View Full Version : Forced Induction
- How to choose gear ratio with current setup?
- My head is spinning!!!
- Trans Am front mount turbo/rear exhaust Q?
- I just put a MSD 2-step in
- Finally started the twin turbo project!
- Turbo A/R vs Elevation vs Spool time affect
- The infamous Turbo whistle...
- pully question
- What gears?
- Tru boost setup help
- Which gauges are you guys running?
- FI Cam spec review
- remain turbo or go N/A?
- STS Turbo setup - question on Cats
- open downpipe
- LS2 or LS3 which one for boost?
- Professional products typhon intake
- not getting enough boost question
- 2nd stock longblock into the 9's!
- Is this the correct fitting?
- Just a few teaser pics
- paul major crashes bad!! Pictures and video!
- Is an L92 block ok to run under moderate boost?
- What valve covers and what catch can?
- Help with LS3 air build!
- whats really needed?
- Hot side Fab Construction questions
- Discussing "PSI" should be a ban'able offense...
- New to Turbos
- Meth injection??
- 5.41@125 with a 1.24 60ft on radials with a APS kit on formula
- New Best with the Ebay kit! 10.64@129
- blow off valve question
- boost sensor for LM-1
- 5.3 nova swap
- LS2 402 or L92 418?
- Anybody use a JGS Bov?
- Sts guys
- ***Cartek C5 Vette 8.98 at 158 (Video)
- Rpms to spool Turbos..Any spec sheets?
- How much are those mods worth??
- Maximum boost.
- Need help identifying procharger bracket, QUICK please
- Turbo M6 to Auto Swapers come inside!
- headstuds
- Procharger guys, boost vs. gearing
- ECS 347ci Novi 2000 Stock LS6 Heads/powerglide ran 8.7@154mph
- what kind of power do you think this turbo motor will make?
- Budget build info wanted
- My vert turbo camaro project
- New 1/4 mile best today
- F1C siezed on me today. Anyone send their blower in to Procharger?
- GT4202 LS1 camaro goes 10.55 @ 130 new PB
- New best 9.04@154!!!!!!
- My 5.3L truck manifold DIY turbo setup
- What cubic inches for d1sc
- Thinking of selling your K member for the new BMR APS?
- AN radiator hoses?
- Question for the tubular turbo manifold guys
- Should I dump my 243s for 317s?...
- Help me choose turbo setup!
- Cablebandit new best.
- 434 with L-92 heads?
- Another great night of racing at PBIR. New PB.
- Heads: 317s vs 243s
- Tapping oil pan
- Phil Thomas runs 4.70 @ 164-one bad LSX
- Turbo LS based Fox bodies?
- BBC vs LSX blocks
- Intercooler ambient air flow TRANS AM
- What Should I Build?
- What can I replace my MPGT45 with thats bigger??
- Front mount intercooler LSxTurbo S10
- what intake!
- Ultimate Street Car (On A Budget)
- LMR new drag radial car ever come around?
- procharged t/a 7psi.. question.
- Best motor for boost
- LS1 ECU & Coils on my Turbo LT1
- Best price for 80 or 88mm????
- Building Headers 101
- Ok to run open DP for tuning?
- 98+ camaro intercooler mounting?
- 402 F1 Procharged, what oil?
- Need a 6 rib procharger pulley<3.85
- Exhaust Set-up with 3.5+ downpipe?
- Vid of my cars 10.001 run on Pass Time
- Procharger help
- Renegade 116?
- New Edelbrock TVS Superchargers at Sema
- looking for a good fbody turbo kit
- Project Turbo LS2/350z begins.
- Kyle's KY-Turbo Tube Header T4 Hot Parts "Non A/C"
- Looking for Single T76 or T78 Kit for 04 GTO
- Back in the 9's and it isn't cold here yet.
- C6 LS3 maggie install
- Twin turbo'ed Rat Rod?
- 3" downpipe on pt88?
- 402 and d1
- fuel pump recomendations
- looks like my car is going to be on pass time
- Radix Magnacharger + Heads + cam ?
- A few questions on what size bov, wg, and intercooler for t76 street car?
- 42lb duty cycle of 115% at only 0.5bar - possible?
- made new inlet piping for my f body ls1 aps turbo kit
- 5.3l dish volume??
- Anyone make a prefabbed hotside using C6 Manifolds
- What switch panel for tbrake, 2step, and line lock?
- Help! AFR 225cc. What springs???
- Would you run this cam?
- Will the Bmr turbo k-member work with an OFI kit?
- please help
- Spark Plug/Oil for my setup?
- Twin Turbo
- Questions on a 5.3L Vortech SC build up
- help with pulley vs RPM
- Please suggest timing curve on WOT
- Breaking up in the higher rpms?
- Oil out of dipstick tube question
- manifolds/headers to keep A/C
- at what boost level does GT-60 turbo max out?
- Anyone have a 6 rib Procharger Idler pulley?
- Who is running 10psi (or more!) on a stock LS1
- 2in arh
- Pics of new BMR K member for APS guys with install pics
- Turbo & Lingenfelter GT11 Cam??
- Few FI questions
- backed up my 9sec run(TT Typhoon)
- Quick manifold question?
- rx7 5.3/TC78, 9 sec pass
- what rings? stock ls1 7-9psi
- Intercooler piping help
- Road work = Doom - help!
- APS Kit goes 8.57 at 154.47
- Air to water intercooler for twins
- hobbs switch... which one to use?
- New video's of my Turbo SS!!
- Steve Turley at Orlando
- Intercooler... What one?
- procharger
- diffrent radiator placement????
- car overheated, weird cooling fan issue
- What block to run for FI
- 60 trim vs 67 trim
- Thiking about switching power adders
- Headers on FI cars
- D1SC F-Body Kit Question.........
- Video 9.71 @ 157 C5 427 TTIX 6 speed
- How much vacuum do you make at idle?
- Steve (BLNLS1/RX7) goes 9.72 right off the trailer Wednesday night at Muncie Dragway!
- Speed density and auto transmissions hear maf is needed or transmissions get damaged?
- Denting the downpipe..
- L92 w/ GM cts-v s/c?
- 2002 Z06 cam in 402FI???
- Starting the maggie install on my SS
- 38mm or 44mm TiAL Wastegate?
- if you havent seen a 91mm T-4 turbo (trick or treat)
- Third gen 5.3 guys lend me your knowledge
- EPP LS1 F Body ProCharger Cog Drive & Assembly Directions
- Custom Rear Mount Questions
- do you really benifit from ported heads with FI?
- Supporting mods for 91mm turbo
- Magnacharger vs Procharger
- ...Just got my STS tune numbers : )
- single turbo header?
- turbo/ procharger preference daily driver
- Direct Filter for D1SC
- Turbo Cam Basics...
- custom cam for tc78 370 setup what do you think?
- Good place to buy turbo???????????
- ls6 or tr224 on a turbo 5.3?
- 02 sensor question
- How To Hook UP Manual Boost Controller On STS???
- questions about aps tt kits
- Heatshielding for motormounts, lines, wires, etc..
- Last chance for vac kit and free torqe arm
- Sts guys, little help please
- EPP FI cam users inside please..
- Truck manifolds, stock k-member and 4" downpipe?
- Help with build
- A/C heat question
- 1300rwhp Vette
- What do you think of these manifolds for turbo?
- Am I the fastest APS car???????
- Is it safe to use stock IAT sensor? Can it react fast enough?
- So im thinking about boosted.
- port matching Victor Jr. manifold?!?
- KY-Turbo Inc. is Sponsoring LS1Tech "again"
- where can i get turbonetics gtk's
- Edlebrock pro flo xt
- Snow nozzles in a TNT power ring!
- 5.3 turbo guys in here plz
- Maggies here ready 2 b on fbody
- do i need to brace the turbo flange?
- car vs truck accessory location with turbo?
- TT Typhoon 9 sec video
- A/A intercooler to support 1000rwhp? Will eBay 4" unit support this....
- C6 exhaust manifold flanges
- What turbo for lq9/4l80 in 4700lb car?
- AIS meth kit summit line lock
- Highest Horse Power Numbers using a ProChargers D1SC
- Stock LS1 with 317's
- carbed 5.3 turbo??
- Is anyone else liquifying the poly motor mounts with truck manifolds?
- Install instructions for QMP turbo kit or TTI Street kit
- FI cam selections???????
- might have an alternative for the F body aps guys with bunk turbos
- New best 9.133@154.97!!!
- Rear mount turbo can I run headers?
- Radiator Supports
- what belt size for my procharger pullys?
- Help Choosing Turbo
- STS kit anyone?
- SOOO close to the 9's
- New inlet hat is in
- TT LS1 typhoon single digit pass!!
- Critique this cam for blower application
- f body guys looking for turbo headers
- Replacement for my Snow Performance Meth controller?
- Notching the s/c pulley?
- 106mm price please .
- Anyone make an Alternator reloc. brack for LS2 GTOs?
- Turbo calculation question?
- Boost psi vs. displacement
- Bad custom twin turbo install
- new prochargers can be ordered with helical gears=quiet
- Is it worth it
- 9.63 vid.
- Need ideas for turbo placement. Twin Turbo
- What size stall for D1SC?
- What motor should I build for my procharged gto
- Got some new numbers with the D1SC
- New best after Valve spring install.
- WTB - ProCharger 10 rib pulleys
- Does anyone know the difference between the LS1...LT1 STS kit?
- Maxing out the Novi Project
- new acc. tensioner set-up with pics
- 110% F1R blower speed with Cartek Flip Drive 2
- Anyone using the CryO2 system?
- What A/R for rear mount TC78?
- Sts Oil Restrictor Question
- does this sound like the right belt for my procharger?
- 402 F1C results. 8 rib belt
- Here is a couple of dyno video's from a car that I just helped a friend build!
- Large frame turbo guys step in please.
- Is a 90mm Throttle body worth it??
- Boost goal ?
- l92 heads lifting???
- couple of supercharge questions
