View Full Version : Forced Induction
- stock or ported LT1 heads(not aftermarket) what amount of boost and/or rwhp?
- Procharger pulley help
- Pics of my BRAND NEW GTO F1A Procharger
- Injector question for turbo setup
- Yes another "Help me get to 1000+ hp"
- Finally got the car on the road again.
- Turbo cars, MPH, ET and 60'
- NEW 383 ci LS1, D1-SC, good cooling system... heating up!!
- ls1 build for boost?
- List of things that could potentially go wrong on the dyno.
- Do I need a blow off valve with an automatic
- looking for turbo videos with staight pipes.
- wire harness that goes across the radiator
- What would you do with this housing?
- 383 shortblock for boost...your thoughts and criticisms welcome
- Need some help on buying used turbo, guys
- Max effort 346. Cog Drive F1c or F1r
- Bigger wastegate recomendations?
- Boost spike help.
- Stock crank v.s Compstar Input needed
- Boost with 11:1 compression ratio
- How to calculating volumetric effeciency to help choose turbo if I don't even......
- sts. turbo
- Anybody boosting the new aftermarket raised port stuff yet?
- sanity check...please tell me if i'm jacked up
- 317 heads limitations
- Turbo Front Bumper???
- Maggie on Stock bottom end?
- Twin MP70's on an LS3 416 w/ AFR 225's
- Gear for turbo car
- what are you guys coating your manifolds /headers with
- Mp t-76 power limits
- Let's see those powder coated pipes
- cooling fan question for procharged car
- belt slip!! d1 procharger!
- what intercooler do you run?
- What is the best header wrap?
- LSX block for a daily driver-any heating issues?
- Question about High Octane with forced induction and increasing power?
- twin oil feed ?
- 2 step help
- how do i find out what size my wastegate is?
- Maxx hp
- Oil supply for turbo
- 1 7/8 vs 1 3/4 headers
- Oil change on a rear mount setup---
- BS3 setup cuts out when coming into boost
- Need help getting to 1200hp
- Changing Oil Drain to braided lines
- Catch can / Valve cover breather
- which intake for a RMT?
- 5.3 forged rods
- does the outlet of a bov matter?
- People who have or had valve float issues- come on in
- Factory gauges
- spacing procharger pulley
- MAF or speed density
- what radiator are you guys running?
- what is the best rotating assy for a blown ls2?
- 625rwhp with great drivability possible?
- Forced Induction
- front mount vs. rear mount turbo??? some one explain the difference?
- ~NEED HELP~ what WG with a gt-91 turbo?
- Turbo 4th gen lt1 guys??
- wastegate
- Weiand LS1 Intake install
- problems with start up
- Stand alone nitrous with boost
- Truck manifold flange?
- PCV under boost
- Procharger Hat Problem Fixed
- Another Ebay turbo project ! Need Help...
- LS1 LS6 Crank Pin Kit
- pulley sizes for max rpm on v9
- diff and transmission concern
- f1a overheating???
- f1-c vs 80mm t6
- ebay kit guys...spark plugs
- fmic intercooler?
- anybody use these fans ?
- anybody selling ls1 supercharger setup?
- oil return pump proper install info needed
- oil drain on canton pan
- Large FMIC ??
- Broken Tensioner Bolt
- Blown Head Gasket
- Piston and Rings for boost
- procharger help
- flexplate?
- what turbo/turbos?
- What belt?
- budget twin build plan, input welcome
- Wiring for procharger single fan
- vortech aftercooler waterpump....
- Does the BW SX80 really have 5" inlet?
- my turbo car is smoking like a mofo help
- Miscellanous Procharger Parts?
- gears
- what oil catch can do i need???
- Time for my high mileage APS kit update
- ANY input on gear selection would be appreciated!!
- How much boost before I should worry?
- (Brand New) Procharger F1A FOR 04 TO 06 GTO
- (Ls1 347 compression Help)
- borg warner s400 75mm turbo w/t6 hot side
- Sway me - F1a
- best header gasket for a turbular turbo header?
- fast 90/90 on stock ls1 with boost?
- PT76gtsh Results (very pleased)
- LQ4 Build
- STS to Trick swap
- Need opinions!
- ModularTurbo needs help!!!!!!!!!!!!!!
- Anybody running a LM7 with stock 5.3 heads?
- what happened to OFI?
- Rear mounts chime in!! intake in the rain...
- Flex pipe
- stock block hp limit???
- Procharger upgrade help
- lm7,lq4 or lq9?
- How determine hot side size of turbo?
- vortech supercharger ?
- Need larger turbo?
- Twin Garrett 3271
- Max boost - min compression?
- 421ci SBC High Boost E85 Project
- best 3 bar map sensor
- Shops around Chicago IL??
- Hot Wire Installation question
- Any pics of twin turbo setups using truck manifolds?
- Single or twins with lsx 427
- turbo build question
- Borg Warner ST80 1.25a/r
- Intercooler Selection Fact and Fiction
- do i need a fuel pressure regulator???
- F1c$$$$
- 1000+ RWHP With Ls9 Head Gaskets
- Oil pump help.
- procharged mustang guys...
- Which intake for FI LS2 or LS6?
- Who has made their own double Walbro in-tank kits?
- single turbo with MAF tunning?
- Will this be the ideal PCV/catch can setup for my TT setup?
- Breather Tank - What should I do with the ports on TB/Intake
- JBA Truck Headers?
- ETP 6 bolt heads
- Results from Dyno Tune
- Powerdyne BD11A problems
- Vortech ?
- maf location
- Twin Turbo Choice...
- Best clutch set up for T76 5.3
- need to pick Turbos and cam for a TT forged 408
- Does this turbo kit look familiar?
- Rear Mount GT-4788 Z06!!
- APS F-body With GT35 option
- Your boost gauge?
- Issues with my setup
- t4 flange with y-pipe
- What gears for a roots blown Trans Am?
- 441 LSX,TFS 235,Nasty Sheetmetal Intake,Twin TC70's Turbo kit by KYTP 6spd street car
- Lifted Head with ARP Studs Question
- can i see how you trimmed your bumper for intercooler
- ebay kit
- ? about going with e85
- Procharger questions!
- Made a vortech airlid
- PT88 Rebuild
- my attempt at a complete vac/pcv diagram
- I need Fuel Advice for Procharger..
- Help with bov, iat sensor and Methanol nozzle placement
- Waste gate dumping, examples if possible
- turbo air filter
- Fuel pressure drops when Electric Cut-outs are open???
- Cometic Phuzion Gaskets
- What size oil feed line for my mid mounted turbo?
- Turbobygarrett.com sticky?
- How much horsepower can you make with a TC76?
- Iron 408, twin turbo choice?
- 87 Iroc-Z 6.0L Turbo Build
- looking for anodising services
- Pcv & fi?
- Where can I find a valveseat for JGS wg?
- maggie and water /meth spray location
- Syclone IAT, connector different on LS2?
- how big of a bore can you get a ls9 head gasket in
- Fell into race class, want street class. I have a restictive cat/muff Tune question
- going STS Turbo, need some advice on the set up please.
- TT Z06 Build Thread
- turbo suggestions please
- Valve Float - High RPM breakup
- turbo and 317 head's?
- Anyone build X-over pipes?
- turbo exhaust
- Junkyard LQ9 runs 9.92@141, 4000lb race weight!
- WHIPPLE SUPERCHARGER KIT UNDER STOCK HOODS for LS1/LS6/LS2/LS3/LS7
- thread?
- How much HP should I be making?
- tapping compressor housing master power 76
- what size wastegate spring
- LT1 TIMING Quse ?
- okay school me on wastegates for my turbo setup
- Higher elevation = moore boost?
- 2010 Fastest FI List
- Where did the Fast FI list go????
- Turbo kits for transplanted LS1s
- What turbo?
- GT 2-3 cam for a 370?
- Granatelli Version of 2010 Camaro Twin Turbo
- need cam help with 5.3
- Can flow direction on Mocal oil return pump be changed?
- Valve Spring Issue on D1SC 347
- What is a good size turbo for 6.0 swap? (plus more questions needing answers)
- Extra Bolts in Procharger J-Bracket
- Need advice if you don't mind
- Kytp Tubular header/radiator hose?
- Turbo Big Dogs Need Your Help
- Quick Radiator Question.... pics added
- GTO Procharger Bracket Question...
- Notching Radiator support
- belt size for speed inc relocation and slp underdrive
- Does an exhaust crossover matter under boost?
- Spool Up? 96 Impala SS TTLSX
- What dos everyonr think?
- does anyone have any info on innovative turbo systems
- PCV system on 15psi - help.
- TR224 112 and turbo
- Helion 2010 Camaro twin turbo kit makes 580rwhp
- New Vette Updates
- ls3 in 98 camaro f1 or d1
- fmic d1sc help!
- LS2Formula goes 7.95 @ 177.5 on E85 and DR's
- 10.01 @ 137 stock 6.0 76mm
- Deck thickness Q. 317s vs TFS/ETP/AFR aftermarkets.
- My 2010 Build... lotsa pics... almost done!
- No boost with my procharger setup?
- boost/vacuum reference help please
- ATI balancer or SLP?
- Powerdyne Questions
- MasterPower & Rob @Modular are the man
- maf
- Precision Pt6765sp Billet turbo questions
- Custom exhaust for turbo setup.
- Nitrous and boost
- Should I Do It Now Or Wait?
- Thinking about going FI... Any tips?
- C6Z makes 1050rwhp through Auto!
- ALL stock block FI guys come in!
- Threaded MAP Sensor
- Has anyone tried a 928 motorsports impeller?
