View Full Version : Forced Induction
  1. Intercooler
  2. procharger bearing sound
  3. Outlaw 10.5 Dyno Run
  4. PTK street/race setup
  5. building my own turbo kit...
  6. Question for a friend...
  7. I want to build my own turbo setup.
  8. Will my SyTy turbo work with LS1?
  9. Post pics of your Twin Turbo setup!
  10. turbo controller
  11. Highest Dyno for Turbo Tech Street Kit?
  12. Which Wastegate / BOV ?
  13. Why does Vortech get such a bad rap??
  14. Whats up with Magnacharger?
  15. Anyone Boosted with 2.73's?
  16. Twins for a LS1, on a budget
  17. boost question and twin turbo!!!
  18. Custom Aeromotive Fuel System for STS Pics
  19. Turbo and auto
  20. aluminum vs iron block
  21. 500 to 600 RWHP WTF
  22. Any STS users experience misfires after install??
  23. 408 Turbo Headers??
  24. This guy must be kidding
  25. Powerdyne XB-1A Upgrade
  26. Wormboy's car (Video)
  27. ???402 with a turbo question????
  28. 2001 truck stuck
  29. Any results with the ptk turbo kits?
  30. Boost guages. Which one?
  31. finally some videos of Boostaholic's tt camaro
  32. stainless steel turbo headers
  33. Anybody have a sound clip of a procharger and sdce setup
  34. oil pan help
  35. 918's on mild (550) lift at 16 - 20psi.. will it float valves?
  36. PT76gts vs GT42 76 and more...
  37. How much is the ATI Super Damper
  38. 500-600hp Range
  39. turbo-cats issues
  40. nx-sprayer + meth inj on turbo ls1 good or bad?
  41. What can I realistically expect from this Vortech?
  42. possible with 4link?
  43. Ever had a Mondo Bypass sticking Open??
  44. turbo 408
  45. Catchcan setups with F/I
  46. what would happen?
  47. Procharger sound
  48. pt88+408 dyno vid
  49. Supercharger and Turbo Specials!
  50. a 700rwhp capable turbo system setup.
  51. can a stock ls1 take 5-7 pounds from a turbo?
  52. STS owners in or near Pittsburgh PA...
  53. Tial 44mm wastegate flange and clamp
  54. what's the quickest anyone has gone in the 1/8th on 12psi???
  55. High or Low compression?
  56. Video footage of my car
  57. procharger or sts?
  58. Will the ATI 6-rib crank pulley work with a UD pulley?
  59. belt breakers
  60. boost options
  61. Special thanks to Mike at Next Level Performance
  62. Diff. in AFR from no Meth to Meth on boost?
  63. lt1 turbo question
  64. STS (F-bod)guys, What kind of ETs are you seeing?
  65. E Boost2 Guys...MM, Cablebandit.......
  66. turbo catback?
  67. Big Flames from exhaust on Procharged C5
  68. Which sounds better
  69. Very Odd Idea
  70. Turbo Headers? Cost and who
  71. which cam for turbo?
  72. STS kit what else?
  73. Question about installing A/F gauge
  74. how much will my FMIC block the radiator?
  75. 2-3" cutouts or 1-4" cutout for turbo setup
  76. Snow performance GM maf kit?
  77. Flipping exhaust manifolds
  78. STS runs and issues....please help
  79. Alternator & Downpipes
  80. What pulley sizes for F1R?
  81. a4 turbo blow off?
  82. Vortech guys - balancer issue here.
  83. Got some Motor/Turbo pictures!
  84. STS set up?
  85. GTP blower? Not the question you think it is....
  86. quick FI question #2
  87. GREDDY boost controller problem-STS kit
  88. Procharger inline pump... specs?
  89. 9sec 93 octane setup?
  90. Belt shredding problems
  91. anybod have any 3" 90's -pipe not couplers- left over to sell?
  92. |Congrats to Speed inc and hugger orange!!!!
  93. Intercooler for a PT91..
  94. Is 600rwhp realistic for my setup?
  95. quick FI and N20?
  96. Catch Can With A Vortech??
  97. Thoes with a turbo/supercharger and an Automatic in here
  98. Turbo Differences
  99. Pin kit for a 6 rib P1SC?
  100. SDCE set up with ATI damper
  101. Bad O2s = Lean??
  102. some turbo ???'s
  103. GTO/ Light Truck turbo system inquiry
  104. can I dump turbo oil into the valley of the motor???
  105. F1/F2 Procharger question
  106. Built a dual nozzle alcohol system
  107. How much did you spend?!
  108. LEAKING Under Boost?
  109. Its finally here
  110. Where to buy ATI procharger
  111. a lil help here getting started guys
  112. Where is the fluid plug?
  113. relocating filter on ati is possible.
  114. STS IAT location?
  115. Headers Wanted!!!!!!!!!!!!!
  116. Belt came off!!
  117. High RPM torque on truck intake manifold
  118. 157 MPH in a turbo car!
  119. Undecided on gauges
  120. Need help deciding on how to go
  121. oil feed fitting.
  122. supercharger and stock bottom
  123. OBX users
  124. Where to buy STS turbo kit in NJ PA
  125. Which turbo kit?
  126. Going Forced
  127. still learnin n need help
  128. Pulley change?
  129. what kind of pumps are being used for scavenge??
  130. !!!!!!!!!!!!new Part Coming!!!!!!!!!!!!!!!!!!!
  131. Pro-M MAF
  132. STS guys, have you switched from manifolds to LT's or vice versa? What difference?
  133. downfalls to low compression?
  134. Anyone going to...
  135. TA Nats Drags
  136. Any Recomendations on Piston COaters?
  137. Will I need a different MAP sensor?
  138. Nasty Performance Sheet Metal intakes
  139. This is stupid
  140. A few Procharger ?'s
  141. phamspeed/GZM factory manifold kit.
  142. Your opinion on this T4 flange...
  143. 402 Twin Turbo
  144. BOV open at idle
  145. Low compression 408 break in..
  146. ? about difference in Prochargers from different years
  147. launching a turbo car off of a transbrake...2-step or not???
  148. what is needed with Forced ind..:low compression heads ,fuelpump ect...
  149. Will a 160 thermostat lower iats at all?
  150. Vortech Superchargers On Sale! Plus You Could Win $250.00!!!
  151. 2 blown C6's
  152. How much Hp will I gain?
  153. Upright radiators anyone?
  154. Turbo news 8/22
  155. got a problem with my vortech...
  156. MM here is that PTE88 race kit forsale on ebay
  157. Did anyone get valve float with PR dual springs.
  158. My thoughts on rear mounts...
  159. Trade for FMIC?
  160. Turbo or N/A w/Nitrous
  161. Is there a 2.5 bar map sensor??
  162. G5X3 with D1SC? Opinions needed....
  163. SES light Blinks then stays on Help.
  164. ATI 4 WS6:Help Please!!
  165. White Firehawk on boost for sale on EBAY
  166. What do ya think???
  167. look whats going in the car tomorrow
  168. Some Phamspeed install pics
  169. CAS TT update....fab work is nearly finished! Pics!
  170. WHY are heads not as "important" with FI?
  171. My 625 dyno graph
  172. what torque for head bolts?
  173. LS6 SSR with radix kit
  174. Looking at getting a charger have cam question
  175. NEED STS Wiring info quick!!!
  176. Banks?!!
  177. Best Magnacharger Cam
  178. suggestions on water temp gauge?
  179. New Ic Mounted
  180. ugh... I need a new wastegate
  181. Cracked manifold
  182. Is this setup looking alright?
  183. Trying to clean out extras...
  184. Turbo cam selection 101
  185. ATI Guys: Are you running your air pump?
  186. Power difference bt 71mm&76mm Hi Flow
  187. My New Ic... Will This Hurt Anything
  188. Belt question
  189. Advantages of a upgraded BOV???
  190. Turbo my 383 FWD! All welcome.
  191. lt1 roots type superchager
  192. Poll: Heads/Cam or Supercharger
  193. phamspeed guys here!
  194. Boost cooler?
  195. Ballpark cost for Single Turbo in Fox Mustang LS1
  196. Phamspeed budget kit?
  197. Dont Be Scared
  198. Are there any single turbo kits out for a stock gto?
  199. I think hardcore needs to update their web page
  200. New D1sc Bad Oil Leak
  201. Maggie I/C pump flow ?too much?
  202. Photos from W2W open house
  203. Cars done! Video and dyno #'s inside
  204. Magcharge/Nitrous
  205. Anyone got FI on a F13 cam car?
  206. the right turbo cam
  207. Boost Creep Bad?
  208. Thinking of making some changes to my setup, tell me what you think
  209. Vortech help??
  210. Anybody know anything about HP Performance?
  211. Stainless braided power steering lines
  212. Turbo 101 changes
  213. taping turbos for boost nipple
  214. JohnsonRacing-Turbo camaro
  215. looking for vortech and intercooler pics
  216. Stenod Single Turbo Project Update Pics Round IV
  217. ATI big intercooler questions
  218. How did the old "Q M P" Turbo Intercooler mount?
  219. Hi-Flo Turbo "Street Killer" Preliminary Pics
  220. which one should i get?
  221. Anyone running a vacuum pump??
  222. Recommended turbo upgrade for rear mount for 402
  223. D1sc tuned VE
  224. Where to Tap in & run Boost Gauge Line Through Firewall?
  225. turbo and auto trans.. need boost quicker
  226. FAL fans question
  227. Procharger D1SC tuner guys in here please.......
  228. T70 vs. T76... when to use which one?
  229. Has anyone built a ????
  230. T76 rear mounted setup at 14 psi dyno
  231. Anyone have a stock ATI bypass valve for sale?
  232. Anyone relocated your stock fans to the front of the radiator?
  233. D1SC:mail order tune/predator/HPTuners
  234. 15-20psi w/LS6 egr plugged?
  235. Area under the curve on stock cube vs. Larger motors...
  236. what front shocks and springs should i run need to rasie up
  237. What brand wastegates are these?
  238. Boost a Daily driver?
  239. Guys, this isn't a CLASSIFIEDS forum...
  240. Boost difference between 2.95 and 2.75 vortech pulley
  241. VP C16 versus Sunoco 117?
  242. turbo book??
  243. How does PCV effect detonation
  244. ls1 sts guys
  245. 38 lb injectors enough for powerdyne?
  246. need advice from people with Vortech exp
  247. max psi with just a front mount intercooler...
  248. can you beef the 346 enough?
  249. where to buy flexible hose for ati intake?
  250. ATI owners: opinions please..
