View Full Version : Forced Induction
- whats your GAS MILLAGE under boost and not under!!??
- BOV needed
- groundzero turbos
- what do i need for boost?
- Help identify turbo
- Size of the vaccum line off the back of the intake?
- Check valve needed for rear mount
- boots lt1 or ls1
- Pinning kit for stock balancer??
- Hi-flo single turbo kit
- how to make a low cost turbo blanket/cover
- Any info on sts rear mount turbo?
- Vortech V27 YSi ??
- turbo exhaust housing
- Who makes a good 1 way check valve ??
- how will a t70 react on a Stock SB LS1?
- Converting from D1 to F1
- FI gurus, please help!
- FI-Experts: Please check this setup.
- superchargers
- Heads for boost?? LQ9
- 36000 miles stock springs
- Question about pressure leak
- Another truck manifold question.
- My Turn--So Close Yet So Far Away!
- Supercharger Sounds
- rad packaging?
- Any Quick Fixes?
- How far can you get with 16k?
- how do you guys get it passed?
- Any use DEVILSOWN alcohol injection kit? Looking for feedback.
- DIY Turbo help
- FADMIC Front Air Dam Mounted Intercooler "Save the Bird"
- Fmic ?
- Bypass Valve and boost gauge off same vacuum source?
- manual boost controller?..opinions?
- T-88 + built 346 Hp #'s??
- Swapping turbine wheel
- F/I Crew, Who has knowledge of broken comp 918 spring with less than .590 lift?
- Pros/Con on throttle by wire vs. manual throttle body in FI setup?
- Who has dyno testing comparisons of the Victor Jr intake vs LS6 style intake?
- Going F.I. This summer!
- supercharger? how much
- Any particular supercharger cam I should look for?
- What to do?
- Procharger noise
- Catch Can Pic?
- BOV placement
- Air Filter Size???
- Heads showed up...
- Need help - stroked turbo build
- Wastegate springs
- hey guys
- sts kit-electrical question
- New 408" dyno queen - 950HP @12psi
- Oil suppy/drain ?'s for Precision t76
- Air to Water/Liquid Intercoolers from ebay...
- what gears you guys running?
- h/c super vs turbo pricing?
- What turbo for single setup on 85 350 engine
- Question Lots Of Questions
- Hi-Flo Street Killer Update (includes pictures)
- Good deal!! Let me know
- Worth it or NOT?
- Supercharging performance
- Electronic Boost Controllers...
- post some 88+mm turbo install pics ...
- Comp 918s vs. Patriot Dual Golds for BLown stock LS6 motor?
- Supercharger question for experts
- spark plugs?
- A4 D1SC Done !!
- Desktop Dyno
- Question about ATI inlet hat and small filter
- Cam selection for my setup...
- where did you get your truck manifolds?
- FI Fuel Economy
- Another Vortech Question
- Fast 90 and NW TB on forced induction
- Top speed challenge vid
- For best reliabilty, should i swap out LS6 springs for Pat. dual golds on Blown Z06?
- Which coilpacks to run for boost?
- Procharger help needed
- lq9 patriot heads..compession drop..
- any one use this for eliminating belt slip?
- Magnacharger kit on LS1
- Crankcase Evacuation Kit
- MAFless Procharger question
- Stenod Performance "Red Rocket" Update
- When is water or meth injection used??
- how far can i push the tr6's?
- Which will make more power 8.5.1 or 10.1 on pump gas and boost
- Super Chevy show TT 69'
- TURBINE housing swap?
- In need of procharger ls1 Advice
- turdblow
- turbo people....what muffler???
- Max Boost On Stock LS1 Bottom end?
- Looking for a supercharger
- D1sc
- Opinion on what to do
- 6.0 gmpp single plane and PCV
- Vortech Supercharger Problems
- silicone 90* from tb to maf housing?
- header wrap
- Air filter for Procharged F-Body?
- Sorry, question on roots/screw in an FBody
- Procharger pulley help
- NEED an Oil pump for Turbo set-up?
- Procharger
- magnacharging
- turbo question
- thinkin about the future of my build...
- what is about the most HP a stock CubicInch turbo ls1 can make on pump gas
- 98 ls1 block- is it ok for turbo apps??
- moving fuse boxes - question for you turbo guys
- blowing oil help?
- best price for T76 ?
- compressor housing?
- Misfire in #2 after boosting
- Dump after turbo
- Would I benefit from taking off....
- ???'s about custom turbo set up?
- quick turbo question
- Anyone running mac's with a procharger? or USED to at that?
- mpe racing fab anyone know anything about them
- Going FI, rebuild my 427 or get a new 402?
- Progress is made, track update...
- Can you hear your Wastegate?
- does anyone have ground zero turbo kit?
- Update on my Twin-T67, 408 Build
- Bored, thought I'd post a few pics :)
- Need to upgrade MAF?
- fmic on trans am
- Vacuum line from Bypass valve to what???
- who has my old kit???
- A2W Chargecooler... how big ??
- which fmic intercooler?
- I want budget FORCED INDUCTION! How much for 5-8psi? Procharger or STS!
- where to find hot parts
- STS plus STS EBC *?*
- Few ?'s about the LS1
- mmmm heads are shipping
- Turbo ?
- Stopped by Hi Flo today...
- Procharger oil change...
- Anyone have pics of TTI Street kit installed?
- will these truck manifolds fit a lt1?
- Wideband / Narrowband A/F
- Can I have a 60-1 convertered to a T76 compressor?
- Ok need some motor upgrading advice.
- Turbo'd Do you run coolant through your turbos?
- Is a T76 too big for my car?
- BOV differences?
- Which Would You Run?
- Mock up pics of my CAS
- 4.8/5.3 turbo idea
- Loctite when installing new crank bolt?
- What do u think feels fastest? supercharger,turbocharger or Heads/cam?
- Blower pricing
- H/C combo or FI
- SD-Concepts
- Rear Pulley Sizes on S/C Vettes
- Audi story, not LSx
- Boost Ref. cutout
- pcv for SC'd 6.0 blocks
- Boost...A/F....
- 2001 silverado 5.3 6.0 heads question.
- Where can i get a alternator relocation kit?
- Fabbed aluminum elbow noise? ..ringing
- ovaled pipe for clearance?
- ATI bracket question?
- Boost an Lt1?
- Upgraded ICs for Incon kit?
- Ati #'s 5 Psi
- ATI blow off valve
- Blow-off Valve Question
- Intercooler help...
- Is a T 70 a big turbo?
- Just ordered my WG and BOV!
- Well looking forward to being in the forced induction club soon with my 99 ta.
- supercharger torque converter
- ati pulleys
- Vortech vs. ATI for cars with stock bottom end..
- what sensor?
- turbo question or 2
- phamspeed kit help?
- Speed Inc Twin Turbo Kit - Finished Pics
- need a wye and exhaust manifold flanges for o2 z28
- GMR Kit?
- ported MAF and blower?
- How do you measure exhaust back pressure?
- NHRA and STS
- Turbo cam
- WHAT TO DO TO PCV SYSTEM 4 Boost???
- Forced induction engine and internal choices?
- guys with SC and N20
- Who sells Master Power turbos?
- sequential turbos?
- STS Turbo setup
- I have two sets of heads. Which set should i use.
- FI injector ?
- Need Help--Someone to Dynotune
- Determing how many rpm's the blower is spinning...
- Loud Screeching Noise on Startup???
- Question
- How can I lower the compression on my Cartek S2 heads for FI?
- Is he crazy or am I wrong?
- F1 pulley ???????
- Suggestions for a m6 99 blown hawk
- Which would you go with?
- Meth injection: Consistant vs. Progressive
- can i get away with this?
- Guys running the LQ9 heads...
- A few noob FI questions :)
- Will my cam work?
- New 1/4 mile best today, getting there..
- corvette master cylinder ....
- Turbo--good for FM?
- Novi 2000 Brackets?
- went to dyno friday
- 408 turbo build up?
- Single big or twins?
- WTT:wilson 105mm for a 90mm
- Testing a Fast 90 or LS6 vs Victor with FI
- ATI belt is too SMALL...HELP!!!
- Help with blower cam selection
- How far are you willing to boost?????
- Congratulations Kyle!
- My New 408 And T88 Turbo Setup Pic's Inside
- Cam question on current combo...
- Can it be done?
- Teaser pics Hi Flo Twin Turbo
- Damage Report!!
- how Much ignition Advance are you at WOT?
- ? on diamond piston
- need a mean turbo cam
- wastegate maintenance?
- where to buy aluminum pipe and silicone hose? - silicon replacement?
- ls1 edit version needed
- big cam or custom rear turbo?
- W2w Shortblock....
- why so much oil befor i hit boost??
- Cam?
- Does anybody have the part # for 3 bar map?
- Is this cam to big for a turbo?
- turbo?
- What stall w/daily driven turbo setup???
- turbo question
- What are the best heads to use for my FI car?
- new turbo toy : new gen wastegate
