View Full Version : LT1-LT4 Modifications
- Im not a mechanic i NEED HELP Leave FEED BACK PLZ
- New Problem, Im Thinking Maybe Stall! ??????? !!!
- Bad opti causing code 43(ESC)?
- Wiring Mystery??? Please help!
- SBC Guideplates
- McLeod bell housing install...
- Gm 846 Cammed, need to replace O2, Ac Delco my only option?
- Porting stock Throttle Body
- What A/C delete pulley with under drives?
- bolt on and free mods list
- what kind of damper are you guys using on your 383/396
- cooling fans not coming on
- ABS INOP Light is on because of third brake light?
- o2 sensor
- ATTN about LPP Header fitment
- Texas Motor Speedway Strip Opening
- Dallas/Fort Worth Tuning
- CRT AirForce LT1 Intake Elbow & Air Foil Kit adds 6-10 HP??
- what stock replacement fuel pump should I use?
- Ls1/lt1 tc?
- '93 Camaro LT1 396 with ProCharger F-1A build at EPP
- SVO Brown Top 34# Injectors?
- LT1 Valve Covers!!!
- 30lb svo injector ?'s
- how much power can your stock crank shaft bolts handle
- Low oil sensor plug
- LPP Longtubes w/ Moroso Oil Pan
- ngk tr55 gap question...
- Need Help
- 2009 LTX Shootout Final Results
- What rings for backyard rebuild?
- Stupid exhaust tip question
- LT1 Misfire
- lt1 and manual trans
- Should I? And will it work...
- Question about 'free mods'
- More Issues...
- LTX Shootout
- LT1's with nitrous. What coil are you running?
- Fuel pump question.
- Need HELP!
- aanother opti problem?
- budget stall
- Took Cammed only LT1 to track!! And BROKE!
- Need A/C bolt
- Made my own custom intake (Large pics)
- bets price for gm hotcam kit?
- Best place to buy gaskets
- lt1 mods
- Trip to the track = carnage!
- z28 vs mustang gt
- 1.6rr
- LT1 block identification?
- fan question
- slave cyl help
- LTXTech is back up
- Has this happend to ANYONE with there car before EVER !!!!!
- Tighter LSA's
- GMMG oval exhaust tips
- Opti wiring harness?
- New Best at the LTX Shootout
- 97 formula ws6, 6.0lq4 or rebuild lt1??
- who the
- fuel and idle. WTF!
- A few TCS questions
- high idle
- why would someone hack another site?
- could use some help... get this i accidentally broke my turn signal arm off the colum
- 1989 vette lt1 swap
- Shakedown dyno runs w/ AI H/C (stock shortblock)
- passenger side rear view mirror
- front turn signal...
- New shocks...which brand?
- Gauge cluster swap
- Will these cams fit (94 Z28)?
- crankshafts ???
- What Next?
- Will it work?
- LT1 fuel specialists advice requested
- How much power steering fluid does the system hold?
- Couple questions about rebuild
- should i pulley a 96 firebird formula?
- Re-use stock rods after rod bolts stripped?
- PCM Swap Question
- What would you pay...
- LT1 running wierd, need help
- TB size 95 lt1 and Trick flow elbow ?s
- High Pitch Squeal In Wet Conditions
- Buddy has LT1 problems
- where does this go?
- LT1 Tunercats help....
- what good brand for stock thermostat ?
- ordered pacesetter's now which high flow cats?
- Starter snapped in half
- Lost camera at shootout hotel.
- T-56 bites the dust
- Car runs bad New a tune
- LTX Shootout results
- What to mount LT1 Scanmaster in Trans Am??
- o2 sensor ?
- Cat Delete Questions
- is the 93 AC compressor DIFFERENT than 94-97?
- My Motor is finally complete LE1.6, PICS
- under steering wheel panel 96 trans am?
- Opti spark problem need help
- Running poorly under part throttle
- Street light king?
- need help
- optispark bearing price & avalibility?
- Went to the track!
- radiator?
- 1993 lt1 injectors
- What cat back with my pacesetter lt's and 3" ory?
- HELP daily driver down
- Warlock mufflers?
- header burns threw plugwire
- ebay optisparks?
- plug #7 getting wet with gas
- Cam questions...please help!
- New motor mounts
- WTF is going on with this!!!
- Finally
- Is it real or bs
- What next?
- STEAM coolant pipe
- LT1 cam not roller?
- The mess inside my bellhousing
- is there anyone that can tune my car? local, chicago area.
- .999
- It's coming along
- Estimates on HP and track times please
- Poly Tranny Mount Question...
- Lets build a 427 Dart block LT1
- Which Cat-Back?
- LE2 355 Sound Clip
- 383 Build injector Question
- Ai 230 / 238 take 2
- lt1 swap in to 1978 camaro
- Nitrous timing
- Got some stuff today from Scoggin Dickey and Brakemotive!!!!
- Is it the same???
- How much HP is left on the table with LT pacesetter
- ARP bolt part numbers for Lt1?
- who's got over 600hp running a 4l60?
- Question?
- 4th Gen D/s in a 3rd Gen?
- Weird idle issue
- transmission bolts size
- Car Shakes/Vibrates
- Questions on engine removal
- dropping an LT1 - have a question
- Throwing a P1133 code any thoughts
- Piston To Valve clearance
- Ground issue
- Super Sad Story
- Good set of forged rods and pistons for a 350?
- how much hp can i expect/ 1/4 mile times
- Transmission temp guage help.
- oil problem
- What kind of posi is this?
- shorties
- if your making over 600hp then come in
- Knock Knock!!
- 94 camaro Z28 header question..help please
- New clutch (I wanna go fast)
- The Final Piece is built and Shipped
- Can I even run LT's?
- do i need new bolts?
- cc306 experience step in
- i think we solved the wheelstand issues...
- Free mods?
- Head gasket replacement
- Intake Manifold Gasket Replace.
- looking to buy a twin 52 or 58mm throttle body
- need help pullin motor
- Center bolt valve cover spacers?
- what is this???
- Cutting out WS6 ram air hood
- Looking for Quiet/Smooth Cam - for 10second 383 Nitrous LT1 :)
- msd cap and rotor
- Ai 230 / 238 - .575/.575 - 110 LSA
- Its finally running
- lt1 idle problem
- What mods next for me?
- 1LE Elbow?
- Best Suspension?
- I think I got screwed.
- SLP Exhausts?
- Kotzur Racing engines
- What should my A/F ratio be on a wideband?
- B-Body, F-Body crank hub the same?
- Cowl induction?
- biggest cam on stock LT1
- Converter problem
- need a stall for my 4l60e
- timing problem????
- 396 start up......video
- need a exhaust guru
- 1.6rr ??
- Dart Pro-1/CC306 Start up open header
- Some factory heads better than others?
- After a 2 year hietus FOUL SPARROW rides again!
- Colorado emissions?
- header rubbing on steering knuckle help
- Anyone used this brand of converter?
- WTB T56 Shift knob
- Who sells LT1 ECMs?
- In-Car Fuel Pressure Gauge?
- 2009 LTX Shootout Raceday Schedule Posted
- tips on tuning NEEDED! 94 lt1
- vht time!
- lt1 swap no start.
- Would two TD exhaust cross-overs be a bad thing?
- stock windage tray...
- anyone know what this a/c part is called or a part number?
- Anyone running Mac catback?
- WTF: prime the engine oiling system, Rebuilt 355 LT1 motor!
- bearing clearences?
- 92 Vette won't fire
- 1967 engine swap
- Tuning software vs. scan tool ability to read engine management info...
- 4 bolt mains
- HELP!! electrical problems
- Ignition issues, heat soaking, wtf is going on!!
- Vacuum question?
- LTX Shootout Questions
- used 398ci LT1 stroker kit wanted
- Anyone here running AI on a 355 or 383 ?
- stutter problem
- Lt-4
- Cutting out in higher rpms at WOT
- oil breather smoking? help?
- How much off my 1/4 mile?
- Vave spring swap on-car
- 97 LT1 Rebuild Advice?
- Problems with wiring a Meziere waterpump w/ Painless harness
- 388 finally runs, startup vid inside!
- Maf?
- bring the vht..
- LT4 water pump question
- Jack A$$
- Injector impedance? driveability issues
- 2 options, advice please.
- msd coil on stock opti,,,bad idea?
- body harness removal
- Just a quick fast quesion for you guys
- rod bearing question
- Track Rental Results Finally
- Cam bearing!?
- Lt1 cuts out under load
