View Full Version : Forced Induction
- 408 turbo options will these work?
- building a turbo ls what block to use?? budget kinda sorta
- Used tubos for free, couple questions.
- 2002 TA F1A procharger
- help, can i run tial bov with 22psi springs, if im only running 16-17?
- how amazing will this cam be for a twin turbo 5.3?
- A few boosted rides from RPM Motorsports
- Longshot...
- 91 formula
- Stock 6.0 chevy twin turbos
- gt3582r's as twin turbos
- Procharger Head Unit Reliability?
- Mahle?? No>>
- cam and head combo on a turbo ls1 question
- procharger head unit decision
- Having some issues
- Chassie breakout:) 7.47@175mph
- I need help!
- How to make sdce tensioner
- backfire?
- procharger question
- eboost2 set up questions
- 4 barrel TB's
- s-10 LSx Manifolds & headers...
- turbo 5.3 cam
- Help choosing a turbo size
- Need help choosing, top mounted TT, single T, or rear mount on a 1933 ford!
- Procharger D1SC w/ 3.85 pulley, 3lbs?
- What makes an engine able to make more power on pump gas?
- Guys logging pressure ratio
- Wiring a Two-step?
- What's the largest T4 turbo that would drop in where my TC76 is now?
- Lt1 mainfold!!!!!!
- Hissing noise when I hit boost
- Centrifugal Supercharger w/ Front Mount Intercooler
- Coating IC Parts?
- Intakes for boost
- My 71 camaro LS2 w/ MAG build
- Wastegate
- How strong is the LSX 376
- meth and nitrous At the same time?
- compression to low or no? mill heads or no?
- LS1+Procharger+10psi+meth= Which Fuel Pump??
- Took the GT55 Turbo Z06 to the track tonight...
- Procharger idler bearings?
- the "Catch Can"
- Anyone have specs on this turbo by chance?
- Any maggied ls1's out there??
- Stock plug wires or aftermarket?
- Bought used STS kit and found small amount of oil inside intercooler
- Aluminum vs Iron.....
- 9lbs of boost then nothing on Vortech Ttrim
- 408 s91 boost question with l92s through exhaust
- '98 WS6 Trans Am, 8 yr old ProCharger - Not Building Boost?
- Roots blown 4th gen question about k member spacers
- who to have spec a turbo cam?
- Cheap vortech v9 f-trim!!!!!
- ATI Super Damper Pinning
- Edelbrock TVS2300/GMPP L92/LS2 questions...
- Cold Side Pipe Size Step
- Blower cams?
- The Pass Time Experience
- LS3 3bar map sensor??
- Deja Vu. Forgive the non LSX build.
- cleaning out exhaust pipes
- aps twin turbo on gto questions
- piston limits
- Night Ryders 106mm build
- What kind of oil do you recommend?
- Any Turbo Kits I can bolt on from home w/o losing AC?
- Check Valve Needed... Where Would I Get On?
- cog pulleys bare or anodized ?
- Turbo help
- Process of Mounting Intercooler
- Making the switch from Procharger to Turbo
- Truck manifold question i gotta ask
- pulley interchangability
- Force induction + nitrous
- Best Map for 18+lbs
- innovators west
- Procharger Intercoolers...
- Vortech T trim Vs Procharger D1SC
- Used STS kit?
- What are the correct valves (LS3 head) for FI
- What intercooler are you guys running
- Engine builder Recommendations
- TVS Guys...
- Engine for turbo application
- Ems dilemma efi live, hp tuners, pro efi, bs3
- Congrats Mike Brown and Ray Litz (wins at Norwalk)
- Anyone useing the 3.3 Bar Delphi Map sensor ?
- Looking to be pointed in the right direction
- procharger balancer
- Smoking at idle BAD
- More JGS wastegate springs?
- procharger 8 rib crank pulley options
- F1r vs F2
- procharger 8 rib slipping
- Anyone using Spek boost controller?
- Answered my ? 6.0 is 9.teen for my rear mount
- How much hp on stock 6.0 crank
- How much boost on stock plastic intake
- upgrading to 8 rib
- turbo build cost
- Dyno on wednesday quess HP
- SLP LM2 for turbo
- D1SC Questions
- Gasket Thickness?!?!
- For Those Who WANT To KEEP A/C !!! single or twin lOok InSiDe!
- F1A question (got a lot louder)
- Engineering the weak link into my project
- let me hear a sound clip of your turbo/turbos
- cam help on 6.0 truck manifold build
- help!!!!
- Piston Sleeve Wear
- Those with turbos and A/C
- Magnacharger tune
- Building Boost w/ 2 Step In A 6SPD Car
- procharger s fan
- F1A procharger setup
- JetHot 2000 Coating on Turbo Manifolds, Did you coat the inside?
- LS6intake/78mm TB vs. LS2intake/90mm TB for 1000rwhp? Restriction....
- STS turbo Kit for Sale 2500 OBO
- stall/gear suggestions to use with Brute Speed/EPP cam
- Starting a build thread
- ProCharger adds intercooler options to their GTO systems!
- 90* silicone TB hose.
- 107,000 boosted miles comes to an end!
- Wish me luck!
- intercooler upgrade?
- 2008 Silverado ext cab - est MPG with a MP76?
- Underhood temps of 170-180F - normal??
- First turbo build. Couple of questions
- My Precision 76mm turbo build
- RACEPAK... IQ3 vs UDX ? whats better for ForcedInduction
- Source for cheap and cheap-er turbos?
- Intercoolers:Twins VS Front Mount?
- You guys using special gaskets for exhaust manifold to piping?
- wanting to test fire motor before kit is on car.
- Procharger rotation question
- How much to expect from a cam swap?
- Can you keep DOD with forced induction?
- maximum safe rpm of stock internals??
- Anyone try a b1 with turbo?
- Rear Mount Turbo??????
- 364ci forged engine: best intake and cyl head combo? Comp Turbo CT81 setup
- WHO sells ported throttle bodies with the meth nozzle tapped?
- Rear mount on stock 5.3l
- 5.3l and 88 mm turbo? Pros and Cons Good or Bad?
- F-body screw and roots blower ppl enter
- 4th gen LT1 to 5.3 turbo budget
- **LMR Standing Mile Corvette Updated Pics***
- Need some help Please.
- New record: 7.66@177mph
- 2xxx Tahoe Turbo E85 Conversion
- what are stock bottom end ls3/l92's making
- Oil Feed line for front mount turbo
- 2010 base 4.8 truck 2wd mpt76q trim build
- My Sleeper!
- Screen for procharger inlet
- Just wondering about my 402, D1sc setup.. opinions?
- BOV location and FMIC question
- Gear drive on the street: Durability???
- carbed blow through!!!!!!
- anyone interested in trading new smaller new for bigger used??
- Turbo Tuner Charlotte NC or Surrounding Area
- procharger.com are spec on head unit accurate?
- Head Gasket Issue
- how to remove a Procharger head unit
- Which 3 bar map for 102mm LsxR Intake?
- ls3 cylinder head gasket to lower the compression ratio
- APS kit got me an Tax audit.
- ? re: exhaust manifolds for turbo setup
- ?s for the big power procharger guys
- can i get some opinions on this turbo please...
- dyno results t76 ls1 setup
- My 1225 RWHP C6 Z06
- couple questions for the remote turbo guys...
- Intake and TB Recommendation
- Good converter companies for turbo cars
- mp t76 ?
- vid of new 88s on dyno
- which pin kit for slp underdrive pulley
- V6 camaro turbo
- do i need to pin my crank pully?
- procharger race blowoff valve
- What size turbine in PT88?
- p1sc question
- diesel turbo question
- after shutdown bearing lube
- LS2 corvette turbo drain to pan question...
- Mustang supercharger question.
- Finally some track times!
- Vortech SC belt sizing
- how would an Evo turbo do on a stock LS1?
- who is the fastest 6.0 stock headed/stock crank/truck manifold turbo car?
- twin turbo lt1 z
- *aps kit with kando carts update*
- Procharger Inlet Problem/Question?
- Lets see u procharged strokers out there!
- Best Turbo Route for 7s?
- Mac Mids on a rear mount setup
- Help me pick a BOV, Questions!
- Which shortblock?
- twin turbo vs turbo
- Possible causes of seized PT88...?
- ARP head bolts?
- What should I do? Help!
- grand national turbo on lt1 ?
- Started the car for the first time... Vid inside... Need help ASAP!!!!
- another FMIC MP t70
- What to do about APS turbos?
- Boost Response & Backpressure VS Turbine Dia and Housing AR
- Rear Mount turbo on my '98 WS6. Need help
- okay..Snow variable controller..placement??
- help picking a turbo
- Boost? What Boost?
- Pinning front of crank?
- National Speed Build: 2010 Chevrolet Camaro - Eric Berry - NZ1200 - 1,200hp+...
- Two step ?
- Critique my set-up, I want more power!!
- Custom STS build questions?
- 434lsx what turbo thinking of a s91??
- ProCharger pricing changes 8/23/10
- i need help please
- 2 Turbo/ Tuning Questions
- What plugs yall running.
- sluggish boost on transbrake
- N20 to spool turbo
- Going from a 22x19x2 to a 24x19x1 to try and solve over heating problem...
- Is a support required for twin turbo setup?
- 2 bar map not registering boost
- Coolant temp issue (stop and go driving) on front mount turbo
- Header advice
- Have you played Car Town yet? Game for car people on Facebook
- APS owns with LG upgrades inside please
- Those with alt's on pass head w/ turbo by battery
- need help with smoking
- 82mm Turbo on 347ci !! Lots of questions
- u1016 loss of comunication with VCM !!!!
- what map do i need 2 bar or 3????help
- looking for a 5.3 or 6.0 long block
- what the best spark plug ? 18 psi
- Help Me with my build!
- turbo vs. procharger
- D-1 Rebuild Time - How Many Miles On Yours?
- Camaro Turbo Build
- LSA Supercharger on ebay
