- back to the dyno... again, 1055rwhp
- Blow-off into turbo better than atmosphere?
- New 1/4 mile best today
- Failing fuel pressure under boost.
- Nothing too exciting to talk about yet had some problems...
- What shortblock for a turbo project?
- Comp 918's or stock springs?
- Turbo, 60# injectors, cam, Idle issues.
- FI newbie ?'s
- NGK-8s ??
- procharged car making alot of heat under easy driving
- Few questions on STS kit.
- Anyone relocate power steering?
- can too low of timing under boost cause detonation?
- APS Twin Turbo....thoughts???
- H/C ZO6....possibly going F/I ????'s
- Best true bolt-on FI Kit?
- 408/stock heads/88mm turbo at 24 psi = 920 rwhp
- Pukes
- where do you guys start to tune your boosted setup
- Install Vortech supercharger how long?
- Twin Turbo dyno results....
- Vac source for boost gauge
- ways of spooling a turbo faster
- Installed procharger and no boost
- Dyno Numbers
- Custom rear mount guys what oil scavange pump ?
- Trt Turbos
- Placed an order on a LME 408
- should i turbo an LT1 or LS1. (limited on $$$)
- Intercooler over Meth for STS??
- MTP T70 Exhaut AR ?
- Rear Mount, How does it affect sizing
- Found my boost leak
- Best engine parts for FI Type Engine
- reliability questions
- FI M6 guys come inside!
- any body tried the Evans water pump to help cool your boosted setup
- Max Spark Advance @ 7-8psi???
- ATI ProCharger Friday the 13th Sale at Exotic Performance Plus!
- Wanted - 2002 Pontiac Trans Am for twin turbo system development
- do prochargers like peak timing before,right@,or after peak TQ
- Found oil in charge line of STS Turbo
- cant find sc pistons for 3.908 bore?
- 8 rib belt question..
- Roots Type for the ls1?? Manifold base plates?
- Which piston? Pick one
- Post your dyno #/ ET/ MPH
- How do these bearings look?
- Making a custom Turbo setup, Tell me what else i might need!!
- Lighting supercharger????
- how cool is meth???
- STS guys (come inside)
- stalled a4 turbo
- How restrictive will stock heads be with a procharger D-1SC
- Max power out of T76??
- Looking for specs and info on use of restrictor plates for Vortech S-trim
- procharger timing...
- intercoolers
- Video of me breaking my car
- Boost Time????
- hummer h2 with sts turbo , need help
- Hope I picked right!! ordered a new blower cam today
- Help me get a parts list for a twin buildup
- Car breaking up at 5,500 RPM Please HELP
- Help me decide
- Twins completely plumbed
- Harlan 2 step install question
- TE44 get the boot hello new turbonetic turbos
- finding how much timing i need on a d1sc car
- Anyone need a 71MM??
- high hp turbo timing/fueling help
- Procharger guys with Alky injection
- Which is Better F2 or 88mm Turbo
- I got the wrong pistons in my shortblock, can i change the combo to make these work?
- Magnuson Supercharger's 3/36000 Powertrain Warranty Info
- more head gasket fun!
- guys with relocated alternator come in
- What Motor Build should i look into?
- Machine gun before full boost?? turbo
- D1SC Back from the Dyno!
- Is anybody running the intercooler spray bar?
- granatelli with turbo?
- oil return ???? on STS kit
- Head Gaskets
- T-rex inline pump on stock engine?
- Turbos and catbacks?
- OFI will take orders agian begining of NOV...
- where to buy stock 317 heads?
- having a hard time idling... i have a log and a bin
- DTE/APS Twin Turbo C6 Corvette Results- 10.89 @ 129
- lifters
- Best turbo for Corvette
- electronic boost controller
- Not forced induction but I thought you guys could help.
- bout to start a turbo project
- Fuel flow requirements
- Search dead/Corvette single intercooler
- Fast intake worth it on a turbo setup?
- Replacement sensor for DJ Wideband?
- PurEvl track times
- Is it easy to reach around 500rwhp with P1SC?
- twins and intake dyno....(long)
- Help!! car stumbling on dyno
- best cam
- Got some new dyno numbers
- pistons and rods
- Stock ATI 16" Camaro fan needed.
- LS1TA guys with OBX intercooler have ??? about front bumper
- test runs and some loading up questions?? Turbo guys?
- What is normal idle vacuum?
- New best and then BOOM ***videos and pics***
- Finally Got Her on the Dyno.....
- Turbo cam???????????
- STS Kit... YUCK!
- YS + YSi Lets hear what they can do!!
- 02 turbo ws6 34k what is it worth
- frustrating situation, can't make more than 14psi
- Tial 44mm Wastegate issue, HELP!
- I'm finished...
- New best and Broken stuff --Advice Please
- Prelim HI-Flo Dyno numbers ***
- Supercharged C6 Video
- Ran the car today, new best.....
- Problem with GM PN 12580698 2 bar MAP
- New Best STS (1/8)
- Bypass Valve Question
- New personal FI best, 10.63 @ 132.8
- TB for FI?
- What CFM does a 90mm FAST TB flow?
- Stock LS1
- Magnuson F-body dyno results
- Tom K >>> 8.08 on drag radials video
- Finally in the 5s in the 1/8..
- looking for a tune/tables from a blown 408.
- World Street Nationals in Orlando Oct. 27-29
- PCV Turbo Venting!
- Procharger or 408 engine build?
- Pully seal on Vortech leaking
- Picked up my new heads today!
- figured out why it runs like a dog
- sts turbo cam
- anyone know who owns this beast?
- Managed to get the Formy out...
- F1 or F1-R on 8.5:1 383 LT1??
- turbo ls1??
- Found some boost leaks, how much could I be losing?
- Just got back from the track..... (yay!)
- sts intercooler question
- High Octane
- with stock motor and setup,..What would the differnce be going from d1sc to a p1sc
- which best cam ??
- anyone ever tried this?
- LS6 Bottomend Safe Limit
- Hey Kyle, is this your car?
- Pics of my new setup...
- Speed Inc Eliminator Turbo Systems Kit
- Twin Turbo or Single?????
- How to get a pair of 3" pipes over the K ?
- some issues- need some help fast-
- Superman has parts on the way!
- sts turbo setup w/ my mods?
- Where to get FMIC Piping for Procharger???
- Little Twins action
- Considering Custom Mid-Mount - Need Turbo Suggestions Please.
- Boost Controller Hook Up????
- Installed a bigger housing on my T76
- Pinning Crank...ATI guys
- my custom procharger inlet with thick Be-cool rad
- T67 and methanol: predictions? Jose?
- What thread is oil feed on a ITS turbo ?
- ..turbo charger/super charger..what do i get
- Incon 9.93 at 141mph vid plus blowing off the 325MT DR's vid.
- KB on a f body if new hood and cutting is done???
- Dyno Queen #s, Final 3bar SD @18#s
- V band inlet exhaust housings???
- Does this sound right?
- Procharger guy's inside
- Questions for the turbo dudes!
- ic mounting location?
- LT1 Procharger on a LS1
- Tracking down exhaust leaks
- Power gain going from 93 to 100 octane
- i need help with this setup? (wastegate)
- i need a bov!
- line connected to passenger side of TB...?
- How restrictive is it to run stock manifolds?
- strength...
- How loud are open downpipes
- Looking for advice on Stall...
- can anyone explain these Z06 dyno numbers....
- What causes some turbos to be loud and others to be quiet?
- Boost.
- LT1 2nd Gen RX7 Looking For Boost :)!
- faster @ 1/2 to 3/4 throttle than @ full need help
- Cometic .120's
- best palce to buy fi forged shortblock
- T76 front mount
- Supplies?
- Compund og BI Turbocharging
- 1/2 inch head studs fo boost 900+
- ATI SC users with Larger Filter setups in here
- Looking for the magic 500RWHP w/Vortech.
- How to:
- Need some fans.... Twin Pushers, questions!
- Trt Fmic
- Difference in units
- Anyone running a KB twin screw on a LS1? (Vette guys I guess)
- Belt Slippage?
- When it comes to a front mount turbo, what is the best way to go with headers?
- poll on stock ls1, sc or sts setup
- 8:1 or 9:1 comp
- How loud can P1SC be????
- gonna get BLOWN
- twin gt28rs...what do you think?
- Qyestions about methanol injection(boost cooler)
- crank
- quick pcv question
- Turbo Blazer Pics And Vid :d
- Ran the TT Chevelle on Tuesday.
- magnacharger
- New 1/8 mile best Friday night
- OFI Single f-body kit with a 80mm T6
- Anyone own GMR twin kit
- PCV/crankcase Evac with Drawings, need Help
- Getting ATI crank pulley off balancer?
- Streetable long term turbo setup?
- Forged LS2 Bottom/L92 Top w/ D1sc?
- worth it to reduce exhaust to 2.5"?
- New Dyno Numbers!
- So I am installing my PTK
- Help me with what Im not getting?
- Formula? Boost vs HP gain??
- Critique my FI rotating assembly
- Could the AC be used to cool the water in a air/water IC?
- not sure what this sts part is???
- Rear mount turbo goes 10's :)
- Zombie ss finally went 10's...
- Does anyone make a crossover for truck manifolds?
- well, im getting blown!
- ATI shroud/Spal 9" 30100452
- Lowest psi springs for Racegates? Anyone have any laying around??
- Finally!!!!! in the 10's!!!!!
- Turbo Car Restrictive Exhaust
- t74 build ???
- How finicky are wastegates?
- Hp ?
- Define "useable boost"
- need to buy Pulley and Belt, need info
- Need help - Boost or H/C paclage
