View Full Version : Forced Induction
  1. Assembly limits
  2. V-band sizes, is this right?
  3. Stock Long block LS2 breaks 700whp!!!!!
  4. Give me your PUMP gas numbers!!
  5. Reliability of FI'd LSx
  6. 11:1 CR, H/C, and Boost from D1SC ... Need some info
  7. P1SC Cam ideas
  8. blow thru ls1 Q`s
  9. fi street methanol
  10. does this look right (pic)
  11. Help!! Please
  12. Spraying e85 through a meth injection kit
  13. Using E85 and Methanol Injection?
  14. LS6 vs. GT2-3 or similar custom grind on D1SC 347 w/ heads
  15. Couple pics of Turbo Car!
  16. Need intercooler tubing or header tubing? We can mandrel bend you whatever you need.
  17. Twin GT42 LSX T/A
  18. help with overheating
  19. 2007 C6 Vert
  20. Going FI
  21. S91 408 T/A....dyno on low boost and pump gas
  22. What belt length with PTK turbo kit?
  23. where would I get compression clamps for exhaust?
  24. pics of ATI race valve installed
  25. First drive D1sc Video
  26. Is this a gt47-88???
  27. what size motor for f1r
  28. APS twin turbo what size of engine to get?
  29. Ignition system for Procharged ls1
  30. Building a block for FI
  31. What would happen ?
  32. 10's on stock heads/cam/intake/tb
  33. Wanted advice on potential vortech buy *Pic*
  34. Nitrous intercooler spray
  35. what size is a t3 turbo?
  36. Does running E85 affect turbo sizing?
  37. Stock block + 13psi + 7250rpm = (pics)
  38. whose main studdin?? and TB flange..
  39. Cam and Pulley ideas
  40. APS TT GTO vs Modded GSXR 1000
  41. Congrats MIGHTYMOUSE!
  42. Home made meth kit
  43. Procharger F1 Head unit?
  44. Wastegate for a T88
  45. Thick Cometic head gaskets for SC FI
  46. Going from Juice to Boost......help
  47. Good Cam For Turbo'd 408
  48. Semi Results
  49. I just bought a Procharger!!!!
  50. Going Fast...
  51. Paging EPP f1a install help
  52. ECS Paxton Novi 2000 Stock Bottom end 9.8 @ 139 Mph
  53. -10 to 3/8 good enough for return?
  54. My F1A/402 Setup
  55. remote turbo...wastegate feed
  56. new LPE 2 step
  57. Lifted the heads on the Dyno
  58. another aps tt
  59. BOV going bad?
  60. i represented for the FI LS1 crew
  61. SDCE ProFlosurge valve
  62. 408 + stock 317's
  63. FI stuff for sale
  64. 434" Buildup
  65. What would my car be worth?
  66. Turbocharged question!!!!!!
  67. Cheapest place to buy tial products??
  68. Which cam for a vortech blower?
  69. STS guys, get in hurrr.
  70. Procharger?
  71. Help with an F-1
  72. turbo drain ?
  73. any turbo guys had any problems with exaust lifters?
  74. P1SC pulley sizing and boost?
  75. Tial 44mm Wategate Q
  76. Pinning balancer
  77. best heads for boost
  78. Procharger Help.....
  79. Stock heads VS Ported heads
  80. Truck Manifold Twin Turbo New #'s
  81. Flipped GTO manifolds on an F-body
  82. CAM Recommendations for D1SC Procharger
  83. New motor setup for STS car
  84. Will these turbos work for me
  85. Custom rear mount turbo?
  86. Little compressor mapping script
  87. Big single turbo + 481ci
  88. whipple model for mid 90s vortec trucks?
  89. 618/643 aps tt @ 10 psi
  90. Pinning balancer
  91. Need Help With Sts Info
  92. ported victor jr. intakes ?'s
  93. What todo with a slow LT1?
  94. Stepping Up to a 3 Inch Exhaust On my Fi setup
  95. LS4 Turbo, Valve spring & misfire question
  96. the merge into a T4 flange (truck manifold setup)
  97. New to the ls1 world, s/c questions
  98. Best intake manifold for turbo kit?
  99. another "what do you think"???
  100. Have you seen this turbo question
  101. pro flow bypass valve
  102. Garrett Turbo and a Forged 346ci
  103. What is everyone running w/ a D1SC
  104. Future GM Engineer here.
  105. APS f-body it with th400?
  106. Anybody know if the new turbo BMR k member will work with the Fbody APS TT kit?
  107. Help me make up my mind...
  108. Got Fr1 Now Need Motor
  109. Well, did a little tuning
  110. What would YOU like to see in a Vortech big blower setup?
  111. What car to buy to super or turbo? which way?
  112. Garrett GT28R versus T3 60 trim
  113. No one can diag my turbo issue,please help!!!
  114. Shake down passes - D1SC 3.8 V6 Firebird (street driven).
  115. 370 vs. 408 stroker????
  116. LPE MAF? - What are the limits HP/Boost that you know of... ?
  117. paging Bob @EPP
  118. Bypass valve over BOV?
  119. lined up a sts first question
  120. C5 Single Front Mount 91mm Turbo Kit Done [PICS]
  121. How necessary are dual valve springs on 12 psi ls6 heads
  122. APS G8 Pontiac twin turbo system - First pics
  123. 826 RWHP from the 346 cube APS twin turbo
  124. LS1 block?
  125. APS kit with 4l60E
  126. Look what came today :) Gen TT
  127. can I get 800rwhp with my d1 and a 408?
  128. ls2, l92, ls7, lq9 head lifting???
  129. Which 3 disc Vig are people having the most luck with?
  130. Pair of TT Pontiac G8s
  131. how much boost can stock lq4 pistons take
  132. FI valve/spring question
  133. SEMA Photos (all fi)
  134. Oil in downpipe/intake
  135. Starquest Update
  136. What should I go with?
  137. P1SC + 385 ci LT4 Question
  138. Turbocharged LS1 Questions
  139. i need help ?
  140. This is what happens when you go for 9s on a stock 4l60e and stock block!
  141. ohio turbo kit
  142. Yep, another cam ?. Z06 vs. 224's
  143. speed inc tt 6 speed car goes 9.2@156.35
  144. New PB With STS..10.74@126
  145. GM 5-layer MLS thickness?
  146. Going for a twin T off road car, engine Q's
  147. D-1 car finally done (mostly)
  148. turbo selection ?
  149. where to buy 6.0 truck manifold exhaust flanges?
  150. Waste gate on a Centrifugal Supercharger with adjustible boost...
  151. need beger turbos
  152. Who do you use for U-bends/Elbows
  153. Not LS1 but cool Hellion Twin kit with Eaton
  154. BPV/BOV over the stock Procharger
  155. d1sc Procharger oil?
  156. Pt71GTSHP?
  157. TTi LSX holiday Pricing
  158. Should I expect anything going from my 4L60E to TH400?
  159. Which BOV/BPV for procharger
  160. Going to make one more try for the 8s tomorrow with the old 346, wish me luck
  161. Coolant Source
  162. Comp is 10:75 to 1 pro & cons of turbo vs nit
  163. Giving up on turbos, new and improved setup
  164. New Weiand LSX Intake Manifold
  165. Some videos from the track, one showing my spool time.
  166. EPP's blower cam with 1.75 rocker arms?
  167. Got my turbo back from Turbonetics
  168. D-1 kit to F-1 on LT4 motor???
  169. Best Oil return pump?
  170. 98 C5 with F-2 PICS......(56k good luck)
  171. What have you gained going to a larger A/R housing?
  172. 7.84@179 on 275's
  173. Crank Bolt came out
  174. magnacharged TA running to hot?
  175. What will I have to change
  176. Where does the BOV go?
  177. LT1 Forced Induction Gasket?
  178. STS Turbo Installation Guide?
  179. More News at KYTP.
  180. 408 turbo build - need advice
  181. HP Predictions
  182. Best Forced Induction Cam...?
  183. Turbo Choices.....
  184. slp Y with sts
  185. how much boost?
  186. Boost #s with D1SC 7.6/3.4 Pulleys? SDCE Help?
  187. LT1 TWIN TURBO-custom or homemade please post up!
  188. stock ls1 boosted
  189. Paging Ed at Late Model Speed....
  190. Maggie dyno video
  191. map sensor
  192. P0300 Code when car is stopped.
  193. Any F-2 Procharger kits for the LS1?
  194. LT1/ 89 GTA turbo kits?
  195. Jake brake sound
  196. Procharger SES light?
  197. Boost setup ?s
  198. alt 6 rib to 8 rib info (clutch pulley)
  199. Target Static compession on E85?
  200. Ready To Give Up My Money Lol
  201. Attn Ohio boys: O-ring question
  202. LSx misfire issue, come inside
  203. BW S388 turbo?
  204. Which Forged Engine for Boost???
  205. APS kit K member
  206. 60 lbs injectors
  207. GM Kenne Bell 6.0L supercharger
  208. Little vid of the TT Chevelle from Yesterday
  209. Trans Am Build.....
  210. FMIC for 01' TA
  211. Has anyone run LS6 heads milled to 62cc and ran up to 15 lbs of boost?
  212. wheres the best deal to get a Precision T88 turbo?
  213. Windshield Washer Fluid
  214. gm mls gasket purchase
  215. Wiring up 2step
  216. Oil on impeller side
  217. What to do with my turbo 5.3 powered stang?
  218. Most Bad Ass 76mm Turbo
  219. So how much did it cost?
  220. Muffler shop damaged my turbo, need help in fixing
  221. What Garrett turbo is this.
  222. Procharger 4.11's
  223. Turbo Setup in G-Bodies?
  224. Going boosted need help please!
  225. Tune and Boost
  226. Is anyone runnin KY turbo system or Ohio forced
  227. I took the leap!
  228. Some technical supercharger questions
  229. anyone got any info on this turbo
  230. The Turbo Project has Begun......
  231. 2008 ProCharger calendar, we have a C5 in there!
  232. HX60 on a LS1?
  233. custom turbo set-up for 71 Camaro who should I use
  234. What gears with Procharger?
  235. quarter mile magnacharger time
  236. similar ET but nice new MPH best today!
  237. last pass of the year, new best by a bunch!
  238. Can we hear turbo people's exhaust sounds
  239. gathering parts for a tubro build...critique away!
  240. is a D1sc enough blower for a 408ci?
  241. Couple more pics of my new Performance Auto Fabrication GT-47 turbo system
  242. New best, 10.67@131.71.
  243. Instant Tube Fittings
  244. Just installed Wideband need Tuner DFW for a Touch-up Tune
  245. BOV question
  246. corvette alt pulley removal
  247. Who sells excellent off the shelf F/I piston close to -3cc dish?
  248. BOV vs BPV flange question
  249. Rearmount setup new best. 10.139 @132.74
  250. Pump Gas Turbo
