View Full Version : Forced Induction
- 320dw/340aero/walbro400?
- turbos vs supercharger
- Vacuum/boost line routing
- New project-twin turbos
- Catch Can/PCV question on cleanest set up
- Boost with EVAP system?
- What size turbo to fit my needs!
- do you have to run a waste gate with a turbo
- Which heads and intake
- Reverse Rotation setups? (selling YSI for forward facing)
- F/I air filters?
- Huron Speed Turbo Kit question
- any builders have a 1000hp longblock fi package for 8-9k?
- Estimated 1/4 time?
- borgwarner match bot
- 2012 ZL Camaro By Late Model Racecraft
- APS Camaro with LG turbos
- will this cam work in a 5.3
- A4 tranny with boost?
- turbo headers
- Ball bearing single vs journal bearing twins
- 700 Rear Wheel HP Unleashed Performance Twin Turbo 2010 Camaro SS #002.
- Enough Room for s91??????? Stock radiator and condensor moved forward.....
- Finally boost per mph for street, off front wheel!
- Turbo Bracket Car????
- Custom Intercooler...where?
- help what procharger to use?
- Name this Turbo...Old STS kit?
- ls3 top end guys with LQ engines?
- New Bee Need Supercharger help
- aps w/meth
- Name this turbo kit
- 2.9 whippled Cts-V on boost
- What should your tune look like to get best 60' times?
- Help with adding a whipple
- Modified stock manifold turbo kits
- vega turbo builds
- LSx Head Gaskets
- who still uses crankcase evac?
- Truck (Exhaust) Manifold Size
- Vengeance Built 2012 Camaro SS Vert-VR Cam & Whipple..Details/Graph/Vids/Pics INSIDE!
- Single port or two port for wastegate/boost controller?
- Need opinions for boosted 454 LSX
- Fuel pump and injectors 15lbs
- Power with stock TTY headbolts?
- TT Factory Five GTM Project Runs
- What size valve springs?
- 78gts vs pt88 log comparisson
- My 444 CI F1x C6Z build
- Will this cam work or suck
- PCV on a F1 LQ9
- 5.3 with LS9 cam 76mm turbo
- 60lb to 80lb Injector Swap Need Help Please!
- Need advice for 4.8 turbo swap
- GBody single turbo 5.3 and ebay obx headers. *pics*
- efi vs blow through
- 347 switching from nitrous to single truck manifold
- Ls2 cylider walls
- pck me out a meth setup.
- supercharger belt help
- Anyone use a Magnum 80mm turbo yet?
- 2000 SS APS Engine build questions
- Procharger Guru's come in....some help NEEDED for my d1 set up
- My observations and opinions of current street/strip turbo LS trends.
- Turbo AMC Gremlin
- ***Pics of new turbo***Spec my Comp Billet 80mm Turbo!
- new turbo, new heads/cam, new fuel system and MOAR BOOST!
- front mount turbo ac question
- 4500 TB and boost with hat ?
- Best machine shop near sacramento???
- 5.3 turbo question
- spec my s480 :)
- Procharger with 11+ compression
- lt1 procharger
- boost non I/C 5.3
- ****LMR 2013 ZR1 Video****
- Which is better for boost L33 or LQ4. S475 Turbo
- 2.3 whipple
- Intercooler question
- tuning and what octane fuel to use / its limits
- AES 390 w/F1A IS FINALLY ALIVE!!!!
- ms4+boost=???
- Can 304cfm heads make 900 RWHP......single turbo....
- Rebuilding APS Turbos TD06H or TD06???
- stock vvt cam and forced induvtion
- 5k rpm wall t76 370ci
- Hp twins or supercharger???
- New engine and turbo break in?
- Overtorquing Head Studs?
- thoughts on my cam.
- 2004 GTO Turbo Build
- LIMITED TIME. Huron Speed front mount single kit with fuel pump!!
- most compression with boost? (success stories?)
- TT 5.3l A/R selection help.
- Problems with 99 ls1 block?
- 87 IROC with a Magnum t-70
- Belt length
- Is a .623 intake .623 exhaust 112 lsa cam to much cam for....
- what size are the aps upgraded lg turbos?
- blow thru carb guys cfm question
- Slow spool
- 6.87@204mph drifting:)
- gears selection on an F1A.?
- Wideband bouncing around while cruising
- question
- JY 5.3 w/gt42 in foxbody
- What rings for high boost and big power?
- 4.8 and turbo from 6.5
- need advice on this cam.
- supercharge it or not?
- Sdce bracket
- 95 Z28 TT 5.3 true street. build
- Update on my whip
- stock exhaust manifolds are seriously this thin?!??!
- how do i get more boost out of my p1sc? *CAUTION* more info wanted inside
- Stock 6.0 crank and procharger guys inside
- FAST 102mm TB and intake, injector/rail question
- eBay head studs with ARP specs... ? Comment please...
- Where do I put the 2 o2 probes on my turbo conversion?
- New turbo design
- 6.0 truck 04 gto mp112 supercharger
- 2010 Whipple Camaro w/ 4L80 Swap
- Maggie Experts Please chime in
- Switching from 853's to 317s, worth it?
- How to: Adding Idler Pulley to Modular Turbo Alt Relocation Bracket
- Huron Speed turbo + PT7675 WS6
- Twin Borg Warner S472s?
- Turbo 5.3 RX-7 First Start Up!
- 6.0 cam/intake only and turbo ?
- My 6.0 front mount build
- custom grind cam not ao custom
- 2.5" or 3.0 ic pipe
- will my cam work in a turbo build?
- Messing around in my turbo car before teardown
- how to reduce stress cracks on twin mid mount setup
- Turbo 5.3
- Turbo and S/C guys, let's hear your 4l60e issues
- Boosted 5.3 Coupe New PB
- Explain this TT 375ci set-up...1100+ HP....how hot is this charge air...no IC.....
- Simple LS Swap Gone Awry (370/LS3 heads/PT88)
- How much boost?
- Intercooler?
- crank case pressure under boost
- 600rwhp goal with my new d1sc
- Trying To Build Ls1-ls3 or LQ4/LQ9 Street/Strip Motor Hopefully Boosted
- Turbo LM7 advice
- 4.8 on3 turbo
- what is the best radiator and cooling fans for a vertical setup
- Truck manifolds? Really?
- Green tops enough for D1?
- eBay twin turbo kit?
- Vacuum line Help
- Which 1000hp rotating assembly? (6.0L)
- What radiator to buy?
- Valve float 52-5300 rpm. Than no issue.
- do heads make power with boost?
- Ls7, Beck vs carys.
- Huron Speed TC78 Trans Am Build
- supercharger help...
- what cam w / blower
- Tuned my car yesterday! Turbo got damage
- ring and cam question
- Who is using these 160# injectors from Bosch?
- Can I use this old intercooler (PSJ style)? Change to newer? Chemical cooling?
- 454 LSX - Need help picking a turbo
- Need some advice - 6.0 and twins..
- I plan on turboing a stock 4.8 with stock 243/799 heads with a 76mm turbo.. CR help.!
- Add 100-150hp ... Information overload. Best way?
- Crap! Still overheating
- Killed it
- Welding vband to stock manifolds
- Warning
- sleeper turbo build
- Turbo to small questions
- ProCharger 3D Supercharger Animation and chance to win a prize
- which turbo to get? step inside
- ls6vsls2/ 04gtovs06gto
- Turbo fuel pump woes...
- lsa parts
- 5.3 truck manifold for turbo question
- Best place to buy LSA heads?
- Ebay Turbo Kit
- H/C/I guys wants to go procharger
- 5.3l lost oil pressure
- Head bolts or head studs??
- what to do for a cam?
- anyone ever did a custom intercooler setup on a aps tt kit?
- cant get my turbo car to cool, what kinda cfm do i need?
- Harris Speed Works
- shimming valve springs for more seat pressure and boost.
- LS1 STS Kits??
- 05 up LQ4 boost limits
- I know it gets old but goin crazy lol help
- will the turbo spacer and waste gates be an issue??
- ls9 cam + pac 1218 + 14 psi
- Maggie cog belt
- FI PCV System
- Critique this custom cam- turbo 6.0
- Attention E-Force dealers.....
- Opinion on a cam please
- Toyota Truck, different LS1 turbo conversion
- 5.3L boost ?
- T4 vs. T6 Which is more beneficial
- Turbo S-10
- blow through carb
- Pontiac G8 GT going under the knife for an F-1D!
- 5.3 sts???
- May run into some issues (Injectors & Map Sensor)
- Cheap good Electronic boost controller?
- What turbo kit would suit me?
- What do I need
- ***LATE MODEL RACECRAFT NEW Website***
- 370 or 408 and what internals??
- TT C6 ZO6 vs 91mm WS6 vs UGR Lambo
- Turbonetics Racegate sticking/rusted shut, need recommendations
- building my 1st turbo motor need your head suggestions
- d1sc question's
- turbo exhaust
- Magnacharger,, help with Cam?
- entertain me this, boost cam for N/A Car
- Borla or Magnaflow or ? on turbo
- Wideband before the turbo
- Turbo Foxbody fuel system ?
- I'm having boost issues
- what converter stall speed for a turbo 4.8?
- anyone running fans on the front AND rear of theyre radiator???
- spark plugs turbo drag race on E85
- Procharger bypass valve removal
- supercharger
- ls9 valvesprings and turbo?
- Need some help with fuel system (fuel cell)
- Anyone have a TT manifold kit like this??
- anyone turbo'd a 6.0 with a HX35w?
- My engine doesn't like NGK TR7's
- Compressor wheel rubs inside of housing
- Anyone have dyno / times at 10 PSI
- procharged ls1 running slow
- holset hx52/hx55
- Need suggestion for down pipe clamp or vband for percision 6265?
- c5 vette alternator bracket
- My 1969 Camaro Prostreet Twin Turbo Build!
- Supercharger..
- L92 vs. 317
- Turbo too small?
- Turbo Advice. Looking to upgrade from PT88 *COMP TURBO RESULTS*
- BruteSpeed / EPP blower cam - users!
- Supercharer or turbo
- LSA head for under $200
- Any 5.3's out there with Prochargers?
- Found an old video of my Camaro back when it had 120,000 miles on original engine
