View Full Version : LT1-LT4 Modifications
- cant find elbow sleeve?
- Door handle question
- Supercharger?
- Will this "ebay" Y-pipe work with my headers?
- NEW lt1 hauler!! well new to me
- lt1 exaust
- lt1 exaust
- 20 Degree and low coolant light come up
- Best tune?
- Timing cover seal installer
- interior parts
- A few seconds..
- Fast LT1 guys come in... 383LT1, Fast DFI etc... Come
- OTVC plug wires
- Tranny Question
- Intake Elbow
- what cube LT1 should i build??
- Sweet Z28 Convertible inside!
- Camaro gt1 hood
- OBDII to OBDI conversion
- 1993-1997 Stainless Steel Y-Pipe $80 SHIPPED
- Ls1Tech Calender.
- Very low end miss.
- Best mid length headers for 95 z28..??
- codes from AZ
- crank repair sleeve
- Shift light
- Need help picking a stall for a Turbo LT1
- carb intake question
- 95 Trans Am spark plug stuck not stripped, maybe rusted shut, and feul promblems
- 52mm TB to 58mm TB no tune?
- Getting the car back on the road after almost 2 years
- Strange 12 or 9
- Stall Question
- Right bank killing O2 sensors?
- Changing wiring harnesses
- Rotating Assembly
- Coolant Frozen
- NPT plug size in LT1 heads? Is it 1/4"-20?
- Best oil for my LT1?
- LT1 fuel fire n o start
- Question!!!!
- How to change rev limiter ?
- Ever Use These Head Gaskets?
- Replacing opti, do water pump at same time?
- Ring gap, this ok?
- head gasket question
- arp headbolts
- Looking for a Vic E
- GAS!! epic fail
- Keep Cam....or... Sell to buy Stall?
- 1996 WS6 Smells Like gas inside and outside of car.
- Car Still Slow, Getting Sick Of It
- 1996 WS6 6speed Transmission shakes when i let clutch out?
- Who wants a little LT4 manifold??
- Cracked Dash? Need Advice
- piston and ring kit.
- heads/cam
- EVAP solenoid resistor
- Overheating
- GMPP / SLP Cold air intake on a 93 w/ no maf sensor?
- p1441
- LT1s running skinnys on the street
- Stock style replacement radiator?
- what gears 3.73 or 3.90's
- head gaskets
- 4l60e
- Set up question:transmission
- Getting started with FAST
- What's next?
- really bad oil leak
- Dick Harrel rear flares
- Le1+Hot cam what injectors
- LT1 Heads FS/T
- Anyone got Borla Cat-Back Adjustable Plates?
- Seats and Defroster Circuit Breaker
- Removed my balancer/crank hub, got a ??
- Got the Cam... Now I got some questions...
- Borla or True duals?
- 1997 camaro shell
- accessories brackets
- stripped crank snout
- Help w/Data log on Datamaster 4.0
- The Fastest Bolt On Only LT1's in the World List
- Vic E with elbow and WS6 hood
- 2.5" or 3" True duals? And what muffler to go with....
- Part # needed
- bumper repair
- How much compression does a Shim gasket add
- Using a 94 MSD opti with a 95+ cam?
- Is this guy pulling my chain?
- Process for swapping out to 1.6 Comp Cam roller rockers?
- quck/electric dissconect sway bar links off road style?
- Small starter wiring question
- Good Bye LT1....
- backfire intake exahust
- Lt1 stock rebuild kit
- FAST Computers
- Beaten to death injector question.
- CC503 or GM846, will it pass emissions with a tune??
- Need some help guys
- Stock rings and rod bearings
- does any1 have a picture
- LS1 lid swap is easy
- Cheap LT4KM?
- How much hp can stock 4L60E handle?
- help with 94 Z28 camaro
- 94 and up questions
- electric cut out wireing
- headers?
- EGR AIR delete?
- msd crank trigger
- Which muffler to choose?
- Removing heads
- LT1 Novi 2000 supercharged
- Lt1 Revving On Its Own....
- y pipe question
- whats the best approach?
- Quick question about intake porting
- What kinda of hp u guys think??
- Born to go fast
- small problem
- Oil on Optispark
- Low Coolant light after high rpm
- Intake Manifold??
- Let Me Introduce Myself
- BRE Cam
- cam install & degree
- power + clutch = $$$$
- Question about TCS and the SJM Hurst Style ABS Delete w/ Line Lock
- 93 opti replacement?
- is this suspension ok for daily driver
- Help changing timing cover gaskets!
- 24lb injectors
- spark plugs? advise please.
- 375hp? +/-
- Fuel Pressure Regulator Vacuum?
- Torqued studs down on heads. A few studs show more threads, should I.......
- Gaskets
- Gen 1 SBC guys inside
- Any one used or heard of this stall ???
- Gears installed Dallas Tx area???
- Horrible vibration
- camaro z28 fans
- Convertor size for a Stock LT1 with a 373
- lt1pcmtuning.com
- Coolant in oil...
- Isky adjustable pushrod guide plates
- Which Cloyes timing set for LT1
- 1.7 rockers on stock cam lift?
- k-member???
- Golen Heads
- Keep My Magnaflow Tips (And Polish Them) or Get Corsa Clones?
- Gears, Cam, & Stall???
- Idle vid just because!
- hooker super comps
- tune and steering wheels
- winter mods
- code p0141 and code p0300 thrown together what does it mean??
- modifying a injector rail for 900hp
- water pump Question on instalation
- Replacing Foglight
- Trick Flow LT1 Heads for sale
- part number for scorpion 1.6 7/16 stud rockers
- Aftermarket Pulley and Damper?
- Removing ABS system
- PCM Question
- LT1 Tuner in Orange County, CA
- Stock LS lifters vs LT1 lifters
- datalog with a/f readings
- Jegs Crank Hub #555-51607 replacement?
- Lt1 not running correctly
- fuel pump questions
- Code p0227 throttle pedal position sensor, help!!
- block drain plugs
- looking for this LT1 intake,anyone got one?
- Stock LT1 Times
- Lawhead's 355 Build
- Procomp H-beams?
- Cold start, won't hold steady idle, stalls at stops.
- Hotcam has mild surge when taking off, how to fix it??
- Roadmaster w/ LT1 having ignition issues
- I ordered my tune!!!!
- opti-spark for 93 or 94
- Noob Question - Removing PCM
- Cheap opti?
- Rear end gears
- Hooker headers question
- Whole new exhaust set up question
- What sensor is this??? pics inside
- cat question
- Skeptical about water pump? help!!!!!
- lt4 heads
- where are the ls1's?
- P0443, P1657, possible bad PCM
- opti/throttle body advice
- Popping/back firing
- Give me a goal for my build. What ET to shoot for?
- NEED 2 CATS in any condition!
- Opti problems
- ABS Light Flashing
- STARTING ALL OVER WITH A LT1 BLOCK.. WHAT 1st?
- header gasket
- Are Lt1 head bolts Tty
- Removing LT1 with Tranny attached
- Major help needed, greatly appreciated
- 52mm Throttle Body Help....
- Post your LS1 lid swap!
- Optispark keeps going out
- oil pump gasket??
- good mufflers
- Which 1.6 Roller rockers do you guys recommend?
- RPMs with stock short block
- LT1 timing control question
- Anyone got a used Cam for lt1?
- Draks 94z camaro build thread
- LT1 Setup help...
- Running rough? Opti? maybe?
- A fluff and buff gone wild.
- What is a safe Rev Limiter Setting 4 me?
- all boltons need cam help.
- Those with Stage 8 locking header bolts and LT's
- If i were to cutt out the screen inside my maf sensor?
- No thermostat, no problem???
- MIG or TIG guide plates
- Oil and trans temp gauge
- how far have you pushed the stock suspension?
- Going from cam only to H/C/I and have questions
- Clunking sound when I lightly push the brakes in
- How do you adjust e-brake
- Walbro pump failing? Or pressure regulator?
- Murdered out Formula... MAKING THE CHANGE!!! Part 2
- Clutch problems
- longtubes and slp powerflo
- Fuel gauge fluxuates
- Quick question
- BMR LT1 K-Member help??
- Bad Misfire. Help please.
- Losing Lots of Coolant
- PCM problems
- identifying injectors
- Critique this setup for me
- Engine removal and cam question.
- 3 inch under the axle TD build thread
- Tuner cats vs Tunerpro
- LT1 swap/gbody
- So I can stop an argument me and pops are having
- MSD 6AL Digital?
- post pictures of your rims please i cant find good pix on google
- Need help looking for temperature switch connector
