View Full Version : Forced Induction
- How many of you are running solid rollers????
- GT60 and GT67 STS turbos
- some kind of misfire thing happening.. help
- cooling system
- good turbo "?" , experts please>>
- 347 with T76 and Dart 225's. What cam??
- The 383/Phamspeed Build Begins!
- twin turbo update....
- Solid-Tech LS1 turbo kit interest???
- forged bottom end?
- new twin turbo headers
- what size piping do it need
- My Turbo Z28 Begins...
- I tried searching... Turbo break-in???
- Stock manifolds upside-down?
- does any body know
- STS Remote Mount Turbo Video
- P1SC Cam questions
- One for all you thecies! :)
- Boost lower than usual
- Turbo Kit Or Cam
- meth kit...best bang for buck! & boost controllers
- STS turbo ???
- help with buliding a turbo set up
- Can a stock 346ci aluminum block BUILT UP handle 800-850 rwhp on boost?
- Need Opinions
- Turbo guys what are the specs on your cams
- Underhood turbo in a camaro?
- boost problems
- First STS f-body in the 10's???!!!
- Oil restriction for MP T70
- How much does turboing your 346 really cost?
- Big Chargecooler
- Good luck at the track, lil bro!
- Question IAT cooling using n2o and FI.
- Opening Chambers on LS1 Heads
- Miss At Idle??
- 8psi
- I tried to get Ernie to log on here and discuss his new combo...
- turbo lt1
- Rebuilding a turbocharged LS1
- Where To Get An Intercooler
- thumper kit
- Video of my junk on dyno/driveway
- New custom turbo
- Highest boost (Psi) on 346 aluminum LS1
- How Much Power Is Possible Turbo And 98 Pcm???
- Por20
- Turbo Guys--Could this be my problem?
- What intercooler position does Hi-Flo kit use?
- knock knock..... who's there??
- Cats on METH
- Spal extreme ,Procharger fan set up?
- LQ4 or LQ9
- New Pics of Tom's (FSTR-THANU) Turbo Camaro
- who has edelbrock intake? MAP location?
- stenod still in business?
- What Would You Put It On?
- How much oil did you burn during break-in on low comp motor?
- Cats or no Cats
- Injector question
- Newbie with a whole lotta Qs!
- dont add up....
- Ps1c owners
- Which power adder for my 408?
- Has anyone gotten tired of Forced Induction?
- Whats the smallest turbo you can run and make power?
- HELP!!!! i need the wireing diagram for a sts meth kit
- Junkyard Turbo
- how many of you are running an engine girdle???
- If a 6.0L crossover were were made would you buy it?
- Roush sounding supercharger
- Electric Supercharger?
- At what point do you need an LS6 PCV system?
- F-1 vs F1-R
- Gear for turbocharged applications??
- Bob(epp)...d1sc Kit Question
- boosted spark plug help
- Pics of our 59 Impala LS1 Turbo system
- Procharger with my setup?
- Crank pulley arrived, quick questions
- sts dealers question or custom rear turbo owners
- use of afr205's for d1sc
- DO NOT BUY CHEAP SILICONE 90's
- Stock Manifold Pics
- Turbo set-up for LS1
- 2 core 3 core..what's the difference?
- Procharger on stock LS1 engine?
- Procharger Bellow Issues...Need a Few Helpful Solutions
- Should I go for it??? (408 build)
- anybody g-tech w/turbo car??
- Spal extreme fan installed, no low speed
- Meth/H2O injection
- Does this sound like a winner to you ??
- ATI Crank Pulley driven me nuts
- What is the best max psi ???
- Is this turbo suitable
- What size is oil cap brass fitting on STS kit?
- On the road again
- LS6 heads with a Turbo setup
- Motor Arrived!!!!
- Air to Water or Air to Air cooling.. An arguement we have had for years.....
- A Tuesday treat :)
- Which setup for my z06.
- Turbo distance
- Video of car!!!
- Automatic trannied turbo guys...
- Why not tall gears for a blower??
- Any blower guys using a speed density tune?
- Heat Issues??
- Routing intake pipe for STS between radiator/ power steering. What's the best way?
- Not LS1 but is Steve Kamis's Twin Blower Merlin still around
- my new t76 gts ans heads and fuel ectt....cool video inside!
- newbie fi question
- My Turbo Truck is slow... help!
- <1/2oz a big deal on P1SC
- Guys with Iron blocks, turbo, and qa1's...
- Gauge help for turbos
- Can we see the WS6 front ends with FMIC??
- remote turbo question
- STS turbo is pushing oil into intake piping. Gasket? Input appreciated!
- turbo cam theory.
- Greddy boost controller problem-sts kit
- FAL Fans
- Crank pinning, 2nd time around. Forged crank
- Turbo cam question
- 76mm or 80/88mm..
- Ideas on next round of mods. What you think?
- Valve cover oil in Procharger
- Getting textralia clutch for planned turbo which flywheel?
- Boost Spikes?
- controllers
- Procharger question
- Vortech cooling alternatives
- 671 BLOWN LT1 INSIDE, one question though.
- New dyno numbers: 638rwhp/588rwtq
- cylinder heads, velocity, cross sectional area, and forced induction.
- CAS Twin Turbo pics!!
- Sucked a chassis washer into my Z06!
- what spark plugs to run with turbo?
- ati procharger p1sc for gm truck
- Good Twin Turbos
- Vortech or ATI Procharger?
- Cooling concerns with new combo?
- Powerdyne Superchargers
- Z06 cam or Futral F7? Which one would you use?
- Where is Lasershop?
- Anyone checked this company out???
- Custom homemade air to water intercooler...
- Help finding weldon 9200 fluid pump for incons
- STS Help!!
- Slowhawks at it again...victor intake on purevl
- How much valvespring pressure?
- PSC1 for 5.3 Silervado will it fit Fbody?
- Finished!!!! Pics
- 408 truck with D1SC, good idea?
- Turbo Help!
- Best of all FI kits
- Best Intake for Forced Induction? (Supercharger)
- What spring for tial BOV
- 2 small gates vs. 1 big gate
- P1SC Boost VS D1SC boost
- True Duals
- 6.0 Crank boost - HP ???
- 6 days to decide on what turbo...one last thread.
- Header studs??
- Which gaskets and bolts for heads for boost ??
- Car misfires and sputters really really bad when under boost
- Turbo heads
- Looking for possibly a cheaper 76millimeter turbo replacement
- 80mm turbo
- 688 rwhp and 697.9 ft lbs of torque with a D-1SC at 14 psi
- How to adjust BOV
- D1SC Dyno Sheets??
- Need Help!!
- twin turbo collectors?
- what the difference between(flow wise): stock ls1 exhaust manifold & 6.0 exhaust mani
- best plugs, wires, and gap to run with boost?
- Anyone have success using toulene
- New Pics of Setup!
- LQ9 heads are done
- Question about turbo
- Speed Inc. Turbo?
- A couple questions for the gen III experienced...
- You won't believe this sh@&!!!!!
- Turbo kit for Trailblazer
- Crank/SC support
- BBK 80 mm throttle body ?
- Rotrex superchargers?
- Blow-through 750 carb?
- ATI Harmonic Dampener Pics (For Procharger)
- more STS numbers
- How much boost with these pulleys?
- What Kind of Power Can I Expect
- Spark plugs with boost???
- Plug gap for FI
- twin turbo gto?
- Why are turbos and Centrifugal superchargers so different?
- Almost ready to go again
- 427 turbos
- pics of my homemade turbo system
- Which B.O.V. for high power
- Help me out...
- how much are S/C benefitted by a small blower cam?
- Twin Screw's and Root's Blowers
- WTB: f-body lt1 supercharger
- Why I had been losing boost (pics)
- Installing Magnacharger on ls1
- Evap question on 2002 Turbo Z
- Do you guys fuse your gauges?
- s/c and cam ?
- looking for a good place to buy a T76, T67, or T61.
- 2001 clucth master mod ?
- some turbo help please!!!
- Turbo Oil Pump Noise?
- What needs to be done to the suspension on a blower car?
- Blue silicon couplings for piping?
- Turbo-acceptable shaft play (side to side)
- Heads???
- What Compression should I run
- Superchargers and Turbos Available At TBYRNE Motorsports!
- Engine Management, which PCM.
- Got My Stuff.....well Most Of It
- BOV. Does this sound right?
- Boost gauge question?
- Installed STS kit...AC running 24/7. Any ideas?
- GMR single turbo question-GMR Single Turbo???
- can this piece be purchased?
- CAS twin turbo car FINALLY running...
- what is lame about kyle's setup is that...
- Which supercharger cam? GT 2-3 or Speed inc SC1
- Twin Turbo Z06 Dyno Results
- twin T04E sizing question
- Building a Block thats turbo friendly, help
- Looking for a little guidance
- maf with supercharger problems
- Dyno again :( again
- Best deal on short block (assembled)
- Ok.. I give up.. where is it?
- How much boost?
- Any pics of Magnuson blowers on F-bodies?
- What else to buy
- Paging JZ 97 SS 1500
- Sts Intercooler
- Fox LS1, Single or Twin Turbo Setup?
- Tuning my turbo car
- is this a good turbo cam
- Need input....I want a SC. Waaaaaah!!
- Magnacharger camshaft suggestions?
- How does lower CR help with boost?
