTs for a 96-97 on a 94?
  176. Weight of LT1 Motor
  177. Hotcam F/s
  178. Short or mid or long tube headers?
  179. bog issue
  180. How is the sound for Flowtech muffler????
  181. Biggest cam for daily driver??????????
  182. Shortys or Mid length headers - '97 LT1 Ram Air
  183. Anyone with the cc305
  184. lt1 questions
  185. car surging
  186. Tsp duals on LT1s
  187. Catted Y- Pipe
  188. Work in progress 56K users beware!
  189. SLP LT headers buy it or don't buy it?
  190. strokin it
  191. Recalls?
  192. Pics of the HPC coated Y-pipe
  193. What do I need for 12's?
  194. Need Help Tuning! 94 Procharged Z-28
  195. supra vs TA
  196. cam question
  197. Plans and questions
  198. 1500 - 1800 rpm Stumble
  199. Hooker Aerochamber? Or Full Hooker Catback?
  200. Pacesetter Midtubes fit with stock y-pipe?
  201. how much horse power can i expect
  202. question involving intake removal
  203. I need an Estimate from you guys
  204. Neeeeeeeeed Your Heeeeeeeeeeelp!!!!
  205. 10s on stock bottom end?
  206. LT1 ss
  207. Best Mod?
  208. LE3 LE3 <-- its the rage right?
  209. radiator overflow lines?
  210. quick: intake inlet elbow & airfoil
  211. is there a forumula for LT1s hitting 350 whp
  212. Custom Grind Cams For LT1?
  213. lt4 hot cam kit
  214. Air pump for engine?!?!?!
  215. What's the fastest you've gone?
  216. OK I found out whats wrong with my car but how to fix??? EGR
  217. Brake Kits
  218. Help! I need to beat a supercharged 99 Vette!
  219. got a couple questions im new
  220. Nos
  221. mods for my 95 ta
  222. Swap A4 to M6
  223. What should I get from these mods @ 1/4?
  224. pistions at 30 pounds
  225. crane valve springs
  226. Can someone explain?
  227. what do i need for lt4 hotcam?
  228. LT1 Newbie....
  229. LT4 Knock Module
  230. Many LT1 Hypertech Power Programmers in stock $275.00 ea
  231. whats wrong??
  232. dash swap
  233. Its been beat to death.. but still
  234. Pacesetter headers
  235. headers choices
  236. Power Programmer Plus for '95 LT-1
  237. Comp "R" lifters yay or nay
  238. Changed out my comp R's to Morels....What do I do about Pushrods????
  239. Stall
  240. Rocker Arms
  241. What is the diffrent between internal balance and external balance ?
  242. meziere
  243. 190,000, rebuilding question
  244. different lt1 intakes
  245. cam
  246. Head studs on a '94 LT Formula
  247. will no rear o2s plugged in cause bad missing??
  248. A cool cruiser for you LT1 guys - LT1 Jag XJ6
  249. cant find the thread
  250. Cam research/question
