View Full Version : LT1-LT4 Modifications
- 396 or?
- LTCC users, where do you get the long plug wires?
- Anybody running the Hydra-rev kit?
- Sponsors: How much for a 383 stroker?
- header question
- New best Bolt on
- obd1 - obd2 swap??
- Double Roller timing set question?
- 2nd stage of the rebuild
- Delteq-Opti Direct LT1 opti spark replacement
- Broken header bolt!!!!
- fuel psi
- PICS of KOOKS and Custom Y-Pipe
- stupid question
- Have you done the LE1 or 2 conversion?
- LT1 computer tuning
- Oh MOMMA!!
- What Numbers amI looking at with this setup 383
- Jet Hot Coat Exhaust Leak
- cam in my ta
- cam question (cc305, 306)
- stroker times?
- LT1 vs. LS1
- mysterious crank
- LT1 Questions
- Shop Version LT1 Edit and Laptop 4 sale..
- cam??
- Transmission Options
- ok, almost all boltons, on, now time for the cam, but which one?? HELP!
- Show me some TA LT1 Cowl Hoods!!
- Damn Overlays Is Drivin Me Nuts!!!!!!!!!!!!!!!
- Square or flat o2 sims?
- Need Help With LT1 into Pre-Runner
- Alternator help!
- Quick Injector ?
- Questions about TQ specs
- removing engine from top???
- changed my mind for good this time... i think
- CC305 or CC503
- Auto tranny Question?
- slp ram air
- 3/8 or 7/16?
- Paint is finished! (56k death)
- '95 z28 problem starting...
- What kind of Cat-back?
- Gas mileage?
- 224/230 Cam For Sale
- Need advice on roller rockers? Which ones?
- One for the LT1 Faith
- njk tr-6
- Biggest cam on LT1?
- 94 ram air
- Exhaust Question
- rearend gears
- cam question
- Long tubes question
- Cam swap guide?
- Questions on LT4 Conv., any experienced LT4 ppl out there?
- NEW Edelbrock LT1 Intake, pic within
- Why you shouldn't always trust aftermarket gauges.
- Got bored this weekend....
- Need some advice...
- exhaust quuestion
- Still no oil up top??? Help
- Has anyone here have upgraded front 13inch. rotors??
- LT1 Wiring Schematics Collection
- How many of you use Meth?
- New N/A best today!
- Light question
- who has the best price on trick flow?
- Clutch Suggestions
- TSP Rumbler?
- wings west
- SB2.2 heads on standard block
- Torsen
- Le2/lt4
- suspension set up?
- Engine Removal Guide
- people with the GM846 cam chime in please!!!
- Control timing with Delteq
- Comp R problem
- LT4 Hot Cam and Springs
- How much does your LT1 weigh?
- replace oil pump
- need cam install help quick!!!!!!!!!!
- I killed it...
- What size injectors?
- how much nitrous??
- Where to put the Cats???
- manifold glowing red
- Gas tank question....?
- anyone with single chamber flows, got a question
- Is this cam good for daily driving??? specs inside
- Roller Rockers
- What size cc's are LT1 stock heads?
- Base coat = Done! (56k warning!!)
- Newbi 383
- C/950 ECM + Delteq? Is it possible?
- Updated LT1 setup pics!!!
- newb LT1 question?
- CC305 Question, Setup.
- lt1 straight pipes
- QUestion need help fixing.
- stock T56
- ASM Throttle Body vs Holley 58MM Throttle
- Cant decide, want 11s
- Car wont start!!
- Airbox Placement Question
- Losing power and MPG help!!1
- Another High RPM miss thread...
- Delteq Ignition system
- how much boost on a stock Lt1?
- 1/4" line sufficient for stand alone fuel system?
- need help and computer
- bbk intake manifold.....
- LT1 True Duals? - Help A Newbie...
- rebuild or crate motor
- 396 LT4, what do you guys think...
- LT1 Stroker Guys In Here!
- what should my next mod be?
- 400+ horsepower
- Edelbrock shorties
- B Body
- ss intake
- Vortech Horespower
- So, I failed inspection because of a broken hi-beam headlight and a non-working horn.
- Threads stripped on head advice please
- granatelli mass air
- le1 or le2?
- Those of you with Gm847 & CC306
- doing LE2heads GM847..can I start my car on stock tune..
- Is this possible LT1 to LS6
- About to order the Meziere Electric WP...
- Should I Get the LT4 Cam??!!?
- Can't find after cat o2 plug *HELP*
- intake manifold for lt4 style heads
- 4000 $ what to do!
- 383 Estimate
- White Face Gauges
- Ported TB's
- Dyno #'s estimate
- Horsepower Estimate
- Leaking tranny fluid all over...
- Exhaust Pop at 5000-5800 RPM
- cam swap?
- 1997 t/a 02 simulator help
- narowed rear
- Torque specs
- Video of my cc306
- ASP Pulley, 23% or 34%???
- Some headers
- Upgrade For Opti-spark Any Good???
- short throw shifters
- super street fighter
- No Oil Pressure!!!
- Quick Header Performance Question
- Who wants a new LT4 firehawk
- 396 stroker motor. Whats next?
- cam budget question
- car running hot but no circulation?
- Ideas floating around
- Whining noise
- old vids
- Pulley Gains???
- 355 Rebuild Dyno numbers
- o2 sensors questions
- Those of you with the Delteq ignition
- cam and stock convertor
- Lt1 - Lt4
- homemade turbo kit...
- cutouts... good or bad
- Programming
- Need directions to changing brake pads and rotors
- looking for budget short block
- Edelbrock mid length headers and custom Y pipe
- who has the best price?
- 42# Ford Injectors
- LT1 in a S10 needing acc brackets!
- I have a throttle body ?
- AIR Plugs, what size?
- Which exhaust system???
- Horsepower Speculation
- Do headers give better gas mileage?
- stealth nitrous kit?
- Damn, what should I do?
- Best Lt-1 clutch
- am i missing something or is this stupid high?
- F/S Lt1 heads and stock T/A hood..
- Progress so far...
- spark jumping maybe??
- Hotcam and programming
- What all is performed in a "tuneup" and how much does a shop usually charge?
- Borla Cat Back, well almost.
- proper LT1 break in
- Engine pull - B*tch is stuck!
- New Lifters?
- Bad lifters?
- power numbers??
- Tryign to figure out where to put gauges, need help?
- clutch decision... HELP!!!
- Crower lifters
- LT1 Engine Bay pics
- LT1 even worth modding?
- 94 Z28 Stalling Out
- What do you guys think about this 383 z28 should i buy?
- Do I need to send my PCM or just the chip to a tuner?
- I would kill for this...
- CC306 stock converter A4?
- Forged Pistons?
- From park or neutral when I shift into gear, I hear a rattling sound.
- Crane Cams
- Head & Cam Removal Guide
- Oil Pump
- stock fuel system with big shot
- PCMforless questions!
- Lt1 t-56 for sale
- Sucked up water?
- car wont start!!!!!!
- Cranks, won't start
- What heat problems would I encounter with having Edelbrock shorty headers?
- hot cam
- Car still won't shift!
- advise on bottom end and H/C
- car problems need help
- Oil Pressure???
- I need CAM info!! :)
- Smog/air pump removing.. alt and radiator reloaction.. then turbo
- big rubber insulation peice under dash on firewall
- News on the Comp Cams Extreme Energy Cams?
- Race Gas 103 oct. on Stock Motor
- hypertech
- Major Engine Problems
- Pacesetter Install
- Best Monoblade TB for LT4 intake?
- Local Houston Sale: LT1 heads, JetHot headers & GM-847 cam
- DelTeq vs. LTCC
- flex plate and starter
- advise for short throw shifter???
- 355 specs?
- question
- Low Coolant Sensor
- Delteq and nitrous install :-D <---makes me very happy!!!!
- Who makes off road y-pipe for 97s?
- PLEASE HELP oil pressure sensor busted!
- Whinning Noise, anyone know???
- delete ac on lt1 what belt size?
- pacesetter midlength question
- Gas Mileage
- O2 sensor wiring help
