- Forged Motor Build In Progress
- DCR's turbo engines?
- ms3 with fi??
- Anyone use a powerglide in thier turbo setup?
- 7" Velocity Stack
- Anybody used LS2 plugwires on a LS1 for turbo pipe clearance?
- STS and driving in rain
- 408 with single Turbo T76??
- Alky Control Kit Install ?'s
- 946 hp street tune
- Anyone Got one!
- 796 Rwhp 720 Rwtq 347cid C5 Auto F1r
- is it ok to spray lube in wastegate to prevent it sticking open?
- MSBC-1. where to buy?
- IS this turbo capable of 800whp?
- Who has/uses a Bead Form?
- new 403 in and running
- only 5ps1 help1
- ProCharger belt length rule of thumb?
- New Car New Build PART 2
- more boost with restricted exhaust?
- Supercharger Surging @ Idle
- Fireball FI98x Turbo Build
- My STS turbo 383 build **PICS**
- Twin Turbo Vette. Anyone know this guy?
- cam shaft for 6L with f1 procharger
- my first new car pass little video
- intercooler inlet
- Ls6 Intake Gain?? Worth the cost??
- Twin Turbo Manifold Kit(Coated Hot Parts)
- Final Twin Tirbo Kit Pic's
- Intake suggestions for my street Twin Turbo set-up
- basic FI questions
- Progress pics of twin turbo Firehawk
- procharger & exhaust
- Any one using greddy catch can for pcv system?
- need help, chance to buy headunit
- Physical Dimensions of the Procharger Red Race BOV?
- coolant recovery
- More power with higher octane same tune?
- Suction hose on Procharger
- turbo vs. supercharger(LT1)
- procharger systems(LT1)
- tuning software
- A&A procharger/LS2 throttle body fit?
- problem with snow progressive meth kit
- Boost drops off? I need a drink..anybody?
- BBC turbo headers
- wideband acting up...AFR 50+
- Turbo rebuilds
- HELP!!! Problem with BOV!!!!
- e85 instead of methanol injection
- Dyno numbers
- FMIC question
- FI+Shot on Stock bottom end
- Procharged A4 question
- mounting stock fans to radiator?
- Those who moved radiator up and verticle.... in here
- quick heat wrap question...front mount turbo
- turbo manifolds
- Where are my old kits?
- Testing S95 placement
- ATI F1A and No Intercooler on Pump Gas??
- scavenge pump for turbo...return to pan?
- Coolant temp drop from removing the condenser?
- Any ATI users ditch the fan shroud?
- Anyone using Zirgo fans?
- CR help??
- Heads on procharger???
- f1r
- Side mount magnacharger...any good?
- ETP 265's and Victor Jr manifold
- Lowering Swaybar
- A & A Progercharger 8 rib-stock idler pully?
- New D-1SC from EPP on NHRA Trans Am
- effing crank bolt...
- 83# inj and fuel system ??
- Underdrive Pulleys with a Procharger P-1SC-1
- TTiX Manifolds....
- Block?
- what should my max boost pressure be at max impeller speed?
- GT3582r
- I need a sensor or gauge to let me know my turbo is getting oil??
- Got a Speed Inc. Street Twin setup coming and have a few??
- Turbo Maintenance??
- Can I stand the stock radiator up if I modify the core support?
- exhaust housing q
- hp/boost ##
- Patriot Gold Valve Springs on a stock motor
- why is whats his name selling his twin turbo?
- boost????
- Who has BEST PRICE on F1C Procharger System?
- STS Rear Mount Maximum Boost?
- turbo headers
- Belt Alignment On A D!sc.
- TURBO or SUPERCHARGE?
- Home built D1-SC and fmic, finally got to start it (Vid & Pics)
- 2 step
- Whose running HV oil pumps?
- would supercharger from a lt1 work on an ls1
- Patriot duals: Gold or Gold Extreme?
- Anyone use Royal Purple?
- p1sc ls1 pully size q?
- Forged 347
- People w/a catch can is there a oil smell?
- 8.5 DCR OK for NA, what about supercharged 6#s???
- fuel cut 2 step
- PLX Wideband
- those with ams1000
- rad size 4 relocation
- What way to go suggestions wanted
- Had a good time at the Pinks all-out thing..
- I need help....1969 camaro LS series motor
- heads/cam for a procharged ls1
- 427 procharger F-1A l92 dyno numbers
- D1SC Bigger inlet hat/elbow???
- AEM tru-boost controller?
- 427 or 388 with S88 turbo? cam specs?
- header wrap affecting my AFR?
- doing supercharger install this weekend Vortech guys come inside!
- is it an issue?
- Stock ATI BOV.
- I'm almost there.
- Apexi AVC-R help
- Vortech Supercharged 2006 C6 Z06
- Heads poll for D1SC and stock 346
- Best head / intake combo for 427ci FI build
- quiet bov or bypass valves
- What size air filters are you guys using?
- Katech Tensioner
- going back to the dyno monday to finish 635 so far with fuel pump problem and no timi
- OIL restrictor starting place.
- Going FI, basic necessities?
- 106MM 347 in a GN build thread
- My new setup: P-1SC w/ forged 347 (632 RWHP)!!
- A few ?s guys
- 90degree silicone elbows OFF the intercooler?
- Zangel
- Little bit of progress on my GT47-88 project
- Turbo oil question????!!!
- So whats the status of all the Hi-Flo kits??
- DynoTune Boost Gauge Sending Unit ?
- oil return line location
- A2A intercooler
- LS6 Head and Cam and Vortech V9 Kit?
- sts and homemade rearmount guys pcv???
- New Dyno#'s - WTF is Going On?
- Auto=SC Manual=Turbo?
- 650rwhp help on ignition...
- Stock Bottom End, Stock Head A&A P1SC Dyno Numbers
- Mild DD turbo...questions.
- where to find boost-a-pumps
- Money Well Spent!! Procharged C5
- innovate gauge mounting
- Please help me choose a heads/cam/intake setup
- quick pics of pt88 build
- Started my car today and its running like crap?
- restricting oil to turbo?
- fabricate your own 8-Rib Balancer
- for u guys that want a supercharger on ur intake manifold
- Alkycontrol knob...?
- Air to Air intercooler efficiency
- Vortech Mondo and race bypass
- boost???
- Turbo or Nitrous
- LPE 100 mm MAF
- 408 shortblock build or buy???
- headers
- New S88 turbo hits the track.....
- SDCE kit question
- procharger d1sc
- Recent pics of my Turbo Formy...
- Who's running meth
- Tried search, looking for people with STS kits and dual exhaust
- Where to buy 3bar for a corvette
- Tial BOV 9psi or 11psi spring?
- Cleaning a intercooler??
- AEM Map Sensor
- My DIY 6.0L manifold build thread
- sts turbo vs. headers cams...
- turbo exhaust pics?
- alky injection kit installed finally, almost
- Balancer
- Thoughts& opinions on ATI D1
- d-1sc question
- questions about the LS2 Power+Plus Typhoon Manifold
- OFI build taking shape..no 56k
- Custom Turbo Set Up. Will It Work
- TOO much boost..
- 98 pcm with 2 bar map os
- Twin turbo question
- 2 bar map sensor
- New STS Dyno numbers (T76)
- What SIZE twin turbo's for a forged 6.0L IRON BLOCK
- Ok seriously how big to go for engine size?
- Wideband tailpipe reading after cats ?
- tryed search but no good what the most boost from P1SC?
- Turbo ignition coils: LS7 or Truck coils
- FMIC's..T/A no cutting bumper
- Vortech hood rape?
- not gonna make it out this year
- Wideband O2 STS turbo mounting??
- Anyone ever wonder why Supra BOV's sound so badass?
- Synergy GTO Twin Turbo pics.
- Dyno Chart: Is This Belt Slip ?
- APS v/s Gen-TT
- procharger 4 1/2" intercoolers...
- Is it worth removing the stock cats for straight pipes?
- Few changes for Spring..
- 6 Bolt AFR heads
- Turbo Suggestions
- Injector drivers
- Tires for Higher HP FI cars... ? ?
- ProCharger idler pulley issues...AGAIN!
- Which 160# injectors are you turbo guys running?
- Improved Throttle Response
- APS TT GTO You Fbody guys are gonna love APS
- Ultimate Sleeper 1987 Chevy C20 with nasty 355
- set up ???
- Turbo Heat issues
- what are you engine temps at end of run?
- I Got To Ride In This!!!!!!!!!!
- Twin T-61 Mustang Project - Part 2 - 883rwhp/715rwtq
- lt1 throttle body straight adapter
- Goin FMIC on my T/A, couple ?'s
- F1A with Air Conditioning???
- question about my PCV w/ STS
- Moved my turbo Formy...
- 408+P1SC-1 Boost results
- STS turbo - Can I run 9PSI on a stock LT1 motor
- Wrapping [B]INTAKE[/B] side of sts?
- What sounds better?
- how much boost?
- 25 psi and minus intake temps
- FI guys what motor oil are you running?
- Turbo Setup Gurus.. I have a few questions..
- LS7 Intake under boost
- Why are headers bad with STS?
- mandrel bending services ??
- My 1st Passes of 2007
- Tune thread!
- Turbo intake for mustang project
- Started turbo system..
- gagues and sensors
- which kits better (Turbo)
- Downsides of 3 bar MAP sensor?
- sound of t76 on a truck manifold kit?
- Mixing VP 116 with Sunoco Pump 94?
- bearing-flange turbo questions (LT1)
- More Turbo Pics!!!!
