View Full Version : LT1-LT4 Modifications
  1. Need advice...
  2. 32valve LT1 Progress...
  3. CSR Electric Water Pump
  4. Plugs and Wires
  5. LT-4 Mods
  6. Can you use "used" splayed caps?
  7. new setup, ET results and pics! Crank trigger rules!
  8. Looking for people who own(ed) PaceSetter LT's/Y-Pipe. (College budget setup)
  9. piston choice
  10. Help Not Sure what's wrong....Clutch, trans, hydraulics?????
  11. Waterpump
  12. MSD LT1 ignition question?
  13. My 383 Build Pictures for anyone interested
  14. 355: What is needed etc?
  15. Gas Smell... uh oh...
  16. brand new MSD cap and rotor....still not working
  17. Intake powder coating, Is this guy lying??
  18. Fastest Stock Bottom End N/A LT1
  19. looking for feedback
  20. 355 vs. 383
  21. tall valve covers alternator!!
  22. valve springs
  23. HELP with my V-2 Vortech Supercharger
  24. Midnight street run...tested the crank trigger ign.
  25. Low oil pressure at idle
  26. low oil pressure at idle
  27. Back from the track
  28. Will the LS2 fit 4th Gen F bodies???
  29. Vibration at high RPM'S?????? HELP!!!!!!!!!!!!!
  30. 94 trans am
  31. New LT1 Owner-Any Suggestions Welcome
  32. LT1 guys lookng for another urbo alternative??
  33. Need info on LT1 MAP sensor electricals
  34. ** Lest talk water pumps**
  35. smoke at wot
  36. Good or bad race?
  37. Made my own ignition! No more misfires!
  38. Supporting hardware
  39. Lifters
  40. 380-400 tq.....
  41. Port Pros Holiday Special
  42. Need help picking a block. . .
  43. Need Help Picking A Block
  44. Whats a good cam kit?
  45. Problem with window.... plz help
  46. Timing cover removal
  47. Opti Is Out - Suggestions, Advice, ANY HELP?
  48. Head Choices?
  49. What roller rockers to use?
  50. Quick question bout LT1 valves
  51. Considering Porting Intake, Need Opinions
  52. ORY placement
  53. Take a look at this pic, and help me understand.
  54. Is it possible.......
  55. intake
  56. LT1 Heads???
  57. How big can we go
  58. o2 sensor deletes?
  59. Intake Manifold
  60. Brake Abs Bypass
  61. Switch idea's
  62. This forum makes me feel like i made a mistake
  63. Crank Scraper??
  64. 95 LT1 Camaro
  65. buildign up from a bare block.
  66. Heads and cam question once again.
  67. 7.4's with a bolt on LT1
  68. cc305?????
  69. 383 Stroker
  70. new best at both ends...
  71. Trans Am Vs WS6
  72. master cylinder
  73. Underdrive pulley on Lt-1 is it worth it??
  74. lt1 electric water pump
  75. borla
  76. Gauging interest on parting out 94z
  77. LT1 Gurus inside please. Loud Knock
  78. harland sharp 1:6 rr's?
  79. Really low Dyno numbers...
  80. Quick Pacesetter LT Questions
  81. Knock Sensor/LT4 Knock Module
  82. Water Pump question?
  83. 383 stroker cam and head question
  84. picking Cam please healp
  85. carrier question
  86. lt4???
  87. 94 TA LT1 vs. 96 Caprice LT1 interceptor...differences?
  88. Lt1 Valvetrain noise
  89. Cutout location
  90. Can I hit 350hp?
  91. Timing chain question?
  92. Help with hotcam kit on a-4. any owners of this combo
  93. pilot bearing
  94. Cam Setup Help Please
  95. my starter..pics..
  96. 1996 vs 1997
  97. anyone with a trashed lt1 block I need caps
  98. swap interiors
  99. cat question
  100. Why is my car stalling?
  101. Recommendations
  102. Are LT1 and LS1 O2 sensors the same?
  103. How hard is it to put LT's on my 97 WS6?
  104. Need an Auto Tranny for LT1 w/ Powerdyne Build
  105. Lt1 Bored .060 over
  106. Lt1 Bored .060 over
  107. Best Cam Choices?
  108. Does a collasped lifter hurt?
  109. How bad will I lose?
  110. Tire pressure?
  111. tires
  112. i need a LT4 block
  113. Cam Help
  114. LT4... Street Legal?
  115. CSR or MEZIERE
  116. Good Deal?
  117. corvette valve covers
  118. Project LT1 & Powerdyne: TOP ENGINE BUILD
  119. 3:73 Gear?
  120. Help!
  121. Operation MSD Opti Cap and Rotor: SUCCESS
  122. Still waiting for your AFR heads?
  123. Quick question about borla
  124. Cam's LSA effect on nitrous
  125. 1994 trans am
  126. help appreciated for abs light that turns on!
  127. cc306...injector upgrade needed?
  128. Looking Foreward 2 Spring -Post Your Plans
  129. Check out pics of my new 355.
  130. alternators suck...
  131. how much is a 93 z28 with 125k~ worth?
  132. Should I be Worried?
  133. OBD-II Owns!
  134. Modifications to a LT1 and what to expect?
  135. Dyno locations in New England area
  136. Ignition experts help an LT1 guy out.
  137. Starter Hook Up
  138. coated or uncoated LT pacesetter headers?
  139. lt1 vs tp1
  140. the age old Front End conversion
  141. F/S New AFR LT4 210 BARE CASTINGS
  142. big problems!!
  143. LT1 Problem
  144. Time for a new battery?
  145. Trickflow Heads-lets See Yours
  146. 383 or 396?
  147. Front Bumper Options?
  148. F.I SCR issue (request advice)
  149. Noisy Cat after Borla install
  150. Huge Problems... flashing SES... CRY FOR HELP!!!
  151. I need a catted Y-Pipe!
  152. Pro-am TA?
  153. cleaning motor opti problem
  154. super gasy smell
  155. STOCK engine capablity
  156. Question about heads for LT1
  157. MSD Opti-Spark Replacement?
  158. wheels
  159. Is this pulley good?
  160. Help!! Won't Start
  161. car turning off
  162. all parts needed to put in headers
  163. LT1 engine on ebay - is it worth it?
  164. timing chain question
  165. Rebuild/Blue Print Questions
  166. pacesetter shorties on a 95LT1
  167. t56 conversion from A4
  168. Sticky This Lt4 Conversion Why Not To Buy
  169. Valve Spring Question
  170. Couple new problems, help me out.
  171. Best 58mm TB
  172. UD Pulley's??
  173. best head gaskets for lt1
  174. Next bolt on?
  175. cam only autos
  176. New Cam only Lt1 times!!!
  177. Formula to run mid-12s on street tires?
  178. Iridium Spark Plugs
  179. Cam Swap plans Complete
  180. wheels
  181. Times with boltons + 100 shot
  182. Engine Swap Question
  183. Drivability question?
  184. Cat back with cut out?
  185. SI LT1 Drag List Please
  186. what is this
  187. torque converter
  188. help head gasket failure
  189. Lt1 To Lt4 Conversion W/ 9 Lb. Powerdyne
  190. Help Me!!!!
  191. Lets Talk Sensors. . .
  192. spark plugs
  193. Snow Sucks Balls
  194. fiberglass or carbon fiberhood
  195. Over the valve cover wires
  196. In need of help.
  197. LT1 Fuel Question
  198. rear end damage pictures
  199. LT1 rx7 advice =)
  200. Plastic fuel tanks
  201. Head And Cam Question
  202. Turn Signal Switch broken?
  203. Head Lights Motor Making Noise
  204. head and cam 97 SS
  205. couple of questions about gm847 cam
  206. EGR removal
  207. Couple of Questions
  208. aaaaahhhhhhhhhh
  209. BIN file for Hot Cammed LT1 A4 1993
  210. Header Gaskets
  211. 6spd inspection cover
  212. Need a ? answered please...
  213. Alarm wiring kit / mod for electric H2O pump
  214. Can someone tell me...
  215. electrical problem
  216. K&N cold air kit, not applicable?
  217. bouncing off rev limiter
  218. close on a deal, looking for insight on the build
  219. gear drive for lt-1? 1/4 mile times with h/c
  220. Changing Fog Lights
  221. Traction with 4.10s'
  222. Anyone know anything about Lingenfelter cams??
  223. fans not turning on
  224. Anyone Need Metric Rings?
  225. new combo
  226. opti
  227. question
  228. Rear End Question
  229. Ingredients for 11's in my sig! ! !
  230. Blower setup for my 383 LT1.
  231. Couple of questions
  232. cammed smog...
  233. 396cid+ LT1/4's?
  234. black zr1s who has them???
  235. 700R4 Transmission?
  236. opti?
  237. Stock Internal LT1 Record
  238. 05 Mustangs, Fast?
  239. ASP crank pulley??
  240. Bolt on lt1 New best
  241. timeing question
  242. This is probably a NewB question, but here goes
  243. Anyone know about these LCA's/manufacturer?
  244. $1,500 Budget Vavetrain
  245. heads vs cam specs>>>technical question
  246. 12 bolt questions?
  247. Question about camshafts and high mileage engines...
  248. Is a K&N even worth the money?
  249. A little help please?
  250. Cheapest lt4 intake?
