View Full Version : LT1-LT4 Modifications
- Oil pump help
- Fuel Rail Question?
- LS1 Engine Block
- 1995 TA T56 won't start-security light on!!
- Starting problems
- Head light grinds when closed
- LT1 Borlamouth
- charging issue
- Crank Position Sensor / Reluctor Ring
- Will a Moroso Spiral flow muffler fit in front of the axle?
- whats the worst thing that can happen from a plug wire to header short?
- Anyone know the LT1 Spark Plug Wiring off the top of their head?
- what header gaskets with AFR 227's
- Compression Test Information / Problem Solving
- Just an Exhaust Leak ?
- What Gear???
- exhaust question
- 95 TA...15.4@90mph!!??!?!?!
- i am in lt1 hell!! HELP PLEASE!
- Wat gears?
- spraying a 93 lt1
- AI 200cc 383 start-up vid inside.
- HELP: thermostat change, collant in opti?
- I will never ever go to my gm dealer any more !!!!!
- Need some more opinions...
- Best Opti for the price
- LT-1Vette wants to start after shut off HELP
- No saprk what to do
- 4.10 and 28"tall tire equals like a having 3.73 ???????
- sticking with the LT1 for a while longer
- high temp RTV for head to header gaskets
- Best Heads for 408
- which heads are better?
- Getting my car dyno tuned today.
- air/fuel ratio gauge
- Anybody considered the gen II K&N FIPK for LS1's as a conversion alternative?
- Stock TB -> 52MM bored stock
- Whats yalls honest opinion on these heads:
- Help LT1 issue
- Lt1 coil burns out
- LS1 lid question
- block off plates
- Interesting cooling system pressure test results
- Big cam
- How much hp????
- Doing a heated O2 conversion and incorporate a wide band in??
- problems...
- Car starting issues, sometime yes, sometimes no. HELP ME!
- cant get any codes
- Trans Am takes a long time to start
- Spohn Crossmember and 3 inch True Duals
- i know its been discussed before but...
- Idle clips needed
- MGW Shifter
- Question about full exhaust
- No Start
- Anyone hear from OutlawZ?
- cracked flexplate
- problems
- Need help with a Lt1 355 build
- So not only is the car dead, My clutch still isnt in
- Security Light
- LT1 1995 trans am sptting and sputtering
- Rocker arm question
- Heads / Cam Parts List
- A/C Delete Questions
- How do I adjust the emergency brake?
- Fuel Pressure Help
- Cars dead! Not good for the LTXShootout!!!
- fuel pump help!!!!!
- Thinking about a new exhaust setup-Good or bad idea?
- well 383 back now whats better head bolts or head studs
- Question about the A/C system/heater core
- Motor "ticking" at idle
- throttle cable bypass
- 1.6 roller rocker 1/16 stud question
- How do you get the back injectors to pop in?
- just bought a block
- valvoline oil filters
- what else do I need to run this safely?
- Rod Bolts and Head Bolts
- Finally got my exhaust on!
- obd 2 to obd 1? (i know its been covered)
- What to do?
- Fuel Cut off switch?
- lt1 single plane info needed
- Wased the motor now it wont crank over
- car cuts off in the rain
- factory oil put in LT1's?
- A/C in LT1 car..
- 0-60 reduction with 3.73 gears
- Wont start..... Opti? ECU?
- Need help on drivability
- LS1 coverter to LT1
- sway bar endlink size?
- lt1 4 bolt main
- PCM Ignition fuse
- LT1's Hate me.... Another Optispark it seems.
- Anyone have an OBDI Connector Harness?
- What do you think of this bottom end?
- What Cam for my 383
- Pics/info for installing a Main Stud Girdle on a LT1
- Couple last questions
- Wanting to build a 383
- Electric Waterpump Wiring Question
- Largest Cam
- Finally bought another Fbody
- Newby
- sputtering bad only in heavy rain?????
- Oil pressure?
- Running Lt's and ORY only?
- N2o?
- Ewp
- issue after intake manifold gasket and water pump rr
- Getting k member bolts out
- 3 Code , need help ASAP !!
- Picked up my 355!!!
- what is entailed to remove a/c compressor?
- Cam Lobe Discussion
- Who has the fastest car with a gm lt4 hotcam?
- How do you delete the oil cooler?
- Mileage on Cam Bearings
- Weird problem help me pleaseeeeee
- Those that ran the XFI 292 cam. converter??
- Cam Istall/Rear Gears Swap??
- Silly Question
- cant get to turn over. power just disappears?
- Some theoretical LT1 discussion, how much will it handle, stock 10bolt capacity...
- 7/16 studs, trick flow guide plates, roller rockers
- LT1 temps????
- LT4 or LT1
- about how much power
- Oe fpr
- Heard a Rumor!!
- Converting SBC heads to reverse flow
- problem with my lt1
- Need Part Name
- coolant hose routing
- Fuel pump replacement what one?
- Can i run stock style intake on a solid roller motor?
- Thoughts on a header install write up...
- does anyone know off
- Anyway to make sure Im getting forged pstons?
- Anyone ever dealt with....
- Quick question
- Cracked Line/Hose Fuel Smell? (Pics Inside)
- cc503 cam setup help.
- Does anyone know of any good shops in.
- who makes a 3"turndown w/ a flange?
- It's been a while!
- I'm stumped-Is the motor gone??
- Computer died before completing load of file
- Msd opti
- trying to find arp rocker stud part #
- How is the install on EWP and UDP?
- What do you guys think about this engine kit
- True dauls over the axel and two out the side
- questions on putting a 383 in
- 4l60E question
- Question about going to the track
- Anyone running a paxton supercharger on their lt1?
- How to fix exhaust leak on 96 LT1 with Edelbrock shorties
- How to fix rattling stock y pipe on 96 TA?
- Any interest in pics/info for using a main stud girdle on a LT1?
- WTF Over???!!!
- Need more power
- O2 question
- please help!!! cc503 h/c ongoing prob..
- Quick Question - replace head bolts or not?
- lt1 jet hot caoated long tubs and y pipe
- Overheating!!!
- Weird gauge problem
- Thoughts on this rotating assy.
- lt1 sputter problem
- which LTs for a 96 impala ss
- help on pat #'s links, whatever you got.
- A I or A F R
- When installing a EWP?
- Valve Spring install HELP!!!!
- Unburned gas in the manifold and exhaust ports?
- What Walbro 255 Setup should i get?
- anyone using the lokar throttle cable?
- trans temp
- Whats a good...
- Why or how can my LT's leak from here?
- very curious anyone have any pictures
- Trans problem?
- Starting trouble!
- Exhaust weight question
- Heat shielding material...
- Oil dipstick showing low?
- Motor mounts and oil pan??
- Question!!!!!
- 1LE Elbow wtb
- roller rocker question
- Not charging
- beat to death topic... :(
- Crane duals too much for stock cam?
- Opti mounted @ back of the intake?
- Issues starting
- best way to clean moroso CAI filter??
- porting the lt1 intake manifold
- Head gasket is blown! 355 build coming
- oil filter threads?
- TSP Rumbler on my LT1
- Steamline of back of heads!!!???
- Trick Flow 195 CC heads
- Valvetrain decision
- lt1 bolt on dyno results
- gas leak ? oil leak ?
- Couple quick questions.
- just bought lt1. engine is out, mods are in.
- Would this Exhaust Kit and Headers bolt on?
- ac lines hit headers...
- Damn Car!!!
- What forged pistons n rods
- Heads and Cam Advice
- Anyone that has done the fuel line relocation mod come in
- ? about a 355 LT1 setup with valve clearance and head gasket choice!
- Car runs bad on the bottom end. Also need tuning suggestions.
- lt1 timing chain
- Another swap question.
- ntk ngk o2 sensor people common in
- are these better then LE2 heads
- Advanced Induction!! GREAT PEOPLE
- Walk me through adjusting my TB (monoblade)
- Fergymotos Transmission Carnage PICS INSIDE
- got an LT1!
- Start-up video and pics after my LE2 upgrade
- Anyone converted to a dual plane intake?
- Will these headers fit?
- 396ci stroker kit for a good price?
- Do You Have Hesitaion, Stumbeling Under Slight Exceleration ??? Come Inside !!!
- bearing clearances
- i think i just about blew my engine help!!
- Project "bad ass" TRUE DUALS underway. Please comment on my design.
- long tube install
- Oil Pressure Sending Unit and Long Tubes
- solid roller 396. how much power you thinking?
- AIR system delete question.
- Throttle body question
- 383 guys come in here
- It lives!!!!
- Doing cap and rotor tomorrow...Tips?
- Cranked up the TA today for the first time
- Factory LS2 Injectors on a 93 LT1?
- rebuild question
- fuel rail covers installed!
- Tie rod energy suspension rebuildable?
