View Full Version : Forced Induction
- Sucked a chassis washer into my Z06!
- what spark plugs to run with turbo?
- ati procharger p1sc for gm truck
- Good Twin Turbos
- Vortech or ATI Procharger?
- Cooling concerns with new combo?
- Powerdyne Superchargers
- Z06 cam or Futral F7? Which one would you use?
- Where is Lasershop?
- Anyone checked this company out???
- Custom homemade air to water intercooler...
- Help finding weldon 9200 fluid pump for incons
- STS Help!!
- Slowhawks at it again...victor intake on purevl
- How much valvespring pressure?
- PSC1 for 5.3 Silervado will it fit Fbody?
- Finished!!!! Pics
- 408 truck with D1SC, good idea?
- Turbo Help!
- Best of all FI kits
- Best Intake for Forced Induction? (Supercharger)
- What spring for tial BOV
- 2 small gates vs. 1 big gate
- P1SC Boost VS D1SC boost
- True Duals
- 6.0 Crank boost - HP ???
- 6 days to decide on what turbo...one last thread.
- Header studs??
- Which gaskets and bolts for heads for boost ??
- Car misfires and sputters really really bad when under boost
- Turbo heads
- Looking for possibly a cheaper 76millimeter turbo replacement
- 80mm turbo
- 688 rwhp and 697.9 ft lbs of torque with a D-1SC at 14 psi
- How to adjust BOV
- D1SC Dyno Sheets??
- Need Help!!
- twin turbo collectors?
- what the difference between(flow wise): stock ls1 exhaust manifold & 6.0 exhaust mani
- best plugs, wires, and gap to run with boost?
- Anyone have success using toulene
- New Pics of Setup!
- LQ9 heads are done
- Question about turbo
- Speed Inc. Turbo?
- A couple questions for the gen III experienced...
- You won't believe this sh@&!!!!!
- Turbo kit for Trailblazer
- Crank/SC support
- BBK 80 mm throttle body ?
- Rotrex superchargers?
- Blow-through 750 carb?
- ATI Harmonic Dampener Pics (For Procharger)
- more STS numbers
- How much boost with these pulleys?
- What Kind of Power Can I Expect
- Spark plugs with boost???
- Plug gap for FI
- twin turbo gto?
- Why are turbos and Centrifugal superchargers so different?
- Almost ready to go again
- 427 turbos
- pics of my homemade turbo system
- Which B.O.V. for high power
- Help me out...
- how much are S/C benefitted by a small blower cam?
- Twin Screw's and Root's Blowers
- WTB: f-body lt1 supercharger
- Why I had been losing boost (pics)
- Installing Magnacharger on ls1
- Evap question on 2002 Turbo Z
- Do you guys fuse your gauges?
- s/c and cam ?
- looking for a good place to buy a T76, T67, or T61.
- 2001 clucth master mod ?
- some turbo help please!!!
- Turbo Oil Pump Noise?
- What needs to be done to the suspension on a blower car?
- Blue silicon couplings for piping?
- Turbo-acceptable shaft play (side to side)
- Heads???
- What Compression should I run
- Superchargers and Turbos Available At TBYRNE Motorsports!
- Engine Management, which PCM.
- Got My Stuff.....well Most Of It
- BOV. Does this sound right?
- Boost gauge question?
- Installed STS kit...AC running 24/7. Any ideas?
- GMR single turbo question-GMR Single Turbo???
- can this piece be purchased?
- CAS twin turbo car FINALLY running...
- what is lame about kyle's setup is that...
- Which supercharger cam? GT 2-3 or Speed inc SC1
- Twin Turbo Z06 Dyno Results
- twin T04E sizing question
- Building a Block thats turbo friendly, help
- Looking for a little guidance
- maf with supercharger problems
- Dyno again :( again
- Best deal on short block (assembled)
- Ok.. I give up.. where is it?
- How much boost?
- Any pics of Magnuson blowers on F-bodies?
- What else to buy
- Paging JZ 97 SS 1500
- Sts Intercooler
- Fox LS1, Single or Twin Turbo Setup?
- Tuning my turbo car
- is this a good turbo cam
- Need input....I want a SC. Waaaaaah!!
- Magnacharger camshaft suggestions?
- How does lower CR help with boost?
- Pictures of the Limit engineer 91 turbo for "Fear"
- low gear for turbo?
- Speed density tune with turbo?
- Mthanol Injection, IAT Sensor, and MAF Sensor
- Turbo Or Supercharger?
- LS1 S-10 Turbo
- Sneak pictures of my custom turbo fuel tank.
- STS+8psi+Meth Inj.=Boom on stock block?
- F13 and PP 59cc heads with turbo
- 1st day track results
- FI - Timing Chain
- What parts do you need for a turbo install?
- The Turbonetics Super T76
- Building new engine!! Need Advice
- vortech dampaner
- how much boost
- Power Outlook
- Adjusting Boost level need Tune?????
- Engine compartment paint on turbo setup?
- which fuel pump should i get???
- wastegate spring problem
- Correct oil for my turbo setup...
- Anybody know whats going on with the HI FLO kit?
- meth injection help.... few ?'s
- Quiet or loud S/C?
- When is O-ringing the block called for?
- Whats the best way to cool off a turbo?
- Advice: Looking to maybe purchase a STS kit and need info with my set-up.
- Spark Plug FI Question
- Installed the ATI D1SC? Come inside...
- FI guy's have a question on my build motor
- Dropping stock comp.
- What compression ratio and boost level are you running?
- STS kits, how much did you guys pay?
- congrats to red91Z for chevy high performance magazine
- Going to be one mean STS Car!!
- Supercharging a High-compression Motor.
- New Best Today! Details/Video inside!
- Boost Control Diagram
- STS turbos?
- update on slow progress
- Evaluate my FI setup!!!!
- new setup quistions
- Cam question
- Best Compression Ratio for Turbo
- Gauges Necessary for FI
- You saw the graph, here's the video...
- Turbo size for a 402???
- Turbo Mounting Angle
- What do you think about this set-up???
- Flex-a-lite fans
- using the SD-concepts tentioner with the Procharger 8 rib crank pulley?
- Farewell supercharger, hello turbo setup (coated manifold pics)
- ebay turbo crap
- Stainless or Mild Steel
- pulley sizes
- Procharger D1SC video/sound clips
- boost limitations 30+psi?
- S88 Questions???
- innovative twin turbo manifolds?
- 402 + P-1SC @ 6 psi Dyno results
- Need help planning my setup
- Turbo Mounting
- turbo cam
- Is the only difference between a TT and a T set-up.....
- Jose, Where Are Ya?
- what timeing chain? ls2 or double roller for FI
- almost there!
- PICS!!! Turbo headers,clutch,Fuel Rail Covers
- My Stenod Performance Single Turbo Build-up Almost there..
- QMP setup opinions?
- Not enough fuel?
- Incon TT for sale...$6500
- What are cars like ours worth?
- ANyone have a Q trim on center housing for sale/trade?
- D1-SC and 91 octane?
- SDCE 8 rib setup pics?
- Dyno Results :(
- Simple turbo cam question
- S95 turbo vs GT55-91mm
- Best Setup for Reliable 600hp Near Stock LS1?
- Turbo Exhaust Questions
- Stenod Performance...new for '06!!
- Single "STREET" turbo guys post up
- tuning a supercharged car?????
- which headgaskets ?
- 90mm MAGNACHARGER !!!
- boost gauge problems
- t60 TO A t67
- Heads/Cam for ATI ProCharger D-1SC
- Supercharged Ls1 Help
- METH Users Inside..........
- 2006 C6 Twin Turbo Project In Progress
- Fan ?
- t70 or t76 on a built 346
- Ls1 intake and stock throttle body restriction??
- 597 rwhp on Mustang Chassis Dyno with 11 psi of boost with stock LS6 heads and cam
- Blowing Dip Stick Out
- Custom turbo build
- incon trouble, need pics!
- Squires Turbo?
- Vortech Horespower
- Future procharger build any suggestions ?
- supercharger cam
- Procharger Balancer Confusion????
- 3.73 gears OK for FI?
- AllPro Head Question
- Twin GT3076R Turbos - .63 or .82 A/R?
- Lid filler with Turbo
- Procharger Twin to FMIC.. how to go about plumbing?
- just purchased my turbo kit!! help inside
- Picture Meth Injections
- 6.0L manifold question
- Procharger Filter?
- Waiting we are...
- Need A Wg....any Sponsors Feel Sorry For Me
- Custom T4 turbo bracket to mount to chassis
- D1SC install questions
- D1SC oil change questions??
- asp pulleys
- camaro root style SC
- Future Procharger Build ideas, suggestions??
- turbo fellas jump in
- For you guys in the FI section - KB unit release:
- turbo cam
- gt40 or 62-1 or what?
- cam choice
- First time organizing my turbo/fuel system
- Dyno this week
- a question about available turbo kits out there.
- SLP radiator with LS1 procharger kit?
- variable geometry turbo
- Cheap Silicone Tubing Adapters?
- FMIC on a vortech LT1 car??
- Going over my list for STS install...please tell me if I'm missing something
- vortech guys!
- Wrapped or coated???
- sts cough need help!
