View Full Version : LT1-LT4 Modifications
- need some rear end advice
- having trouble installing passenger side pacesetter
- Any tube chassis LT1s?
- Abs Inop Light?
- Valve Springs
- help me identify my injectors please!
- cam change??
- leaking oil...need help
- can I run the NOS dry kit on my 93' speed density?
- Few mods on my mind, need opinions and which order would be the best to put them on?
- stumble at low rpms T56
- pcm programing
- LT1 true dual input needed...
- mallory 685 question need help asap please
- Lt1 ?
- I hate my crank hub...
- Le 1.5 Numbers
- LE1 Cam specs?
- 94 LT1 Canton pan sits on steering rack
- No F/S threads in the LT1 section
- Timing Cover When Running an Electric Water Pump?
- Oil pressure gauge?
- Need suggestions for a fuel pump
- lookin for some tips
- 94 LT1 motor into a 96 trans am
- Balancing and Blue Printing?
- Performance Upgrade List for Camaros and Firebirds
- ticking noise?
- Headers and tubular K-member
- Crane HI-6R woes. Help!
- To cam or not to cam...that IS the question!
- 93 throttle body pic
- is it worth it
- another problem
- ignition problems
- Whats wrong with my turn signals VID
- 396 numbers ????????
- Turbo LT1's?
- Engine Oil
- True Duals! Pics and Vid
- Any sponsor vendors sell a neutral balanced LT1 M6 Flywheel?
- Had a wreck some major help please
- Whch valve do I use to recharge the AC
- bearing cap torque specs
- Tsp Rumbler On A Lt1 355
- procharger or le2
- Compresion
- I'm STUMPED! Wierd one, Any takers?
- Killed me some fords last night!
- Clutch Master cylinder mod?
- lt1 tranny ?
- A true dual exhaust video clip
- Power Seats/Window Defogger relay
- If you want a cheaper possibly stepped stainless header option step inside
- New to f-bodies and need some advise
- how healthy is my LT1?
- Spark Plug Tips Are Orange?????
- Exhuast
- Why is my fuel pump not running? PLEASE HELP!!!
- who has sent their heads to lloyd for work?
- valve lash help
- cam for LT4 heads/intake
- upgrade mechanical waterpump?
- Electric waterpump
- used rods
- 383 Stroker Kit
- Fans arent turning on
- Car wont start after Header install
- CC305 ?s
- LT1 Knock numbers? Anyone seen any?
- LE2 + 150 shot = stock short block??
- Headers and exhaust installed!
- 97 camaro m6
- opti, opti, opti...oh what luck i have.....
- AFR 210's vs SR355
- Another question.
- LT4 or LE2
- 1996 Trans Am WS6 + hypertech chip, reflash, whateveritscalled = ?
- maf and tb ?
- 1/4 time
- hotcam guys come in
- 402 Complete..
- Need Help In Choosing Headers/exhaust
- Can't get valve cover off
- oil capacity
- Outlet diameter of factory muffler?
- 75 psi of oil pressure "warm"
- IS this enough for a 200 shot of n20
- how many of you daily drive your E waterpump
- Over The Top Spark Plug Wires.
- Shorty Block Hugger Headers
- Need a measurement
- Question on the LT1
- Perplexing Oil Pressure issue on new motor
- Injector question
- 12 Bolt
- how much HP/Torque?
- Time to do some mods...
- ABS Light???
- Why are mods locking threads in this section telling us to do a search
- launchin a A4
- magnaflow catback
- port stock heads/buy cam and ?
- Sb2.2 Heads
- Help me choose between two grinds
- Good cam for stock shortblock?
- Delteq or LTCC??
- Advantage of an LT1 block vs SBC block...
- What do you think of this cam?
- gear ratio untuned
- slp loudmouth 1?
- Oil Pressure question.
- Innovate LC-1 wideband install
- idle vid for 233/239
- TH400 Question
- notice to LT1's with LS1 center console, custom mount for sale
- 550 hp LT1 build
- Dirty Injectors
- im looking to get an LT1
- Does this appear to be an SLP SS?
- pics of dash removal and a few questions
- Those of you who did a fuel pump without racetronix chime in
- Project update..
- Fitting Driver Header In Place
- un-vented opti dowel pin length
- Possible blown head gasket... With a twist!
- More than one kind 02 extentions to buy?
- Need help in chosing my LT1
- You ever get to that ONE point......
- SES light problem
- Cam price
- removing valve covers.
- Tach signal?
- Juice On A Stock Motor
- PCM Question
- plugs and wirs
- What do you guys think?
- Running rich!
- What numbers shoud I excpet from this?
- 96 formula upgrade to 98-02 tail lights
- Optispark ?
- My LT4 Knock Module is junk...WTF
- pcmforless
- muffler delete
- A4 Won't Upshift at WOT/ Backfiring
- True duals?
- very wierd? need help
- cam change??
- LT4 vs. 03 Cobra
- LT1 intake gains... is it worth it?
- My Track Times before/after Converter...
- lt1 brake swap question
- Header install.... O2 delete?
- best spark plugs for the lt1?
- New motor progress!
- Oil Sending unit
- new setup no oil pressure
- rear main seal?
- best header gaskets?
- I need help asap.
- Reccomended dampners and hub?
- who has dynoed a 847 cam?
- Heating & cooling...
- SES Light??
- Valve spring install tool??
- People with ATI Dampners..
- delteq/LS1 coil packs
- have around a gradn to spend
- code 36 and 42. New opti, and new icm, icm ground, plugs, and wires. What the?
- Who's considering the 09 Camaro?
- 1 7/8 or Stepped Headers???
- Lets Look at BLOWER CAMS Guru's
- O2 Sensors Questions.
- 950rwhp LT4 in Parts For Sale section
- valve springs?
- how long should a cam swap take?
- Cutting out at WOT!
- Dyno vid
- LS1 Airlid Conversion, WITH PICS!!!
- crank hub
- Will ls1 coil springs fit in my 96ws6?
- I have no idea whats wrong
- "Gauge" fuse blows when I put M6 in reverse
- Stall Or No Stall For Lt1/nos
- How many miles can I expect from my LT1?
- oem convertor color
- Spark plug wire routing
- high idle
- Fuel Pump Upgrade Help ... Gauge now pegged at Full ???
- Ready to give up!!! PLEASE HELP!!!!
- ABS InOp, and ticking noise (possibly manifold...who knows)
- extra 6speed center console laying around?
- How many bolts holding on stock manifold
- intake conversion
- ls1 lid? Tried search.
- LS1 nose to LT1 nose?
- My LT1 feels slow...
- MSD Probillet distributer for lt1
- what's involved in lowering the Z?
- new edelbrock LT4 intake just arrived....my thoughts
- Dyno results are in
- Time to start modding
- LS1 SS spoiler
- lt1 build up help
- ready to blow up motor, cant figure out problem
- My camaro is slow!
- shorties or lt's
- LT1 Sonoma help
- Need some input
- blown ignition fuse?
- stock LT1 head volume question
- Help me make shopping list...
- Got in the 11's today
- Tourque Specs
- Car wont start! Need help ASAP
- Need Help Selling this LT1
- msd opti-spark - FRESH AIR HOSES-VENT??
- Where does this wire go? (PIC)
- what size throttle body
- $2000 Budget What Shoud I Buy
- first night at the track
- Possible bad program/tune????
- Lt4 Head
- need new radiator-how about fluidyne ?
- Installing Headers
- cam for 383 LT1 w/D1SC 12 lbs
- Whistle from under timing cover?
- tuning options other that LT1Edit?
- Rods/Pistons?
- Air-Gap Intake Man
- any interest in my trans, 2 LT1 Street twins clutch assemblies, and more...
- LT4 "Hot Cam" purchase
- ss lt1 hood
- intake manifold done!!!
- fan switch=a/c issues?
- Car wont turn over
- Cam/intake question
- Car Dose not START!!!! only when i drop clutch.
- Ever used mx scan
- Air condition is blowin hot air
- Better cam for my setup...
- spedo stuck at 150mph
- Looking foe info on the lt-5
- Best Y-Pipe Hooker Headers
- fuel pump?
- what opti to get....
- after pacesetter lt install
- For those who question your Optispark look here...
- 94' LT1......wire question.....
- Whats it worth?
