View Full Version : Forced Induction
- twin turbo kit for a 76 vett?
- Collapsing Inlet Ducts - APS
- TWIN GT35'ed 408 what boost controller & CORRECT way to Hook up
- truck manifold turbo kit
- Scavenge Pump Set Ups - APS
- Stock LS1 D1SC dyno/et? Looking for information!(+EPP/brutespeed cam)
- Magnacharger TVS2300 Hot Rod Kit - Where?
- water to air for procharged f body
- Gmpp lsx 376
- Boosted head choice ??
- New best mph @ Pinks All out
- Proparts Spek boost controler
- turbo spark pulug and gap
- Piping for rear mount
- PLEASE HELP>>>balancer separated, any suggestions on fixing
- need some help..
- Twinturbo help needed
- Have extra Large Yellow TIAL W/G spring
- sts dragstrip times
- Overheating issue
- radiator used for turbo setups
- question about procharger f1c
- round 2 new build, pics page 2(s85,th400,370ci,9")
- IROC Boost
- Why no Kenne Bells?
- Truck manifold turbo people...please step inside
- Considering pair of GT-K 650 for 408 pump gas build
- Boost and stroker Q
- Muffler before the turbo????
- Blown with ICE?
- Screw Roots!
- Twin gt37's or single ?
- E-boost 1 fitment in TA vent
- Procharged ls3 dyno numbers?
- BOV Question
- What turbo is best for me? rear mount, 408.
- KY-Turbo Inc. TC78 A/C Turbo Setup.
- Starting 5.3 turbo E85 build?
- High RPM turbo cam?
- Cooling with front mount single turbo???
- Edelbrock 245cc heads from WCCH...
- Is this the correct way to set up a manual boost controler APS!
- STS truck kit. Convert to f-body?
- twin 255s intake
- 00 turbo ta...2bar 3bar??? Wtf
- The Texas grudge superman get's his head cut off!!!
- Vortech v9 gtrim
- 317s on a 4.8 LR4
- Who Sell's Power Steering Relocation Bracket
- stock 6.0 truck crank power levels
- Turbo oil return line - different
- can a forged 346 or a forged 370 handle more boost?
- 88mm to big???
- Installing 3 Bar map sensor on LS6 intake.
- Help with clutch selection...
- What step plugs?
- ProCharger Survey
- procharger guys what filter are you using????
- fuel pressure gauge question
- What grade bolt for turbo manifold?
- My build I driving me nuts!
- High A/F ratio on fresh engine
- Who makes custum MSD wires
- Where to buy this bendable after blower coupler?
- What coupler to use for AT1 truck inlet hat???
- Which truck coils are best for FI?
- My new turbo ride...eh, project
- ls1 vs ls1 gt67turbo
- Best stock head for forged 370" FI motor
- Will gto magnacharger kit work on f-car ls1
- N/A to Forced Induction
- Flywheel holder necessary?
- Blew the oil dipstick tube out
- Supercharger EXPERTS, technical question
- FMIC installation
- vortech SC pulley for LT1?
- walbro gss341 fuel pump
- Front mount MP70 turbo, a few questions
- 98 vette on the dyno
- Turbo kit?
- Finally! I have cut my lag time down!!!!
- Muffler Before Turbo----Rearmount??
- Twin Turbo Charge/Hot side pipe SIZE question
- Tial WG and Turbo XS boost controller help
- 2 step on stock bottom end
- need help with belt size on procharger
- Need help with SCDE tensioner install
- thinking of the right blower for my 2010 ss
- Remote mounted turbo vs. Conventional mounted turbo.
- Please Help! Still Working the Bugs Out of New Turbo Setup
- optimal oil return size for rearmount turbo
- Oil on the intake side of my Vortech V9 G-trim
- Got Boost Sag?? Don't need that fancy EBC!
- Wastegate Question!
- Will this turbo help me reach my goals?
- Stock bottom and single plane intake.
- Finally Good Pics of my Pro Charged LSX Nova..56k stay away
- Custom Twin Turbo setups F-body post pics
- First updade in along time on my outlaw 10.5 T/A
- Newb with a question :)
- P1SC on silverado 2007 classic body
- Upgrading the STS
- Vengeance Racing | Magnacharged GTO
- Is it necessary to o-ring the heads at 1k plus rwhp?
- need a better understanding on wastegates and bovs
- Smallest turbo of physical size for a built 408 TT
- Stock ls3 mains vs Callies billet vs Katech
- Cam question??
- time to down size
- looking to build a boost car. New guy here. Sorry. Lots of questions.
- Very odd issue on turbo ls6
- how much can the stock bottum end handle?
- Thinking Of Boosting The Slowmaro....
- Sts turbo installation manual needed...
- What can I do to make my procharger quite
- YSi on ls?
- turbo engine build
- ? about a turbo...no idea...
- fast 102
- Target AFR's w/ E85 & boost?
- stock 06 gto A4 with F1 procharger 13-15psi
- Nelson Racing Engines
- PTK/Ebay Kit spark plug wires - Anyone try LS2 Corvette Plugs?
- KYTP GT-88 Truck Manifold 408ci Build w/Pics
- 2 step retard question
- Help - P1SC 98 Camaro..
- Trans Am FMIC
- LS2 APS W/LG Turbo (part 2)
- The Purple Bird
- LMR Twin Turbo Corvette runs 8.37@173mph!!
- Quick question
- ls1 boosted map sensor
- Looking at budget 6.0 TT build
- WTB any used 8 rib balancer and blower bracket pulleys.
- weird Procharger questions HP to turn a F1C and belt slip/max hp ?
- APS owners: have a look!!!!
- crankshaft cog drive pulley
- is my turbo to small for my goals?
- Synapse Syncronic waistegate
- holset H2e turbo....17cm exhaust housing
- single 76mm max power
- Turbo Cam Spec'd Out
- turbo cam
- Any one have pics of fire rings/ steps cut into heads and block for hi power builds?
- WTF! Still no boost of the line!
- Need 10psi WG spring for Tial
- jgs wastegate and boost controler help
- Guess what Ill dyno!
- Question on heads and supercharger setup?
- Dyno video...ebay turbo...
- Downpipe Size for Twins
- What block are turbo users using?
- Turbo for Forged 364 (turbo gurus please come in)
- I reached one of my goals tonight.
- Crank pin problem, help!
- 2500hd lq9/w pt88 questions
- Which thread
- LG APS upgrades.......Let us know what you think
- Fmic
- s400 turbo with 408 stroker
- Super quiet exhaut for a 5.3 turbo setup???
- magnacharged 08 silverado! #'s
- Any decent hp non-intercooled guys???
- Losing Boost in Intercooler - Thoughts/Suggestions?
- where to find oil feed adapter plate gasket
- Hope you big Turbo guys can help
- House of Boost LT1 Cog set up
- LS Pontiac Astre
- Bypass valve vs BOV
- breaking in my V-9 vortech S/C
- piston ring gap?
- 6speed guys..how do you activate your launch controller?
- I need measurements on a GT4788 (pics inside)
- best size turbo for ls1
- which budget heads would u use?
- Hobbs switch after bypass valve?
- Anyone using the FJO meth/water injection
- Silicone reducing 90
- Quick question about procharger bypass valves
- L92 valves for twin turbo setup
- Im Back! Yea the guy with the Ebay turbo kit.
- why dont we see more compound turbos or superchargers
- Looking for GTO PROCHARGER Bracket spacers/bolts
- ATI j-tube w/ surge and Race bypass vavle?
- Brute Speed F Body ProCharger Kit
- 370 hke with 72mm turbo
- factory rev limiter
- 10 psi and stock head bolts- will it hold up to this build?
- Iron 370 for turbo build
- GMPP intake clearance with 96 SS hood
- sprayed meth and went leaner??
- Easiest PCM software to use?
- ProCharger F1R Cog Help....
- GMPP puts LS9 into a 2002 Camaro!
- mp t70 or t76
- 317 heads
- Need a biggger pully
- Which Twins?
- vortech v9 boost question
- d585 coil pack dwell needed
- Spec 5 reviews?
- Twin GT37, L92-headed, 408....camshaft?
- By pass and hobbs switch ?
- Procharged ls3 ?
- Question about Snow methonal kit/more boost
- BOV In Place Of The Bosch Surge Valve
- Is an intercooler really necessary....?
- Finally got to test the new combo
- Maggie m112 on c5 Z06?
- final part to turbo build
- Thanks to all the LS1 Tech guys day one FI build went excellent!
- so I just found out Isky Cams is around the corner from my house...
- devils own testing info
- Need Help!!! Turbo feed and drain advice
- mpt70 and LQ4?
- O2 placement??
- th400 turbo guys- 3rd gear feel significantly weaker ?
- Maggie 1:1 pulleys?
- how much is too much for the street? looking for guidance
- is a D1SC too much?
- sts turbo camaro smoking like a mofo!!! need help!!!
- boost with big converter
- ATI crank pin removal?
- What A/F to run @ 15psi boost
- STS Meth Kit Trouble shooting?
- Adapter for 5 wire MAF to 3 wire and IAT Sensor?
- TT with 6.0 manifolds flipped
- Where do you guys put your alternators?
- Vortech owners, have you replaced your BPV?
- High compression with a turbo
- Boost jumping around normal or turbo fubared?
- help with duel nozzzle meth
- APS 20g turbo question
- I have a D1sc for a 2002 trans am and now...
- What size pulley to get 15psi on a F2 unit?
- looking for solid motor mounts
- what are better heads for FI out of these two
- Turbo Question ONLY Experts need to reply.
- head gasket questions for lt1 guys!
- My D1SC Procharger build and more for 2010
- P1SC owners
- What size inlets for the intercooler?
- any spark pulg pic with meth inj
- Crazy boost problem!!!!!
- Turbo BMW finished -video
- Anyone have an STS Manual?
- 2010 Twin Turbo Camaro For ME
- went from 10.5#s to 14+ with sdce upgrade.
- Turbo Cam?
- 5.3 vs 5.7
