View Full Version : LT1-LT4 Modifications
- Pricing..
- can someone help wire issue
- Are supporting mods REQUIRED for a cc306?
- spark plug wires
- High Pressure Oil Pump
- LS7 Lifter Noise
- electrical water pump help needed =/
- Remote Waterpump plumbing.
- No start, wiring issues
- Code 36 high res help
- 95 lt1 opti chandler motor sports
- 4L60E swap to T56 questions
- Starter Shattered
- Stock lt1 injector replacement.
- LT1 388 stroker HELP!!!!! URGENT!!!!
- LT1 Challenge Mode!
- i need help! electrical
- Hate to ask this......
- Could it be optispark???
- Anyone make a bolt in 8.8?
- quick ???
- Time to make a decision on the Firebird
- 24x question
- Looking for some parts
- walbro 416lph fuel pumps
- HELP!! The 5 Year long Clutch change story
- Failing PCM???
- Cheap 383 swap
- gen 1 hr in non vented lt1?
- Oil pan thickness??
- Best aftermarket oil pan?
- 97 lt1 problem
- Is it worth my time?
- One more cam question! UPDATE
- need some help
- Custom Cam and Supporting Mods?
- Anybody have a stock cam laying around??
- I'm new and I need helpppp :(
- Whats it worth?
- How many flaps are in one electric cutout?
- Is it possible to put a street scoop on an LT1?
- High RPM Miss (stumped)
- SAGA continues, ANY suggestions welcomed
- Powdercoated wheels and calipers(updated)
- Rear main seal?
- 3:73 - 4:10/11 gears on stock 4L60E
- After Laughing at all of you with Opti problems.. It hits me..Karma..Help
- 200cc heads and cam?
- Edelbrock LT4 airgap on AFR 227 heads
- AFR 195 heads are they truly bolt on?
- Fuel line relocation kit?
- 97 trans am ram air functionality
- Help Identifying Stall Converter on 94 Z28
- Facepalm Rear Main Seal?
- 94 lt1 overheating help im nrw to f-bodys
- Best spark plugs and wires for 95 z28?
- Misfire issue on new build - LT1
- 94 Corvette - runs great, dies, won't start, starts, runs great, dies, repeat...HELP!
- security light
- Got a question on some HP ratings? Custom Plaque
- Is it possible to have a double cut-out exhaust near the headers?
- Notchy shifter after clutch replacement?
- Another nostart issue
- 94 z-28 vats issues
- 95 lt1 not running rite.
- Should I be good with a stock fuel pump? Loaded question
- Safe nitrous shot size
- Max Effort W/ Rods
- Need help finding coolant gauge wire. Broke off, where is it in harness.
- flow Master 2 hooker aero
- LT1 headers
- o ring vs umbrella valve seals
- Where can I find LTX decals (not badges) or a good image to send to my print guy?
- vac leak/valve cover/ o2 sensor
- What is the difference between an ignition switch for an A/T and one for an M/T?
- Flat, Dished or Domed Pistons?
- LT1 or 400 ?
- AC Comp Broken??
- Best stall for stock lt1 and a 125 shot
- 1995 TA running rough during first mile
- Spark plug wire question.. Car running rough
- Finally had the time to move around some engine stuff
- 396 E85 Street Car Build
- Radiator issues?
- need help finding out about my car
- lt1 veterans step in
- lm7 in my airboat
- Bought 2 cheap LT1 cars.. fix up or sell?
- What muffler for loudmouth exhaust system to make it the quietest it can be?
- struggles and dies unless maf is unplugged
- LT1 Engine Question
- Fuel line to regulator fuel feed
- Misfire after altitude change
- LT1 Project car
- Oil pump replacement
- ls1 ram air on lt1?
- Scan Tool and SES Fun 1995 Z28
- LT1 No Start Condition - Lots of test completed
- Lt1 Texas mile
- New member w/ new LT1 car; mod game's on (UPDATE: It's broken, PLEASE HELP!!!)
- front bumper sagging Camaro
- Fixing borked gauges - it's not the cluster (wiring)
- LT1 Fbody Swap (97LT1 to Vette LT1)
- Tuner Pro Speedo multiplier
- Is this a Gen-II or Gen-III LT1??
- noid light
- SES Light (With Codes) Need Help
- Lt1 dies and starts randomly, now won't start at all
- Cardone optispark
- 97z intermittent problem
- LT1 Land
- another build almost complete!
- 94 z-28 security light vats issue
- Head shaving question
- LT1-LS1 Swap
- Can you tune a 1995 LT1 computer?
- Spark retard in closed loop at idle...
- 95 camaro project
- How much RWHP should i be making?
- Can't get LT1 separated from T56
- iac valves
- Edelbrock LT1 heads
- My LE2 heads came today...
- O2 idle scan
- need help with these dtc codes
- LT1 balancing question.
- stock flywheel, how far can you cut?
- 3.73 gears with 93 T-56?
- Spring choices!
- Went from A4 to M6, have cam questions now.
- Torque Arm delete
- LT-4 GM Hot Cam Kit
- Help 94 Z28 Issues w/ Datamaster Pics
- Rocker Arm Problems..
- How many LBS of refrigerant?
- T56 shifter boot bracket
- weird knocking sound...
- Holley 58mm TB - Blades opening past WOT
- R1 Concepts
- Exhaust
- 383 dies after getting warm
- E85
- I need a list of all the differences between a 94 LT1 and 97 LT1
- LT1 beginner project
- 1995 Firehawk
- Need advice: 93 LT1 M6 into a 94 A4
- 95 fuel gauge stuck at full level all times
- Need help with stumbling idle
- What the hell...
- Just got a 96 Z28..........
- LT1 Camaro Front Pads
- Bad Crank Position Sensor???
- need crank spacer/washer
- Opti headache!
- Tips for better traction?
- LT1 rebuild questions
- lt4 hotcam wanted
- lt1 headers
- Intake question?
- Some Question About Rear End Gear Brands.
- Opinions on what to do with my 97 z28?
- Superchaged drag times.
- Newbie question on lt1 engine
- LT1 High Output Alternator
- 355 c.i. nitrous build advice...
- Looking for an option
- Details on ls1 swap .
- Manual Fan Switch question
- How much is my LT1 worth?
- Retune after a bad TPS?
- More LT1 Autocross!
- 700r4 in a 95 z28
- Thermostat Question?
- Valvecovers that clear shaftmount rockers w/ factory alt location?
- just wondering
- gm847
- my first lt1
- LT1 Confusion , PLEASE HELP!!! cant figure this knocking sound out....
- Knock sensor problems and lacking performance lt1
- Parts for sale...
- Built z28...whats it worth?
- question about gear ratio change in tunerpro RT
- Cams,P&P Heads Trouble
- A/C System Vs Cooling System
- The Gear Swap Has Begun!
- 95 T/A anyone replace cooling fans with higher flow units?
- Stock exhaust upgrades
- Air pump injection delete
- Idler pulley # for Speed Inc alt/ps relocation bracket?
- Lt1 Hedman Longtubes Leak?
- My wait is almost over.
- 95 T/A cooling question
- High RPM Stumble (With Video)
- Anyone seen this intake??
- metal on metal sound when trying to crank?
- Cooling system bleeder Problem
- 7 Second Pass
- LT1 Probs after mods
- 1995 Z28 Rear Diff Lube
- Bad MSD Opti's
- T/A towing
- coloradoSPEED | COMP Cams | Lunati CAMSHAFT SALE
- 24x tune numbers
- Lt1 bored 60. Over
- clutch question help plz
- question about CAI
- Speed Inc. alternator reloc/AC delete - anyone else having belt shredding issues?
- Which Lifters? High RPM build and help me ditch my polylocks!
- naaaasty wheel hop
- What do you think of my next project?
- OBD1 tuning Cable
- 94 Lt1 o2 bank one lean and rich codes and how to check code 51
- Cm vs steel kmember
- Looking for assistance on building a nice little beast
- 96 LT1 breaking up under load
- LT1 is misfiring bad!
- Slick or Radial for M6 car?
- Looking for someone to tune my bolt on lt1 Reno
- 396 "Stroker Clearanced" Connecting Rod Question.
- opti vacuum lines
- Any one running 11's and lifting the wheels? Lets hear your experience.
- Rear alternator bracket installation..HELP!
- Need to know what this sensor is called?????
- Worked Inatke manfold/95 z28
- car running hot
- PCM or Trans
- Headers For LT1 In 88-98 Chevy Truck Advice?
- no spark help
- oil leak... from opti...?
- A/C problem
- LT 1 fuel/overheat issue
- My first top-end “Craigslist” build (build sheet and dyno results)
- LT1 rebuild.
- Need info on this 385 1996
- Hear me out lt1
- Please help 94 camaro z28 wont start
- weird idling issue
- LT1 Oil Filter
- Hid fogs 95 ta
- Somebody please help LT1 cai unknown hose
- decent economical performance clutch?
- 94 z28 fuel pressure numbers are weird pump failure
- Trying to figure out what my mechanic did with my opti vent hose
- Help needed with understanding my Datamaster scan
- 96 TA injectors/stall
- 383 LT1 LE3 Heads True Duals - Final stages!
- hydraulic clutch question
- question about a arms
- Transmission fluid - 6 speed
- LT1 Coil Bracket for LS1 Coils
