View Full Version : LT1-LT4 Modifications
  1. went to the dyno today
  2. your opinion valued
  3. My new supension set up
  4. Need help/info asap
  5. motor and tranny
  6. Replacing LT1 barings
  7. Car won't start when its cold out
  8. Slp Cold Air Lt1
  9. cut and extend harness?
  10. Need a 96 LT1 ignition module!
  11. throttle cable question for carbed or single plane guys
  12. Coil dual connector plug
  13. got a quote for lt and td install
  14. Air pump removal
  15. Best LT1 cam for mild headword
  16. speed pro 383 pistons - HP capacity?
  17. lt4 flexplate ?
  18. lt1 problem!!!
  19. connecting rods??
  20. Took it out today
  21. Low oil level sensor??
  22. Alternator Relocation Kit
  23. Which water pump?
  24. Squeak/Chirp coming from under car at low speeds
  25. Ewp Heating Problems
  26. which clutch to buy
  27. Baaaaaaaaaaaaaarrrf!!!!!
  28. STS turbo kit install? driveablity? MPG? etc?
  29. whos got the best deal on opti's?
  30. 396 LT4, Needs TB.HELP! Mono or twin 58mm?
  31. I know this is not the section for this but, I Need a 96 LT1 (6-speed) engine harnes
  32. Can i offset my rear wheels?
  33. valve spring question
  34. slp air intake ?
  35. buying a high mileage lt1=bad idea?
  36. New Coil
  37. special way for porting LT1 intake manifold
  38. Car has trouble starting after new motor
  39. -40* Timing?
  40. Plate kit (N2O)
  41. 1991 Rx-7 (302ci) vs. 1993 T/A
  42. About to buy....any suggestions?
  43. Started new motor for next season. thoughts?
  44. 1.7 Rocker arm geometry
  45. edelbrock/bbk 52mm TB HP
  46. please help-my head hurts
  47. Anyone like Borg Warner parts brand?
  48. Tranny Mount A4?
  49. Got it now..
  50. Kinda confused looked on comps site..
  51. keep have trouble
  52. o2 sensor question
  53. wat to get for 150-175 bucks?
  54. Roller Rockers
  55. Camshaft Timing Chain and Gear Question
  56. 1988 Rx-7 Vs LT1?
  57. Anyone need some nice pushrods??>>
  58. show me some lt1's running 11's!!
  59. Just installed LS1 driveshaft...
  60. car over heating very quickly
  61. misfiring like crazy
  62. What pushrods should I use?
  63. Intake Elbow do anything?
  64. EWP guys come in!
  65. Cam ID
  66. What mod to buy first??
  67. Anyone sell good 355 short/long blocks other than Golen?
  68. Has anyone used the Accel opti
  69. Official 'What You got for Christmas' Thread!
  70. How much are my gears hurting me?
  71. 396 stroker Shortblock
  72. 1.6 RR worth it?
  73. oil pressure
  74. engine building questions...
  75. lt1 edit
  76. Christmas Mods Opinions
  77. LT1 What rpm is over rev? How to change rev limter?
  78. Fuel line question???
  79. just a clip of my CC306
  80. 97+ Bezel in 93-96 cluster
  81. superflow number to dynjet numbers???
  82. A/C removal
  83. is this worth it?
  84. What Kind Of Numbers Can I Make Cc503
  85. help choosing H/C package for 388 stroker kit
  86. 355 Piston questions
  87. LT1 into a 95 3.4?
  88. ET Performance LT1 Heads
  89. Need help with LT1 Turbo setup
  90. SJM Line lock/ABS delete
  91. Clutch problems, need help
  92. Installing Pillar Pod on 96 T/A
  93. Car won't start
  94. trans dipstick
  95. Compression ratio with these pistons???
  96. driving me insane... any more suggestions?
  97. fuel enable bypass
  98. Everyones Fav video of their LT1
  99. Clutch question
  100. PICs of my Tear down before pulling(56K= not worth the wait)
  101. dynoed Again!
  102. cleaning intake
  103. Sombody Help Me!!!
  104. What ive been up to...
  105. Exterior Appearance is complete
  106. bmr k-member install
  107. will a cc503cam in a 383ci with 11:1 compression make around 400hp 450 tq
  108. Need help pricing my car for sale
  109. So the car won't start
  110. Merry Christmas Fellow LT'rs
  111. Need help fast
  112. Cam Parts...
  113. high performance oil pump?
  114. lt1 into a lt4
  115. Sticky injectors?
  116. Where To Buy Tranny Ready To Go
  117. Whats the other cable on my tb for
  118. MSD Opti... car won't start
  119. Anyone have a hard time finding an exhaust shop to hook up true duals?
  120. Need answer Fast! LT1 Impala SS push rod length??
  121. lope
  122. TH-350 or 400 conversion
  123. lt1 Canton pan owners
  124. new motor problem
  125. 385ci Solid Roller Cam
  126. emission or not headers
  127. My car hates me
  128. removing waterpump????
  129. Idle Point for my car?
  130. Scored me an intake CHEAP
  131. OBD Question
  132. Whats the ideal oil for an LT1?
  133. Shift points higher after stall installed
  134. I'll be willing to bet not many of you have ever herd of this before(starting problm)
  135. 374's or 643's?
  136. Anyone looking for LT1 parts or a car?
  137. Gen 1 RR for LT1 question.....
  138. Decided to pull motor
  139. lt1 missing problem
  140. belt length with underdrive?
  141. Jet Stage 2 chip/module ?
  142. 3.42 guys need your help
  143. Interesting Chirping Sound -- Looking for Insight
  144. just about ready to drop in!
  145. looking for piston weights for...
  146. Stroker guys come in
  147. Need quick response
  148. Lt1 Water pump Hose connection to stock 1970 c10 radiator.
  149. cc503 Vid: Cold Start
  150. Coolant in the car?
  151. Vacume port on TB does nothing is this normal ?
  152. How many optis/caps/rotors have you guys gone through
  153. Are LT1 cams hollow?
  154. New HOLLEY 52mm, having TPS problems, please help!
  155. Whats it worth??
  156. off to the body shop
  157. 383's w/ scat forged h-beams come in!
  158. Look what i found.
  159. 02 wiring help please
  160. Help! What goes behind my intake manifold?
  161. Help!!! Problem Starting car!!!
  162. tried searching but came up short. Who has the fastest shortblock car?
  163. income tax returns
  164. Best LT1 stock head casting
  165. lt1 clearanced oil pan
  166. AC compressor Q
  167. What balancer for 97z with 383?
  168. 96 Vette Lt1
  169. lt1 heads
  170. 383 lineup
  171. 3/8 and 7/16
  172. Who does your machine work?
  173. How to Fix Stall Wall?
  174. Top Dead Center
  175. 383 stroker
  176. installed my pacesetters, fitting problem
  177. Flywheel ??
  178. LT1 into a ZR2
  179. O2 sensor question
  180. Head and cam questions??
  181. NSA or SA rockers??
  182. Solid Roller Question
  183. Does anyone make a power steering delete kit for LT1 cars?
  184. 10 second bound!!!!!
  185. Can't get the hub off the crank
  186. LT1 Guys Come on in!
  187. Casting number questions
  188. ultra z hood
  189. Compression question
  190. Are my motormounts shot, or is the y-pipe hanging loose?
  191. cracked header
  192. about engine
  193. OPTI vent question
  194. custom grind cam
  195. will this work?
  196. Cam packages?
  197. How critical is a High volume oil pan?
  198. Engine Problems
  199. Pilot bearing???
  200. trick flow heads coolant port??
  201. Question about opti..
  202. Whats the best clutch for a worked LT4
  203. ARP balancer
  204. Removing or bypassing the EVAP canister
  205. Kook's Headers
  206. ignition trouble!!
  207. no fire when starting!!! I just bought it too.
  208. Your plans for next season
  209. A/C Delete
  210. Racetronix Injectors
  211. another stupid question :)
  212. does a bigger throttle body really help
  213. cooling fans not working....
  214. steel braided fuel lines for the LT1
  215. Comp Xfi 230/236
  216. ingnition crapped out on me
  217. where is the best place in CA to have my buddys 383 lt1 tuned?
  218. LT1 M6 Shift Points
  219. Educate me about RPM's
  220. Best 60' with 6 spd. and bone stock rear
  221. Injectors
  222. 95 LT1 Spedometer/RPM Gauge
  223. A bit of trouble when starting
  224. Is it a sign???
  225. Mallory 685 LT1 settings
  226. What cam for highway?
  227. Too big?
  228. LT1 white gauge overlay question
  229. New hood cam in...finally!!
  230. cam thread
  231. Lightest Stock Wheel???
  232. powerdyne
  233. Converting to manual brakes...
  234. Weld up kits for LT1??? and a few other BS questions...
  235. Top reason we should all sell our LTx cars
  236. pushrod length, help!
  237. LS1 Intake Coversion
  238. Stock Suspension Record?
  239. 3" intake piping not so good?
  240. LT1 fuel rail question
  241. Discharging the A/C
  242. At what point are stepped headers necessary?
  243. Best Valve Stem Seals?
  244. set up question
  245. Lt1 gas mileage, worse than ls1 ?
  246. 94 A4 stock gear are 2:73s or 3:42s? also what carrier 2 or 3
  247. Headers out the top or bottom?
  248. will I be able to hit low 12s to 11s with the set-up
  249. Comp Springs for ported heads and stroker
  250. WTF is the PCV valve for?
