View Full Version : Forced Induction
  1. 370 ci LS2 FI
  2. Drove the Formy around tonite...
  3. 6.0 heads on LS1, what head gaskets do I need?
  4. electric super charger or elec-turbo
  5. AEM boost controller
  6. Holy Sh&t check out this F.I. Import
  7. supporting mods just to run sts kit?
  8. ATI 6rib & 8rib differences?
  9. Turbo questions, yes I read the FAQ's!
  10. Did the PN# change on GM 2bar MAP?
  11. tial BOV
  12. Front mount intercooler dimensions on an LT1 Camaro
  13. Turbo-Zone HOLIDAY SPECIALS !!
  14. S91 vs. GT55-91
  15. Procharger rebuild?
  16. Lost my copy of dynojet wideband, help?
  17. Will the LS6 coolant tube conversion hurt cooling system performance?
  18. STS + SFCs?
  19. STS and catbacks?
  20. How can you tell if a turbo is ball bearing or not??
  21. Need pic of front mounted turbos
  22. STS Question! HELP PLZ!
  23. SUPER or NOT
  24. 365 CID, MP122HH project done!
  25. Twin intercooler owners take a gander
  26. Gas Water in my Catch can
  27. How can I build a Low CR block.
  28. turbo kit destoys belts
  29. Hoses
  30. How come so few 1500hp LSx's?
  31. New Setup Update
  32. Turbo Exhaust
  33. noob turbo question
  34. Where are you guys mounting your meth stuff?
  35. pump gas limits?
  36. Rearmount WG question
  37. turbo smoking need some help
  38. C5, APS Twin Turbo, Head/Cam -- Questions
  39. Block to max a T76
  40. Heads/cam for D1SC
  41. Blower size for specific displacement?
  42. need help with new turbo set-up for 98 ls1
  43. Stock coils provide enough spark?
  44. Just for fun YSI
  45. Anyone still with QMP turbo kit?
  46. ATI vehicle guide
  47. Turbocharges off a 1994 3000gt vr4
  48. HP Limit of Magnuson?
  49. Iron 402: Twin 76s or single 96
  50. Going FI want to change my cam.
  51. Well, What did Santa bring?
  52. Hi-flo problems, go figure! (pics)
  53. What should I expect from this turbo?
  54. Head choice, valve sizes and stages LQ9 heads
  55. Tranny and rear diff gear ratio for TT Vette??
  56. I need help
  57. Merry Xmas fellow LS1tech BOOST members! and what did you get FI wise
  58. sts pcv switch working?
  59. Replaced the 2bar with a 3bar today....+ Boost.
  60. Wastegates: dump to atmosphere or route back to DP?
  61. Supercharger DIY?
  62. t-6 turbo flange
  63. Anyone running a LS1 Accufab Throttle body with there blown F-body?
  64. Would i be the fastest STS turbo car if i reached high 9's?
  65. turbo choice help
  66. supercharger??
  67. Turbo exhaust?
  68. Stock block done!!!!!!!!!!!!
  69. Newbie curious ques.
  70. How to tighten Procharger Belt?
  71. Inconel valves necessary for 700whp turbo setup?
  72. PCV setups with forced induction
  73. New member with some boosted 5.3 questionsin a mazda?!?! WTF
  74. d1sc bracket
  75. extremely low oil pressure after sts
  76. STS guys! in here please...
  77. Safe Limit Boost on Stock Engine
  78. what makes a good turbo cam
  79. Post up if you have a 3bar SD EFI/HPT tuned stock pcm FI car.
  80. just got my twin turbo car back together after coating
  81. A fully built turbo charged 3.8L camaro? (video)
  82. hey guys this is a lesson i leared along time ago!!
  83. Building a sequential turbo system
  84. oil drain into oil pan right underneath timing cover
  85. Attn: Paging All Turbo Sponsors!!!
  86. turbo power numbers?
  87. F1r Procharger F/s
  88. STS/ Formula owners ??
  89. help me decide On which on these blower cams
  90. Tr6 gap?
  91. F1-C is here...
  92. STS/A4 owners come in please
  93. 9 psi and stock LT1 ignition?
  94. Vacuum lines and gauge install Help to Newbs
  95. Anyone used a Holset HX40 turbo?
  96. significant increase in boost...why?...how?
  97. not sure on how to ask this ?
  98. Anyone ever regret going with a procharger?
  99. Who can make me an intake elbow?
  100. procharger inlet hat q
  101. Devil's Own Meth Kit?
  102. Turbo Brakestand bog
  103. Cobalt SS MAP sensor?
  104. vortech v9g
  105. PROCHARGER Questions,
  106. Jose Dr Turbo Frcefed98....Turbosmart help!
  107. D1SC owners, how much boost are you getting?
  108. Input on Weiand
  109. Sts kit
  110. Superchargers vs. Turbochargers
  111. Screw the Twins...i want QUADS!!!!!
  112. Will this cam WORK with a turbo car?
  113. finally turned to the darkside
  114. GT42 or TC76
  115. hot side question
  116. WG Flange
  117. Budget turbo kit... Who has em?
  118. Would forced induction systems fit LS2 F-body cars fine?
  119. So who makes complete turbo systems for LS1 F-body cars?
  120. split or single pattern cam?
  121. Which would you think would bettter be suited for long-term use?
  122. Hot Hot Hot
  123. just a little ask
  124. Something better than any Turbo
  125. Going FI what do I need to change ?
  126. Twincharging
  127. STS oil pump resistor failed!!!!
  128. Procharger 346ci, +58rwhp/+63rwtq with new Inlet Hat,Exhaust,+1deg timing
  129. Boost gauge stuck?
  130. ls6 intake HOW MUCH......
  131. Cooling system advice (fans?)
  132. 402 PT88 build
  133. anyone have before and after cam swap dyno charts for fi motor?
  134. Vortech self containment?
  135. Which rockers
  136. turbonetics t76 vs gt42
  137. Hypothetical turbo question
  138. 6.0 Boost Capibilities
  139. Superman09's Twin Turbo Build Thread (Turbo-Zone Twin Kit)
  140. Went and did the dyno thing...
  141. HELP! Did I mess up? power adder vs. NA
  142. truck manifold kit... please help
  143. 4" elbow and K&N
  144. sts turbo install
  145. Powerdyne install
  146. Highest CR for low boost?
  147. finally got the F1A on..
  148. Lower Compression= Safer??
  149. intercooler position?
  150. Is a supercharger without headers worth it?
  151. Biggest turbo/turbos for C5
  152. Need the best FI cam I can get
  153. Check out this intercooler. Perfect size for Camaro grill opening
  154. Innovative Mounting
  155. tried the .96 housing on my car, some interesting results
  156. Has anyone ever used this turbo kit?
  157. sts wont boost
  158. Guess HP
  159. LS2 vs L92/LS3(07 Cady Escalade) GM longblock for my turbo project. Expert opinions?
  160. Where to put the turbo...any ideas?
  161. Got car back from LS1SpeedInc...
  162. Thoughts on this combo...
  163. ct26 turbos ??? anyone???
  164. Break in the new motor?
  165. 6.0l heads
  166. fastest stock bottom end turbo or supercharged cars?post your times!
  167. 98 block safe for boost
  168. Exhaust question for the FI guys
  169. NHRA Pro Mod rules regarding turbochargers
  170. PT88 Nossle kit, 408, more pics of the camaro
  171. Mandrel Bent Piping for FMIC...is it really that important???
  172. Mufflers
  173. Anyone thought to extrude hone a 6.0l manifold?
  174. Help with crank pining
  175. Magnacharged F-body track videos inside
  176. Anyone ever tried one of these for a cog setup?
  177. Winter Mods (cam, meth, heads) HELP NEEDED
  178. Turbo guys: Tell me about your timing and CR
  179. Lt1 Sts 383 preliminary dyno numbers
  180. 122 ci Magnacharger ???
  181. Headgaskets
  182. STS Turbo/Daily Driver/Low Boost, is it worth it?
  183. APS GTO Phase 2 twin turbo system - one time deal - $5695 delivered to your door
  184. Spark plug?
  185. P1SC build with stock exhaust
  186. 07 C6 with D1SC Video!
  187. Hardline vs braided stainless pros and cons
  188. oil drain question
  189. How much boost on forged 10:1 compression motor?
  190. How many 1000 hp dreamers have had over 500 rwhp?
  191. Too much compression?
  192. will a Procharger LT1 set up work on a LS1 car?
  193. another is this a good turbo cam thread?
  194. M6=more fun than auto?
  195. mixing turbo parts???
  196. Changing Main Serpentine Belt w/ Procharger Set up
  197. sts installation booklet
  198. Ring gapping questions
  199. twin turbo outboard boat engine
  200. twin turbos + nos pics.
  201. need timing help ASAP!!
  202. STS Owners - What did you do with your IAT Sensor
  203. What is the limit of boost 02 35th LS-1
  204. spark plugs and FI
  205. New Site
  206. turbo questions
  207. OFI single LT1 dyno numbers
  208. exhaust
  209. Looking For Inside Mounted Air To Water Intercooler Pics
  210. sts return oil pump
  211. STS Mufflers III!
  212. Downpipe. to step, or not to step
  213. Info or pics on Turbo Zone Kit.
  214. Best Procharger for Street Setup?
  215. My 402 D1 vs Stock bottom #s
  216. SuperCharged Ls1- Question
  217. will this cam work with a blower?
  218. PTK owners with the NEW alt arrangement
  219. Looking for that T unit for brake booster to hook up turbo stuff...
  220. D1 402 numbers
  221. Ideas for bumper cover support on 98+ TA?
  222. Procharged guys...
  223. So Masterpower sucks right? Now what? I need a turbo.
  224. Guys With 6.0 Iron Blocks Come In
  225. Leak Down Test?
  226. charger vs turbo?
  227. Buying a D-1 from EPP
  228. Oil drain setup.
  229. Has anyone put together a complete DIY turbo guide?
  230. Exhaust temps STS
  231. Back pressure... help an ignorant fool here please.
  232. 2006 C6 Z06 Twin Turbo with Pictures and Dyno Graphs
  233. 88 single on 346, spooling questions
  234. some loose ends for my Hiflo install, need help
  235. Took a Sunday Cruise in my 8 sec IRS C5 Corvette Street Car [VIDEO]
  236. few pics of my system
  237. Top ring to use for forced induction?
  238. Twin Turbo Dyno Video
  239. leaky exhaust for sts
  240. Eboost2
  241. Need help with this SDCE pulley.
  242. TT Viper 7.98@183
  243. New valve springs with Turbo Setup?
  244. oil drain and feed fittings
  245. Got a TSB today (STS owners read)
  246. what size housings for a tt 427?
  247. 2 ques. on turbo
  248. how are you routing all your wires for gauges
  249. TTI car in classifieds
  250. for turbo apps why carb style intakes
