View Full Version : LT1-LT4 Modifications
- EFI 24x owners chime in
- 3 dayz after installing my optispark it died!
- injector ???
- Speedometer Question
- Seriously considering selling this P.O.S.
- engine light on, can't get a code
- Throttle body bypass on a 96 TA
- sticky throttle STILL won't go away
- LT1 tuners help me out please
- Pressure Washing Engine Bay
- month away from first run on track.. installing new rims after that
- Fuel pressure getting me aggravated,Please help
- cooling problems
- Changing just the heads from LE1 to LE3, do I need a retune?
- WTF is this port?
- Aeroforce LT1 new scangauge, PT401, V2.7, install, pics
- need a alt & power steering relocate kit
- LT1 Supercharger on LS1
- PCV evacuation for boosted LT1's
- Why do cometic gaskets become necessary at a 250 shot but not at a 150-200 if both..
- Please Help - Input needed - Video
- Any cam ideas? And if my stock bottom end can handle it.
- Exhaust setup, bullet mufflers straight off of the collectors. What clamps?
- im confused?!?! somthing with gas
- Guys with LE heads. Time to show off your...
- any one see " Mad Max " movie ?
- Vats system
- My stock LT1 acceleration.
- Need throttle cable.
- Alternator Question
- MSD Customer Service
- g.t.p heads
- 1994 Transam securtity problem? need help.
- Cody: 1 VATS: 0
- LPP Catted Y?
- sound like opti problem?
- supplier info
- When it tells you to exit all programs...
- If you know how to hook up a STAND ALONE COME IN HERE PLEASE
- can I just any double roller timing chain?
- Anyone know where I can buy this CAI
- new guy!
- how many gallon of fuel 97 camaro z28 can hold ?
- Anyone reuse stock exhaust manifold bolts on LTs?
- are these brake lines for the rear ?
- no power
- Ported TB
- spark plug wire set for as&m headers
- Exhaust Question
- Can I up my shot of nitrous on coated or cryoed pistons. Reason I ask.....
- 94 vette not idling and in limp mode
- exhault pop ?
- vortech supercharger
- gen 1 sbc in 94 camaro
- Any one know where I can get rear z28 emblem or cool looking one ?
- OEM SS Hood Value
- What are my Weld ProStars worth?
- idle issues, help plz
- Anybody know torque and horsepower rating of top fuel dragsters?
- Trouble finding correct pushrod length
- Vacuum leak, fuel issue IDK!
- stock block compression/ head ?
- Need battery
- Modding my suspension
- Signal light problem :/
- Igniton help
- Could it have caused some??
- bolt on and new fuel pump trouble starting?
- will this cam fit?
- cam/Double roller timing set?
- Is my optispark bad?
- Lloyd Elliot
- good news and bad news...
- 93 formula code 14 WTF is it ???? cant seem to find
- Heads Question
- willhoitescams has anybody used these cams
- crank hub seal intall question
- Did I buy a l99?
- What is this connector?
- Anyone running the LE 226/230 .565/.565 111 LSA cam?
- Stupid question about Drag Radials
- What lifters
- Pic Re Tapped Intake Mani
- Needs some encouragement.
- why does this stuff happen to me? lol
- HELP!!! Head studs?
- Help pushin a stockbottom end lt1 into the 10s
- Anyone that used pro-gram main caps to convert to 4 bolt
- what do you think of this?
- valve size :)
- how long has it taken you guys ??
- spark plug gap?
- LS lid conv. w/out LS lower support
- What mods, if any, would you recommed?
- Rear end cover
- The Z is finally back on the road
- LT1 oil pressure?
- My rear diff cover is rust
- new crank hub
- FOr you guys who want your Opti's to LIVE...do this.
- Lots of tech questions about scan info
- *** passenger side running lean.!?!
- 10 sec stock bottom
- My New new ride...
- More Eagle cast crank carnage!
- Head removal on 96 z28
- Initial test fit, BLS HID setup (96 WS6), Pics!
- hot cam kit for lt1? whats involved?
- Anyone ever run the strip with no t tops?
- Fuel Tank seal
- Lid Conversion On TA Non-Ramair Hood - Pics
- Poly Motor Mount Question
- Question About Deleting Air And EGR.
- what oil pump for lt1
- quick egr delete question
- what opti?
- Spark Plug #8 keeps shooting out!
- How long can it sit?
- Could this cause my zero brake power issue? I have no brakes.
- What coils for EFI 24x conversion...LS1 or LS2?
- my as&m headers have me paranoid
- Torque spec for steering wheel ?
- oil pressure
- any one here running Pennzoil Synchromesh on m6 ?
- 2 throttle body questions...? NOS
- What are these and do I need to replace?
- Deal or No Deal
- '93 Z/28 Starting issues.
- Need 3/8" poly lock for Comp Pro mags - Anyone have any?
- What spark plugs for supercharged LT1?
- Heater Core outlet plugs for water pump?
- torque specs? and head bolt sequence?
- Help 93 LT1 starter possesed!!
- is it worth me getting a tune for what i have?
- Bottom End Died, have a few questions
- Tune for throttle body
- LT1 valve guides.
- IM BACK !! feeling really good
- What kinda plugs and for LT1 turbo?
- melling lifters
- Custom gauge pod / black alcantara, Dyno-tune gauges, PICS
- before and after shots of my 97 ws6
- coolant level sensor
- Will this fuel filter work?
- diff connecting rod lengths make ?
- Random bucking?
- Feels like a miss?
- Anyway to remove the clutch master/slave without pulling trans?
- Another issue
- Please help me!
- Its Flat...
- Can't get fluid to flow out of bottom of master cylinder
- Burning/Losing Almost a Quart Every 1,500 Miles
- head gasket?
- QA1 Shocks
- Is it time for me to go to stepped headers with my setup?
- My car pulls all timing at WOT
- New best with the lt1
- 97 throttle cable
- Trans maybe?
- What is this?
- update and wtb
- time for a CLUTCH
- pinion nut
- Well i made a stupid mistake and need serious opinions
- ant decided on stall converter ?
- When 10 dollars turns into 200 dollars
- What are bolt sizes for dipstick tube and flywheel cover bolts
- Where to get tuned in NY?
- Aftermarket ECU's, Fast, Accell BS3 etc...
- notching valve covers
- crank ???
- noob question
- Using Guides with Self Aligning Rockers?
- WTF! Where does this bolt go!?!?
- HELP!!! CAM center pin fell out
- Hard to start why?
- WTF is the deal TrickFlow 185's.
- Tuning/Dyno Shops In North Western PA/ Twin Tiers NY?
- Gm white spring question...
- Quick final questions about Port/Polishing Intake/TB
- ls1 engine harness and computer on a lt1
- Leaning back the radiator...
- My Radiator Support Mod...
- New Opti straight from thepartsladi's connect
- Battery draining
- Throwing codes, fans staying on
- Project is all done... Couple pics
- who makes this CAI
- stock lt1 with h/c/i= I have ?
- What's up fellas (Elliott's94Z)
- Where does this go?? Help me get this 383 running tonight (will update regularly)
- Need help with fuel
- 2010 LTXshootout low car count so far!!!!!!!!!
- Will a WS6 Ram Air hood fit on a 95 z28?
- Need Location of O2 Sensors on 95 z28
- best sounding bullet?
- Alternator/everything else belt lol
- Shift points to rev limiter question
- Alternator bolts
- Weird transmission noise
- 4" exhuast
- stock tune
- Where did i go wrong?
- decoding the stamp on engine block
- Ptv clearance ? With bigger valves
- sorry guys...
- whats the most lift i can go on a stock motor
- Help W/ Wiring..
- What type of coolant?
- seem to have ignition issues, opinions?
- Someone please help me figure out this misfire
- are LT1s worth it expert advice or any advice welcome
- Underdrive pulley ????? ASAP
- LT1 fuel line replacement options..?
- Hood Hardware
- Fuel pump options
- Elliots94Z
- Nitrous Window switch wiring
- It's been a while.......
- FTRA :usefull or not(picture inside)
- Could it be my spark plug wires?
- ltx intake ?/request
- lt1 6speed wont chirp 2nd gear hard
- Header clearence on sides of collectors?
- clearence with pushrod guideplates?
- advanced induction?
- Think my opti just went out DOH!!
- '96 Z28 Throwing codes
- lt1 ticking passanger side .please help its probably not my clutch slipping
- Injectors and a tune...need help
- evap question..
- anyone using these ebay headers and y pipe???
- Best intake for LT1?
- Spark plug replacement....help!
- opti-spark
- 94 lt1 short block build
- Little sluggish at WOT
- Low fan speed nearly never stop...
- New 95 m6 z28 owner needs some advice- Car is running Slow and fouling plugs
- 97 Running like shit
- autometer oil pressure gauge install
- hows this mark look for pushrod lenght
- Hand brake light always *ON*
- Using 18* (or 15*) SBC heads on a LT1
- lt1 torque converter question
- Supporting the trans with the motor out?
- Quick Question!
- track
